Securely Mount Wyze Camera on Ceiling with Adjustable Long Mount
Mount Wyze Camera Securely on Ceiling with Adjustable Long Mount
When it comes to mounting your Wyze camera securely on the ceiling, especially with an adjustable long mount, choosing the right accessories is essential. Whether you want a sturdy, versatile mount or a complete mounting kit, Wyze offers several solutions tailored to fit your needs perfectly.
Wyze Cam Mounting Kit: Complete Ceiling Mount Solution
The Wyze Cam Mounting Kit is designed specifically for Wyze Cam v2, v3, and v3 Pro models, providing everything you need for a secure ceiling installation.
Key Features:
  • Complete Mounting Set: Includes a wall plate, adhesive tape, screw set, and a longer 5-foot Micro USB extension cable.
  • Versatile Compatibility: Works seamlessly with Wyze Cam v2, v3, and v3 Pro.
  • Secure Installation: Use the adhesive for quick mounting or screws for a more permanent, sturdy setup.
  • Extended Cable Length: The included USB extension cable allows flexible placement away from power outlets.
This kit is perfect if you want a straightforward, all-in-one solution to mount your Wyze camera on the ceiling with confidence.
Wyze Universal Mount (Long): Adjustable and Durable Ceiling Mount
For those seeking a more robust and adjustable mounting option, the Wyze Universal Mount (Long) is an excellent choice. This mount features a longer neck, ideal for ceiling or patio installations where extra reach and flexibility are needed.
Why Choose Wyze Universal Mount (Long)?
  • Heavy-Duty Metal Construction: Ensures durability and long-lasting support for your camera.
  • Adjustable Neck: Allows you to angle your camera precisely for optimal coverage.
  • Wide Compatibility: Supports a broad range of Wyze cameras with a standard 1/4”-20 mount, including Wyze Cam v1, v2, v3, v3 Pro, Pan series, Outdoor series, and Battery Cam Pro.
  • Easy Installation: Comes with screws and drywall anchors for secure mounting on ceilings or walls.
  • Load Bearing: Supports up to 2 kg (70 oz), making it sturdy enough for most Wyze cameras.
This mount is perfect for users who want a flexible, professional-grade mounting solution that can be adjusted after installation. Wyze Cam Floodlight Outdoor Mount Secure your Wyze camera on ceiling or outdoor spaces with versatile mounts.
Wyze Cam v4: Ideal Camera for Ceiling Mounting
If you are upgrading your camera or starting fresh, the Wyze Cam v4 is a top-tier choice that pairs well with the mounting accessories mentioned above.
Highlights of Wyze Cam v4:
  • High-Resolution Video: 2.5K QHD (2560x1440) for crystal-clear footage.
  • Wide Field of View: 115.8° diagonal, 98.5° horizontal, and 53.1° vertical.
  • Multiple Mounting Options: Includes wall mount, ceiling mount, magnetic adhesive mount, and stand.
  • Weather Resistant: Rated IP65, suitable for indoor and outdoor use.
  • Advanced Features: Color night vision, built-in siren, two-way talk, and noise cancellation.
  • Connectivity: Supports Wi-Fi 6 and Bluetooth 5.2 for reliable performance.
The Wyze Cam v4’s compact size and multiple mounting options make it an excellent candidate for ceiling installation using either the Wyze Cam Mounting Kit or the Wyze Universal Mount (Long).
Why Choose Wyze Mounting Accessories for Ceiling Installation?
Mounting your Wyze camera securely on the ceiling is crucial for optimal surveillance coverage and camera safety. Wyze’s mounting accessories are designed to provide:
  • Strong, reliable support to prevent camera falls.
  • Adjustability to fine-tune your camera’s angle.
  • Compatibility with a wide range of Wyze cameras.
  • Easy installation with included hardware and adhesive options.
Whether you prefer a quick adhesive mount or a heavy-duty metal adjustable mount, Wyze has you covered.
Summary of Recommended Products for Ceiling Mounting
Product NamePriceKey BenefitsCompatible Cameras
Wyze Cam Mounting Kit$5.99Complete kit with adhesive & screwsWyze Cam v2, v3, v3 Pro
Wyze Universal Mount (Long)$9.99Adjustable, heavy-duty metal mountMost Wyze cams with 1/4”-20 mount
Wyze Cam v4$100.00High-res, weather-resistant cameraN/A (camera itself)
Final Tips for Secure Ceiling Mounting
  • Use the Wyze Cam Mounting Kit if you want a simple, all-in-one solution with adhesive and screws.
  • Opt for the Wyze Universal Mount (Long) if you need a longer, adjustable mount for precise camera positioning.
  • Pair these mounts with the Wyze Cam v4 for the best video quality and versatile mounting options.
  • Always ensure the mounting surface is clean and dry before installation.
  • Use the included screws and anchors for the most secure hold, especially on drywall or ceilings.
FeatureWyze Cam Mounting KitWyze Universal Mount (Long)Wyze Cam v4
TypeAccessoriesAccessoriesCamera
Compatible ModelsWyze Cam v2, v3, v3 ProWyze Cameras with 1/4”-20 mount (not OG or OG Telephoto)Wyze Cam v4
Price$5.99$9.99$100.00
Mounting ComponentsMounting bracket, adhesive, longer Micro USB cableDurable metal mount with longer neckStand, Wall mount, Ceiling mount, Magnetic wall mount (adhesive)
MaterialNot specifiedHeavy-duty metalPolycarbonate body; Glass + Plastic lens
Mounting ApplicationsGeneral mounting for Wyze Cam v2, v3, v3 ProVersatile mounting (ceiling, patio, fences, trees)Standalone or wall/ceiling/magnetic mounting
Weather ResistanceNot specifiedWeather-resistant (can withstand tough weather)IP65 rated
Cable IncludedLonger Micro USB cable includedNo cable included6-Foot Flat micro USB to USB-A cable included
Compatibility NotesOnly for Wyze Cam v2, v3, v3 ProNot compatible with Wyze Cam OG or OG TelephotoCompatible with various Wyze Cam v4 colors
Return Policy30-day hassle-free returns30-day hassle-free returns1-Year warranty
Additional FeaturesAdhesive mounting optionAdjustable and flexible for perfect angle2.5K QHD video, color night vision, Wi-Fi 6, Alexa/Google Assistant integration
What is the best way to mount a Wyze camera securely on the ceiling?The best way to mount a Wyze camera securely on the ceiling is to use dedicated mounting accessories such as the Wyze Cam Mounting Kit or the Wyze Universal Mount (Long). These mounts provide strong support, easy installation, and adjustable angles for optimal surveillance coverage.
Which Wyze cameras are compatible with the Wyze Cam Mounting Kit?The Wyze Cam Mounting Kit is compatible with Wyze Cam v2, v3, and v3 Pro models. It includes all necessary hardware for secure ceiling installation, including a wall plate, adhesive tape, screws, and a 5-foot Micro USB extension cable.
What are the benefits of using the Wyze Universal Mount (Long) for ceiling installation?The Wyze Universal Mount (Long) offers heavy-duty metal construction, an adjustable neck for precise camera positioning, and wide compatibility with most Wyze cameras that use a standard 1/4”-20 mount. It supports up to 2 kg (70 oz) and comes with screws and drywall anchors for secure mounting on ceilings or walls.
Is the Wyze Cam v4 suitable for ceiling mounting?Yes, the Wyze Cam v4 is ideal for ceiling mounting. It features high-resolution 2.5K QHD video, a wide field of view, multiple mounting options (including ceiling mount), and weather resistance (IP65 rating), making it suitable for both indoor and outdoor use.
What mounting options are available for Wyze Cam v4?Wyze Cam v4 offers several mounting options, including wall mount, ceiling mount, magnetic adhesive mount, and a stand. This flexibility allows you to install the camera in the optimal position for your surveillance needs.
How do I ensure a secure installation when mounting my Wyze camera on the ceiling?To ensure a secure installation, always clean and dry the mounting surface before installation. Use the included screws and drywall anchors for the most secure hold, especially on drywall or ceilings. For a quick setup, you can use the adhesive tape provided in the Wyze Cam Mounting Kit.
What is included in the Wyze Cam Mounting Kit?The Wyze Cam Mounting Kit includes a wall plate, adhesive tape, screw set, and a 5-foot Micro USB extension cable. This all-in-one kit provides everything needed for a secure and flexible ceiling installation of your Wyze camera.
Can I use the Wyze Universal Mount (Long) with outdoor Wyze cameras?Yes, the Wyze Universal Mount (Long) is compatible with a broad range of Wyze cameras, including the Outdoor series and Battery Cam Pro, as long as they use a standard 1/4”-20 mount. Its heavy-duty metal construction makes it suitable for both indoor and outdoor installations.
Why should I use official Wyze mounting accessories for ceiling installation?Official Wyze mounting accessories are designed for strong, reliable support, easy installation, and compatibility with a wide range of Wyze cameras. They offer both adhesive and screw mounting options, ensuring your camera stays securely in place and can be adjusted for the best viewing angle.
What are the prices of the recommended Wyze ceiling mounting products?The Wyze Cam Mounting Kit is priced at $5.99, the Wyze Universal Mount (Long) at $9.99, and the Wyze Cam v4 camera itself at $100.00.
What are the key features of the Wyze Cam Mounting Kit?Can the Wyze Universal Mount (Long) be used for outdoor installations?Do you have any deals, ongoing sales, discounts, or promotions?
