Weather Resistant Refurbished Doorbells for Indoor & Outdoor Use
Weather Resistant Refurbished Doorbells with Indoor and Outdoor Functionality
When it comes to securing your home’s entry points, a weather resistant doorbell that works seamlessly both indoors and outdoors is essential. Whether you want crystal-clear video, two-way communication, or smart home integration, Wyze offers a range of refurbished doorbells designed to meet your needs with advanced features and reliable weatherproofing. Explore the best refurbished doorbells that combine durability, smart technology, and versatile installation options for complete indoor and outdoor functionality.
Wyze Video Doorbell v2: Wired 2K Video with Robust Weather Resistance
Wyze Video Doorbell v2 lifestyle Experience clear, detailed video and smart alerts with Wyze Video Doorbell v2. The Wyze Video Doorbell v2 is a top choice for those seeking a wired doorbell with exceptional video quality and weather resistance. Rated IP65, it withstands rain, snow, and harsh outdoor conditions, ensuring reliable performance year-round.
Key Features:
  • 2K HD Video Resolution: Capture every detail on your porch with crystal-clear 2K video and a wide field of view.
  • Local microSD Storage: Continuous 24/7 local recording lets you review footage anytime without relying solely on cloud storage.
  • Two-Way Audio: Communicate with visitors instantly through the Wyze app, whether you’re inside or away.
  • Motion-Activated Voice Deterrence: Automatically warn unwanted visitors with a voice prompt when motion is detected (requires Cam Plus subscription).
  • Works with Existing Chimes: Includes a chime controller so you can keep your traditional doorbell sound.
  • Night Vision: Award-winning starlight sensor provides vivid color night vision for clear images even in low light.
  • Smart Home Integration: Compatible with Alexa and Google Home for voice commands and live feed viewing.
  • 30° Corner Kit Included: Adjust your doorbell’s angle for the perfect view, reducing blind spots.
This doorbell is perfect for homeowners who want a wired solution with advanced features and dependable weatherproofing.
Wyze Duo Cam Battery Doorbell: Dual Cameras and Wireless Convenience
Wyze Duo Cam Doorbell lifestyle Dual camera views and battery power for flexible installation anywhere. For those who prefer a wireless option with enhanced coverage, the Wyze Duo Cam Battery Doorbell offers dual camera views—one facing forward and one downward—to monitor both visitors and packages simultaneously.
Highlights:
  • Dual 2K and 1080p Cameras: Front camera delivers 2K resolution while the bottom camera covers the doorstep in 1080p.
  • Battery Powered with Optional Hardwired Setup: Install without wiring or connect to existing power for continuous recording.
  • IP65 Weatherproof Rating: Built to endure all weather conditions, from freezing cold to scorching heat.
  • Two-Way Talk & Voice Deterrence: Talk to visitors and deter suspicious activity with motion-triggered voice warnings.
  • Local and Cloud Storage: Supports microSD cards for local storage and cloud backup via Cam Plus.
  • Smart Alerts: AI-powered person, package, and vehicle detection with real-time notifications.
  • Includes Wyze Wi-Fi Chime and Removable Battery Pack: Ensures you never miss a visitor and can swap batteries easily.
Ideal for renters or homes without existing doorbell wiring, this battery-powered doorbell combines flexibility with high-end security features.
Wyze Video Doorbell Pro: Wired or Wireless with Wider View and Smart Alerts
Wyze Video Doorbell Pro lifestyle Quick install, wider view, and smart detection in one sleek package. The Wyze Video Doorbell Pro offers the best of both worlds: wired or wireless power options with a wider ultra-wide viewing angle. It’s designed for easy installation and smart home compatibility.
Features:
  • HD Video with Ultra-Wide Angle: Capture more of your porch and surroundings with a broader field of view.
  • Battery or Hardwired Power: Choose the power method that suits your home setup.
  • Smart Detection Alerts: Person, package, vehicle, and pet detection with Cam Plus subscription.
  • Motion-Activated Security Light: Adds an extra layer of protection by illuminating your porch when motion is detected.
  • Two-Way Audio & Quick Responses: Communicate with visitors and use preset quick replies.
  • Customizable Chime: Includes 20 unique tunes and adjustable sound levels.
  • Works with Alexa and Google Assistant: Voice control and live feed access.
  • IP65 Weather Resistance: Reliable performance in all weather conditions.
This doorbell is perfect for users wanting a versatile, high-performance smart doorbell with easy installation and comprehensive smart features.
The Front Porch Security Bundle: Complete Indoor and Outdoor Security Solution
For those looking to upgrade their entire front porch security, the Front Porch Security Bundle combines the Wyze Video Doorbell v2 with the Wyze Lock for a seamless smart home experience.
Bundle Benefits:
  • 1080p HD Video Doorbell with Two-Way Audio: Monitor and communicate with visitors easily.
  • Remote Lock Control: Lock or unlock your door remotely and view lock history via the Wyze app.
  • Integrated Security: Control your doorbell and lock from one app for convenience and peace of mind.
  • Weather Resistant: Both devices are designed to withstand outdoor conditions.
This bundle is ideal for homeowners wanting a comprehensive, weatherproof indoor/outdoor security system.
Wyze Video Doorbell v2 Wedge Kit: Perfect Angle for Maximum Coverage
If your doorbell installation area has an angled door frame or stairs, the Wyze Video Doorbell v2 Wedge Kit is an essential accessory.
Features:
  • Adjustable Viewing Angles: Includes a 15° horizontal bracket and two 7.5° vertical brackets to eliminate blind spots.
  • Weather Resistant: Made from durable plastic with IP65 rating.
  • Easy Installation: Quick setup with included screws and guide.
Compatible Only with Wyze Video Doorbell v2. This kit enhances your doorbell’s field of view, ensuring you never miss a visitor or package.
Why Choose Wyze Refurbished Doorbells for Indoor and Outdoor Use?
Wyze refurbished doorbells combine affordability with premium features, including weather resistance, high-resolution video, and smart home integration. Whether wired or battery-powered, these doorbells provide reliable indoor and outdoor functionality, making them perfect for any home environment.
  • IP65 Weatherproofing: All featured doorbells are rated to withstand rain, snow, and extreme temperatures.
  • Smart Features: Two-way audio, motion detection, voice deterrence, and AI-powered alerts keep your home secure.
  • Flexible Installation: Options for wired, wireless, or hybrid setups to fit your home’s needs.
  • Local and Cloud Storage: Choose between local microSD storage or cloud plans for video recording.
  • Smart Home Compatibility: Works with Alexa, Google Assistant, and IFTTT for voice control and automation.
Conclusion
For a weather resistant refurbished doorbell with both indoor and outdoor functionality, Wyze offers a variety of options tailored to your security needs. From the wired Wyze Video Doorbell v2 with 2K video clarity to the versatile battery-powered Wyze Duo Cam Doorbell, and the all-in-one Front Porch Security Bundle, you can find the perfect smart doorbell solution that fits your lifestyle and budget. Enhance your home security today with a Wyze doorbell that delivers clear video, smart alerts, and reliable weatherproof performance.
FeatureWyze Video Doorbell v2Wyze Duo Cam Battery DoorbellWyze Video Doorbell ProThe Front Porch Security BundleWyze Video Doorbell v2 Wedge Kit
TypeWired Video DoorbellBattery-Powered Video DoorbellWired or Wireless Battery-Powered DoorbellBundle (Wyze Video Doorbell + Wyze Lock)Accessory (Wedge Kit for Doorbell v2)
Video Resolution2K (2048 x 1536)Front: 2K (2048 x 1536), Bottom: 1080pHD (Crystal-clear)1080p HD (Doorbell)N/A
Field of View135° Horizontal, 103° Vertical, 166.8° DiagonalFront: 132° H x 100° V, Bottom: 121° H x 60° VUltra-wide viewing angle120° Vertical x 88° Horizontal (Doorbell)N/A
Power16V-24V AC, ≥10VABattery (Lithium-ion 6200 mAh) or Hardwired ACHardwired or Battery16V-24V AC, ≥10VA (Doorbell)N/A
StorageLocal microSD (up to 256GB FAT32), Cloud optionLocal microSD (up to 256GB exFAT), Cloud storageCloud storage with Cam PlusNot specified (Doorbell included)N/A
AudioTwo-way audio, ECM microphone, 8Ω 1W speakerTwo-way audio, siren 90 dBTwo-way audioTwo-way audio (Doorbell)N/A
Motion Detection & AlertsYes, with motion-activated voice deterrenceYes, with AI detections and voice deterrenceYes, smart detection alerts with Cam PlusYes (Doorbell)N/A
ConnectivityWi-Fi 2.4 GHz b/g/nWi-Fi 2.4 & 5 GHz, Bluetooth 5.0Dual-band Wi-FiWi-Fi 2.4 GHz b/g/n (Doorbell)N/A
Weather ResistanceIP65IP65IP65IP65 (Doorbell)Weather resistant
Dimensions4.3" x 1.7" x 0.9" (110mm x 44mm x 24mm)5.90" x 1.88" x 1.18" (150mm x 48mm x 30mm)Not specified1.5" x 3.25" x 0.625" (Doorbell)N/A
InstallationWired installationBattery or hardwired30-second install, wired or wirelessBundle includes installation kitsQuick installation
Included ItemsDoorbell v2, Chime Controller, Wall Plate, Wedge (30°), Installation Kit, Wire Caps, Extension Wires, Screws, Wall Anchors, Quick Start GuideDoorbell, Wi-Fi Chime, Back Plate, Corner Kit, USB-C Cable, Wire Nuts, Jump Wire, Extension Wires, Screws, Expansion Tubes, Adhesive Tape, Detaching Pin, Removable Battery Pack, Quick Start GuideDoorbell Pro, Chime includedWyze Lock, Lock Gateway, Batteries, Video Doorbell, Chime, Wall Plate, Wedge, Wire Caps, Screws, Extension Wires, Fuse, Quick Start Guides15° Horizontal Bracket, 2x 7.5° Vertical Brackets, Short Screws, Quick Start Guide
Price (USD)$44.98$89.98 - $109.99$99.98$123.99 - $173.97$8.99 (Wedge Kit Only), $51.97 (Doorbell v2 + Wedge Kit)
Warranty1 Year1 YearNot specifiedNot specified1 Year
Special Features2K video, local microSD storage, motion-activated voice deterrenceDual cameras (people & packages), AI detections, removable battery packMotion-activated security light, 20 chime tunes, smart detection alertsIncludes smart lock with remote lock/unlock, lock history, Alexa/Google integrationAdjusts viewing angle for Doorbell v2, reduces blind spots
What makes Wyze refurbished doorbells suitable for both indoor and outdoor use?Wyze refurbished doorbells are designed with IP65 weather resistance, making them capable of withstanding rain, snow, and extreme temperatures. This ensures reliable performance and durability for both indoor and outdoor installations.
Which Wyze refurbished doorbell offers the best video quality?The Wyze Video Doorbell v2 provides crystal-clear 2K HD video resolution with a wide field of view, allowing you to capture every detail at your entryway.
Are Wyze refurbished doorbells compatible with smart home systems?Yes, Wyze refurbished doorbells work with popular smart home platforms like Alexa and Google Assistant, enabling voice commands and live video feed viewing for seamless integration.
Can I use Wyze doorbells without existing doorbell wiring?Yes, the Wyze Duo Cam Battery Doorbell and Wyze Video Doorbell Pro both offer battery-powered installation options, making them ideal for homes without existing wiring or for renters.
Do Wyze refurbished doorbells support local video storage?Yes, many Wyze doorbells, such as the Wyze Video Doorbell v2 and Wyze Duo Cam Battery Doorbell, support local microSD card storage for continuous 24/7 recording, in addition to optional cloud storage.
What smart security features do Wyze refurbished doorbells offer?Wyze doorbells include advanced features like two-way audio, motion-activated voice deterrence, AI-powered person, package, and vehicle detection, and real-time smart alerts to enhance your home security.
Is there a Wyze doorbell bundle for complete front porch security?Yes, the Front Porch Security Bundle combines the Wyze Video Doorbell v2 with the Wyze Lock, offering integrated video monitoring and remote lock control for comprehensive front porch security.
How do I ensure the best viewing angle for my Wyze Video Doorbell v2?The Wyze Video Doorbell v2 comes with a 30° corner kit, and you can also purchase the Wyze Video Doorbell v2 Wedge Kit, which includes adjustable brackets to eliminate blind spots and optimize your doorbell’s field of view.
What are the installation options for Wyze Video Doorbell Pro?The Wyze Video Doorbell Pro can be installed using either battery power for wireless convenience or hardwired for continuous power, offering flexibility to suit your home’s setup.
Why choose a refurbished Wyze doorbell over a new one?Refurbished Wyze doorbells offer the same premium features—such as weather resistance, high-resolution video, and smart home compatibility—at a more affordable price, making them a cost-effective choice for reliable home security.
What are the key features of the Wyze Video Doorbell v2?Can you tell me more about the Wyze Duo Cam Battery Doorbell?Are there any ongoing sales or discounts for Wyze doorbells?
