Wyze Battery Cam Pro Mounting Options: Best Ways to Install
When it comes to securing your home or property with the Wyze Battery Cam Pro, understanding the mounting options is essential for optimal placement and performance. The Wyze Battery Cam Pro offers versatile mounting solutions designed to fit various environments, whether indoors or outdoors, ensuring you get the best coverage and convenience.
Standard Mounting Features
The Wyze Battery Cam Pro comes with a 1/4” - 20 standard mounting thread, which is compatible with a wide range of mounts and tripods available on the market. This universal mounting method allows you to easily attach the camera to walls, ceilings, poles, or any other surface using compatible mounts. Included in the package is a wall mount that measures 2 inches by 2 inches by 2.2 inches and weighs just 1.5 ounces (44 grams). This mount is compact and lightweight, making installation straightforward and secure. The matte finish and durable PC plastic construction ensure the mount blends seamlessly with your camera and withstands outdoor conditions.
Flexible Placement with Wire-Free Design
Thanks to its wire-free design and removable, rechargeable 6200mAh battery packs, the Wyze Battery Cam Pro can be mounted virtually anywhere without the hassle of running power cables. This flexibility is perfect for locations where power outlets are not readily accessible, such as garages, backyards, or remote areas around your property. The camera supports IP65 weatherproofing, allowing it to withstand rain, dust, and varying temperatures from -20°C to 50°C (-4°F to 122°F). This makes the Wyze Battery Cam Pro ideal for outdoor mounting in diverse climates.
Enhanced Mounting with Solar Panel Option
For users seeking extended battery life and less frequent charging, the Wyze Battery Cam Pro + Solar Panel bundle is an excellent choice. This option maintains all the mounting features of the standard Battery Cam Pro but adds the convenience of solar power to keep your camera running continuously. The solar panel can be mounted near the camera using the same 1/4” - 20 standard mount or other compatible mounts, providing a sustainable power source that reduces maintenance. This setup is perfect for sunny outdoor locations, such as porches, patios, or garden areas.
Additional Accessories for Mounting and Power Management
To complement your mounting setup, Wyze offers several accessories that enhance the usability and convenience of the Battery Cam Pro:
  • Wyze Removable Battery Pack: Keep extra fully charged batteries on hand to swap out quickly without needing to take down the camera. Each battery pack has a 6200mAh capacity and charges in approximately 9 hours via USB-C.
  • Wyze Battery Charging Dock: Charge two battery packs simultaneously with this compact dock, ensuring you always have backup power ready. The dock is lightweight and easy to place on any countertop or shelf near your charging area.
With these mounting options and accessories, the Wyze Battery Cam Pro provides a flexible, reliable, and easy-to-install security solution tailored to your specific needs.
Wyze Battery Cam Pro Specifications Overview
  • Video Resolution: 2.5K HDR (2560 x 1440)
  • Wireless: Yes, supports 2.4 GHz & 5 GHz WiFi
  • Power Source: Removable, rechargeable 6200mAh battery packs
  • Battery Life: Up to 6 months per charge
  • Charging Time: Approximately 9 hours
  • Weather Resistance: IP65 rated for outdoor use
  • Operating Temperature: -20°C to +50°C (-4°F to +122°F)
  • Field of View: 134° diagonal, 108° horizontal, 56° vertical
  • Night Vision: 2 IR LEDs + 2 White LEDs (187 lumens)
  • Audio: Two-way with built-in speaker and MEMS digital microphone
  • Siren: 100 dB SPL at 0.1m
  • Mounting: 1/4” - 20 standard thread, wall mount included
  • Dimensions: 2.5 x 1.8 x 3.5 inches
  • Weight: 0.94 lbs
Why Choose Wyze Battery Cam Pro for Your Security Needs?
The Wyze Battery Cam Pro stands out with its combination of high-resolution video, flexible mounting options, and long-lasting battery life. Whether you prefer the standard wall mount or want to leverage solar power for continuous operation, this camera adapts to your environment with ease. Its wire-free design and weatherproof build make it perfect for both indoor and outdoor use, while the included accessories like extra battery packs and charging docks ensure your system stays powered and ready.
Outdoor Security Camera Mounted on Porch Alt text: Wyze Battery Cam Pro mounted on a porch wall providing outdoor security
Summary of Wyze Battery Cam Pro Mounting Options and Accessories
ProductMounting TypePower SourceKey Feature
Wyze Battery Cam Pro1/4” - 20 standard mountRechargeable battery packWire-free, weatherproof, spotlight
Wyze Battery Cam Pro + Solar PanelSame as above + solar mountBattery + solar panelContinuous solar charging
Wyze Removable Battery PackN/ARechargeable 6200mAh batteryQuick battery swaps
Wyze Battery Charging DockN/ACharges two batteries simultaneouslyConvenient dual charging
Enhance your home security with the versatile mounting options and reliable power solutions of the Wyze Battery Cam Pro series.
FeatureWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelWyze Removable Battery PackWyze Battery Charging Dock
TypeCameraCamera + Accessory BundleAccessory (Battery)Accessory (Charging Dock)
Video Resolution2.5K HDR2.5K HDRN/AN/A
PowerRemovable, Rechargeable Battery PacksRemovable, Rechargeable Battery Packs + Solar Panel6200mAh Rechargeable Battery PackCharges up to two batteries simultaneously
Battery CapacityIncludedIncluded6200 mAhN/A
Battery TypeLithium IonLithium IonLithium IonN/A
Charging MethodUSB-C (via battery pack)USB-C (via battery pack) + Solar PanelUSB-CUSB-A to USB-C cable included
Weatherproof RatingIP65IP65N/AN/A
Motion DetectionRadar + PIRRadar + PIRN/AN/A
Spotlight & SirenIntegrated Spotlight (150 lumens) & SirenIntegrated Spotlight (150 lumens) & SirenN/AN/A
WiFi Support2.4 & 5 GHz2.4 & 5 GHzN/AN/A
Local RecordingYes (with microSD card)Yes (with microSD card)N/AN/A
SetupBluetoothⓇ Setup, No Hub RequiredBluetoothⓇ Setup, No Hub RequiredN/AN/A
DimensionsNot specifiedNot specified2.9 in x 1.6 in x 0.9 in (75 mm x 40 mm x 22 mm)Charging Dock: 2.6in x 2in x 1in (58mm x 52mm x 26mm)
WeightNot specifiedNot specified3.9 oz (110 g)2.75 oz (78 g)
Charging TimeN/AN/AApprox. 9 hours at 25°C/77°FApprox. 8.5 hours at 25°C/77°F
Price (USD)$89.98 (1 Pack)$109.98 (Bundle)$22.99$17.99
Additional FeaturesRemovable battery packs, dual-band WiFi, two-way audio, IP65 weather resistanceSolar panel for continuous power, all features of Battery Cam ProHot-swap battery, long battery life up to 6 monthsCharges two batteries simultaneously, includes power adapter and cable
CompatibilityN/AN/AWorks with Wyze Battery Cam Pro and Duo Cam DoorbellCompatible with Wyze Battery Cam Pro battery packs
What mounting options are available for the Wyze Battery Cam Pro?The Wyze Battery Cam Pro offers versatile mounting options, including a 1/4” - 20 standard mounting thread compatible with a wide range of mounts and tripods. It comes with a compact wall mount for easy installation on walls, ceilings, or poles, both indoors and outdoors.
Is the Wyze Battery Cam Pro suitable for outdoor installation?Yes, the Wyze Battery Cam Pro is IP65 weatherproof, making it ideal for outdoor use. It can withstand rain, dust, and temperatures ranging from -20°C to 50°C (-4°F to 122°F), ensuring reliable performance in various climates.
Does the Wyze Battery Cam Pro require power cables for installation?No, the Wyze Battery Cam Pro features a wire-free design powered by removable, rechargeable 6200mAh battery packs. This allows you to mount the camera virtually anywhere without the need for power cables.
Can I use a solar panel with the Wyze Battery Cam Pro?Yes, the Wyze Battery Cam Pro + Solar Panel bundle allows you to use solar power for continuous operation. The solar panel can be mounted using the same 1/4” - 20 standard mount, providing a sustainable power source and reducing the need for frequent battery charging.
What accessories are available for the Wyze Battery Cam Pro to enhance mounting and power management?Wyze offers several accessories, including removable battery packs for quick swaps and a battery charging dock that can charge two batteries simultaneously. These accessories ensure your camera remains powered and easy to maintain.
What are the dimensions and weight of the included wall mount for the Wyze Battery Cam Pro?The included wall mount measures 2 inches by 2 inches by 2.2 inches and weighs 1.5 ounces (44 grams). It is compact, lightweight, and made from durable PC plastic with a matte finish.
How long does the Wyze Battery Cam Pro battery last and how is it charged?The Wyze Battery Cam Pro battery lasts up to 6 months per charge, depending on usage. Each 6200mAh battery pack charges in approximately 9 hours via USB-C.
What are the key features of the Wyze Battery Cam Pro’s mounting system?The Wyze Battery Cam Pro’s mounting system features a universal 1/4” - 20 thread for compatibility with most mounts and tripods, a compact included wall mount, and support for both standard and solar-powered setups.
Can I use the Wyze Battery Cam Pro with smart home integrations?Yes, the Wyze Battery Cam Pro integrates with Alexa, Google Assistant, and IFTTT, allowing you to connect it with your smart home ecosystem for enhanced convenience and control.
What makes the Wyze Battery Cam Pro a good choice for home security?The Wyze Battery Cam Pro combines high-resolution 2.5K HDR video, flexible wire-free mounting, long-lasting battery life, weatherproof construction, and smart home integrations, making it a reliable and easy-to-install security solution for both indoor and outdoor use.
What are the different mounting options available for the Wyze Battery Cam Pro?Can the Wyze Battery Cam Pro be used indoors as well as outdoors?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Battery Cam Pro?
