Discover the Wyze Cordless Vacuum S: Powerful Cleaning with Versatile Attachments
If you're searching for a
cordless vacuum with versatile attachments for upholstery, the
Wyze Cordless Vacuum S stands out as an exceptional choice. Designed to combine industrial-level suction power with lightweight convenience, this vacuum is perfect for tackling everything from pet hair on sofas to dust in hard-to-reach corners.
Wyze Cordless Vacuum S: Lightweight Yet Mighty
The Wyze Cordless Vacuum S delivers an impressive
20,000 Pa suction power thanks to its dual-motor design—one motor in the main unit and another in the brush head. This ensures deep cleaning on all surfaces, including upholstery, carpets, and hard floors.
- Weight: Only 2.8 pounds, making it as light as a fluffy corgi puppy, so you can clean effortlessly without arm fatigue.
- Battery Life: Up to 40 minutes of fade-free power with an interchangeable lithium-ion battery.
- Cleaning Modes: Choose from Eco (6,000 Pa), Medium (9,000 Pa), and Turbo (20,000 Pa) suction speeds to suit different surfaces.
- LED Lights: Six bright LED lights on the brush head illuminate dust and debris hidden under furniture or in dark corners.
- Filtration: A 3-stage filtration system including a HEPA filter captures 95% of particles as small as 0.3 microns, perfect for allergy sufferers.
"Finally! A vacuum that is free and independent and no longer reliant on its parents for financial and emotional support." — Wyze
Lightweight and pet-friendly cleaning for upholstery and sofas
Versatile Attachments for Upholstery and More
To maximize your cleaning experience, the Wyze Cordless Vacuum S offers a range of specialized accessories designed to enhance its versatility, especially for upholstery and delicate surfaces.
Mini Motorized Brush Head
- Purpose: Ideal for car seats, sofas, and other upholstery where precision cleaning is needed.
- Size: Compact dimensions (6 x 5.5 x 5 inches) allow it to reach tight spaces and remove embedded pet hair and dust.
- Compatibility: Exclusively designed for the Wyze Cordless Vacuum S.
This attachment makes cleaning fabric surfaces effortless, ensuring your furniture stays fresh and hair-free.
Foldable Vacuum Tube
- Function: Bends to reach awkward angles and under furniture without straining your wrist or back.
- Compatibility: Made specifically for Wyze Cordless Vacuum models.
This accessory enhances maneuverability, making it easier to clean upholstery on couches, chairs, and even car interiors.
HEPA Filter Replacement
- Maintenance: Regular replacement keeps your vacuum performing at peak efficiency and maintains air quality by trapping fine dust and allergens.
- Pack: Available in convenient 2-packs for ongoing use.
Extend Your Cleaning Time with Extra Battery Pack
For larger homes or extended cleaning sessions, the
Wyze Cordless Vacuum S Battery Pack is a perfect companion. It provides additional power so you can clean without interruption.
- Designed for: Wyze Cordless Vacuum S only.
- Benefit: Swap batteries easily to double your cleaning time.
Why Choose Wyze Cordless Vacuum S for Upholstery Cleaning?
- Powerful suction and dual motors ensure deep cleaning of fabric surfaces and pet hair removal.
- Lightweight design makes it easy to handle upholstery without strain.
- Specialized mini motorized brush targets sofas, car seats, and delicate fabrics.
- LED lights reveal hidden dust under furniture and cushions.
- Long-lasting battery and optional extra battery pack keep you cleaning longer.
- HEPA filtration system improves indoor air quality by trapping allergens.
Effortless cleaning on hardwood floors and upholstery alike
What’s Included with Your Wyze Cordless Vacuum S?
- Wyze Cordless Vacuum S main unit with dual motors
- Interchangeable lithium-ion battery
- Brush head with LED lights
- Mini motorized brush head (sold separately)
- Foldable vacuum tube (sold separately)
- HEPA filter (replaceable accessory)
- Charger and user manual
Experience the freedom of cordless cleaning with the Wyze Cordless Vacuum S — powerful, lightweight, and equipped with versatile attachments to keep your upholstery and home spotless.
What makes the Wyze Cordless Vacuum S ideal for upholstery cleaning?
The Wyze Cordless Vacuum S is perfect for upholstery cleaning due to its powerful 20,000 Pa suction, lightweight 2.8-pound design, and specialized mini motorized brush head. This attachment is designed to remove embedded pet hair and dust from sofas, car seats, and other fabric surfaces, ensuring a deep and thorough clean.What attachments are available for the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S offers several versatile attachments, including a mini motorized brush head for upholstery and car seats, a foldable vacuum tube for reaching awkward angles and under furniture, and a replaceable HEPA filter for improved air quality. These accessories enhance the vacuum’s ability to clean various surfaces and tight spaces.How powerful is the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S delivers up to 20,000 Pa of suction power, thanks to its dual-motor design—one in the main unit and another in the brush head. This ensures deep cleaning on upholstery, carpets, and hard floors.How long does the battery last on the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S provides up to 40 minutes of fade-free cleaning power with its interchangeable lithium-ion battery. For extended cleaning sessions, you can purchase an extra battery pack to double your cleaning time.Does the Wyze Cordless Vacuum S have a HEPA filter?
Yes, the Wyze Cordless Vacuum S features a 3-stage filtration system that includes a HEPA filter. This filter captures 95% of particles as small as 0.3 microns, making it ideal for allergy sufferers and improving indoor air quality.Are the mini motorized brush head and foldable vacuum tube included with the Wyze Cordless Vacuum S?
The mini motorized brush head and foldable vacuum tube are sold separately as specialized accessories for the Wyze Cordless Vacuum S. These attachments are designed to enhance cleaning performance, especially on upholstery and in hard-to-reach areas.What surfaces can the Wyze Cordless Vacuum S clean?
The Wyze Cordless Vacuum S is designed to clean a variety of surfaces, including upholstery, carpets, hard floors, sofas, car seats, and delicate fabrics. Its versatile attachments and powerful suction make it suitable for all-around home cleaning.How does the LED lighting on the Wyze Cordless Vacuum S help with cleaning?
The Wyze Cordless Vacuum S features six bright LED lights on the brush head, which illuminate dust and debris hidden under furniture or in dark corners. This ensures you don’t miss any spots while cleaning.What is included in the box with the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S package includes the main vacuum unit with dual motors, an interchangeable lithium-ion battery, a brush head with LED lights, a replaceable HEPA filter, a charger, and a user manual. The mini motorized brush head and foldable vacuum tube are available separately.How do I maintain the Wyze Cordless Vacuum S for optimal performance?
To keep your Wyze Cordless Vacuum S performing at its best, regularly replace the HEPA filter and empty the dustbin after each use. Replacement HEPA filters are available in convenient 2-packs for ongoing maintenance.
