Buy Leak Sensor Kit with Probe & Hub for Indoor Water Safety
Buy Leak Sensor Kit with Probe and Hub for Indoor Safety
Protect your home from unexpected water damage with a reliable leak sensor kit that includes a probe and hub. Designed specifically for indoor use, these kits provide early detection of water leaks in critical areas such as under sinks, dishwashers, and crawlspaces. By alerting you immediately when a leak is detected, you can prevent costly repairs and maintain a safe living environment.
Why Choose a Leak Sensor Kit with Probe and Hub?
Comprehensive Leak Detection
A leak sensor kit typically includes multiple leak sensors and a probe attachment. The leak sensor is the main device that detects water presence, while the probe extends the sensor’s reach to hard-to-access places. This combination ensures that even the smallest leaks in tight or hidden spots are caught early.
The probe extends about 1 meter from the leak sensor, allowing it to detect leaks in places where the sensor alone cannot reach.
Reliable Indoor Monitoring
These kits are designed exclusively for indoor use, with an IP67 rating that protects against dust and temporary water immersion. However, they are not weatherproof and should not be used outdoors. The sensors operate effectively within a temperature range of 32ºF to 104ºF (0ºC to 40ºC) and a humidity range up to 85% at 86°F (30°C).
Long-Lasting Battery Life
Equipped with a CR2450 battery, the leak sensors offer up to 18 months of battery life. This means you can install them and enjoy peace of mind without frequent battery replacements.
Key Features of Leak Sensor Kits with Probe and Hub
Easy Setup and Integration
Setting up your leak sensor kit is straightforward. The sensors connect wirelessly to a central hub, which acts as the communication bridge to your smartphone app. The hub supports a range of up to 500 feet in ideal conditions, ensuring reliable connectivity even in basements or attics.
  • No hardwiring required; sensors are battery-powered.
  • Adhesive backing allows flexible placement.
  • The probe plugs directly into the leak sensor for extended reach.
Instant Notifications and Smart Alerts
Once installed, the system sends immediate notifications to your phone when a leak is detected. The app can differentiate whether the leak was detected by the sensor itself or the probe, helping you pinpoint the exact location of the issue.
Automations can be set up to trigger other smart home devices or alerts, enhancing your home’s safety and response capabilities.
Pack Contents and Expandability
A typical leak sensor kit includes:
  • 3 Leak Sensors
  • 1 Leak Sensor Probe
  • 1 Sense Hub (required for operation)
Additional probes can be purchased separately in packs of two, allowing you to customize your monitoring setup based on your home’s needs.
Ideal Placement for Leak Sensors and Probes
  • Under kitchen and bathroom sinks
  • Beneath dishwashers and washing machines
  • Crawlspaces and basements
  • Near water heaters and sump pumps
Proper placement ensures early detection before leaks cause significant damage.
Indoor Safety with Leak Sensor Kits: A Smart Investment
Investing in a leak sensor kit with a probe and hub is a proactive step toward protecting your home from water damage. With easy installation, long battery life, and smart notifications, these kits provide peace of mind and help you avoid costly repairs.
Home Kitchen Leak Sensor Setup Detect leaks early in your kitchen with smart sensors. Basement Leak Detection Keep your basement safe from hidden water leaks.
Remember, these leak sensor kits are designed for indoor use only and require pairing with a compatible hub for full functionality.
Summary
  • Leak Sensor & Probe: Detect water leaks in hard-to-reach places.
  • Sense Hub: Connects sensors and sends alerts to your phone.
  • Battery Life: Up to 18 months on a single CR2450 battery.
  • Range: Up to 500 feet from the hub in ideal conditions.
  • Indoor Use Only: Not weatherproof; do not use outdoors.
  • Pack Includes: 3 sensors, 1 probe, and hub (sold separately).
Protect your home today by choosing a leak sensor kit with probe and hub designed for reliable indoor safety.
What is included in the Leak Sensor Kit with Probe and Hub?The Leak Sensor Kit with Probe and Hub typically includes 3 leak sensors, 1 leak sensor probe, and 1 sense hub. Additional probes can be purchased separately in packs of two to expand your monitoring setup.
How does the leak sensor probe work?The leak sensor probe extends about 1 meter from the main leak sensor, allowing you to detect water leaks in hard-to-reach or hidden areas where the sensor alone cannot fit. This ensures comprehensive leak detection in critical indoor locations.
Where should I place my leak sensors and probes for optimal protection?For best results, place leak sensors and probes under kitchen and bathroom sinks, beneath dishwashers and washing machines, in crawlspaces and basements, and near water heaters and sump pumps. Proper placement ensures early detection of leaks before they cause significant damage.
Are the leak sensor kits suitable for outdoor use?No, these leak sensor kits are designed exclusively for indoor use. They have an IP67 rating for dust and temporary water immersion but are not weatherproof and should not be used outdoors.
How long does the battery last in the leak sensors?Each leak sensor is powered by a CR2450 battery, providing up to 18 months of battery life. This long-lasting battery ensures you can monitor your home with minimal maintenance.
How do I receive alerts if a leak is detected?When a leak is detected, the system sends instant notifications to your smartphone via the connected app. The app can specify whether the leak was detected by the sensor itself or the probe, helping you quickly identify the source.
Is the installation of the leak sensor kit difficult?No, installation is straightforward. The sensors are battery-powered and require no hardwiring. They connect wirelessly to the central hub, and adhesive backing allows for flexible placement. The probe plugs directly into the sensor for extended reach.
What is the wireless range of the leak sensor kit?The hub supports a wireless range of up to 500 feet in ideal conditions, ensuring reliable connectivity even in basements or attics.
Can I expand my leak detection system with additional probes?Yes, you can purchase additional leak sensor probes in packs of two to customize and expand your monitoring setup according to your home's needs.
What are the operating conditions for the leak sensor kit?The leak sensor kit operates effectively within a temperature range of 32ºF to 104ºF (0ºC to 40ºC) and a humidity range up to 85% at 86°F (30°C).
Do I need a hub for the leak sensors to work?Yes, the sense hub is required for the leak sensors to operate and communicate with your smartphone app. The hub acts as the central communication bridge for the system.
What are the leak sensor and probe used for?What kind of leaks does the leak sensor detect?How big does a leak need to be to be detected?
