Recording Continuous Video on a MicroSD Card with Wyze Cam v4
If you're looking to record continuous video for more than a day on a microSD card using the Wyze Cam v4, you're in the right place. Wyze Cam v4 offers advanced local recording capabilities that allow you to capture high-quality footage 24/7, making it ideal for home security, outdoor monitoring, or any situation where continuous surveillance is needed.
Wyze Cam v4: Powerful 24/7 Local Recording
Crystal-Clear 2.5K QHD Resolution
Wyze Cam v4 delivers stunning 2.5K QHD (2560x1440) video resolution, ensuring every detail is captured with clarity. Whether it's daytime or nighttime, the camera’s wide dynamic range (WDR) and enhanced color night vision provide vibrant, clear footage.
Continuous Local Recording on MicroSD
The camera supports continuous local recording directly to a microSD card, allowing you to store hours of video without interruption. It supports microSD cards up to 512GB, which can hold days of footage depending on your recording settings.
Motion-Activated Spotlight & Night Vision
Wyze Cam v4 features a motion-activated spotlight and 4 IR LEDs plus 2 white spotlight LEDs for color night vision, ensuring clear video even in low-light conditions.
Smart Features & Compatibility
With Wi-Fi 6 support and compatibility with Alexa, Google Assistant, and IFTTT, you can easily integrate Wyze Cam v4 into your smart home ecosystem. Two-way audio, a built-in siren, and noise echo cancellation add to its security features.
MicroSD Card Slot & Storage
The camera requires a microSD card for continuous recording. Using a high-capacity card (like 128GB or 256GB) allows for extended recording times, making it perfect for recording more than a day continuously.
Wyze Cam v4 Outdoor Bundle: Complete Security Solution
What’s Included?
The Wyze Cam v4 Outdoor Bundle comes with the Wyze Cam v4, a Wyze Outdoor Power Adapter, and a 128GB Wyze MicroSD Card. This bundle is designed for outdoor use with weather resistance (IP65) and wired power for uninterrupted recording.
24/7 Local Recording with Included MicroSD
The included 128GB microSD card supports continuous local recording, capable of storing approximately 192 hours (8 days) of HD video. This makes it ideal for users who want to record continuously without worrying about running out of storage.
Enhanced Color Night Vision & Motion Spotlight
The outdoor bundle’s camera features enhanced color night vision and a motion-activated spotlight, providing clear and colorful footage even in complete darkness.
Wi-Fi 6 & Smart Home Integration
Enjoy fast and reliable Wi-Fi 6 connectivity and seamless integration with Alexa and Google Assistant for voice control and smart home automation.
"Keep your home safe day and night with continuous, high-quality video recording and smart alerts."
Wyze Cam v4 Outdoor Bundle in action with night vision and spotlight
Wyze Cam v4 Home Security Bundle: Enhanced Features for Extended Recording
All-in-One Security Package
This bundle includes the Wyze Cam v4 with a 128GB Class 10 UHS-3 microSD card, optimized for continuous HD video recording. The card supports up to 192 hours of HD footage, perfect for recording more than a day without interruption.
Advanced Video & Audio
- 2.5K QHD video resolution
- Enhanced color night vision with IR and spotlight LEDs
- Improved two-way audio for clear communication
- Built-in siren for added security
Flexible Mounting & Weather Resistance
Mount indoors or outdoors with multiple mounting options and IP65 weather resistance, ensuring reliable performance in various environments.
Smart Detection & Alerts
Person detection, motion-activated spotlight, and smoke/CO alerts keep you informed in real-time.
Wyze Cam v4 + FREE 32GB MicroSD Card: Budget-Friendly Continuous Recording
Affordable Continuous Recording Solution
This package includes the Wyze Cam v4 and a free 32GB microSD card, enabling continuous local recording right out of the box. While 32GB offers less storage than larger cards, it still supports several hours of continuous video, ideal for shorter-term monitoring.
Key Features
- 2.5K QHD resolution with color night vision
- Motion-activated spotlight and person detection
- Wi-Fi 6 support and smart home compatibility
- Requires outdoor power adapter for wired operation
Wyze MicroSD Cards: Unlock Extended Continuous Recording
Expand Your Storage
Wyze offers microSD cards in 32GB, 128GB, and 256GB sizes designed specifically for Wyze cameras. These cards unlock continuous recording and time-lapse features, allowing you to customize your storage needs.
Features
- Continuous local recording support
- Timeline controls and calendar view for easy footage navigation
- High-speed read/write for smooth video capture
Using a 128GB or 256GB microSD card with your Wyze Cam v4 can provide days of continuous recording, perfect for users who want to monitor their property without frequent card changes.
Summary: Best Wyze Cam v4 Options for Continuous Video Recording
Product | MicroSD Card Included | Max MicroSD Support | Continuous Recording Capacity | Price Range |
Wyze Cam v4 Outdoor Bundle | 128GB Included | Up to 512GB | ~192 hours (8 days) | $69.99 |
Wyze Cam v4 Home Security Bundle | 128GB Included | Up to 512GB | ~192 hours (8 days) | $169.99 |
Wyze Cam v4 + FREE 32GB Card | 32GB Included | Up to 512GB | Several hours | $35.98 |
Wyze Cam v4 (Standalone) | No | Up to 512GB | Depends on microSD card | $100.00 |
Wyze MicroSD Cards | N/A | 32GB, 128GB, 256GB | Varies by card size | $8.99 - $29.99 |
With Wyze Cam v4 and the right microSD card, you can confidently record continuous video for more than a day, ensuring your home or business stays secure with crystal-clear footage day and night.
Peace of mind with Wyze Cam v4 continuous recording
Why Choose Wyze Cam v4 for Continuous Video Recording?
- High-resolution 2.5K QHD video captures every detail
- Supports large microSD cards up to 512GB for extended recording
- 24/7 local recording without subscription fees
- Enhanced color night vision and motion-activated spotlight
- Robust smart home integration with Alexa and Google Assistant
- Weather-resistant design for indoor and outdoor use
- Affordable bundles with included microSD cards for immediate use
By selecting the Wyze Cam v4 with an appropriate microSD card, you can easily achieve continuous video recording for more than a day, making it a top choice for reliable, high-quality home security.
How do I record continuous video on a microSD card with Wyze Cam v4?
To record continuous video with Wyze Cam v4, simply insert a compatible microSD card (up to 512GB) into the camera. In the Wyze app, enable continuous recording in the camera settings. The camera will then record 24/7 footage directly to the microSD card, allowing you to capture every moment without interruption.What is the maximum microSD card size supported by Wyze Cam v4?
Wyze Cam v4 supports microSD cards up to 512GB in capacity. Using a larger card allows for extended continuous video recording, making it ideal for long-term surveillance needs.How many days of continuous video can I store on a 128GB microSD card with Wyze Cam v4?
A 128GB microSD card can store approximately 192 hours (8 days) of HD continuous video footage with Wyze Cam v4. Actual storage time may vary depending on video quality settings and motion activity.Does Wyze Cam v4 support color night vision for continuous recording?
Yes, Wyze Cam v4 features enhanced color night vision with 4 IR LEDs and 2 white spotlight LEDs. This ensures clear, colorful footage even in low-light or nighttime conditions during continuous recording.What is included in the Wyze Cam v4 Outdoor Bundle?
The Wyze Cam v4 Outdoor Bundle includes the Wyze Cam v4, a Wyze Outdoor Power Adapter, and a 128GB Wyze MicroSD Card. This bundle is designed for outdoor use with weather resistance (IP65) and supports 24/7 continuous local recording.Can I use Wyze Cam v4 outdoors for continuous video recording?
Yes, Wyze Cam v4 is IP65 weather-resistant and can be used both indoors and outdoors. With a compatible outdoor power adapter and microSD card, you can achieve uninterrupted continuous video recording in various environments.What smart home integrations are available with Wyze Cam v4?
Wyze Cam v4 supports integration with Alexa, Google Assistant, and IFTTT. It also features Wi-Fi 6 connectivity for fast and reliable performance, making it easy to add to your smart home ecosystem.What are the benefits of using a Wyze MicroSD card with Wyze Cam v4?
Wyze MicroSD cards are designed for high-speed, reliable video capture and support continuous local recording and time-lapse features. Available in 32GB, 128GB, and 256GB sizes, they allow you to customize your storage needs for extended recording.Is a subscription required for continuous video recording on Wyze Cam v4?
No subscription is required for continuous video recording on Wyze Cam v4. All footage is stored locally on the microSD card, allowing you to record 24/7 without any monthly fees.What is the video resolution of Wyze Cam v4 for continuous recording?
Wyze Cam v4 records in stunning 2.5K QHD (2560x1440) resolution, ensuring crystal-clear footage for both daytime and nighttime continuous video recording.How does the motion-activated spotlight work on Wyze Cam v4?
Wyze Cam v4 features a motion-activated spotlight that automatically turns on when motion is detected, enhancing visibility and providing clear, colorful footage even in complete darkness.What is the difference between the Wyze Cam v4 bundles for continuous recording?
Wyze Cam v4 is available in several bundles: the Outdoor Bundle (includes a 128GB microSD card and outdoor power adapter), the Home Security Bundle (includes a 128GB Class 10 UHS-3 microSD card), and a budget-friendly option with a free 32GB microSD card. Each bundle is optimized for different recording durations and environments.Can I upgrade the microSD card in my Wyze Cam v4 for longer continuous recording?
Yes, you can upgrade to a higher-capacity microSD card (up to 512GB) in your Wyze Cam v4 to extend the duration of continuous video recording without needing to frequently change or overwrite the card.Does Wyze Cam v4 offer two-way audio and a built-in siren for security?
Yes, Wyze Cam v4 features improved two-way audio for clear communication and a built-in siren to enhance your home security setup.How do I view and manage recorded footage on my Wyze Cam v4 microSD card?
You can view and manage recorded footage using the Wyze app, which offers timeline controls and a calendar view for easy navigation of your continuous video recordings stored on the microSD card.
