Continuous Wyze Camera Video Feed Without AC Power: Solar & More
Maintain Continuous Video Feed for Wyze Security Cameras Without AC Power
When it comes to securing your home or property with Wyze security cameras, maintaining a continuous video feed without relying on AC power is essential—especially for outdoor or remote locations. The Wyze Battery Cam Solar Panel is the perfect accessory to extend your camera’s battery life by harnessing solar energy, ensuring your Wyze Battery Cam Pro or Wyze Cam Outdoor stays powered longer without frequent recharging.
Wyze Battery Cam Solar Panel: Power Your Cameras with the Sun
Extend Battery Life Effortlessly
The Wyze Battery Cam Solar Panel is designed specifically to keep your Wyze Battery Cam Pro and Wyze Cam Outdoor (v1 and v2) running longer by continuously charging the camera’s battery using solar power. This means fewer interruptions and less hassle bringing your camera indoors for recharging.
Weather-Resistant and Flexible Mounting
Built with an IP65 weather resistance rating, this solar panel is dustproof and waterproof, making it ideal for all weather conditions. Its 360° freestyle mount allows you to position the panel for maximum sun exposure anywhere around your home, from rooftops to garden walls.
Long-Range Power Cable for Ultimate Flexibility
The included 13-foot weatherproof power cable gives you the freedom to mount the solar panel in the best sunny spot while placing your camera exactly where you need it for optimal security coverage.
Record for longer and keep your Wyze cameras powered continuously without the need for AC power.
Wyze Cam v4 Outdoor Bundle: Wired Power with Advanced Features
If you prefer a wired solution for continuous power, the Wyze Cam v4 Outdoor Bundle offers a powerful security camera with 2.5K QHD resolution and enhanced color night vision. This camera supports 24/7 local recording and Wi-Fi 6 for seamless connectivity.
Key Features:
  • Enhanced Color Night Vision for clear images day and night
  • Motion-Activated Spotlight to deter intruders
  • Wi-Fi 6 Support for faster, more reliable connections
  • Compatibility with Alexa and Google Assistant for smart home integration
  • Wired Power Source ensures continuous operation without battery concerns
This bundle includes the Wyze Outdoor Power Adapter and a 128GB microSD card, making it a complete solution for uninterrupted outdoor surveillance.
Power Your Wyze Cameras Without Outlets: Lamp Socket v2 Bundles
For locations where AC outlets are limited, the Wyze Lamp Socket v2 Bundles provide an innovative way to power your Wyze cameras by using existing lamp sockets.
Pan v3 + Lamp Socket v2 Bundle
  • Powers the Wyze Cam Pan v3 without needing an outlet
  • Supports motion-activated lighting for added security
  • Easy installation with E26 socket compatibility
  • Suitable for damp locations (not fully weatherproof)
Cam v4 + Lamp Socket v2 Bundle
  • Powers Wyze Cam v4 cameras directly from lamp sockets
  • Features dusk-to-dawn scheduling and motion-activated lights
  • Linkable with multiple sockets for expanded coverage
  • Compact and durable polycarbonate design
These bundles are perfect for enhancing your outdoor lighting while powering your cameras continuously, eliminating the need for battery swaps or AC outlets.
Why Choose Solar or Lamp Socket Power Solutions for Wyze Cameras?
Maintaining a continuous video feed without AC power is crucial for reliable home security, especially in outdoor or off-grid locations.
  • Solar Panels provide a green, maintenance-free power source that keeps your battery cams running indefinitely.
  • Lamp Socket Adapters utilize existing lighting infrastructure to power cameras without additional wiring or outlets.
  • Both options ensure your Wyze cameras stay online, capturing every moment with no downtime.
Summary
For uninterrupted video surveillance with Wyze security cameras without relying on AC power, the Wyze Battery Cam Solar Panel is the top choice for wire-free, weatherproof solar charging. For wired continuous power, the Wyze Cam v4 Outdoor Bundle offers advanced features with a reliable power adapter. And for creative power solutions, the Lamp Socket v2 Bundles for Pan v3 and Cam v4 cameras provide convenient, outlet-free operation. Choose the power solution that fits your setup and enjoy peace of mind with continuous, reliable video monitoring.
Outdoor Security Camera with Solar Panel Keep your Wyze Battery Cam powered outdoors with solar energy Wyze Cam v4 Outdoor Mounted Wyze Cam v4 delivers crystal-clear 2.5K QHD video day and night Lamp Socket Powering Wyze Cam Power your Wyze cameras easily using existing lamp sockets
FeatureWyze Battery Cam Solar PanelUltimate Security Bundle (13-piece)Wyze Cam v4 Outdoor BundleCam v4 + Lamp Socket v2 Bundle
TypeAccessorySecurity System BundleSecurity Camera BundleSecurity Camera + Lamp Socket Bundle
Price$24.99 (Sold Out)$499.99 (Sold Out)$69.99$49.96
Main PurposeExtend battery life of Wyze Battery Cam ProComplete home security system with cameras, locks, sensors, and hubOutdoor security camera with 2.5K QHD resolution, spotlight, and local recordingPower Wyze Cam v4 via lamp socket, motion-activated lights
Compatible CamerasWyze Cam Outdoor v1/v2, Wyze Battery Cam ProIncludes 2× Wyze Battery Cam Pro, 2× Wyze Cam Pan v3, 2× Wyze Cam v4, Wyze Cam Duo DoorbellWyze Cam v4Wyze Cam v3, v3 Pro, v4, OG, Pan v3
Weather ResistanceIP65 (Weatherproof and dustproof)Cameras included have weather resistance (e.g., IP65 for Pan v3, Battery Cam Pro)IP65Not weatherproof, suitable for damp locations
Power SourceSolar panel with 13-foot weatherproof cableBattery-powered cameras (Battery Cam Pro), plug-in cameras (Pan v3, v4), smart lock with batteryWiredPowered via lamp socket (E26), 120V~, 60Hz
Key ComponentsSolar panel, USB-C adapter cable (sold out)Wyze Cam Duo Doorbell, Wyze Lock Bolt, 2× Wyze Cam Pan v3, 2× Wyze Cam v4, 2× Wyze Battery Cam Pro, Wyze Sense Hub, sensorsWyze Cam v4, Wyze Outdoor Power Adapter, 128GB microSD cardLamp Socket v2 with motion-activated lights, dusk to dawn scheduling
Video ResolutionN/ACameras vary: Battery Cam Pro (2.5K HDR), Pan v3 (1080p), Cam v4 (2.5K QHD), Doorbell (head-to-toe view)2.5K QHD (2560x1440)N/A
Night VisionN/AColor night vision on Battery Cam Pro, Pan v3, Cam v4Enhanced Color Night VisionN/A
Motion DetectionN/AAdvanced AI detection on Battery Cam Pro, motion tracking on Pan v3, smart motion detection on Cam v4YesN/A
Audio FeaturesN/ATwo-way audio on cameras and doorbell, siren on Battery Cam ProTwo-way audioN/A
Mounting OptionsMountable anywhere, 360° freestyle mountVarious mounts included with camerasStand, wall, ceiling, magnetic wall mountLamp socket (E26)
ConnectivityWired to camera via cableWi-Fi 2.4 & 5 GHz, hub connects sensorsWi-Fi 2.4 GHz & Wi-Fi 6Wi-Fi 2.4 GHz, Bluetooth
StorageN/ACloud and local storage options via cameras24/7 local recording with microSD card slotN/A
Warranty30-day hassle-free returns30-day hassle-free returns1 Year1 Year
How can I keep my Wyze security cameras continuously powered without AC outlets?You can maintain a continuous video feed for your Wyze security cameras without AC power by using the Wyze Battery Cam Solar Panel or the Wyze Lamp Socket v2 Bundles. The solar panel harnesses solar energy to keep your Wyze Battery Cam Pro or Wyze Cam Outdoor charged, while the lamp socket bundles allow you to power cameras using existing lamp sockets.
What Wyze cameras are compatible with the Wyze Battery Cam Solar Panel?The Wyze Battery Cam Solar Panel is specifically designed to work with the Wyze Battery Cam Pro and Wyze Cam Outdoor (v1 and v2), providing continuous charging and extending battery life.
Is the Wyze Battery Cam Solar Panel weatherproof?Yes, the Wyze Battery Cam Solar Panel is built with an IP65 weather resistance rating, making it dustproof and waterproof for reliable outdoor use in all weather conditions.
How long is the power cable included with the Wyze Battery Cam Solar Panel?The Wyze Battery Cam Solar Panel comes with a 13-foot weatherproof power cable, allowing flexible placement of the panel for optimal sun exposure while positioning your camera where you need it.
What are the benefits of using a solar panel to power Wyze cameras?Using a solar panel provides a green, maintenance-free power source that keeps your Wyze battery cameras running indefinitely, reducing the need for frequent recharging and ensuring continuous video surveillance.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes a Wyze Cam v4 with 2.5K QHD resolution, enhanced color night vision, a motion-activated spotlight, Wi-Fi 6 support, compatibility with Alexa and Google Assistant, a Wyze Outdoor Power Adapter, and a 128GB microSD card for 24/7 local recording.
Can I power Wyze cameras using lamp sockets?Yes, the Wyze Lamp Socket v2 Bundles allow you to power Wyze Cam Pan v3 and Wyze Cam v4 cameras directly from standard E26 lamp sockets, making it easy to install cameras in locations without AC outlets.
Are the Wyze Lamp Socket v2 Bundles weatherproof?The Wyze Lamp Socket v2 Bundles are suitable for damp locations but are not fully weatherproof. They are ideal for covered outdoor areas or locations where direct exposure to rain is minimal.
What features do the Wyze Lamp Socket v2 Bundles offer?The Wyze Lamp Socket v2 Bundles offer motion-activated lighting, dusk-to-dawn scheduling, easy installation with E26 socket compatibility, and the ability to link multiple sockets for expanded coverage.
Why should I choose solar or lamp socket power solutions for my Wyze cameras?Solar and lamp socket power solutions ensure your Wyze cameras remain online and continuously record without relying on traditional AC outlets. These options are ideal for outdoor, remote, or off-grid locations, providing reliable and uninterrupted home security.
How does the Wyze Battery Cam Solar Panel work to extend battery life?What are the weather resistance features of the Wyze Battery Cam Solar Panel?Are there any discounts or promotions currently available for Wyze products?
