Best Magnetic Mount Alternatives for Wyze Cameras
Discover Magnetic Mount Options for Wyze Cameras
When it comes to mounting your Wyze cameras securely and conveniently, magnetic mount options provide a sleek, flexible solution. While Wyze does not offer a dedicated magnetic mount accessory, several mounting kits and accessories are designed to offer easy installation, versatile placement, and strong hold—ideal for users seeking magnetic or similarly effortless mounting experiences. Explore the best Wyze mounting accessories that complement magnetic mounting needs, ensuring your cameras stay firmly in place while offering flexible positioning.
Wyze Cam Mounting Kit: Simple and Secure Installation
Key Features:
  • Compatible with Wyze Cam v2, Wyze Cam v3, and Wyze Cam v3 Pro.
  • Includes a mounting bracket, adhesive tape, and a longer 5-foot Micro USB cable.
  • Provides a reliable mounting solution for indoor or outdoor use.
  • Easy to install on walls or ceilings without complicated tools.
This kit is perfect for users who want a hassle-free mounting experience that mimics the convenience of magnetic mounts by using strong adhesive and bracket support.
Wyze Universal Mount (Long): Versatility Meets Durability
Key Features:
  • Designed with a longer neck for versatile mounting options such as ceilings, patios, or walls.
  • Compatible with Wyze cameras that use a standard 1/4”-20 mount (excluding Wyze Cam OG and OG Telephoto).
  • Durable construction ensures your camera stays stable in various environments.
  • Ideal for users who want flexible positioning with a sturdy hold.
This mount offers a practical alternative to magnetic mounts by providing extended reach and secure placement for your Wyze cameras.
Wyze Window Mount: Clear Views with Easy Attachment
Key Features:
  • Designed for mounting Wyze Cam v3, v3 Pro, v4, Wyze Cam OG, and OG Telephoto on glass surfaces.
  • Allows for glare-free, reflection-free viewing through windows.
  • Simple installation with strong adhesive backing.
  • Perfect for users wanting to mount cameras inside facing outdoors without drilling holes.
The window mount offers a unique mounting solution that complements magnetic mounting by enabling quick attachment and repositioning on smooth glass surfaces.
Wyze Cam Floodlight Plug-In Mount: Plug-and-Play Outdoor Security
Wyze Cam Floodlight Outdoor Lifestyle Enhance your outdoor security with easy-to-install Wyze Cam Floodlight Plug-In Mount.
Key Features:
  • Eliminates the need for complex junction box installation.
  • Available in black and white to match your home exterior.
  • Plug-n-play design for quick setup.
  • Provides a sturdy mount for Wyze Cam Floodlight, ideal for outdoor security lighting.
This mount is a great choice for users looking for a magnetic mount alternative that offers quick installation and reliable outdoor performance.
Whether you want a quick adhesive mount, a versatile long-neck bracket, or a window mount for glare-free views, Wyze offers a range of mounting accessories that deliver the convenience and flexibility often sought in magnetic mount options.
Summary of Magnetic Mount Alternatives for Wyze Cameras
Product NameCompatible CamerasMount TypePrice (USD)
Wyze Cam Mounting KitWyze Cam v2, v3, v3 ProAdhesive bracket + cable5.99
Wyze Universal Mount (Long)Wyze cameras with 1/4”-20 mountLong neck bracket9.99
Wyze Window MountWyze Cam v3/v3 Pro/v4, OG seriesAdhesive window mount9.98
Wyze Cam Floodlight Plug-In MountWyze Cam FloodlightPlug-in floodlight mount19.98
Enhance Your Wyze Camera Setup Today
Choosing the right mounting accessory can transform your Wyze camera experience, making installation effortless and ensuring your cameras capture the best angles. While magnetic mounts are not explicitly offered, these versatile mounting kits and brackets provide comparable ease and flexibility for your smart home security needs.
FeatureWyze Cam Mounting KitWyze Universal Mount (Long)Wyze Window MountWyze Cam Floodlight Plug-In Mount
Price$5.99$9.99$9.98$19.98
Compatible CamerasWyze Cam v2, v3, v3 ProWyze Cameras with 1/4”-20 mount (excludes OG)Wyze Cam v3, v3 Pro, v4, OG, OG TelephotoWyze Cam Floodlight v1, v2, Floodlight Pro
Mount TypeMounting bracket, adhesive, longer Micro USB cableDurable metal mount with longer neckWindow/glass mountPlug-in mount for floodlight cameras
Mounting LocationWall, ceiling, other flat surfacesCeiling, patio, fences, trees, sidingGlass surfaces (windows)Wall or ceiling, plug-n-play floodlight solution
MaterialNot specifiedHeavy-duty metalNot specifiedNot specified
Weather ResistanceNot specifiedWeather-resistant (can withstand tough weather)Not specifiedOutdoor safe
Installation EaseIncludes adhesive and mounting bracketEasy installation, adjustable and flexibleEasy window mountingEasy plug-n-play installation
Cable IncludedLonger Micro USB cable includedNo cable includedNo cable includedPower cord 20 ft (6m) included
Special NotesSpare mounting plateNot compatible with Wyze Cam OG/OG TelephotoReduces glare/reflection on glassEliminates need for junction box
Does Wyze offer a dedicated magnetic mount for their cameras?No, Wyze does not currently offer a dedicated magnetic mount accessory for their cameras. However, they provide several mounting kits and accessories that offer similar convenience and flexibility, such as adhesive mounts and versatile brackets.
What are the best alternatives to magnetic mounts for Wyze cameras?The best alternatives to magnetic mounts for Wyze cameras include the Wyze Cam Mounting Kit (with adhesive bracket), Wyze Universal Mount (Long), Wyze Window Mount, and Wyze Cam Floodlight Plug-In Mount. These options provide secure, flexible, and easy installation for various Wyze camera models.
Which Wyze cameras are compatible with the Wyze Cam Mounting Kit?The Wyze Cam Mounting Kit is compatible with Wyze Cam v2, Wyze Cam v3, and Wyze Cam v3 Pro. It includes a mounting bracket, adhesive tape, and a longer 5-foot Micro USB cable for easy installation.
Can I mount my Wyze camera on a window for outdoor viewing?Yes, the Wyze Window Mount is designed specifically for mounting Wyze Cam v3, v3 Pro, v4, Wyze Cam OG, and OG Telephoto on glass surfaces. It allows for glare-free, reflection-free viewing through windows and uses a strong adhesive for easy attachment and repositioning.
What is the Wyze Universal Mount (Long) and which cameras does it support?The Wyze Universal Mount (Long) is a versatile mounting bracket with a longer neck, suitable for ceilings, patios, or walls. It is compatible with Wyze cameras that use a standard 1/4”-20 mount, excluding Wyze Cam OG and OG Telephoto. Its durable construction ensures stable camera placement in various environments.
Is there a plug-and-play mounting option for Wyze Cam Floodlight?Yes, the Wyze Cam Floodlight Plug-In Mount offers a plug-and-play design for quick and easy installation. It eliminates the need for complex junction box installation and is available in black and white to match your home exterior.
Are Wyze mounting accessories suitable for both indoor and outdoor use?Many Wyze mounting accessories, such as the Wyze Cam Mounting Kit and Wyze Universal Mount (Long), are designed for both indoor and outdoor use. Always check the product specifications to ensure compatibility with your intended installation environment.
How do Wyze mounting accessories compare to magnetic mounts?While Wyze does not offer magnetic mounts, their mounting accessories—such as adhesive brackets, window mounts, and plug-in options—provide similar ease of installation, flexible positioning, and strong hold, making them excellent alternatives for users seeking magnetic mount convenience.
What are the key features of the Wyze Cam Mounting Kit?Can you tell me more about the Wyze Universal Mount and its compatibility?Do you have any ongoing sales or discounts for Wyze camera accessories?
