Extended Event Detection on Wyze Pan Cam with 128GB MicroSD
Extended Event Detection with Wyze Cam Pan v3 and 128GB Wyze MicroSD Card
For those looking to enhance their home security with extended event detection and ample local storage, the Wyze Cam Pan v3 paired with the 128GB Wyze MicroSD Card offers a powerful and reliable solution. This combination unlocks continuous recording capabilities and advanced motion detection features, ensuring you never miss a moment.
Wyze Cam Pan v3: 360° Coverage with Smart Detection
The Wyze Cam Pan v3 is a versatile indoor/outdoor security camera designed to keep your property safe with comprehensive coverage and smart features:
  • 360° Pan and 180° Tilt: Complete room or outdoor area coverage with smooth pan and tilt controls.
  • IP65 Weather Resistant: Built to withstand rain, snow, and harsh weather conditions, making it perfect for outdoor use.
  • 2.5K HD Video Resolution: Crisp and clear video quality to capture fine details.
  • Motion Detection & Alerts: Detects movement and sends instant notifications to your phone.
  • Local Storage Support: Compatible with microSD cards up to 512GB for continuous local recording.
  • Two-Way Audio: Communicate through the camera with built-in microphone and speaker.
  • Requires Wyze Outdoor Power Adapter (sold separately) for outdoor power needs.
With the Wyze Cam Pan v3, you get a flexible security camera that can monitor wide areas with precision and reliability.
Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3 weather resistant for outdoor use
Wyze MicroSD Card 128GB: Unlock Continuous Recording
The Wyze MicroSD Card is the perfect accessory to maximize your Wyze Cam Pan v3’s potential:
  • 128GB Storage Capacity: Store hours of continuous video footage locally without worrying about running out of space.
  • Continuous Local Recording: Enables 24/7 recording directly to the microSD card, no subscription required.
  • Time Lapse and Event Recording: Capture timelapse videos and motion-triggered events seamlessly.
  • Easy Playback: Access recorded footage anytime via the Wyze app or by removing the card to view on your computer.
  • Affordable and Reliable: Designed specifically for Wyze cameras to ensure compatibility and performance.
Adding a 128GB Wyze MicroSD Card to your Wyze Cam Pan v3 means extended event detection and uninterrupted video storage, ideal for comprehensive home security.
Why Choose This Setup?
  • No Monthly Fees: Local storage means no recurring cloud subscription costs.
  • Extended Event Detection: With continuous recording, you can review any event at any time.
  • Robust Outdoor Performance: The Pan v3’s weather resistance combined with local storage makes it perfect for outdoor monitoring.
  • Easy Installation and Use: Simply insert the microSD card, configure your settings in the Wyze app, and start recording.
Additional Compatible Wyze Cameras with 128GB MicroSD Card Support
If you want to explore other Wyze cameras that support extended event detection with microSD cards, consider the Wyze Cam v4:
Wyze Cam v4: Advanced Wired Security Camera
  • 2.5K QHD Resolution: High-definition video with wide dynamic range for balanced lighting.
  • Enhanced Color Night Vision: See vivid colors even in low light.
  • Motion-Activated Spotlight: Automatically lights up when motion is detected.
  • Wi-Fi 6 Support: Faster and more reliable wireless connectivity.
  • Local Storage: Supports microSD cards up to 512GB for continuous recording.
  • Smart Features: Person detection, sound detection, motion zones, and smoke/CO alerts.
  • Weather Resistant (IP65): Suitable for indoor and outdoor use with an outdoor power adapter.
The Wyze Cam v4 is a wired camera option for those who want advanced features and extended local storage capabilities.
Summary
For extended event detection on the Wyze Cam Pan v3, pairing it with the 128GB Wyze MicroSD Card is the ideal choice. This setup provides continuous local recording, smart motion detection, and reliable outdoor performance without monthly fees. For wired camera enthusiasts, the Wyze Cam v4 also supports 128GB microSD cards and offers enhanced video quality and smart alerts. Invest in the Wyze MicroSD Card to unlock the full potential of your Wyze cameras and enjoy peace of mind with comprehensive, extended event detection. Two-way audio feature with Wyze camera Communicate easily with two-way audio on Wyze cameras
FeatureWyze MicroSD CardWyze Cam Pan v3Wyze Cam v4
TypeStorage AccessorySecurity CameraSecurity Camera
Price Range$8.99 - $29.99$39.98 - $114.94$35.98 - $107.94
Storage Capacity32GB, 128GB, 256GBSupports up to 256GB microSDSupports up to 512GB microSD
ResolutionN/A1080p (1920 x 1080)2.5K QHD (2560 x 1440)
Field of View (FOV)N/A120°DFOV 115.8°, HFOV 98.5°, VFOV 53.1°
Night VisionN/A4 IR LEDs (850 nm), Color Night Vision4 IR LEDs (850 nm) + 2 white spotlight LEDs, Color Night Vision
Weather ResistanceN/AIP65IP65
AudioN/ABuilt-in speaker and microphone, 2-way audio, Noise & Echo cancellation99dB waterproof speaker, 2-way talk, built-in siren, noise & echo cancellation
ConnectivityN/A802.11 b/g/n 2.4GHz Wi-Fi (no 5GHz)2.4 GHz Wi-Fi, Wi-Fi 6
PowerN/A5V/2000mA adapter5V/1A adapter
DimensionsN/A124mm (H) x 60mm (W) x 63mm (D)2in x 2in x 2 3/8in
WeightN/A11.29 oz (320 g)0.49 lb (222 g)
Mounting OptionsN/AScrew 1/4" - 20 mountStand, Wall mount, Ceiling mount, Magnetic wall mount (adhesive)
Video EncodingN/AH.264H.264
Video FPSN/ADaytime 20 fps / Nighttime 15 fpsDaytime 20 FPS / Nighttime 15 FPS
ZoomN/A8x digital zoom8x digital zoom
Smart FeaturesN/APush notificationsMotion & sound detection, motion detection zones, smoke & CO alerts, AI auto-zoom with smart focus
IntegrationsN/AAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Operating TemperatureN/A-4°F to 122°F (-20°C to 50°C)-4°F to 122°F (-20°C to 50°C)
WarrantyN/A1 Year1 Year
Additional FeaturesMicroSD cards for local recording360° pan, 180° tilt, indoor/outdoor useIP65 weather resistance, motion-activated spotlight, built-in siren, Wi-Fi 6 support, continuous local recording
What are the benefits of using a Wyze Cam Pan v3 with a 128GB Wyze MicroSD Card?Pairing the Wyze Cam Pan v3 with a 128GB Wyze MicroSD Card enables continuous 24/7 local recording, advanced motion detection, and extended event detection without monthly subscription fees. This setup ensures you never miss important moments and provides ample storage for video footage.
Does the Wyze Cam Pan v3 support continuous recording?Yes, the Wyze Cam Pan v3 supports continuous recording when paired with a compatible microSD card, such as the 128GB Wyze MicroSD Card. This allows for uninterrupted video storage directly on the device.
How much video footage can a 128GB Wyze MicroSD Card store?A 128GB Wyze MicroSD Card can store hours of continuous video footage, depending on the camera’s resolution and recording settings. It is ideal for extended event detection and long-term local storage.
Is the Wyze Cam Pan v3 suitable for outdoor use?Yes, the Wyze Cam Pan v3 is IP65 weather resistant, making it suitable for both indoor and outdoor use. For outdoor installation, it requires the Wyze Outdoor Power Adapter, which is sold separately.
What video quality does the Wyze Cam Pan v3 offer?The Wyze Cam Pan v3 provides 2.5K HD video resolution, delivering crisp and clear footage to capture fine details in your recordings.
Can I use the Wyze Cam Pan v3 without a subscription?Yes, you can use the Wyze Cam Pan v3 without a subscription by utilizing local storage with a microSD card. This allows for continuous recording and event detection without recurring fees.
How do I access recorded footage from my Wyze Cam Pan v3?You can access recorded footage anytime through the Wyze app or by removing the microSD card and viewing the files on your computer.
What is the maximum microSD card size supported by Wyze Cam Pan v3?The Wyze Cam Pan v3 supports microSD cards up to 512GB, allowing for even more extended local video storage.
Are there other Wyze cameras that support 128GB microSD cards for extended event detection?Yes, the Wyze Cam v4 also supports microSD cards up to 512GB, including 128GB cards, and offers advanced features like 2.5K QHD resolution, color night vision, and smart alerts.
What smart features does the Wyze Cam Pan v3 offer?The Wyze Cam Pan v3 features 360° pan and 180° tilt for full coverage, motion detection with instant alerts, two-way audio, and compatibility with local storage for continuous recording.
Is the Wyze MicroSD Card reliable for continuous recording?Yes, the Wyze MicroSD Card is designed specifically for Wyze cameras, ensuring compatibility and reliable performance for continuous 24/7 recording.
Do I need a special power adapter for outdoor use of the Wyze Cam Pan v3?Yes, for outdoor use, the Wyze Cam Pan v3 requires the Wyze Outdoor Power Adapter, which is sold separately.
What are the benefits of using the Wyze MicroSD Card with the Wyze Cam Pan v3?Can you explain how to set up the Wyze MicroSD Card for continuous recording?Do you have any deals, ongoing sales, discounts, or promotions?
