Top Weather-Resistant Hardwired Doorbell Cameras for Outdoors
Best Doorbell Cameras for Outdoor Weather-Resistant Hardwired Installation
When it comes to securing your home’s entrance, choosing the best doorbell camera that is weather-resistant and supports hardwired installation is essential. This ensures reliable power, continuous monitoring, and durability against outdoor elements. Below, we explore top Wyze doorbell cameras designed for outdoor use with hardwired installation, highlighting their features, specs, and unique benefits.
Wyze Video Doorbell v2: Clear 2K Wired Video Doorbell with IP65 Weather Resistance
Overview
The Wyze Video Doorbell v2 is a standout wired video doorbell offering crystal-clear 2K resolution and robust weather resistance with an IP65 rating. Designed for hardwired installation (16V-24V AC), it delivers reliable power and continuous operation without worrying about battery life.
Key Features
- 2K Video Resolution (2048 x 1536) for sharp, detailed video day and night.
- Wide Field of View: 135° horizontal, 103° vertical, and 166.8° diagonal coverage.
- Weather Resistant: IP65 certified to withstand rain, snow, and dust.
- Two-Way Audio: Built-in microphone and speaker with noise and echo cancellation.
- Motion-Activated Voice Deterrence: Warn visitors or intruders with a customizable voice alert.
- Local Storage: Supports up to 256GB microSD card for continuous local recording.
- Smart Integrations: Compatible with Alexa, Google Assistant, and IFTTT.
- Operating Temperature: Works reliably from -4°F to 122°F (-20°C to 50°C).
Included Accessories
- Wyze Chime Controller for indoor alerts.
- Wall plate and wedge kit for flexible mounting angles.
- Installation kit with wire caps, screws, and extension wires.
The Wyze Video Doorbell v2 is perfect for homeowners seeking a high-resolution, wired doorbell camera that stands up to harsh weather conditions while providing smart home compatibility.
Wyze Video Doorbell v2 installed on a front porch, showcasing its sleek design and weather resistance.
The Front Porch Security Bundle: Complete Hardwired Doorbell and Smart Lock Solution
Overview
For those wanting an all-in-one front porch security upgrade, the Front Porch Security Bundle combines the Wyze Video Doorbell (1080p HD) with Wyze Lock and Chime. This bundle supports hardwired doorbell power and adds smart lock control for enhanced home access management.
Key Features
- 1080p HD Video Doorbell: Clear video with two-way audio and motion detection.
- Remote Lock/Unlock: Control your door lock remotely via the Wyze app.
- Motion Event & Lock History: Monitor porch activity and lock usage.
- IP65 Weather Resistance: Durable for outdoor installation.
- Smart Home Integration: Works with Alexa and Google Assistant.
- Operating Temperature: Doorbell operates from -4°F to 122°F (-20°C to 50°C).
Bundle Includes
- Wyze Lock with Bluetooth and Zigbee communication.
- Wyze Lock Gateway for extended range.
- Wyze Video Doorbell and Chime.
- All necessary mounting hardware and wiring accessories.
This bundle is ideal for users who want to combine video monitoring with smart lock convenience, all in a weatherproof, hardwired setup.
Wyze Duo Cam Battery Doorbell: Dual Cameras with Optional Hardwired Power
Overview
The Wyze Duo Cam Doorbell offers dual camera views—one for people and one for packages—providing comprehensive coverage of your front porch. While primarily battery-powered, it supports hardwired installation for continuous power, making it versatile for various setups.
Key Features
- Dual Cameras: Front camera at 2K resolution and bottom camera at 1080p for package detection.
- Wide Field of View: Front camera 132° horizontal, bottom camera 121° horizontal.
- IP65 Weather Resistance: Built to endure outdoor conditions.
- Two-Way Audio & Siren: Includes a 90 dB siren and real-time voice communication.
- Local & Cloud Storage: Supports up to 256GB microSD card and cloud backup.
- Power Options: Battery-powered with USB-C charging or hardwired (10-24V AC).
- Smart Integrations: Alexa, Google Assistant, and IFTTT compatible.
- Operating Temperature: -4°F to 122°F (-20°C to 50°C).
- Wyze Wi-Fi Chime.
- Back plate and corner kit for flexible mounting.
- USB-C charging cable and wiring accessories.
The Duo Cam Doorbell is perfect for those who want advanced package detection and flexible power options, including hardwired installation for uninterrupted security.
Wyze Duo Cam Doorbell installed on a porch, highlighting its dual-camera design and weatherproof build.
Wyze Video Doorbell Pro: Wired or Battery-Powered with Ultra-Wide View
Overview
The Wyze Video Doorbell Pro offers a wider view and higher resolution with the convenience of both wired and battery power options. Installation is quick and easy, making it a flexible choice for various home setups.
Key Features
- Crystal-Clear HD Video: High-definition video with ultra-wide viewing angle.
- Smart Detection Alerts: Person, package, vehicle, and pet detection with Cam Plus.
- Motion-Activated Security Light: Enhances visibility and deters intruders.
- Two-Way Audio: Quick responses with built-in speaker and microphone.
- Chime Included: Features 20 unique tunes and 8 sound levels.
- Smart Home Integration: Works seamlessly with Alexa and Google Assistant.
- Installation: Screw mount or screw-free adhesive plate.
- Power: Supports hardwired or battery operation.
The Wyze Video Doorbell Pro is an excellent choice for users wanting a versatile, feature-rich doorbell camera with superior detection and lighting.
Wyze Video Doorbell Pro mounted on a modern home exterior, showcasing its sleek design and smart features.
Wyze Video Doorbell (Wired): Compact and Reliable 1080p Full HD Doorbell Camera
Overview
The Wyze Video Doorbell (Wired) is a compact, budget-friendly option delivering full HD 1080p video with hardwired power. It offers essential features for outdoor security with IP65 weather resistance.
Key Features
- 1080p Full HD Video: Clear video with 8x digital zoom.
- Wide Field of View: 120° vertical by 88° horizontal.
- Two-Way Audio: Built-in speaker and microphone with noise cancellation.
- IP65 Weather Resistant: Suitable for outdoor use.
- Motion Detection: Alerts you to activity at your door.
- Hardwired Power: Requires 16V-24V AC for continuous operation.
Included Items
- Wall plate, wedge for angled mounting.
- Wire caps, screws, extension wires, and fuse for installation.
This doorbell is ideal for those seeking a straightforward, reliable wired doorbell camera with solid weather resistance and essential smart features.
Conclusion
For the best outdoor weather-resistant doorbell cameras with hardwired installation, Wyze offers a range of options tailored to different needs:
- Wyze Video Doorbell v2 for high-resolution 2K video and robust weatherproofing.
- The Front Porch Security Bundle for integrated doorbell and smart lock control.
- Wyze Duo Cam Battery Doorbell for dual-camera views with flexible power.
- Wyze Video Doorbell Pro for ultra-wide views and smart detection.
- Wyze Video Doorbell (Wired) for compact, budget-friendly wired security.
Each model supports IP65 weather resistance and hardwired power, ensuring reliable performance in all seasons. Choose the one that best fits your home security needs and enjoy peace of mind with Wyze’s smart, durable doorbell cameras.
Feature | Wyze Video Doorbell v2 | The Front Porch Security Bundle | Wyze Duo Cam Battery Doorbell | Wyze Video Doorbell Pro | Wyze Video Doorbell (Wired) |
Type | Wired Video Doorbell | Bundle (Wyze Lock + Video Doorbell and/or Cam) | Battery-Powered Dual Camera Doorbell | Wired or Wireless Video Doorbell | Wired Video Doorbell |
Video Resolution | 2K (2048 x 1536) | 1080p HD (Doorbell) | Front: 2K (2048 x 1536), Bottom: 1080p | HD (exact resolution not specified) | 1080p Full HD (sensor 2K) |
Field of View | 135° horizontal, 103° vertical | Not specified | Front: 132° H x 100° V, Bottom: 121° H x 60° V | Ultra-wide viewing angle | 120° vertical x 88° horizontal |
Power | Wired (16V-24V AC) | Wyze Lock: Battery powered; Doorbell: Wired or Battery | Battery (removable) with option for hardwired power | Wired or Battery | Wired |
Storage | Local microSD (up to 256GB), Cloud (optional) | Not specified | Local microSD (up to 256GB), Cloud | Cloud storage with Cam Plus | Local microSD, Cloud (with subscription) |
Two-Way Audio | Yes | Yes | Yes | Yes | Yes |
Motion Detection & Alerts | Yes, with motion-activated voice deterrence | Yes | Yes, with AI detections and voice deterrence | Yes, with Cam Plus smart detection | Yes |
Chime Included | Yes (Chime Controller included) | Yes (Wyze Video Doorbell and Chime included) | Yes (Wyze Wi-Fi Chime included) | Yes | Yes |
Weather Resistance | IP65 | IP65 (Doorbell) | IP65 | Not explicitly stated, but designed for outdoor use | IP65 |
Night Vision | Color Night Vision (Starlight sensor) | 1080p HD (likely standard night vision) | IR + Color Night Vision | Not specified, but includes motion-activated light | IR Night Vision |
Special Features | Pre-roll motion recording, works with Alexa/Google Home, motion-activated voice deterrence (subscription required) | Includes Wyze Lock for remote locking/unlocking and lock history | Dual cameras for people and packages, removable battery pack, USB-C charging | Motion-activated security light, 20 chime tunes, quick responses | 5 modern + 4 classic + 3 animal + 6 automation + 1 intruder alarm chime sounds |
Installation | Wired, includes wedge for angle adjustment | Bundle includes multiple devices, installation varies | Battery powered, optional hardwired | Wired or wireless, install in 30 seconds | Wired |
Price (approx.) | $44.98 | $123.99 - $173.97 (depending on variant) | $89.98 - $109.99 | $99.98 | $29.99 - $34.99 |
What are the best Wyze doorbell cameras for outdoor weather-resistant hardwired installation?
The best Wyze doorbell cameras for outdoor weather-resistant hardwired installation include the Wyze Video Doorbell v2, Wyze Video Doorbell (Wired), Wyze Video Doorbell Pro, Wyze Duo Cam Battery Doorbell (with optional hardwired power), and the Front Porch Security Bundle. All these models feature IP65 weather resistance and support hardwired installation for reliable, continuous operation.Is the Wyze Video Doorbell v2 weather-resistant and suitable for outdoor use?
Yes, the Wyze Video Doorbell v2 is IP65 weather-resistant, making it suitable for outdoor installation. It is designed to withstand rain, snow, and dust, and operates reliably in temperatures from -4°F to 122°F (-20°C to 50°C).Does the Wyze Video Doorbell v2 require hardwired installation?
Yes, the Wyze Video Doorbell v2 requires hardwired installation with 16V-24V AC power. This ensures continuous operation without the need to recharge batteries.What features does the Wyze Video Doorbell v2 offer?
The Wyze Video Doorbell v2 offers 2K video resolution, a wide field of view (135° horizontal, 103° vertical, 166.8° diagonal), two-way audio with noise and echo cancellation, motion-activated voice deterrence, local storage up to 256GB microSD, smart home integration (Alexa, Google Assistant, IFTTT), and robust weather resistance.What is included with the Wyze Video Doorbell v2?
The Wyze Video Doorbell v2 comes with a Wyze Chime Controller, wall plate, wedge kit for flexible mounting, and an installation kit with wire caps, screws, and extension wires.What is the Front Porch Security Bundle from Wyze?
The Front Porch Security Bundle combines a Wyze Video Doorbell (1080p HD) with a Wyze Lock and Chime, offering a complete hardwired doorbell and smart lock solution. It provides video monitoring, remote lock/unlock via the Wyze app, motion event and lock history, and IP65 weather resistance.Can the Wyze Duo Cam Battery Doorbell be hardwired?
Yes, the Wyze Duo Cam Battery Doorbell can be hardwired for continuous power (10-24V AC), in addition to its battery-powered option. This makes it versatile for different installation needs.What are the key features of the Wyze Duo Cam Battery Doorbell?
The Wyze Duo Cam Battery Doorbell features dual cameras (2K front camera and 1080p bottom camera for package detection), wide field of view, IP65 weather resistance, two-way audio, a 90 dB siren, local and cloud storage, and compatibility with Alexa, Google Assistant, and IFTTT.Does the Wyze Video Doorbell Pro support both wired and battery power?
Yes, the Wyze Video Doorbell Pro supports both hardwired and battery-powered operation, offering flexibility for various home setups.What makes the Wyze Video Doorbell Pro a good choice for outdoor security?
The Wyze Video Doorbell Pro offers crystal-clear HD video, an ultra-wide viewing angle, smart detection alerts (person, package, vehicle, pet), a motion-activated security light, two-way audio, and easy installation with either screw mount or adhesive plate. It is also compatible with Alexa and Google Assistant.Is the Wyze Video Doorbell (Wired) weather-resistant?
Yes, the Wyze Video Doorbell (Wired) is IP65 weather-resistant, making it suitable for outdoor use in various weather conditions.What power source does the Wyze Video Doorbell (Wired) require?
The Wyze Video Doorbell (Wired) requires a hardwired power source of 16V-24V AC for continuous operation.What smart home integrations are available with Wyze doorbell cameras?
Wyze doorbell cameras are compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless integration with your smart home ecosystem.What is the operating temperature range for Wyze doorbell cameras?
Most Wyze doorbell cameras, including the Video Doorbell v2, Duo Cam Battery Doorbell, and Front Porch Security Bundle, operate reliably in temperatures from -4°F to 122°F (-20°C to 50°C).Do Wyze doorbell cameras support local storage?
Yes, select Wyze doorbell cameras such as the Video Doorbell v2 and Duo Cam Battery Doorbell support local storage with microSD cards up to 256GB for continuous recording.
What are the key features of the Wyze Video Doorbell v2?Can you tell me more about the Front Porch Security Bundle?What is the warranty and returns policy for Wyze products?
