Keep Your Wyze Cam Active During Storms and Power Failures
When severe weather strikes or power outages occur, maintaining continuous surveillance with your Wyze Cam is crucial for home security and peace of mind. The Wyze Battery Cam Pro combined with the Wyze Battery Cam Solar Panel offers an effective, weather-resistant solution to keep your camera powered and recording without interruption.
Wyze Battery Cam Pro: Reliable Wireless Security Camera
High-Quality Video and Smart Features
The Wyze Battery Cam Pro delivers stunning 2.5K HDR video resolution (2560 x 1440), ensuring crystal-clear footage even in challenging lighting conditions. Equipped with a CMOS-Starlight sensor and an F1.6 lens, it captures sharp, vibrant images day or night.
Long-Lasting Battery Life
Powered by removable, rechargeable 6200mAh battery packs, the camera can operate wire-free for up to 6 months on a single charge. This extended battery life is ideal for outdoor use where power outlets may be unavailable or unreliable during storms.
Weatherproof and Durable
With an IP65 weather resistance rating, the Wyze Battery Cam Pro withstands rain, snow, and dust, making it perfect for outdoor monitoring in all seasons. It operates efficiently in temperatures ranging from -20°C to 50°C (-4°F to 122°F).
Advanced Motion Detection and Security
The camera features radar and PIR motion detection, integrated spotlight, and a 100 dB siren to deter intruders. Two-way audio with a built-in speaker and microphone allows you to communicate remotely.
Connectivity and Compatibility
Supports both 2.4 GHz and 5 GHz WiFi networks and integrates seamlessly with Alexa, Google Assistant, and IFTTT for smart home automation.
Wyze Battery Cam Solar Panel: Extend Battery Life with Solar Power
Continuous Power from the Sun
The Wyze Battery Cam Solar Panel is designed to keep your Wyze Battery Cam Pro charged by harnessing solar energy. This accessory significantly extends the camera’s battery life, reducing the need for manual recharging during prolonged storms or power failures.
Weather-Resistant and Easy to Mount
Built with an IP65 waterproof rating, the solar panel withstands harsh weather conditions including rain and dust. Its compact size (173 mm x 120 mm x 17 mm) and 360° adjustable mount allow flexible installation anywhere with optimal sun exposure.
Efficient Solar Power Output
The panel delivers 2.5W at 5V DC, providing steady power to your camera. It includes a 13-foot micro USB-C cable for convenient placement even at a distance from the camera.
What’s Included
- Solar panel with white frame and black solar cells
- Wall mount and screws for secure installation
- Micro USB and USB-C adapter cables
- Quick start guide for easy setup
Compatibility
Works with Wyze Cam Outdoor v1/v2 and Wyze Battery Cam Pro, making it a versatile accessory for multiple Wyze outdoor camera models.
Why Choose the Wyze Battery Cam Pro with Solar Panel?
Combining the Wyze Battery Cam Pro with the Solar Panel accessory is the most effective way to ensure your security camera remains active during storms and power outages. The solar panel continuously charges the camera’s battery using sunlight, while the camera’s weatherproof design guarantees reliable operation in harsh conditions.
This setup eliminates the worry of losing surveillance coverage when you need it most, providing peace of mind with minimal maintenance.
Summary of Key Benefits
Feature | Wyze Battery Cam Pro | Wyze Battery Cam Solar Panel |
Video Resolution | 2.5K HDR (2560 x 1440) | N/A |
Battery Life | Up to 6 months | Extends battery life via solar power |
Weather Resistance | IP65 (rain, dust resistant) | IP65 (waterproof and dustproof) |
Power Source | Rechargeable battery packs | Solar power (2.5W, 5V DC) |
Mounting | Wall mount included | 360° adjustable mount included |
Connectivity | 2.4 & 5 GHz WiFi, Alexa, Google, IFTTT | USB-C cable (13 ft) for flexible setup |
Operating Temperature Range | -20°C to 50°C (-4°F to 122°F) | Suitable for outdoor conditions |
Enhance Your Outdoor Security Setup
By pairing the Wyze Battery Cam Pro with the Wyze Battery Cam Solar Panel, you create a resilient, low-maintenance security system that stays powered through storms and power failures. This combination is ideal for front porches, driveways, vacation homes, RVs, and any outdoor area where reliable surveillance is essential.
Protect your home and loved ones with continuous, weatherproof video monitoring powered by the sun.
How does the Wyze Battery Cam Pro stay powered during storms and power outages?
The Wyze Battery Cam Pro uses removable, rechargeable 6200mAh battery packs that can last up to 6 months on a single charge. When paired with the Wyze Battery Cam Solar Panel, the camera can be continuously charged using solar energy, ensuring uninterrupted operation even during storms and power failures.Is the Wyze Battery Cam Pro weatherproof for outdoor use?
Yes, the Wyze Battery Cam Pro is IP65 weather resistant, making it durable against rain, snow, and dust. It is designed to operate efficiently in temperatures ranging from -20°C to 50°C (-4°F to 122°F), making it ideal for year-round outdoor surveillance.What video quality does the Wyze Battery Cam Pro offer?
The Wyze Battery Cam Pro delivers high-quality 2.5K HDR video resolution (2560 x 1440) with a CMOS-Starlight sensor and F1.6 lens, ensuring clear and vibrant footage both day and night.How does the Wyze Battery Cam Solar Panel extend camera battery life?
The Wyze Battery Cam Solar Panel harnesses solar energy to continuously charge the Wyze Battery Cam Pro, significantly extending its battery life and reducing the need for manual recharging, especially during prolonged storms or power outages.Is the Wyze Battery Cam Solar Panel weather-resistant?
Yes, the Wyze Battery Cam Solar Panel is built with an IP65 waterproof rating, allowing it to withstand harsh weather conditions such as rain and dust, making it suitable for outdoor installation.What is included with the Wyze Battery Cam Solar Panel?
The Wyze Battery Cam Solar Panel package includes the solar panel with a white frame and black solar cells, a wall mount and screws for secure installation, micro USB and USB-C adapter cables, and a quick start guide for easy setup.Which Wyze cameras are compatible with the Wyze Battery Cam Solar Panel?
The Wyze Battery Cam Solar Panel is compatible with the Wyze Cam Outdoor v1/v2 and the Wyze Battery Cam Pro, making it a versatile accessory for multiple Wyze outdoor camera models.What smart features does the Wyze Battery Cam Pro offer?
The Wyze Battery Cam Pro features advanced radar and PIR motion detection, an integrated spotlight, a 100 dB siren, and two-way audio with a built-in speaker and microphone. It also supports both 2.4 GHz and 5 GHz WiFi networks and integrates with Alexa, Google Assistant, and IFTTT for smart home automation.How easy is it to install the Wyze Battery Cam Solar Panel?
The Wyze Battery Cam Solar Panel is easy to install with its included wall mount and screws. Its compact size and 360° adjustable mount allow for flexible placement to maximize sun exposure, and the 13-foot micro USB-C cable provides convenient positioning even at a distance from the camera.Why should I pair the Wyze Battery Cam Pro with the Solar Panel?
Pairing the Wyze Battery Cam Pro with the Solar Panel ensures your security camera remains active during storms and power outages. The solar panel provides continuous charging, while the camera’s weatherproof design guarantees reliable operation in harsh conditions, offering peace of mind and minimal maintenance.
