Wyze microSD Card Storage Capacities for Wyze Cam v4
When choosing a Wyze Cam v4 for your home or outdoor security needs, understanding the microSD card storage capacities compatible with these cameras is essential. Wyze Cam v4 supports local storage via microSD cards, allowing continuous or event-based recording without relying solely on cloud subscriptions. This guide highlights the storage options and capacities for Wyze Cam v4 models and bundles, helping you select the right setup for your security system.
Wyze Cam v4: Storage and Capacity Overview
The Wyze Cam v4 is a versatile security camera designed for both indoor and outdoor use, featuring advanced video quality and smart features.
microSD Card Compatibility and Capacity
- Supports microSD cards up to 512 GB in capacity.
- Requires a microSD card for local storage; cloud storage is available with a subscription plan.
- Compatible microSD cards should ideally be Class 10 or UHS-3 (U3) for optimal performance.
- Local storage enables 24/7 continuous recording or event-triggered video capture.
Key Features Supporting Storage
- Video resolution: 2.5K QHD (2560x1440) for crystal-clear footage.
- Video encoding: H.264 format ensures efficient compression.
- Video frame rates: 20 FPS during daytime, 15 FPS at night.
- Wide Dynamic Range (WDR) and enhanced color night vision improve video clarity in various lighting conditions.
- Supports motion-activated spotlight and person detection to optimize recording events.
Physical and Technical Specs
- Dimensions: 2in x 2in x 2 3/8in; weight: 0.49 lb (222 g).
- Mounting options include stand, wall mount, ceiling mount, and magnetic adhesive mount.
- Weather resistance rating: IP65, suitable for outdoor environments.
- Connectivity: Supports Wi-Fi 6 and Bluetooth 5.2.
- Compatible with Alexa, Google Assistant, and IFTTT integrations.
The Wyze Cam v4’s support for up to 512 GB microSD cards means you can store hundreds of hours of high-quality video locally, giving you peace of mind without monthly fees.
Wyze Cam v4 providing reliable outdoor security with local storage
Wyze Cam v4 Outdoor Bundle: Enhanced Storage and Power
The Wyze Cam v4 Outdoor Bundle is tailored for users who want a complete outdoor security solution with local storage included.
Included microSD Card and Storage Details
- Comes with a 128 GB Wyze MicroSD card included.
- Supports continuous 24/7 local recording on the included microSD card.
- The 128 GB card can store approximately several days to weeks of footage, depending on recording settings.
- Supports motion and sound detection with customizable motion detection zones.
Additional Features
- Enhanced Color Night Vision and motion-activated spotlight for clear night footage.
- Wired power source with included Wyze Outdoor Power Adapter.
- Wi-Fi 6 support for faster and more reliable connectivity.
- Compatible with Alexa and Google Assistant for voice control.
This bundle is perfect for users who want an out-of-the-box solution with local storage ready to go, eliminating the need to purchase a microSD card separately.
Wyze Cam v4 Home Security Bundle: Optimized Storage Performance
For those seeking a comprehensive security setup, the Wyze Cam v4 Home Security Bundle offers advanced features and optimized storage capabilities.
microSD Card Storage Specifications
- Includes support for a 128 GB microSD card (Class 10 and UHS-3 recommended).
- Storage capacity on 128 GB card:
- Approximately 11,520 minutes (192 hours) of HD video.
- Up to 40,320 minutes (672 hours) of SD video.
- Can store around 16,800 16MP photos.
- Read speed: 31 MB/s; write speed: 12 MB/s, ensuring smooth video recording without lag.
Enhanced Security Features
- Motion-activated spotlight and person detection for precise event recording.
- Improved 2-way audio for clear communication.
- Weather resistance rated IP65 for indoor/outdoor use.
- Multiple mounting options and compact design.
The Home Security Bundle is ideal for users who want extended local storage with high-speed microSD card performance, ensuring no moment is missed.
Additional Wyze Cam v4 Options with microSD Storage
Wyze Cam v4 + FREE 32GB MicroSD Card
- Comes with a free 32 GB microSD card included.
- Supports unlimited video length storage with microSD.
- Ideal for users starting with basic local storage needs.
- Features include 2.5K QHD resolution, color night vision, and motion-activated spotlight.
Why Choose Wyze Cam v4 with microSD Storage?
- Local storage up to 512 GB means you control your video data without recurring cloud fees.
- High-resolution 2.5K QHD video ensures detailed footage.
- Multiple bundles offer microSD cards from 32 GB to 128 GB included, catering to different storage needs.
- Weatherproof design and versatile mounting options make it suitable for any environment.
- Integration with smart home assistants enhances convenience.
Investing in a Wyze Cam v4 with the right microSD card capacity ensures your home security system is both reliable and scalable.
Secure your home day and night with Wyze Cam v4’s advanced features
Summary of microSD Card Storage Capacities for Wyze Cam v4
Product Variant | microSD Card Included | Max Supported Capacity | Approximate Storage Time (128GB) |
Wyze Cam v4 (Standalone) | No | Up to 512 GB | Depends on card purchased separately |
Wyze Cam v4 Outdoor Bundle | Yes (128 GB) | Up to 512 GB | Several days to weeks of continuous video |
Wyze Cam v4 Home Security Bundle | Yes (128 GB) | Up to 512 GB | ~192 hours HD video, ~672 hours SD video |
Wyze Cam v4 + FREE 32GB MicroSD Card | Yes (32 GB) | Up to 512 GB | Basic local storage, unlimited video length |
Conclusion
Wyze Cam v4 offers flexible microSD card storage options, supporting cards up to 512 GB for extensive local video recording. Whether you choose the standalone camera or one of the bundles with included microSD cards, you can tailor your storage capacity to your security needs. With high-resolution video, color night vision, and smart detection features, Wyze Cam v4 ensures your home is monitored effectively day and night.
Wyze Cam v4 blends seamlessly into your home environment
This comprehensive overview helps you understand the microSD card storage capacities for Wyze Cam v4 and select the best option for your home security setup.
What is the maximum microSD card capacity supported by Wyze Cam v4?
Wyze Cam v4 supports microSD cards up to 512 GB in capacity, allowing for extensive local video storage without relying solely on cloud subscriptions.Which type of microSD card is recommended for Wyze Cam v4?
For optimal performance, it is recommended to use a Class 10 or UHS-3 (U3) microSD card with Wyze Cam v4.How much video footage can a 128 GB microSD card store on Wyze Cam v4?
A 128 GB microSD card can store approximately 11,520 minutes (192 hours) of HD video or up to 40,320 minutes (672 hours) of SD video on Wyze Cam v4, depending on your recording settings.Does Wyze Cam v4 support continuous 24/7 recording with a microSD card?
Yes, Wyze Cam v4 supports 24/7 continuous recording or event-based recording when a compatible microSD card is installed.Is a microSD card included with Wyze Cam v4 bundles?
Some Wyze Cam v4 bundles include a microSD card. The Outdoor Bundle and Home Security Bundle come with a 128 GB microSD card, while the Wyze Cam v4 + FREE 32GB MicroSD Card option includes a 32 GB card. The standalone camera does not include a microSD card.Can I use Wyze Cam v4 outdoors, and is the microSD card protected?
Yes, Wyze Cam v4 is rated IP65 for weather resistance, making it suitable for outdoor use. The microSD card slot is designed to be protected from the elements when the camera is properly installed.What video resolution does Wyze Cam v4 record at?
Wyze Cam v4 records video at 2.5K QHD (2560x1440) resolution, providing crystal-clear footage for both indoor and outdoor security.What are the benefits of using local microSD card storage with Wyze Cam v4?
Using local microSD card storage with Wyze Cam v4 allows you to store hundreds of hours of high-quality video without monthly cloud fees, giving you full control over your video data.How do I know which Wyze Cam v4 bundle is right for my storage needs?
Choose a bundle based on your storage requirements: the Outdoor and Home Security Bundles include a 128 GB microSD card for extended recording, while the Wyze Cam v4 + FREE 32GB MicroSD Card is ideal for basic local storage. All models support up to 512 GB microSD cards for maximum flexibility.Does Wyze Cam v4 support smart home integrations?
Yes, Wyze Cam v4 is compatible with Alexa, Google Assistant, and IFTTT, allowing for convenient smart home integration and voice control.
