WiFi Light Switch with Vacation Mode & Power Loss Recovery
WiFi Light Switch with Vacation Mode and Power Loss Recovery
Upgrade your home lighting with a smart WiFi light switch that offers advanced features like vacation mode and power loss recovery. These features ensure your home stays secure and your lighting automations remain uninterrupted, even during power outages or when you're away. Discover the Wyze Switch, a top choice for transforming your regular lights into a smart, connected system.
Wyze Switch: Smart Control Meets Convenience
The Wyze Switch is designed to turn your normal lights into smart lights that you can control from anywhere using the Wyze app. It offers seamless integration with other Wyze devices, allowing you to create a fully connected smart home ecosystem.
  • Vacation Mode: Make it look like someone’s home when you’re away by enabling Vacation Mode in the Wyze app. The switch will automatically turn lights on and off to simulate occupancy, enhancing your home security.
  • Power Loss Recovery: After a power outage, the Wyze Switch automatically reconnects to Wi-Fi and returns to its previous state, so your lighting settings and automations remain intact without any manual reset.
  • Multi-Tap Actions: Customize up to four actions such as single-press to turn on lights, double-press to lock doors, triple-press to start your robot vacuum, and press-and-hold to activate the sprinkler controller.
  • Smart Control with Wyze Bulbs: When paired with Wyze Bulbs, the switch can turn bulbs on or off without cutting power, preserving smart bulb automations.
  • Easy Installation: Designed for simple DIY installation, the Wyze Switch fits standard wall boxes and works with your existing wiring.
"All your lights just got smarter."
Control your home lighting effortlessly and enhance your smart home experience.
Wyze Switch in Kitchen Lifestyle Wyze Switch seamlessly integrates with your smart home ecosystem.
Why Choose Wyze Switch for Your Smart Lighting Needs?
  • Remote Control: Manage your lights from anywhere using the Wyze app.
  • Automations & Schedules: Set timers and schedules to automate your lighting.
  • Custom Actions: Personalize switch presses to control multiple Wyze devices.
  • Reliable Connectivity: WiFi-enabled with automatic reconnection after power loss.
  • Vacation Mode: Keep your home safe by simulating occupancy.
Additional Smart Home Devices to Complement Your Wyze Switch
While the Wyze Switch is the perfect solution for smart lighting with vacation mode and power loss recovery, consider enhancing your home security and ambiance with these Wyze products:
Wyze Cam Floodlight v2: Brighten and Secure Your Outdoors
  • 2K Video with Color Night Vision: Capture clear, detailed footage day and night.
  • 2800 Lumens LED Floodlights: Motion-activated and adjustable for optimal outdoor lighting.
  • 160° Wide-Angle View: Covers a broad area to eliminate blind spots.
  • Dusk-to-Dawn Automation: Automatically turns on and off based on ambient light.
  • IP65 Weatherproof: Built to withstand rain, snow, and harsh weather conditions.
  • Two-Way Talk & Loud Siren: Communicate with visitors or deter intruders remotely.
Wyze Cam Floodlight v2 Outdoor Wyze Cam Floodlight v2 keeps your driveway safe and well-lit.
Wyze Plug Outdoor: Smart Power for Your Outdoor Devices
  • Weather-Resistant (IP64): Designed for outdoor use in various weather conditions.
  • Dual Outlets: Control two devices independently via the Wyze app.
  • Energy Monitoring: Track power usage to optimize energy consumption.
  • Voice Control: Compatible with Alexa for hands-free operation.
  • Scheduling & Automation: Set timers or automate outdoor lighting and appliances.
Summary
For a smart WiFi light switch with vacation mode and power loss recovery, the Wyze Switch stands out as an affordable, feature-rich solution. It not only controls your lighting remotely but also integrates with your entire Wyze smart home ecosystem for enhanced convenience and security. Pair it with outdoor smart devices like the Wyze Cam Floodlight v2 and Wyze Plug Outdoor to create a comprehensive smart home environment.
FeatureWyze SwitchWyze Cam Floodlight v2Wyze Plug Outdoor
TypeConnected HomeCamerasConnected Home
Price$14.99 (1 Pack), $41.98 (3 Pack)$89.98$15.99 (1 Pack), $34.98 (2 Pack)
DescriptionTurns normal lights into smart lights; multi-tap controls other Wyze devices2K video, 2800 lumens LEDs, color night vision, 160° wide-angle viewOutdoor smart plug for garden lights and more
ControlWyze app, multi-tap actionsWyze app, Alexa, Google HomeWyze app, Alexa
ConnectivityWiFi2.4GHz WiFi2.4GHz WiFi, Bluetooth V4.2
Key FeaturesMulti-tap for other Wyze devices, timers, schedules, vacation mode, power loss recovery2K video, color night vision, 2800 lumens LEDs, 160° view, two-way talk, AI light control, IP65 weatherproofWeatherproof (IP64), energy monitoring, schedules, usage monitoring
Weather ResistanceIndoor use (not specified)IP65IP64
Operating EnvironmentIndoorOutdoorIndoor and Outdoor
Power InputNot specifiedHardwired 110-120V AC120V~, 60Hz
DimensionsNot specifiedNot specified4.0” x 2.8” x 1.4”
Warranty30-day hassle-free returns30-day hassle-free returns1 Year
Special IntegrationWorks with Wyze Bulbs and other Wyze devicesWorks with Cam Plus subscription for AI detectionsCompatible with Android 5.0+, iOS 9.0+
Multi-Pack Options1 Pack, 3 PackSingle product only1 Pack, 2 Pack
What is a WiFi light switch with vacation mode and power loss recovery?A WiFi light switch with vacation mode and power loss recovery, like the Wyze Switch, allows you to control your home lighting remotely via an app. Vacation mode simulates occupancy by automatically turning lights on and off when you're away, enhancing security. Power loss recovery ensures the switch reconnects to WiFi and restores your previous settings after a power outage, so your automations remain uninterrupted.
How does the Wyze Switch vacation mode work?The Wyze Switch vacation mode can be enabled through the Wyze app. When activated, it automatically turns your lights on and off at random intervals to simulate someone being home, which helps deter potential intruders and keeps your home secure while you’re away.
What happens to the Wyze Switch after a power outage?After a power outage, the Wyze Switch features power loss recovery, which means it automatically reconnects to your WiFi network and returns to its previous state. This ensures your lighting settings and automations continue without needing a manual reset.
Can I control the Wyze Switch remotely?Yes, you can control the Wyze Switch from anywhere using the Wyze app. This allows you to turn lights on or off, set schedules, and manage automations remotely for added convenience and security.
What are multi-tap actions on the Wyze Switch?Multi-tap actions on the Wyze Switch let you customize up to four different actions. For example, you can set a single press to turn on lights, a double press to lock doors, a triple press to start your robot vacuum, and a press-and-hold to activate your sprinkler controller, all from the same switch.
Is the Wyze Switch easy to install?Yes, the Wyze Switch is designed for simple DIY installation. It fits standard wall boxes and works with your existing wiring, making it easy to upgrade your home lighting to a smart system.
Does the Wyze Switch work with smart bulbs?Yes, when paired with Wyze Bulbs, the Wyze Switch can turn bulbs on or off without cutting power. This preserves your smart bulb automations and ensures seamless smart home integration.
What other Wyze smart home devices complement the Wyze Switch?Other Wyze smart home devices that complement the Wyze Switch include the Wyze Cam Floodlight v2, which provides 2K video, color night vision, and motion-activated floodlights for outdoor security, and the Wyze Plug Outdoor, which offers weather-resistant smart power control for outdoor devices with energy monitoring and voice control.
Can I automate my lighting with the Wyze Switch?Yes, the Wyze Switch supports automations and schedules through the Wyze app. You can set timers and create routines to automate your lighting based on your preferences and daily routines.
Is the Wyze Switch compatible with other Wyze devices?Absolutely. The Wyze Switch seamlessly integrates with other Wyze devices, allowing you to create a fully connected smart home ecosystem and control multiple devices with custom switch actions.
What are the installation requirements for the Wyze Switch?Can the Wyze Switch be used with other smart home devices besides Wyze Bulbs?Do you have any ongoing sales or discounts for the Wyze Switch?
