Best Smart Doorbells for Existing Chimes and Outdoor Security
When upgrading your home security with a smart doorbell, compatibility with your existing chime and robust outdoor security features are essential. Whether you want crystal-clear video, two-way communication, or seamless integration with your current setup, the right smart doorbell can transform your front porch into a secure, connected entryway.
Explore the top Wyze smart doorbell products designed to work effortlessly with existing chimes and provide outstanding outdoor security.
Wyze Video Doorbell v2: Wired 2K Video with Chime Controller
Crisp 2K Video Quality and Wide Field of View
The Wyze Video Doorbell v2 offers stunning 2K resolution (2048 x 1536) video, capturing every detail with clarity. Its 135° horizontal and 103° vertical field of view ensures you see visitors and packages clearly, reducing blind spots.
Seamless Integration with Existing Chimes
This wired doorbell works with your home's existing mechanical chime through the included Wyze Chime Controller, making installation straightforward without rewiring your chime system.
Smart Features for Enhanced Security
- Two-way audio with noise and echo cancellation lets you communicate with visitors remotely.
- Motion-activated voice deterrence helps ward off unwanted guests.
- Local microSD storage and cloud options keep your footage safe and accessible.
- Weather-resistant IP65 rating ensures reliable performance in all conditions.
Included Accessories for Easy Setup
The package includes the doorbell, chime controller, wall plate, wedge for angled mounting, wire caps, and installation kit, making it a complete solution for your front door.
Experience peace of mind with a smart doorbell that combines high-definition video and compatibility with your existing chime system.
Wyze Universal Wi-Fi Chime: Plug-and-Play Chime for Any Wyze Doorbell
Effortless Setup Without Wiring
The Wyze Universal Wi-Fi Chime is a perfect accessory for those who want to keep their existing doorbell wiring intact or add a chime in a new location. Simply plug it into a power outlet—no complicated wiring needed.
Customizable Alerts and Automation
Choose from 17 different chime tones to personalize your alerts. The chime can also be set to ring when any Wyze camera detects a person, expanding your home's smart automation capabilities.
Broad Compatibility and Smart Home Integration
Works seamlessly with all Wyze Cams and doorbells, and supports voice assistants like Alexa and Google Assistant, plus IFTTT for custom automations.
Compact and Stylish Design
Its sleek black plastic body fits discreetly in any room, with a 40mm speaker delivering clear chimes.
Never miss a visitor or delivery with this fuss-free, universal chime that complements your smart doorbell setup.
The Front Porch Security Bundle: All-in-One Smart Doorbell and Lock Solution
Comprehensive Front Porch Security
This bundle combines the Wyze Video Doorbell with Wyze Lock and Wyze Chime, offering a complete smart entry system. View your porch in 1080p HD, communicate with visitors, and control your door lock remotely—all from the Wyze app.
Key Features
- 1080p video with two-way audio and motion detection.
- Remote locking/unlocking and lock history tracking.
- Multiple chime sounds including modern, classic, and intruder alarms.
- Works with Alexa and Google Assistant for voice control.
Enhanced Security and Convenience
The bundle includes everything needed for installation and integration, making it ideal for those seeking a turnkey smart home security upgrade.
Secure your home’s entryway with a smart doorbell and lock combo that offers peace of mind and convenience.
Wyze Cam v4 Outdoor Bundle: Superior Outdoor Security Camera
Crystal-Clear 2.5K QHD Resolution
The Wyze Cam v4 delivers ultra-clear video with enhanced color night vision, ensuring your outdoor areas are monitored day and night with vivid detail.
Motion-Activated Spotlight and Alerts
Stay informed with motion detection zones and instant alerts. The spotlight activates automatically to deter intruders and illuminate your porch.
24/7 Local Recording and Wi-Fi 6 Support
Record continuously to a microSD card included in the bundle, with fast and reliable Wi-Fi 6 connectivity for smooth streaming.
Smart Home Compatibility
Works with Alexa and Google Assistant, allowing voice commands and integration with other smart devices.
Elevate your outdoor security with a camera that offers high resolution, color night vision, and smart alerts.
Wyze Video Doorbell v2 Wedge Kit: Perfect Angle for Maximum Coverage
Adjustable Viewing Angles
The Wedge Kit is designed specifically for the Wyze Video Doorbell v2 to eliminate blind spots caused by angled door frames or stairs. It includes a 15° horizontal bracket and two 7.5° vertical brackets.
Weather-Resistant and Easy to Install
Made from durable plastic with weather resistance, the wedge kit installs quickly and securely, enhancing your doorbell’s field of view.
Optimize your doorbell’s perspective for superior home security and visitor detection.
Conclusion
For homeowners seeking the best smart doorbell solutions compatible with existing chimes and enhanced outdoor security, Wyze offers a range of products tailored to your needs. From the high-resolution Wyze Video Doorbell v2 with its universal chime compatibility to the comprehensive Front Porch Security Bundle and advanced outdoor Wyze Cam v4, you can customize your home security setup with ease and confidence.
Enhance your home security with smart doorbells that integrate seamlessly with your existing chime.
Stay connected and monitor your front door from anywhere with Wyze smart doorbells.
Protect your home day and night with Wyze Cam v4’s enhanced color night vision and motion-activated spotlight.
What are the best smart doorbells compatible with existing chimes?
The Wyze Video Doorbell v2 is designed to work seamlessly with your home's existing mechanical chime using the included Wyze Chime Controller. This makes installation easy and eliminates the need for rewiring your current chime system.Does the Wyze Video Doorbell v2 offer high-definition video quality?
Yes, the Wyze Video Doorbell v2 provides stunning 2K resolution (2048 x 1536) video, ensuring you capture every detail at your front door with a wide 135° horizontal and 103° vertical field of view.Can I communicate with visitors using Wyze smart doorbells?
Absolutely. Wyze smart doorbells, including the Video Doorbell v2, feature two-way audio with noise and echo cancellation, allowing you to speak with visitors remotely from your smartphone.Are Wyze smart doorbells weather-resistant for outdoor use?
Yes, the Wyze Video Doorbell v2 is rated IP65 for weather resistance, ensuring reliable performance in various outdoor conditions.What is the Wyze Universal Wi-Fi Chime and how does it work?
The Wyze Universal Wi-Fi Chime is a plug-and-play accessory that works with all Wyze doorbells and cameras. Simply plug it into a power outlet to receive customizable chime alerts without any complicated wiring.Can I customize the chime sounds on the Wyze Universal Wi-Fi Chime?
Yes, the Wyze Universal Wi-Fi Chime offers 17 different chime tones, allowing you to personalize your alerts to suit your preferences.Does Wyze offer a complete smart doorbell and lock bundle for front porch security?
Yes, the Front Porch Security Bundle combines the Wyze Video Doorbell, Wyze Lock, and Wyze Chime, providing 1080p HD video, two-way audio, remote locking/unlocking, and multiple chime sounds for comprehensive entryway security.What are the key features of the Wyze Cam v4 Outdoor Bundle?
The Wyze Cam v4 Outdoor Bundle offers 2.5K QHD resolution, enhanced color night vision, motion-activated spotlight, 24/7 local recording to microSD, Wi-Fi 6 support, and compatibility with Alexa and Google Assistant.How can I improve the viewing angle of my Wyze Video Doorbell v2?
The Wyze Video Doorbell v2 Wedge Kit includes adjustable brackets (15° horizontal and two 7.5° vertical) to optimize your doorbell’s field of view, eliminating blind spots caused by angled door frames or stairs.Are Wyze smart doorbells and cameras compatible with smart home systems?
Yes, Wyze smart doorbells and cameras work with popular smart home platforms, including Alexa, Google Assistant, and IFTTT, enabling voice control and custom automations.What storage options are available for Wyze smart doorbells and cameras?
Wyze devices support both local microSD card storage and cloud storage options, ensuring your video footage is safe and easily accessible.Is installation of Wyze smart doorbells and accessories easy?
Yes, Wyze products come with all necessary accessories and installation kits, making setup straightforward whether you’re using existing wiring or opting for plug-and-play solutions like the Universal Wi-Fi Chime.
