DIY Outdoor Smart Floodlights with Easy Bluetooth Setup
Outdoor DIY Install Smart Floodlight with Bluetooth Setup
Enhance your home security and outdoor lighting with smart floodlights that are easy to install yourself and offer Bluetooth setup options. Whether you want bright illumination, high-definition video surveillance, or seamless smart home integration, these Wyze products provide powerful features tailored for outdoor use.
Wyze Floodlight Security Bundle: Powerful Lighting & Surveillance
The Wyze Floodlight Security Bundle is designed to dominate the dark with intense brightness and crystal-clear video. Perfect for DIY outdoor installation, this bundle includes options like the Floodlight Pro and Floodlight v2, both offering:
  • High-Resolution Video: Floodlight Pro delivers 2.5K QHD (2560x1440) resolution, while Floodlight v2 offers 2K (2304x1296) HD video.
  • Wide Field of View: Up to 180° diagonal on Floodlight Pro and 160° on Floodlight v2, covering large outdoor areas.
  • Super-Bright LEDs: 3000 lumens on Floodlight Pro and 2800 lumens on Floodlight v2 for clear visibility.
  • Color Night Vision: See in full color even in low light conditions.
  • Motion-Activated Voice Deterrence: Scare off intruders with a built-in speaker.
  • 24/7 Recording: Supports microSD cards up to 256 GB for continuous local storage.
  • Weather Resistant: IP65 rating ensures durability in rain, snow, or heat.
  • Smart Integrations: Compatible with Alexa, Google Assistant, and IFTTT for voice and automation control.
  • Easy Mounting: Wall or ceiling mount options for flexible installation.
This bundle is ideal for homeowners who want a comprehensive security and lighting solution that’s easy to set up and manage via Wi-Fi.
"With this much lumen power, you'll dominate the dark, and spot the bad guys, with ease."
Outdoor evening deck with Wyze Cam Floodlight Bright outdoor security lighting for your home
Wyze Cam Floodlight v2: Smart Lighting Meets Security
For those seeking a smart floodlight with Bluetooth setup and DIY installation, the Wyze Cam Floodlight v2 offers an excellent balance of features:
  • 2800 Lumens Brightness: Two dimmable LED panels provide bright, adjustable lighting.
  • 2K HD Video with Color Night Vision: Capture clear footage day and night.
  • 160° Wide-Angle View: Covers broad outdoor spaces like driveways and porches.
  • Two-Way Audio: Built-in speaker and microphone allow communication through the app.
  • AI-Powered Light Control: Automatically adjusts lighting based on activity.
  • Dusk-to-Dawn Automation: Lights turn on/off based on ambient light.
  • IP65 Weather Resistance: Reliable in all weather conditions.
  • Local Storage: Supports up to 256 GB microSD card for continuous recording.
  • Smart Assistant Compatibility: Works with Alexa, Google Assistant, and IFTTT.
  • Bluetooth & Wi-Fi Setup: Simplifies installation and connectivity.
This floodlight is perfect for DIY enthusiasts who want a smart, connected floodlight with easy Bluetooth setup and robust security features. Wyze Cam Floodlight v2 installed on driveway Smart floodlight with wide-angle security camera
Wyze Cam Floodlight Pro: The Ultimate Outdoor Security Floodlight
For the highest level of outdoor security and lighting, the Wyze Cam Floodlight Pro is a top-tier choice:
  • 2.5K QHD Video Resolution: Ultra-clear 2560x1440 video with color night vision.
  • 180° Wide-Angle Lens: Extensive coverage of your yard or property.
  • 3000 Lumens Brightness: Three dimmable LED panels for powerful illumination.
  • Onboard AI Computer Vision: Detects people and vehicles to trigger lights and alerts intelligently.
  • Motion-Activated Voice Deterrence & 105dB Siren: Actively deter intruders with sound and light.
  • Dual-Band Wi-Fi (2.4 & 5 GHz): Reliable connectivity for smooth streaming.
  • Weatherproof IP65 Rating: Built to withstand harsh outdoor environments.
  • Supports up to 256 GB microSD Storage: For continuous local video recording.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
  • Easy Hardwired Installation: Designed for DIY with included mounting kits.
This floodlight is ideal for homeowners who want a professional-grade security system with smart floodlight capabilities and advanced AI detection. Woman with dog near Wyze Cam Floodlight Pro Advanced floodlight security with AI detection
Wyze Bulb Cam + Accessory Bulbs: Bluetooth-Enabled Smart Lighting & Surveillance
If you prefer a smart floodlight solution with Bluetooth setup that fits into existing fixtures, the Wyze Bulb Cam + Accessory Bulbs bundle is a versatile option:
  • 2K HD Video with Color Night Vision: Clear video monitoring integrated into a light bulb.
  • Up to 800 Lumens Brightness: Bright enough for outdoor lighting needs.
  • 160° Field of View: Wide coverage for monitoring.
  • Bluetooth Low Energy (BLE) & Wi-Fi Connectivity: Easy Bluetooth setup and remote control.
  • Motion-Activated Light & Alerts: Receive instant notifications on motion detection.
  • Two-Way Audio & Built-in Siren: Communicate and deter intruders.
  • Local Video Storage: Supports microSD cards up to 256 GB with no subscription required.
  • IP65 Weather Resistance: Suitable for outdoor use.
  • Accessory Bulbs: Add up to 5 accessory bulbs for extended lighting control and automation.
This product is perfect for DIYers who want a smart floodlight camera that installs like a regular bulb and offers Bluetooth setup convenience.
Why Choose Wyze for Your Outdoor Smart Floodlight?
Wyze smart floodlights combine powerful lighting, high-definition video, and smart home integration with easy DIY installation and Bluetooth setup options. Whether you want a simple bulb cam or a professional-grade floodlight with AI detection, Wyze offers solutions that fit your needs and budget.
"Easy to install, weather-resistant, and packed with smart features — Wyze floodlights light the way to safer homes."
Summary of Featured Products
Product NameVideo ResolutionBrightness (Lumens)Field of ViewSetup TypeWeather ResistancePrice Range (USD)
Wyze Floodlight Security Bundle2K - 2.5K QHD2800 - 3000160° - 180°Hardwired, Wi-FiIP65$209.96
Wyze Cam Floodlight v22K HD2800160°Hardwired, BluetoothIP65$89.98
Wyze Cam Floodlight Pro2.5K QHD3000180°Hardwired, Wi-FiIP65$149.98
Wyze Bulb Cam + Accessory Bulbs2K HD800160°Bluetooth, Wi-FiIP65$64.98 - $84.98
Optimize your outdoor security and lighting with Wyze smart floodlights featuring easy DIY installation and Bluetooth setup. Brighten your nights and protect your home with smart technology designed for modern living.
FeatureFloodlight Security BundleWyze Cam Floodlight v2Wyze Cam Floodlight ProWyze Bulb Cam + Accessory Bulbs
Price$209.96$89.98$149.98$64.98 - $84.98
Included Devices1x Wyze Floodlight Pro + 1x Wyze Floodlight v21x Wyze Cam Floodlight v21x Wyze Cam Floodlight ProBulb Cam + 1, 2, or 3 Accessory Bulbs
Camera ResolutionFloodlight Pro: 2.5K QHD; Floodlight v2: 2K HD2K HD2.5K QHD2K (2304 x 1296)
Field of ViewFloodlight Pro: 180°; Floodlight v2: 160°160°180°160°
Lighting (Lumens)Floodlight Pro: 3000 lumens; Floodlight v2: 2800 lumens2800 lumens3000 lumensUp to 800 lumens (Bulb and Accessory Bulbs)
Night VisionColor Night VisionColor Night VisionColor Night VisionColor Night Vision
Motion DetectionAI-powered, PIR, custom zonesAdvanced motion detection, 270° PIRAI computer vision, custom zonesMotion alerts
SirenFloodlight v2: 105dB siren105dB siren105dB siren95dB siren
ConnectivityDual-band Wi-Fi (2.4 & 5 GHz)Wi-Fi 2.4 GHzDual-band Wi-Fi (2.4 & 5 GHz)Wi-Fi 2.4 GHz + Bluetooth Low Energy
Power SupplyHardwired 110-120V ACHardwired or Plug-in Mount option availableHardwired 110-120V AC or Plug-in Mount optionStandard E26 socket, 120V AC
Weather ResistanceIP65IP65IP65IP65
Local RecordingmicroSD up to 256 GBmicroSD up to 256 GBmicroSD up to 256 GBmicroSD up to 256 GB
Cloud StorageOptional with Cam Plus subscriptionOptional with Cam Plus subscriptionOptional with Cam Plus subscriptionCloud storage via AWS
Two-Way AudioYes (Floodlight v2 and Pro)YesYesYes
Ambient Light ModeYesYesYesYes
Voice Assistant IntegrationAlexa, Google Assistant, IFTTTAlexa, Google AssistantAlexa, Google Assistant, IFTTTNot specified
InstallationHardwired; Plug-in Mounts available separatelyHardwired; Plug-in Mount available separatelyHardwired; Plug-in Mount available separatelyScrew-in bulb, fits standard fixtures
DimensionsFloodlight Pro: 10.2" x 9.1" x 7.8"Not specified10.2" x 9.1" x 7.8"Bulb size standard E26
WeightFloodlight Pro: 2.9 lbsNot specified2.9 lbsNot specified
Warranty1 Year1 Year1 Year1 Year
What are the main features of Wyze smart floodlights for outdoor security?Wyze smart floodlights offer high-resolution video (up to 2.5K QHD), super-bright LED lighting (up to 3000 lumens), wide-angle coverage (up to 180°), color night vision, motion-activated voice deterrence, two-way audio, AI-powered detection, weather resistance (IP65), and compatibility with Alexa, Google Assistant, and IFTTT. They also support local video storage and easy DIY installation with Bluetooth or Wi-Fi setup.
How easy is it to install Wyze outdoor smart floodlights?Wyze outdoor smart floodlights are designed for easy DIY installation. Most models offer hardwired installation with included mounting kits, while the Wyze Bulb Cam installs like a regular light bulb. Bluetooth and Wi-Fi setup options simplify the process, making it accessible for homeowners without professional help.
Do Wyze floodlights support Bluetooth setup?Yes, several Wyze floodlight products, such as the Wyze Cam Floodlight v2 and Wyze Bulb Cam, support Bluetooth setup. This allows for quick and easy installation and connectivity, making it convenient for DIY users.
What is the video quality of Wyze outdoor floodlight cameras?Wyze outdoor floodlight cameras offer high-definition video quality, with resolutions ranging from 2K HD (2304x1296) to 2.5K QHD (2560x1440). This ensures clear, detailed footage for effective outdoor surveillance, both day and night.
Are Wyze smart floodlights weatherproof?Yes, all Wyze smart floodlights are rated IP65 for weather resistance, making them suitable for outdoor use in rain, snow, or heat.
Can Wyze floodlights record video continuously?Yes, Wyze floodlights support continuous 24/7 video recording when a microSD card (up to 256 GB) is installed. This allows for local storage of footage without a subscription.
Do Wyze floodlights work with smart home assistants?Yes, Wyze floodlights are compatible with popular smart home assistants, including Amazon Alexa, Google Assistant, and IFTTT. This enables voice control and automation for your outdoor lighting and security.
What is the difference between Wyze Cam Floodlight v2 and Floodlight Pro?Wyze Cam Floodlight v2 offers 2K HD video, 2800 lumens brightness, 160° field of view, Bluetooth setup, and AI-powered light control. The Floodlight Pro features 2.5K QHD video, 3000 lumens brightness, a wider 180° field of view, onboard AI computer vision, dual-band Wi-Fi, and a 105dB siren for advanced security.
Can I expand my Wyze smart lighting system with accessory bulbs?Yes, the Wyze Bulb Cam + Accessory Bulbs bundle allows you to add up to 5 accessory bulbs for extended lighting control and automation, all managed through Bluetooth and Wi-Fi connectivity.
Is a subscription required for Wyze floodlight cameras to store video?No, a subscription is not required for local video storage. Wyze floodlight cameras support microSD cards up to 256 GB for continuous recording and playback without monthly fees.
What is the brightness level of Wyze outdoor floodlights?Wyze outdoor floodlights offer varying brightness levels: Floodlight Pro provides 3000 lumens, Floodlight v2 delivers 2800 lumens, and the Wyze Bulb Cam offers up to 800 lumens, ensuring clear visibility for different outdoor spaces.
Do Wyze floodlights have night vision capabilities?Yes, Wyze floodlights feature color night vision, allowing you to see clear, full-color footage even in low-light or nighttime conditions.
What security features do Wyze floodlights offer?Wyze floodlights include motion-activated lighting, voice deterrence, built-in sirens (up to 105dB), two-way audio, AI-powered detection for people and vehicles, and instant motion alerts to your smartphone.
Can you tell me more about the features of the Wyze Bulb Cam and Accessory Bulbs?What is the installation process like for the Wyze Cam Floodlight v2?What kind of warranty do the Wyze smart floodlights come with?
