Best Floodlight Cameras with Bluetooth Setup for Renters Without Wiring
If you're a renter looking for a
floodlight camera with Bluetooth setup that requires
no wiring or complicated installation, you’ve come to the right place. Traditional floodlight cameras often need hardwiring, which can be a hassle or even impossible in rental properties. Luckily, Wyze offers smart, easy-to-install floodlight cameras and accessories designed for renters who want security without the permanent modifications.
Below, we explore the top Wyze products that fit your needs perfectly — from wireless Bluetooth-enabled cameras to plug-in mounts that eliminate the need for electrical work.
Wyze Cam Floodlight v2: Powerful Security with Easy Setup
Bright, motion-activated floodlight camera for renters
The
Wyze Cam Floodlight v2 is an excellent choice for renters who want a
wireless Bluetooth setup combined with powerful floodlight security. This camera offers:
- 2800 lumens of LED brightness with motion-activated floodlights that turn night into day.
- 2K video resolution with color night vision and a wide 160° field of view to cover large areas.
- Bluetooth 5.2 and Wi-Fi 2.4 GHz connectivity for seamless setup without complicated wiring.
- Plug-in mount compatibility (sold separately) for easy installation using existing outdoor outlets.
- Ambient Light Mode that provides low-level lighting and brightens on motion detection.
- Two-way talk and 105dB siren for active deterrence.
- Dusk-to-dawn automation and IP65 weather resistance for reliable outdoor use.
- 24/7 local recording with microSD card support (up to 256GB) — no subscription required.
This camera is perfect for renters who want to avoid drilling or electrical work but still want a robust security solution with smart home integration (Alexa, Google Assistant, IFTTT).
Wyze Cam Floodlight Plug-In Mount: No Wiring Needed
For renters without hardwired outdoor power, the
Wyze Cam Floodlight Plug-In Mount is a game-changer.
- Plug-n-play design lets you power your floodlight camera from any outdoor outlet.
- Compatible with Wyze Cam Floodlight v1, v2, and Floodlight Pro.
- Comes with a 20-foot power cord, mounting kit, and weatherproof design.
- Eliminates the need for a junction box or electrician.
- Easy DIY installation — just plug it in and mount the camera.
This accessory is ideal for renters who have access to an outdoor power outlet but cannot modify wiring or install permanent fixtures.
Wyze Cam Floodlight Pro + Plug-In Mount Bundle: Premium Security Without Hardwiring
High-end floodlight camera with plug-in mount for renters
For those wanting the ultimate in floodlight camera technology without wiring hassles, the
Wyze Cam Floodlight Pro + Plug-In Mount Bundle offers:
- 2.5K QHD video resolution with color night vision and a massive 180° ultra-wide field of view.
- Three adjustable LED light panels delivering 3000 lumens of bright, customizable lighting.
- Dual-band Wi-Fi (2.4 & 5 GHz) and Bluetooth for easy wireless setup.
- Plug-in mount included for simple installation without electrical work.
- Advanced AI-powered motion detection that distinguishes people, vehicles, and packages.
- 105dB siren and two-way audio for active home protection.
- IP65 weatherproof rating and durable matte finish.
- Compatible with Alexa, Google Assistant, and IFTTT for smart home control.
This bundle is perfect for renters who want professional-grade security with the convenience of plug-in power and wireless setup.
Wyze Cam v4 + Lamp Socket v2 Bundle: Bluetooth Camera Without Outlet Wiring
If you want a
Bluetooth-enabled camera that can be powered without an outlet or hardwiring, the
Wyze Cam Pan v3 + Lamp Socket v2 Bundle is a smart solution.
- The Lamp Socket v2 powers the camera by screwing into your existing outdoor light socket — no outlet or wiring needed.
- Compatible with Wyze Cam Pan v3, v3 Pro, v4, and other Wyze cameras.
- Supports motion-activated lighting by linking the camera and lamp socket.
- Easy installation — just screw in like a lightbulb.
- Supports LED or CFL bulbs under 20W (incandescent bulbs not recommended).
- Control your lighting and camera remotely via the Wyze app.
- Perfect for renters who want to avoid electrical modifications but still want smart lighting and security.
This bundle offers a unique way to power your camera and upgrade your outdoor lighting without any wiring or outlets.
Why Choose Wyze Floodlight Cameras for Renters?
"Wyze floodlight cameras combine powerful lighting, high-resolution video, and smart wireless setup — all without the need for hardwiring or permanent installation."
- Bluetooth and Wi-Fi setup means no electrician or drilling required.
- Plug-in mounts and lamp socket power options provide flexible installation for renters.
- Smart home integration with Alexa, Google Assistant, and IFTTT.
- Weatherproof and durable for year-round outdoor use.
- Affordable pricing with no subscription required for local storage.
Summary Table of Recommended Products for Renters
Product | Power Setup | Video Resolution | Lighting (Lumens) | Installation Ease | Price Range |
Wyze Cam Floodlight v2 | Plug-in mount or hardwired | 2K | 2800 | Plug-in mount, DIY | $89.98 |
Wyze Cam Floodlight Plug-In Mount | Plug-in power cord | N/A | N/A | Plug-n-play, no wiring | $19.98 |
Wyze Cam Floodlight Pro + Plug-In Mount Bundle | Plug-in mount included | 2.5K QHD | 3000 | Plug-in mount, DIY | $169.96 |
Wyze Cam Pan v3 + Lamp Socket v2 Bundle | Lamp socket power | 1080p (Pan v3) | N/A | Screw-in lamp socket | $53.96 |
Final Thoughts
For renters seeking a
floodlight camera with Bluetooth setup and no wiring, Wyze offers multiple innovative solutions. Whether you prefer a plug-in mount for easy power access or a lamp socket that uses your existing light fixture, these products provide smart, secure, and hassle-free outdoor security.
Upgrade your rental home’s security today with Wyze’s flexible, renter-friendly floodlight cameras!
### Product Highlights
What are the best floodlight cameras with Bluetooth setup for renters without wiring?
The best floodlight cameras with Bluetooth setup for renters who want to avoid wiring are Wyze Cam Floodlight v2, Wyze Cam Floodlight Pro + Plug-In Mount Bundle, and Wyze Cam Pan v3 + Lamp Socket v2 Bundle. These options offer wireless Bluetooth setup, plug-in or lamp socket power, and easy installation without the need for hardwiring or permanent modifications.Can I install a Wyze floodlight camera without hardwiring or drilling?
Yes, Wyze floodlight cameras such as the Wyze Cam Floodlight v2 and Wyze Cam Floodlight Pro can be installed using plug-in mounts or lamp socket adapters, eliminating the need for hardwiring or drilling. These solutions are ideal for renters who cannot make permanent changes to their property.How does the Wyze Cam Floodlight v2 work for renters?
The Wyze Cam Floodlight v2 offers a wireless Bluetooth setup and can be installed using a plug-in mount, allowing renters to use existing outdoor outlets for power. It features 2K video resolution, 2800 lumens of LED lighting, two-way talk, a 105dB siren, and is weather-resistant for reliable outdoor use.What is the Wyze Cam Floodlight Plug-In Mount and how does it help renters?
The Wyze Cam Floodlight Plug-In Mount is an accessory that allows you to power your Wyze floodlight camera from any outdoor outlet using a 20-foot power cord. It eliminates the need for a junction box or electrician, making it perfect for renters who want a plug-n-play, no-wiring installation.Is there a high-end floodlight camera option for renters that doesn’t require wiring?
Yes, the Wyze Cam Floodlight Pro + Plug-In Mount Bundle offers premium features like 2.5K QHD video, 3000 lumens of lighting, AI-powered motion detection, and a plug-in mount for easy, wire-free installation. It’s ideal for renters seeking professional-grade security without hardwiring.How can I power a Wyze camera if I don’t have an outdoor outlet?
If you don’t have an outdoor outlet, the Wyze Cam Pan v3 + Lamp Socket v2 Bundle allows you to power your camera by screwing the lamp socket adapter into an existing outdoor light socket. This setup requires no outlet or wiring and is perfect for renters.Are Wyze floodlight cameras weatherproof and suitable for outdoor use?
Yes, Wyze floodlight cameras such as the Floodlight v2 and Floodlight Pro are IP65 weather-resistant, making them durable and reliable for year-round outdoor use.Do Wyze floodlight cameras require a subscription for video storage?
No, Wyze floodlight cameras support 24/7 local recording with a microSD card (up to 256GB), so you do not need a subscription for video storage.Can Wyze floodlight cameras be integrated with smart home systems?
Yes, Wyze floodlight cameras are compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless smart home integration and voice control.What are the main benefits of Wyze floodlight cameras for renters?
Wyze floodlight cameras offer Bluetooth and Wi-Fi setup, plug-in and lamp socket power options, easy DIY installation, smart home compatibility, weatherproof design, and affordable pricing with no subscription required for local storage—making them ideal for renters.
