Wyze Compatible 32GB MicroSDHC Card for Extended Video Storage
Extended Video Storage with Wyze Compatible 32GB MicroSDHC Card
When it comes to enhancing your Wyze camera system with extended video storage, the Wyze MicroSD Card is the perfect companion. Designed specifically for Wyze devices, this memory card unlocks continuous local recording and time lapse features, allowing you to capture every moment without worrying about running out of space. Whether you are using a 32GB microSDHC card or opting for larger capacities, Wyze’s memory cards provide reliable, high-speed storage tailored for your home security needs.
Wyze MicroSD Card: Reliable Storage for Wyze Cameras
The Wyze MicroSD Card is engineered to seamlessly integrate with Wyze cameras, including the popular Wyze Cam v4 and Wyze v3 models. Here’s why it stands out:
  • Capacity Options: Available in 32GB microSDHC, 128GB, and 256GB microSDXC variants to suit different storage needs.
  • Continuous Local Recording: Enables 24/7 video capture directly on the card without monthly fees.
  • Time Lapse & Playback: Create stunning time lapse videos and easily access footage via the Wyze app or by removing the card.
  • Class 10 Speed: Ensures smooth video recording and playback with fast read/write speeds.
  • Compatibility: Works flawlessly with most Wyze cameras that have a microSD card slot.
Unlock powerful camera features and enjoy free local storage with no subscription required.
Wyze Cam v4 + FREE 32GB MicroSD Card: Ultimate Security Bundle
Wyze Cam v4 in Home Setting Alt text: Wyze Cam v4 installed indoors providing home security The Wyze Cam v4 bundle includes a free 32GB Wyze MicroSDHC card, making it an excellent choice for users seeking high-quality video and reliable storage in one package.
Key Features of Wyze Cam v4:
  • 2.5K QHD Resolution: Crystal-clear video quality for detailed monitoring.
  • Enhanced Color Night Vision: See vibrant colors even in low-light conditions.
  • Motion-Activated Spotlight: Adds an extra layer of security by illuminating detected motion.
  • Wi-Fi 6 Support: Stronger, more reliable connection for uninterrupted streaming.
  • 24/7 Local Recording: Continuous video capture on the included 32GB microSD card.
  • Smart Alerts: Motion and sound detection with customizable zones.
  • Voice Assistant Compatibility: Works with Alexa and Google Assistant for hands-free control.
This bundle is perfect for those who want a plug-and-play solution with extended video storage right out of the box.
Wyze v3 Bundle: Trusted Performance with Included 32GB MicroSD Card
The Wyze v3 Bundle offers a pair of Wyze Cam v3 cameras, each equipped with a 32GB Wyze MicroSDHC card, ideal for users who want to monitor multiple areas with dependable video storage.
Highlights of Wyze v3 Cameras:
  • 1080p Full HD Video: Clear and sharp video quality.
  • Color Night Vision: See more details in the dark with four IR LEDs.
  • 360° Horizontal & 180° Vertical View: Wide coverage with a 121° diagonal field of view.
  • Weather Resistant (IP65): Suitable for indoor and outdoor use.
  • Local Storage: Each camera supports 32GB microSDHC cards for continuous recording.
  • Motion Tracking & Two-Way Audio: Follow movement and communicate through the camera.
  • Easy Installation: Comes with mounting kits and outdoor-rated USB cables.
This bundle is a great starter pack for home security enthusiasts who want reliable video storage and versatile camera features.
Why Choose Wyze MicroSD Cards for Your Wyze Cameras?
Using a Wyze-compatible microSD card ensures optimal performance and compatibility with your Wyze devices. Here’s why the Wyze MicroSD Card is the best choice:
  • Guaranteed Compatibility: Tested and approved for Wyze cameras.
  • Affordable Pricing: Starting at just $8.99 for 32GB.
  • No Subscription Fees: Local storage means no ongoing costs.
  • Easy Setup: Simply insert the card and configure recording settings in the Wyze app.
  • Access Anytime: Playback footage directly from the app or by removing the card.
Enhance Your Home Security with Wyze and Extended Storage
Pairing your Wyze cameras with the Wyze MicroSD Card unlocks the full potential of your home security system. Whether you choose the compact 32GB card for basic needs or larger capacities for extended recording, Wyze offers a seamless, cost-effective solution to keep your home safe and monitored around the clock.
Additional Lifestyle Image
Wyze Duo Cam Doorbell Lifestyle Alt text: Wyze Duo Cam Doorbell installed on a home exterior, showcasing smart home security
Summary of Wyze Products for Extended Video Storage
Wyze MicroSD Card Unlock continuous recording and time lapse features for Wyze cameras. Available in 32GB, 128GB, and 256GB sizes. Wyze Cam v4 + FREE 32GB MicroSD Card High-resolution 2.5K QHD camera with enhanced night vision and included 32GB card for local recording. Wyze v3 Bundle Two 1080p cameras with color night vision and 32GB microSD cards included for continuous local recording.
Enhance your Wyze camera experience today with the perfect 32GB microSDHC card designed for extended video storage and uninterrupted security monitoring.
FeatureWyze MicroSD CardWyze Cam v4 + FREE 32GB MicroSD CardWyze v3 Bundle
Product TypeAccessory (MicroSD Card)Camera Bundle (Wyze Cam v4 + 32GB MicroSD Card)Camera Bundle (2x Wyze Cam v3 + MicroSD Cards)
Storage Options32GB microSDHC, 128GB microSDXC, 256GB microSDXCIncludes 32GB MicroSD CardIncludes 32GB MicroSDHC Memory Card
Price$8.99 (32GB), $16.99 (128GB), $29.99 (256GB)$35.98$92.94
Camera ResolutionN/A2.5K QHD (2560x1440)1080p (1920x1080)
Night VisionN/AEnhanced Color Night VisionColor Night Vision (4 IR LEDs, 850 nm)
Video FPSN/ADaytime 20 FPS / Nighttime 15 FPSDaytime 20 FPS / Nighttime 15 FPS
Local RecordingYes (with MicroSD card)Yes, 24/7 local recordingYes, local recording
Storage Capacity SupportedUp to 256GBUp to 512GB microSD card32GB included (Class 10, UHS-1)
ConnectivityN/AWi-Fi 6, 2.4 GHz Wi-FiWired connection
Additional FeaturesContinuous recording, time lapseMotion-activated spotlight, Wi-Fi 6, Alexa/Google Assistant compatibility, smoke & CO alerts360° horizontal, 180° vertical view, motion tracking, two-way audio
Included AccessoriesMicroSD Card onlyWyze Cam v4, 32GB MicroSD Card, power adapter, mounts2x Wyze Cam v3, 32GB MicroSD Cards, power adapters, mounting kits, cables
WeightN/A0.49 lb (222 g)11.29 oz (320 g) per camera
DimensionsN/A2in x 2in x 2 3/8in124mm x 60mm x 63mm
WarrantyNot specified1 YearNot specified
What is the Wyze MicroSD Card and how does it enhance Wyze cameras?The Wyze MicroSD Card is a memory card designed specifically for Wyze cameras, enabling continuous local video recording and time lapse features. It allows you to capture and store footage directly on the card, providing extended video storage without monthly subscription fees.
Which Wyze cameras are compatible with the Wyze MicroSD Card?The Wyze MicroSD Card is compatible with most Wyze cameras that have a microSD card slot, including popular models like the Wyze Cam v4 and Wyze Cam v3.
What storage capacities are available for Wyze MicroSD Cards?Wyze MicroSD Cards are available in 32GB microSDHC, 128GB, and 256GB microSDXC variants, allowing you to choose the right capacity for your video storage needs.
Does the Wyze MicroSD Card support continuous 24/7 recording?Yes, the Wyze MicroSD Card enables 24/7 continuous local recording on compatible Wyze cameras, so you can capture every moment without worrying about running out of space.
Is a subscription required to use local storage with Wyze MicroSD Cards?No, using a Wyze MicroSD Card for local storage does not require any subscription fees. You can record and access your footage for free.
What are the benefits of using a Wyze MicroSD Card over other memory cards?Wyze MicroSD Cards are tested and approved for optimal performance and compatibility with Wyze cameras. They offer reliable, high-speed storage, easy setup, and guaranteed compatibility, ensuring smooth video recording and playback.
What features are included in the Wyze Cam v4 + FREE 32GB MicroSD Card bundle?The Wyze Cam v4 bundle includes a high-resolution 2.5K QHD camera with enhanced color night vision, motion-activated spotlight, Wi-Fi 6 support, smart alerts, voice assistant compatibility, and a free 32GB Wyze MicroSDHC card for continuous local recording.
What is included in the Wyze v3 Bundle for video storage?The Wyze v3 Bundle includes two Wyze Cam v3 cameras, each with a 32GB Wyze MicroSDHC card. The cameras feature 1080p full HD video, color night vision, wide field of view, weather resistance, motion tracking, two-way audio, and easy installation.
How do I set up local recording with a Wyze MicroSD Card?To set up local recording, simply insert the Wyze MicroSD Card into your Wyze camera’s microSD card slot and configure the recording settings in the Wyze app. You can then access and playback footage directly from the app or by removing the card.
What is the price of the Wyze MicroSD Card?The Wyze MicroSD Card is affordably priced, starting at just $8.99 for the 32GB version.
Can I use the Wyze MicroSD Card for time lapse videos?Yes, the Wyze MicroSD Card supports time lapse video creation on compatible Wyze cameras, allowing you to capture and review extended events in a condensed format.
Is the Wyze MicroSD Card suitable for both indoor and outdoor cameras?Yes, the Wyze MicroSD Card is suitable for use with both indoor and outdoor Wyze cameras, such as the weather-resistant Wyze Cam v3.
What are the different capacity options available for the Wyze MicroSD Card?How does the Wyze MicroSD Card enhance the functionality of Wyze cameras?Is there a warranty for the Wyze MicroSD Card?
