Wyze Battery Cam Pro: Record Cars Entering Your Driveway
Wyze Battery Cam Pro: The Ultimate Driveway Security Camera
If you're looking for a reliable camera that records video clips whenever a car pulls into your driveway, the Wyze Battery Cam Pro is an excellent choice. This smart camera offers high-resolution video, advanced motion detection, and weatherproof durability — all wire-free and easy to install.
Stunning 2.5K HDR Video Quality
The Wyze Battery Cam Pro captures crystal-clear video at 2560 x 1440 resolution, providing sharp and detailed footage of any vehicle entering your driveway. Its CMOS-Starlight sensor combined with an F1.6 lens ensures excellent image quality even in low light conditions.
Advanced Motion Detection with Radar + PIR
Equipped with both radar and PIR motion sensors, this camera intelligently detects moving objects like cars, reducing false alerts from wind or small animals. This means you get accurate notifications and video clips exactly when a car pulls in.
Wire-Free and Long Battery Life
Powered by removable, rechargeable 6200mAh battery packs, the Wyze Battery Cam Pro can last up to 6 months on a single charge. The camera is completely wire-free, allowing flexible placement anywhere around your driveway without the hassle of cables.
Weatherproof and Durable
With an IP65 rating, the camera withstands rain, snow, and dust, making it perfect for outdoor driveway monitoring year-round. It operates reliably in temperatures from -20°C to 50°C (-4°F to 122°F).
Smart Features and Integrations
  • Integrated spotlight and 100 dB siren for deterrence
  • Two-way audio with built-in microphone and speaker
  • Compatible with Alexa, Google Assistant, and IFTTT
  • Supports both 2.4 GHz and 5 GHz WiFi for stable connectivity
  • Local storage up to 256 GB microSD card supported
Wyze Battery Cam Pro + Solar Panel: Continuous Power for Driveway Surveillance
For those who want uninterrupted driveway monitoring without worrying about battery life, the Wyze Battery Cam Pro + Solar Panel bundle is the perfect solution.
Solar-Powered Convenience
This bundle includes the same powerful Wyze Battery Cam Pro camera paired with a solar panel that continuously charges the camera’s battery during daylight hours. This means less frequent manual recharging and more peace of mind.
All the Features of the Battery Cam Pro
  • 2.5K HDR video resolution with color night vision
  • Radar + PIR motion detection for precise alerts
  • IP65 weatherproof design for all-season use
  • Two-way audio and integrated spotlight & siren
  • Supports local and cloud storage options
Easy Installation and Setup
The solar panel mounts easily near the camera and connects via USB-C, providing a seamless power source. This setup is ideal for driveway locations with good sun exposure, ensuring your camera stays powered and ready to record every vehicle arrival.
Wyze Bird Feeder Wireless Camera Bundle: Multi-Purpose Outdoor Monitoring
If you want to combine driveway security with nature watching, the Wyze Bird Feeder Wireless Camera Bundle offers a unique solution.
What’s Included?
  • Wyze Battery Cam Pro (same advanced camera for driveway monitoring)
  • Wyze Bird Feeder with vibrant colors to attract birds
  • Wyze Solar Panel for continuous camera power
Dual Functionality
This bundle lets you monitor your driveway for cars while also enjoying live video of feathered visitors at your bird feeder. It’s a great way to keep your property secure and add a touch of nature observation.
Weather-Resistant and Easy to Use
All components are IP65 weatherproof, designed for outdoor use in various climates. The camera’s 2.5K video and radar motion detection ensure you never miss a car pulling in or a bird landing.
Why Choose Wyze Battery Cam Pro for Driveway Video Recording?
The Wyze Battery Cam Pro stands out as a top choice for driveway security cameras because it combines high-resolution video, smart motion detection, and flexible power options in a compact, weatherproof design.
  • Wire-free installation means no complicated wiring or hubs
  • Long battery life with optional solar charging for continuous operation
  • Advanced radar + PIR sensors reduce false alerts and capture relevant events
  • Integrated spotlight and siren enhance security by deterring unwanted visitors
  • Compatible with popular smart home platforms for seamless integration
Product Specifications at a Glance
FeatureWyze Battery Cam Pro / Solar Bundle
Video Resolution2560 x 1440 (2.5K HDR)
Motion DetectionRadar + PIR
Battery Capacity6200mAh, up to 6 months battery life
Power SourceRechargeable battery / Solar panel (optional)
Weather ResistanceIP65
Field of View134° diagonal, 108° horizontal
Night Vision2 IR LEDs + 2 White LEDs (color night vision)
AudioTwo-way audio with built-in mic and speaker
Siren100 dB
WiFi2.4 GHz & 5 GHz dual band
Smart Home IntegrationAlexa, Google Assistant, IFTTT
StorageLocal microSD (up to 256 GB), Cloud (Cam Plus)
Driveway Security Camera in Use Capture every car pulling into your driveway with Wyze Battery Cam Pro
Accessories to Enhance Your Wyze Battery Cam Pro Experience
  • Wyze Removable Battery Pack: Keep a spare 6200mAh rechargeable battery on hand for quick swaps and extended monitoring without downtime.
  • Wyze Battery Charging Dock: Charge two batteries simultaneously to ensure your cameras are always powered and ready.
Conclusion
For anyone searching for a camera that records video clips whenever a car pulls into the driveway, the Wyze Battery Cam Pro and its solar-powered variant offer unmatched convenience, clarity, and smart features. Whether you want a standalone camera or a bundle with solar charging or birdwatching capabilities, Wyze provides versatile options to keep your driveway secure and monitored effortlessly.
FeatureWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelBird Feeder Wireless Camera Bundle
Included ItemsWyze Battery Cam ProWyze Battery Cam Pro, Wyze Solar PanelWyze Battery Cam Pro, Wyze Solar Panel, Wyze Bird Feeder
Video Resolution2.5K HDR (2560 x 1440)2.5K HDR (2560 x 1440)2.5K HDR (2560 x 1440)
Power SourceRemovable, rechargeable battery packsBattery + Solar Panel for continuous powerBattery + Solar Panel for continuous power
Solar Panel IncludedNoYesYes
Motion DetectionRadar + PIR Motion DetectionRadar + PIR Motion DetectionRadar + PIR Motion Detection
Integrated Spotlight & SirenYes (150 lumens LED spotlight)Yes (150 lumens LED spotlight)Yes (150 lumens LED spotlight)
Weatherproof RatingIP65IP65IP65
WiFi Support2.4 & 5 GHz2.4 & 5 GHz2.4 & 5 GHz
Local RecordingYes (microSD card, not included)Yes (microSD card, not included)Yes (microSD card, not included)
Bird Feeder IncludedNoNoYes (Blue or Brown, 1 Liter seed capacity, polycarbonate)
Bird Feeder FeaturesN/AN/AWeather-resistant, macro lens adapter, live view in app
Camera Colors AvailableBlack, WhiteBlack, WhiteBlack, White (camera); Blue, Brown (feeder)
PriceFrom $89.98 (1 pack)$109.98 (bundle)From $139.98
Additional FeaturesWire-free, no hub, removable battery packsContinuous power via solar panelBirdwatching bundle with feeder and solar panel
Dimensions (Camera)2.5" x 1.8" x 3.5"2.5" x 1.8" x 3.5"Camera: 2.5" x 1.8" x 3.5"; Feeder: 7.48" x 10.12" x 8.58"
Weight (Camera)0.94 lb (approx.)0.94 lb (approx.)Camera: 0.94 lb; Feeder: 2.5 lb
What makes the Wyze Battery Cam Pro a good driveway security camera?The Wyze Battery Cam Pro is ideal for driveway security because it offers 2.5K HDR video resolution, advanced radar and PIR motion detection to accurately capture vehicles, wire-free installation, long battery life, and weatherproof durability. Its smart features, such as two-way audio, integrated spotlight, and siren, further enhance driveway monitoring and security.
How does the Wyze Battery Cam Pro detect cars in my driveway?The Wyze Battery Cam Pro uses a combination of radar and PIR (Passive Infrared) motion sensors to intelligently detect moving objects like cars. This dual-sensor system reduces false alerts from wind or small animals, ensuring you receive accurate notifications and video clips when a vehicle enters your driveway.
What is the video quality of the Wyze Battery Cam Pro?The Wyze Battery Cam Pro records in stunning 2.5K HDR (2560 x 1440) resolution, providing sharp, detailed footage. Its CMOS-Starlight sensor and F1.6 lens ensure excellent image quality, even in low-light conditions, making it perfect for capturing clear video of your driveway day or night.
Is the Wyze Battery Cam Pro weatherproof?Yes, the Wyze Battery Cam Pro is IP65 weatherproof, meaning it can withstand rain, snow, and dust. It operates reliably in temperatures ranging from -20°C to 50°C (-4°F to 122°F), making it suitable for year-round outdoor driveway monitoring.
How long does the Wyze Battery Cam Pro battery last?The Wyze Battery Cam Pro is powered by a removable, rechargeable 6200mAh battery pack that can last up to 6 months on a single charge, depending on usage and environmental conditions.
Can I use a solar panel with the Wyze Battery Cam Pro?Yes, the Wyze Battery Cam Pro is available in a bundle with a Wyze Solar Panel. The solar panel continuously charges the camera’s battery during daylight hours, providing uninterrupted power and reducing the need for manual recharging.
Does the Wyze Battery Cam Pro support local storage?Yes, the Wyze Battery Cam Pro supports local storage with a microSD card of up to 256 GB. It also offers cloud storage options through Wyze Cam Plus for added flexibility.
Is the Wyze Battery Cam Pro compatible with smart home systems?The Wyze Battery Cam Pro is compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless integration with your smart home devices and routines.
What is included in the Wyze Bird Feeder Wireless Camera Bundle?The Wyze Bird Feeder Wireless Camera Bundle includes the Wyze Battery Cam Pro, a vibrant Wyze Bird Feeder to attract birds, and a Wyze Solar Panel for continuous camera power. This bundle allows you to monitor your driveway and enjoy live video of birds at the feeder.
How easy is it to install the Wyze Battery Cam Pro and its accessories?The Wyze Battery Cam Pro is completely wire-free, making installation simple and flexible. The solar panel mounts easily near the camera and connects via USB-C. Accessories like the removable battery pack and charging dock are designed for quick swaps and easy charging.
What smart features does the Wyze Battery Cam Pro offer?The Wyze Battery Cam Pro features an integrated spotlight, a 100 dB siren for deterrence, two-way audio with a built-in microphone and speaker, dual-band WiFi (2.4 GHz & 5 GHz), and advanced motion detection. These features provide comprehensive security and convenience for driveway monitoring.
Can the Wyze Battery Cam Pro be used for both security and birdwatching?Yes, with the Wyze Bird Feeder Wireless Camera Bundle, you can use the Wyze Battery Cam Pro for both driveway security and birdwatching. The camera’s high-resolution video and motion detection ensure you capture both vehicles and feathered visitors.
What accessories are available for the Wyze Battery Cam Pro?Available accessories include the Wyze Removable Battery Pack for quick battery swaps and the Wyze Battery Charging Dock, which allows you to charge two batteries simultaneously, ensuring your camera is always powered and ready.
Can you tell me more about the solar panel option for the Wyze Battery Cam Pro?What are the installation requirements for the Wyze Battery Cam Pro?Do you have any ongoing sales or discounts for the Wyze Battery Cam Pro?
