Wyze Battery Cam Pro: Motion-Activated, Wireless Delivery Camera
Motion Activated Battery Powered Cameras for Package Delivery Recording
When it comes to securing your home and monitoring package deliveries, having a reliable, motion-activated, battery-powered camera is essential. The Wyze Battery Cam Pro series offers cutting-edge features designed to capture every moment with clarity and convenience, all without the hassle of wires or hubs. Whether you want to keep an eye on your front porch or monitor deliveries in real-time, Wyze provides versatile solutions tailored to your needs.
Wyze Battery Cam Pro: Advanced Wireless Security Camera
Crisp 2.5K HDR Video Quality
The Wyze Battery Cam Pro delivers stunning 2.5K HDR video resolution (2560 x 1440), ensuring every package delivery is recorded in sharp detail. Its CMOS-Starlight sensor combined with an F1.6 lens captures vibrant, clear footage day or night.
Motion Detection with Radar + PIR Sensors
Equipped with both radar and PIR motion detection, this camera accurately senses movement, reducing false alerts. This makes it perfect for monitoring your porch for package arrivals or unexpected visitors.
Wire-Free and Battery Powered
Powered by a removable, rechargeable 6200mAh battery, the camera offers up to 6 months of battery life on a single charge. The battery is easy to swap out and charges fully in about 9 hours, giving you long-lasting, hassle-free security.
Integrated Spotlight and Siren
The built-in spotlight and 100 dB siren provide active deterrence against package theft or suspicious activity. The spotlight also enhances color night vision with two white LEDs, making nighttime footage vivid and clear.
Weatherproof and Durable
With an IP65 weather resistance rating, the Wyze Battery Cam Pro withstands rain, snow, and dust, making it ideal for outdoor use in various climates. It operates reliably between -20°C to 50°C (-4°F to 122°F).
Smart Home Integration
Seamlessly connect with Alexa, Google Assistant, and IFTTT for voice control and automation, enhancing your smart home ecosystem.
Additional Features
  • Two-way audio with built-in microphone and speaker for real-time communication.
  • Supports local storage up to 256GB microSD cards.
  • Dual-band WiFi (2.4 GHz & 5 GHz) for stable connectivity.
  • Compact size (2.5 x 1.8 x 3.5 inches) and lightweight (0.94 lbs) with included wall mount.
Wyze Battery Cam Pro + Solar Panel: Extended Power for Continuous Monitoring
All Features of Wyze Battery Cam Pro
This bundle includes the same advanced Wyze Battery Cam Pro camera with 2.5K HDR video, radar + PIR motion detection, integrated spotlight, siren, and weatherproof design.
Solar Panel for Extended Battery Life
The included solar panel harnesses sunlight to keep your camera charged longer, reducing the need for manual battery swaps. It features:
  • IP65 weather resistance for outdoor durability.
  • Easy 360° mounting for optimal sun exposure.
  • A 13-foot power cable for flexible installation.
  • Compatibility with Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2.
This setup is perfect for users who want continuous, worry-free monitoring of their package deliveries without frequent recharging.
Wyze Battery Cam Solar Panel Accessory
For those who already own the Wyze Battery Cam Pro, the Wyze Battery Cam Solar Panel is an excellent accessory to extend your camera’s battery life. It is designed to be weather-resistant and mountable anywhere outdoors, providing a sustainable power source.
Key Solar Panel Specs:
  • 2.5W, 5VDC solar power rating.
  • IP65 waterproof rating.
  • Includes wall mount, micro USB and USB-C adapter cables, screws, and anchors.
  • Compatible with Wyze Battery Cam Pro and Wyze Cam Outdoor models.
Why Choose Wyze Battery Cam Pro for Package Delivery?
The combination of high-resolution video, advanced motion detection, long battery life, and weatherproof design makes the Wyze Battery Cam Pro an ideal choice for monitoring your packages. The option to add a solar panel ensures your camera stays powered even in busy seasons, providing peace of mind around the clock.
Summary
ProductKey FeaturesPrice Range (USD)
Wyze Battery Cam Pro2.5K HDR, Radar + PIR, Spotlight, Siren, IP65$89.98 - $219.98
Wyze Battery Cam Pro + Solar PanelAll Cam Pro features + Solar Panel included$109.98
Wyze Battery Cam Solar PanelSolar accessory for extended battery life$24.99
Home Security Camera Monitoring Package Delivery Capture every delivery with Wyze Battery Cam Pro’s motion-activated recording. Solar Panel Powering Outdoor Camera Extend your camera’s battery life with the Wyze Battery Cam Solar Panel.
Invest in the Wyze Battery Cam Pro and its solar-powered options to ensure your packages are always protected with clear, reliable video surveillance — no wires, no hassle, just smart security.
FeatureWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelWyze Battery Cam Solar Panel
Product TypeCameraCamera + Solar Panel BundleAccessory (Solar Panel)
Video Resolution2.5K HDR2.5K HDRN/A
Power SourceRemovable, Rechargeable Battery PacksRemovable, Rechargeable Battery + Solar PanelSolar Panel (extends battery life)
WirelessWire-Free, No Hub RequiredWire-Free, No Hub RequiredN/A
Motion DetectionRadar + PIR Motion DetectionRadar + PIR Motion DetectionN/A
Integrated Spotlight & SirenYesYesN/A
Weatherproof RatingIP65IP65IP65
WiFi Support2.4 & 5 GHz2.4 & 5 GHzN/A
Local RecordingYes (with MicroSD card)Yes (with MicroSD card)N/A
Battery LifeUp to 6 months per charge (6200mAh battery)Extended with Solar PanelExtends battery life by converting solar power
Battery PackRemovable, Rechargeable (6200mAh)Removable, Rechargeable (6200mAh)N/A
Solar Panel IncludedNoYes (includes Wyze Solar Panel)Yes (solar panel only)
Solar Panel Power RatingN/A2.5W, 5VDC2.5W, 5VDC
Solar Panel Cable LengthN/A13 ft (4m)13 ft (4m)
Mounting OptionsFlexible mounting, optional ceiling mountFlexible mounting, optional ceiling mount360° mount, weather resistant
Price (USD)$89.98 (1 Pack)$109.98$24.99
Color OptionsBlack, WhiteBlack, WhiteWhite frame with black solar cells
Additional AccessoriesBattery Charging Dock, Removable Battery PackBattery Charging Dock, Removable Battery PackWall mount, USB-C adapter cable, screws, anchors
SetupBluetoothⓇ Setup, no QR code scanningBluetoothⓇ Setup, no QR code scanningN/A
What is the Wyze Battery Cam Pro and how does it help with package delivery security?The Wyze Battery Cam Pro is a motion-activated, battery-powered security camera designed to monitor your home and record package deliveries. It features 2.5K HDR video quality, advanced radar and PIR motion detection, and a weatherproof design, making it ideal for capturing clear footage of your front porch and deterring package theft.
How long does the Wyze Battery Cam Pro battery last on a single charge?The Wyze Battery Cam Pro is powered by a removable, rechargeable 6200mAh battery that can last up to 6 months on a single charge, depending on usage and environmental conditions.
Does the Wyze Battery Cam Pro require any wires or a hub for installation?No, the Wyze Battery Cam Pro is completely wire-free and does not require a hub. It operates on battery power and connects directly to your WiFi network for easy installation and flexible placement.
What kind of video quality does the Wyze Battery Cam Pro offer?The Wyze Battery Cam Pro delivers crisp 2.5K HDR video resolution (2560 x 1440), ensuring sharp and detailed recordings of package deliveries both day and night.
How does the Wyze Battery Cam Pro detect motion?The camera uses a combination of radar and PIR (Passive Infrared) sensors to accurately detect motion, reducing false alerts and ensuring reliable monitoring of your porch or entryway.
Is the Wyze Battery Cam Pro weatherproof for outdoor use?Yes, the Wyze Battery Cam Pro has an IP65 weather resistance rating, making it suitable for outdoor use in rain, snow, and dust, and it operates reliably in temperatures from -20°C to 50°C (-4°F to 122°F).
Can I use the Wyze Battery Cam Pro with smart home devices?Yes, the Wyze Battery Cam Pro integrates seamlessly with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.
What additional security features does the Wyze Battery Cam Pro offer?The camera includes a built-in spotlight and a 100 dB siren for active deterrence against package theft or suspicious activity. It also features two-way audio for real-time communication.
Does the Wyze Battery Cam Pro support local video storage?Yes, the Wyze Battery Cam Pro supports local storage with microSD cards up to 256GB, allowing you to record and review footage without a subscription.
What is included in the Wyze Battery Cam Pro + Solar Panel bundle?The Wyze Battery Cam Pro + Solar Panel bundle includes the advanced Wyze Battery Cam Pro camera and a weather-resistant solar panel. The solar panel keeps your camera charged longer, reducing the need for manual battery swaps and ensuring continuous monitoring.
Is the Wyze Battery Cam Solar Panel compatible with other Wyze cameras?Yes, the Wyze Battery Cam Solar Panel is compatible with the Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2 models, providing a sustainable power source for extended battery life.
How easy is it to install the Wyze Battery Cam Solar Panel?The Wyze Battery Cam Solar Panel is easy to install with its included wall mount and 13-foot power cable, allowing for flexible placement and optimal sun exposure. It is also IP65 weather-resistant for outdoor durability.
What are the key benefits of using a solar panel with the Wyze Battery Cam Pro?Using a solar panel with the Wyze Battery Cam Pro extends the camera’s battery life by harnessing sunlight, reducing the need for frequent recharging and ensuring continuous, worry-free monitoring of your package deliveries.
What is the price range for Wyze Battery Cam Pro and its accessories?The Wyze Battery Cam Pro is priced between $89.98 and $219.98, the Wyze Battery Cam Pro + Solar Panel bundle is $109.98, and the Wyze Battery Cam Solar Panel accessory is $24.99.
What are the key features of the Wyze Battery Cam Pro?How does the motion detection work on the Wyze Battery Cam Pro?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Battery Cam Pro?
