Wyze Weatherproof Doorbell Cameras: Rain, Snow & Heat Protection
Weatherproof Doorbell Camera That Withstands Rain, Snow, and Heat
When it comes to securing your home’s entrance, having a reliable, weatherproof doorbell camera is essential. Whether it’s pouring rain, heavy snow, or scorching heat, your doorbell camera should perform flawlessly to keep you connected and your home safe. Wyze offers top-tier solutions that combine durability, crystal-clear video, and smart features to meet all your outdoor security needs.
Introducing the Wyze Video Doorbell v2: The Ultimate Weatherproof Doorbell Camera
The Wyze Video Doorbell v2 is designed to be your clearest and most capable wired video doorbell yet. With an IP65 weatherproof rating, it’s built to withstand harsh weather conditions including rain, snow, and heat, ensuring uninterrupted security no matter the season.
  • 2K Crystal-Clear Video Quality: Capture every visitor in stunning detail with 2K resolution, providing a head-to-toe view of your porch.
  • Local MicroSD Storage: Continuous 24/7 local recording means you never miss a moment, even without cloud subscription.
  • Two-Way Audio: Speak directly to visitors or delivery personnel from anywhere using the Wyze app.
  • Motion-Activated Voice Deterrence: Automatically warn unwanted visitors with a voice prompt when motion is detected (requires Cam Plus subscription).
  • Works with Existing Chimes: Keep your traditional doorbell chime ringing with the included chime controller.
  • Night Vision: Award-winning starlight sensor delivers clear color night vision for round-the-clock monitoring.
  • Smart Home Integration: Compatible with Alexa and Google Home for voice commands and live feed viewing.
  • 30° Corner Kit Included: Achieve the perfect viewing angle with the included mounting wedge.
“Rated IP65, the Wyze Video Doorbell v2 is built to brave the worst weather — rain, snow, or heat — so your home stays protected all year round.”
Wyze Video Doorbell v2 in use on a porch during rainy weather Weatherproof Wyze Cam Pan v3 in snowy outdoor setting
Wyze Cam v4: Versatile Weatherproof Outdoor Camera with Spotlight
While the Wyze Video Doorbell v2 is perfect for your front door, the Wyze Cam v4 offers unmatched outdoor security with advanced features and IP65 weather resistance, making it ideal for any exterior location exposed to rain, snow, or heat.
  • 2.5K QHD Resolution: Higher than 1080p, this camera delivers ultra-clear video with vibrant colors thanks to Wide Dynamic Range (WDR).
  • Enhanced Color Night Vision: See more details at night with an upgraded sensor and color illumination.
  • Motion-Activated Spotlight & Siren: Deter intruders with a bright spotlight and loud siren.
  • 24/7 Local Recording: Supports microSD cards up to 256GB for continuous recording without subscription fees.
  • Wi-Fi 6 Support: Enjoy a stronger, more reliable connection for seamless streaming.
  • Two-Way Talk: Communicate clearly with visitors or pets using enhanced audio.
  • Smart Assistant Compatibility: Works with Alexa, Google Assistant, and IFTTT for smart home automation.
  • IP65 Weatherproof: Designed to withstand all weather conditions, from heavy rain to snow and extreme heat.
This camera is perfect for monitoring your driveway, backyard, or any outdoor area where weatherproof reliability is a must.
Wyze Cam Pan v3: 360° Weatherproof Coverage for Outdoor Security
For those who want full panoramic coverage with weatherproof durability, the Wyze Cam Pan v3 is an excellent choice. Rated IP65, it’s built to endure rain, snow, and heat while providing flexible viewing angles.
  • 360° Horizontal & 180° Vertical Pan/Tilt: Cover every corner of your outdoor space with smooth, fast rotation.
  • 1080p Full HD Video: Clear, detailed video with 4 IR LEDs for night vision.
  • Two-Way Audio: Built-in speaker and microphone with noise and echo cancellation.
  • Supports up to 256GB microSD: Local storage for continuous recording.
  • Easy Installation: Magnetic mount and screw mount options.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
  • IP65 Weather Resistance: Reliable performance in all weather conditions.
  • Operating Temperature Range: -4°F to 122°F (-20°C to 50°C), perfect for extreme climates.
This camera is ideal for wide outdoor areas like patios, gardens, or large porches where comprehensive coverage is needed. Wyze Cam Pan v3 mounted outdoors in snowy weather Wyze Cam Pan v3 weatherproof outdoor camera in snowy environment
Why Choose Wyze for Your Weatherproof Doorbell Camera?
Wyze products stand out for their combination of affordability, advanced technology, and robust weatherproof design. Whether you want a dedicated doorbell camera or a versatile outdoor security camera, Wyze offers solutions that:
  • Withstand harsh weather conditions (IP65 rating)
  • Deliver high-resolution video day and night
  • Provide two-way communication for convenience and safety
  • Integrate seamlessly with popular smart home ecosystems
  • Offer local storage options to keep your footage secure without mandatory subscriptions
With Wyze, you get peace of mind knowing your home is protected no matter the weather.
Summary of Weatherproof Cameras for Your Home
ProductVideo ResolutionWeatherproof RatingKey FeaturesPrice (Starting at)
Wyze Video Doorbell v22KIP65Two-way talk, local storage, voice deterrence$44.98
Wyze Cam v42.5K QHDIP65Spotlight, siren, Wi-Fi 6, color night vision$35.98
Wyze Cam Pan v31080pIP65360° pan/tilt, two-way audio, night vision$39.98
Choose the Wyze camera that fits your needs and enjoy reliable, weatherproof security for your home.
FeatureWyze Video Doorbell v2Wyze Cam v4Wyze Cam Pan v3
TypeWired Video DoorbellWired Security CameraWired Pan & Tilt Security Camera
Video Resolution2K (approx. 2560x1440)2.5K QHD (2560x1440)1080p (1920x1080)
Field of View (FOV)Head-to-toe view (exact degrees not specified)115.8° DFOV, 98.5° HFOV, 53.1° VFOV120° FOV
Pan & TiltNoNo360° horizontal, 180° vertical
Night VisionColor Night Vision (Starlight Sensor)Enhanced Color Night Vision4 IR LEDs (850 nm) B&W Night Vision
AudioTwo-way audioEnhanced two-way talk, 99dB waterproof speakerTwo-way audio with noise & echo cancellation
Motion DetectionYes, with motion-activated voice deterrenceYes, with motion detection zonesYes, push notifications
Local StoragemicroSD card slot (continuous local recording)microSD card up to 512GB (continuous local recording)Supports up to 256GB microSD (ExFAT format)
Cloud StorageOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscription
Weather ResistanceIP65IP65IP65
Power SourceWiredWiredWired
Mounting OptionsDoorbell + Chime Controller includedStand, Wall, Ceiling, Magnetic wall mountScrew mount (1/4"-20), indoor/outdoor
Special FeaturesPre-roll motion recording (3-6 seconds), works with existing chime, motion-activated voice deterrenceMotion-activated spotlight, siren, Wi-Fi 6 support, AI auto-zoom tracking360° pan and 180° tilt, redesigned for indoor/outdoor use
DimensionsNot specified2in x 2in x 2 3/8in (approx.)124mm x 60mm x 63mm
WeightNot specified0.49 lb (222 g)11.29 oz (320 g)
ConnectivityWi-Fi (2.4 GHz)Wi-Fi 6, Bluetooth 5.2Wi-Fi 2.4 GHz (no 5 GHz support)
IntegrationsAlexa, Google HomeAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
WarrantyNot specified1 Year1 Year
What makes the Wyze Video Doorbell v2 a reliable weatherproof doorbell camera?The Wyze Video Doorbell v2 is rated IP65, making it highly weatherproof and capable of withstanding rain, snow, and heat. It delivers 2K crystal-clear video, two-way audio, local microSD storage for 24/7 recording, and works with existing chimes. Its durable design ensures uninterrupted security for your home entrance in any season.
Can Wyze cameras operate in extreme weather conditions?Yes, all featured Wyze cameras, including the Wyze Video Doorbell v2, Wyze Cam v4, and Wyze Cam Pan v3, have an IP65 weatherproof rating. This means they are designed to withstand harsh weather conditions such as heavy rain, snow, and extreme heat, ensuring reliable outdoor security year-round.
Does the Wyze Video Doorbell v2 require a subscription for video recording?No, the Wyze Video Doorbell v2 supports continuous 24/7 local recording via microSD card, so you can store footage without a mandatory cloud subscription. However, some advanced features like motion-activated voice deterrence require a Cam Plus subscription.
What video quality does the Wyze Cam v4 offer for outdoor security?The Wyze Cam v4 provides ultra-clear 2.5K QHD resolution, which is higher than standard 1080p. It also features Wide Dynamic Range (WDR) for vibrant colors and enhanced color night vision, ensuring detailed footage day and night.
Are Wyze cameras compatible with smart home systems?Yes, Wyze cameras are compatible with popular smart home ecosystems. The Wyze Video Doorbell v2, Wyze Cam v4, and Wyze Cam Pan v3 all work with Alexa and Google Assistant, and some models also support IFTTT for automation and voice commands.
What are the storage options for Wyze weatherproof cameras?Wyze weatherproof cameras support local storage via microSD cards (up to 256GB for Wyze Cam v4 and Wyze Cam Pan v3), allowing for continuous 24/7 recording without subscription fees. This ensures your footage is secure and accessible even without internet connectivity.
How does the Wyze Cam Pan v3 provide comprehensive outdoor coverage?The Wyze Cam Pan v3 offers 360° horizontal and 180° vertical pan/tilt capabilities, allowing you to monitor every corner of your outdoor space. It features 1080p full HD video, two-way audio, night vision, and is rated IP65 for weather resistance, making it ideal for patios, gardens, and large porches.
What features help deter intruders with Wyze outdoor cameras?Wyze outdoor cameras like the Wyze Cam v4 include motion-activated spotlights and sirens to deter intruders. The Wyze Video Doorbell v2 offers motion-activated voice deterrence (with Cam Plus subscription), automatically warning unwanted visitors when motion is detected.
What is the operating temperature range for Wyze weatherproof cameras?The Wyze Cam Pan v3, for example, operates in temperatures ranging from -4°F to 122°F (-20°C to 50°C), making it suitable for extreme climates and ensuring reliable performance in both hot and cold weather.
Why should I choose Wyze for my weatherproof doorbell or outdoor camera?Wyze offers affordable, advanced, and robust weatherproof cameras with high-resolution video, two-way communication, smart home integration, and local storage options. Their IP65-rated products ensure your home is protected in any weather, providing peace of mind and reliable security.
What are the key features of the Wyze Video Doorbell v2?Can the Wyze Video Doorbell v2 be integrated with smart home systems?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Video Doorbell v2?
