Wyze Battery Cam Pro: Fast Motion Trigger Battery Camera
If you're searching for a battery camera with a fast motion trigger to capture quick movements, the Wyze Battery Cam Pro stands out as a top choice. Designed for wire-free convenience and high-quality video, this camera is perfect for catching fast-moving subjects with precision and clarity.
Key Features of Wyze Battery Cam Pro
  • 2.5K HDR Video Resolution: Capture crystal-clear footage at 2560 x 1440 resolution, ensuring every detail is sharp and vivid.
  • Radar + PIR Motion Detection: Advanced dual motion sensors detect movement quickly and accurately, triggering alerts and recordings instantly.
  • Wire-Free & No Hub Required: Completely wireless setup with removable, rechargeable 6200mAh battery packs that last up to 6 months on a single charge.
  • Integrated Spotlight & Siren: Built-in spotlight and 100 dB siren enhance security by deterring intruders and illuminating dark areas.
  • Weatherproof Design (IP65): Durable and reliable in all weather conditions, from rain to snow.
  • Wide Field of View: 134° diagonal field of view covers broad areas to catch fast movements from multiple angles.
  • Two-Way Audio: Communicate through the camera with a built-in speaker and MEMS digital microphone.
  • Connectivity: Supports both 2.4 GHz and 5 GHz WiFi for stable, fast connections.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home control.
Battery and Power
The Wyze Battery Cam Pro uses removable, rechargeable battery packs with a capacity of 6200mAh, providing up to 6 months of battery life. Charging takes approximately 9 hours, and the camera supports local storage with microSD cards up to 256GB.
Wyze Battery Cam Pro + Solar Panel: Extended Power with Fast Motion Capture
For those who want the convenience of continuous power without frequent recharging, the Wyze Battery Cam Pro + Solar Panel bundle offers the same advanced features as the standard Battery Cam Pro, with the added benefit of solar charging.
Highlights of the Solar Panel Bundle
  • Solar-Powered Battery Cam Pro: Keep your camera running longer with the included solar panel that charges the removable battery pack using sunlight.
  • Same 2.5K HDR Video & Radar + PIR Motion Detection: Enjoy the same high-quality video and fast motion trigger technology.
  • Color Night Vision: Enhanced night vision with white LEDs for color footage even in low light.
  • Weatherproof & Wire-Free: Perfect for outdoor use with IP65 rating and no need for wiring or hubs.
  • Local and Cloud Storage Options: Record locally on microSD or use Cam Plus cloud recording for added convenience.
  • Smart Integrations: Works with Alexa, Google Assistant, and IFTTT.
This bundle is ideal for outdoor areas with good sunlight exposure, ensuring your camera stays powered and ready to capture fast movements without interruption.
Wyze Bird Feeder Wireless Camera Bundle: Capture Quick Movements in Nature
For birdwatchers and nature enthusiasts, the Wyze Bird Feeder Wireless Camera Bundle combines the Wyze Battery Cam Pro with a specialized bird feeder and solar panel, making it easy to catch every quick flutter and visit.
Bundle Features
  • Wyze Battery Cam Pro Included: Benefit from the same fast motion trigger and 2.5K HDR video quality.
  • Wyze Bird Feeder: Designed with vibrant colors to attract a variety of birds, made from durable polycarbonate.
  • Solar Panel for Continuous Power: Keeps the camera charged for extended outdoor use.
  • Weather-Resistant: IP65 rating ensures the bundle withstands outdoor elements.
  • Watch Live in the Wyze App: Stream and record live video of every bird visit with ease.
This bundle is perfect for capturing fast, unpredictable bird movements and enjoying nature from the comfort of your home.
Why Choose Wyze Battery Cameras for Fast Motion Capture?
"Wyze Battery Cam Pro cameras combine cutting-edge radar and PIR motion detection with high-resolution video to ensure you never miss a moment of fast action."
  • Fast and Accurate Motion Trigger: Radar technology detects movement faster than traditional cameras, ideal for capturing quick movements like running pets, fast vehicles, or wildlife.
  • Long Battery Life: Up to 6 months on a single charge means less hassle and more reliable monitoring.
  • Flexible Installation: Wire-free design and multiple mounting options make it easy to place the camera wherever you need it most.
  • Smart Home Compatibility: Integrate with your existing smart home ecosystem for voice control and automation.
Accessories to Enhance Your Wyze Battery Cam Pro Experience
Wyze Removable Battery Pack
  • Rechargeable 6200mAh battery pack designed specifically for the Battery Cam Pro.
  • Provides up to 6 months of power per charge.
  • Convenient USB-C charging port for fast and easy recharging.
Wyze Battery Charging Dock
  • Charge two Wyze Battery Cam Pro batteries simultaneously.
  • Compact and portable design.
  • Includes power adapter and USB-A to USB-C cable.
Capture Fast Movements with Confidence
The Wyze Battery Cam Pro and its related bundles and accessories offer a comprehensive solution for anyone needing a battery-powered camera with a fast motion trigger. Whether for home security, wildlife observation, or outdoor monitoring, these cameras deliver high-quality video, rapid motion detection, and flexible power options to keep you connected and protected.
Outdoor Security Camera in Use Experience fast motion detection with Wyze Battery Cam Pro in real-life settings. Solar Panel Charging Wyze Camera Keep your camera powered continuously with the Wyze Solar Panel. Bird Feeder with Wyze Camera Enjoy birdwatching and fast motion capture with the Wyze Bird Feeder Bundle.
FeatureWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelBird Feeder Wireless Camera BundleWyze Removable Battery PackWyze Battery Charging Dock
Product TypeCameraCamera + Solar PanelBundle (Bird Feeder + Battery Cam Pro + Solar Panel)Accessory (Battery Pack)Accessory (Charging Dock)
Video Resolution2.5K HDR (2560 x 1440)2.5K HDR (2560 x 1440)2.5K HDR (Wyze Battery Cam Pro)N/AN/A
Power SourceRemovable, Rechargeable Battery PacksBattery + Solar PanelBattery + Solar PanelRechargeable Battery Pack (6200mAh)Charges up to 2 batteries simultaneously
WirelessYes, Wire-Free, No Hub RequiredYes, Wire-Free, No Hub RequiredYes, Wire-Free BundleN/AN/A
Motion DetectionRadar + PIR Motion DetectionRadar + PIR Motion DetectionRadar + PIR Motion Detection (via Battery Cam Pro)N/AN/A
Integrated Spotlight & SirenYes (150 lumens LED spotlight)Yes (150 lumens LED spotlight)Yes (via Battery Cam Pro)N/AN/A
Weatherproof RatingIP65IP65IP65 (Bird Feeder, Battery Cam Pro, Solar Panel)Operates -4°F to 122°F, IP rating not specifiedOperates +50°F to +104°F, humidity <90%
WiFi SupportDual-band 2.4 & 5 GHzDual-band 2.4 & 5 GHzDual-band 2.4 & 5 GHz (Battery Cam Pro)N/AN/A
Local RecordingYes, microSD card (optional)Yes, microSD card (optional)Yes, microSD card (via Battery Cam Pro)N/AN/A
Battery LifeUp to 6 months per charge (with removable packs)Extended with Solar PanelExtended with Solar Panel6200mAh, lasts up to 6 monthsCharges two batteries simultaneously
Dimensions2.5" x 1.8" x 3.5"Same as Battery Cam ProBird Feeder: 7.48" x 10.12" x 8.58"2.9" x 1.6" x 0.9"Dock: 2.6" x 2" x 1"; Power Adapter: 1.65" x 1.57" x 0.9"
Weight0.94 lbSame as Battery Cam ProBird Feeder: 2.5 lb; Camera: 0.94 lb3.9 oz (110g)2.75 oz (78g)
Color OptionsBlack, WhiteBlack, WhiteWyze Battery Cam Pro: Black, White; Bird Feeder: Blue, BrownWhiteWhite
Price (USD)$89.98 (1 Pack)$109.98$139.98 (with Blue Bird Feeder)$22.99$17.99
Included ItemsCamera onlyCamera + Solar PanelBird Feeder, Battery Cam Pro, Solar PanelBattery Pack onlyCharging Dock, Adapter Cable, Power Adapter
Mounting OptionsWall, Ceiling (with Universal Mount)Wall, Ceiling (with Universal Mount)Wall, Ceiling (via Battery Cam Pro)N/AN/A
Additional FeaturesTwo-way audio, Bluetooth setup, Cam Plus supportSame as Battery Cam Pro + Solar continuous powerBirdwatching with live video, Macro Lens Adapter includedUSB-C charging portCharges two batteries simultaneously
What makes the Wyze Battery Cam Pro ideal for capturing fast motion?The Wyze Battery Cam Pro features advanced radar and PIR motion detection sensors that quickly and accurately detect movement, triggering instant alerts and recordings. Its 2.5K HDR video resolution ensures you capture every detail of fast-moving subjects with clarity.
How long does the Wyze Battery Cam Pro battery last on a single charge?The Wyze Battery Cam Pro uses a removable, rechargeable 6200mAh battery pack that can last up to 6 months on a single charge, depending on usage and environmental conditions.
Is the Wyze Battery Cam Pro completely wireless?Yes, the Wyze Battery Cam Pro is a wire-free security camera that does not require any wiring or a hub for installation. It operates on a rechargeable battery and connects via WiFi.
Can the Wyze Battery Cam Pro be used outdoors in all weather conditions?Absolutely. The Wyze Battery Cam Pro has an IP65 weatherproof rating, making it suitable for use in rain, snow, and other outdoor conditions.
Does the Wyze Battery Cam Pro support local storage?Yes, the Wyze Battery Cam Pro supports local storage with microSD cards up to 256GB, allowing you to record and store footage directly on the device.
What is included in the Wyze Battery Cam Pro + Solar Panel bundle?The Wyze Battery Cam Pro + Solar Panel bundle includes the Wyze Battery Cam Pro camera and a solar panel that charges the camera’s battery using sunlight, providing continuous power for extended outdoor use.
Does the Wyze Battery Cam Pro offer color night vision?Yes, the Wyze Battery Cam Pro offers enhanced color night vision with white LEDs, allowing you to capture color footage even in low-light conditions.
Is the Wyze Battery Cam Pro compatible with smart home systems?Yes, the Wyze Battery Cam Pro integrates seamlessly with Alexa, Google Assistant, and IFTTT, enabling voice control and smart home automation.
What is the Wyze Bird Feeder Wireless Camera Bundle?The Wyze Bird Feeder Wireless Camera Bundle combines the Wyze Battery Cam Pro, a vibrant and durable bird feeder, and a solar panel. This bundle is designed for birdwatchers to capture quick bird movements and enjoy live streaming through the Wyze app.
How do I recharge the Wyze Battery Cam Pro battery?You can recharge the Wyze Battery Cam Pro’s removable 6200mAh battery pack using the included USB-C charging port. Charging takes approximately 9 hours.
Are there accessories available for the Wyze Battery Cam Pro?Yes, accessories such as the Wyze Removable Battery Pack and Wyze Battery Charging Dock are available. The charging dock allows you to charge two batteries simultaneously for added convenience.
What field of view does the Wyze Battery Cam Pro offer?The Wyze Battery Cam Pro provides a wide 134° diagonal field of view, allowing you to monitor broad areas and capture fast movements from multiple angles.
Can I communicate through the Wyze Battery Cam Pro?Yes, the Wyze Battery Cam Pro features two-way audio with a built-in speaker and MEMS digital microphone, enabling you to listen and speak through the camera.
Does the Wyze Battery Cam Pro require a subscription for cloud storage?Cloud storage is available through the Wyze Cam Plus subscription, but you can also use local storage with a microSD card if you prefer not to use cloud services.
Can you tell me more about the solar panel bundle for the Wyze Battery Cam Pro?What are the benefits of using the Wyze Bird Feeder Wireless Camera Bundle?Do you have any ongoing sales or discounts for the Wyze Battery Cam Pro?
