Long-Term Time Lapse on Wyze Cam with 128GB MicroSD Card
Long Term Time Lapse Recording on Wyze Cam with 128GB MicroSD Card
When it comes to capturing continuous footage or creating stunning time lapse videos with your Wyze Cam, having the right microSD card is crucial. The Wyze MicroSD Card paired with the Wyze Cam v4 offers an unbeatable combination for long-term recording, local storage, and advanced camera features without any subscription fees.
Wyze MicroSD Card: Unlock Continuous Recording and Time Lapses
The Wyze MicroSD Card is designed specifically to enhance your Wyze Cam experience by enabling continuous local recording and time lapse capture. Available in multiple sizes, the 128GB microSDXC Card is the perfect balance of storage capacity and affordability for long-term use.
Key Features:
  • Continuous Local Recording: Record 24/7 directly to the microSD card without monthly fees.
  • Time Lapse Capture: Create mesmerizing videos that compress hours or days into seconds.
  • Easy Playback: Access footage anytime through the Wyze app or by removing the card to view on your computer.
  • Compatibility: Works seamlessly with most Wyze Cams that have a microSD card slot.
  • Affordable Options: 128GB card priced at $16.99, offering ample space for days of footage.
With the 128GB card, you can expect to store several days of continuous video, depending on your camera settings and resolution, making it ideal for long-term monitoring or creative time lapse projects.
Wyze Cam v4: The Ultimate Camera for Long-Term Recording
The Wyze Cam v4 is a powerful, feature-packed security camera that pairs perfectly with the 128GB Wyze MicroSD Card for extended recording sessions.
Why Choose Wyze Cam v4 for Time Lapse and Continuous Recording?
  • 2.5K QHD Resolution: Capture crystal-clear video with four times the detail of 1080p HD.
  • Enhanced Color Night Vision: See vibrant colors even in low-light conditions, thanks to advanced sensors and spotlight LEDs.
  • IP65 Weather Resistance: Use indoors or outdoors in any weather, from rain to snow.
  • Motion-Activated Spotlight & Siren: Deter intruders and illuminate your surroundings automatically.
  • Wi-Fi 6 Support: Enjoy a stronger, more reliable connection for uninterrupted streaming and recording.
  • MicroSD Card Support up to 512GB: Store days or even weeks of footage locally without worrying about cloud fees.
  • Advanced Audio: Two-way talk with noise and echo cancellation for clear communication.
  • Smart Features: Auto-zoom with AI tracking, motion detection zones, smoke and CO alerts, and compatibility with Alexa, Google Assistant, and IFTTT.
Mounting and Setup:
The Wyze Cam v4 offers versatile mounting options including stand, wall, ceiling, and magnetic mounts, making it easy to position for optimal time lapse angles or security coverage.
"Record every second 24/7 with microSD card support up to 512GB — no subscription required."
Wyze Cam v4 in use Wyze Cam v4 capturing motion at night with color night vision
Wyze Cam v4 + FREE 32GB MicroSD Card Bundle
For those just starting out or looking for a great deal, the Wyze Cam v4 + FREE 32GB MicroSD Card bundle is an excellent choice. It provides all the advanced features of the Wyze Cam v4 with a starter microSD card included, allowing you to begin recording immediately.
  • Same 2.5K QHD resolution and color night vision.
  • Motion-activated spotlight and siren.
  • Supports local recording with included 32GB card (expandable up to 512GB).
  • Wi-Fi 6 and smart assistant compatibility.
This bundle is perfect for users who want to experience the benefits of local recording and time lapse without purchasing the microSD card separately.
Wyze Bulb Cam: Security and Lighting with Local Storage Support
If you want a unique combination of security camera and smart lighting, the Wyze Bulb Cam is a versatile option that supports local video storage with microSD cards up to 256GB.
Highlights:
  • 2K HD Video with Color Night Vision: Clear video day and night.
  • Standard E26 Bulb Socket: Installs easily in most light fixtures.
  • Motion Detection & Instant Alerts: Stay informed of activity around your home.
  • Local Storage Support: Use microSD cards (8GB to 256GB) for continuous recording without subscription.
  • IP65 Weather Resistance: Suitable for outdoor use.
  • Two-Way Audio & Siren: Communicate and deter intruders remotely.
This camera is ideal for users who want to combine lighting and security in one device, with the added benefit of local storage for long-term recording. Wyze Bulb Cam installed Wyze Bulb Cam installed in an outdoor light fixture providing security and illumination
Why Choose Wyze for Long-Term Time Lapse and Continuous Recording?
Wyze offers a seamless ecosystem where cameras and microSD cards work together to provide reliable, subscription-free local storage. With options like the 128GB Wyze MicroSD Card and the advanced Wyze Cam v4, you can capture every moment in stunning detail, day or night, indoors or outdoors.
  • No Monthly Fees: Local recording means no recurring costs.
  • Expandable Storage: Support for microSD cards up to 512GB on Wyze Cam v4.
  • Easy Access: Playback footage anytime via the Wyze app or by removing the card.
  • Versatile Cameras: From plug-in to battery-powered and bulb cams, Wyze has a solution for every setup.
Summary of Recommended Products for Long-Term Time Lapse Recording
ProductStorage SupportResolutionKey FeaturesPrice (Starting)
Wyze MicroSD Card32GB, 128GB, 256GBN/AContinuous recording, time lapse$16.99 (128GB)
Wyze Cam v4Up to 512GB microSD2.5K QHDColor night vision, spotlight, Wi-Fi 6$35.98
Wyze Cam v4 + 32GB CardIncluded 32GB2.5K QHDSame as above + free microSD card$35.98
Wyze Bulb CamUp to 256GB microSD2K HDSecurity + smart lighting$49.98
Harness the power of Wyze’s microSD cards and cameras to create long-term time lapse recordings or continuous security footage with ease and affordability.
FeatureWyze MicroSD CardWyze Cam v4Wyze Cam v4 + FREE 32GB MicroSD CardWyze Bulb Cam
TypeAccessoryCameraCameraCamera
Storage Capacity32GB, 128GB, 256GB microSD variantsSupports microSD up to 512GBIncludes free 32GB microSD cardSupports local storage up to 256GB microSD
Price$8.99 (32GB), $16.99 (128GB), $29.99 (256GB)$35.98 (single), $107.94 (3-pack), etc.$35.98$49.98
Video ResolutionN/A2.5K QHD (2560x1440)2.5K QHD2K HD (2304x1296)
Night VisionN/AEnhanced Color Night VisionEnhanced Color Night VisionColor Night Vision + IR Night Vision
Weather ResistanceN/AIP65IP65IP65
Motion-Activated SpotlightN/AYesYesNo
Continuous Local RecordingYes (with Wyze Cam)YesYesYes
Wi-Fi SupportN/AWi-Fi 6Wi-Fi 62.4 GHz b/g/n
Audio FeaturesN/AEnhanced Two-Way Talk, Built-in SirenEnhanced Two-Way TalkBuilt-in microphone, Two-way audio
Smart Assistant CompatibilityN/AAlexa, Google Assistant, IFTTTAlexa, Google AssistantN/A
Motion & Sound DetectionN/AYesYesMotion alerts
Storage TypemicroSD CardmicroSD CardmicroSD CardmicroSD Card
Subscription RequiredNoNoNoNo
Additional FeaturesEnables continuous recording & timelapseIP65 weather resistance, AI Auto-Zoom, SirenIncludes free 32GB microSD card2-in-1 camera and smart LED bulb, 160° FOV
What is the best microSD card size for long-term time lapse recording on Wyze Cam?The 128GB Wyze MicroSD Card is an ideal choice for long-term time lapse recording on Wyze Cam. It offers a perfect balance of storage capacity and affordability, allowing you to store several days of continuous video footage depending on your camera settings and resolution.
Does Wyze Cam v4 support continuous 24/7 recording without a subscription?Yes, Wyze Cam v4 supports continuous 24/7 recording directly to a microSD card, such as the Wyze 128GB MicroSD Card, with no monthly subscription fees required.
How do I access and playback footage recorded on a Wyze MicroSD Card?You can easily access and playback footage recorded on a Wyze MicroSD Card through the Wyze app or by removing the card from the camera and viewing it on your computer.
What is the maximum microSD card capacity supported by Wyze Cam v4?Wyze Cam v4 supports microSD cards up to 512GB, allowing for extended local storage of continuous or time lapse recordings.
Can I create time lapse videos with Wyze Cam and a microSD card?Yes, Wyze Cam allows you to create stunning time lapse videos by capturing footage directly to a microSD card. You can compress hours or days of video into seconds for creative projects.
Is the Wyze MicroSD Card compatible with all Wyze cameras?The Wyze MicroSD Card is compatible with most Wyze Cams that have a microSD card slot, including Wyze Cam v4 and Wyze Bulb Cam.
What are the benefits of using local storage with Wyze cameras?Using local storage with Wyze cameras provides continuous recording without monthly fees, easy access to footage, and the ability to expand storage up to 512GB (on Wyze Cam v4).
What features does Wyze Cam v4 offer for security and time lapse recording?Wyze Cam v4 features 2.5K QHD resolution, enhanced color night vision, IP65 weather resistance, motion-activated spotlight and siren, Wi-Fi 6 support, advanced audio, and smart features like AI tracking and motion detection zones.
Is there a Wyze Cam bundle that includes a free microSD card?Yes, the Wyze Cam v4 + FREE 32GB MicroSD Card bundle includes all the advanced features of Wyze Cam v4 and a starter 32GB microSD card, so you can begin recording immediately.
Can Wyze Bulb Cam record video locally to a microSD card?Yes, Wyze Bulb Cam supports local video storage with microSD cards up to 256GB, enabling continuous recording and time lapse without a subscription.
What makes Wyze a good choice for long-term time lapse and continuous recording?Wyze offers a seamless ecosystem with cameras and microSD cards designed for reliable, subscription-free local storage, expandable storage options, easy access to footage, and versatile camera models for every setup.
What are the benefits of using the Wyze MicroSD Card with my Wyze Cam?How do I set up the Wyze Cam v4 for long-term recording?Do you have any deals, ongoing sales, discounts, or promotions?
