20ft Wyze Cam USB Extension Cable for Tall Porch Ceilings
Extend Your Wyze Cam Setup with a 20ft USB Extension Cable
If you have a Wyze Cam mounted above a tall porch ceiling, the standard USB cable length might not be enough to reach your power source comfortably. The Wyze Cam USB Extension Cable - 20ft is the perfect accessory to solve this problem. Designed specifically for Wyze cameras, this 20-foot extension cable gives you the freedom to place your camera exactly where you need it without worrying about power limitations.
Key Features of the Wyze Cam USB Extension Cable - 20ft
  • Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto models.
  • Length: A generous 20 feet to cover high or distant mounting locations such as tall porch ceilings.
  • Easy Installation: Simply plug the extension cable between your Wyze Cam and power adapter to extend your reach.
  • Affordable and Reliable: Priced at $7.99, it’s a cost-effective solution to enhance your camera setup.
This cable is ideal for outdoor or indoor Wyze Cam installations where power outlets are far from the mounting spot, ensuring your camera stays powered without unsightly or unsafe cable stretching.
Enhance Your Outdoor Security with Wyze Cam v4 Outdoor Bundle
For those looking to secure their porch or outdoor areas with a high-quality camera, the Wyze Cam v4 Outdoor Bundle offers unmatched clarity and smart features. This bundle includes the Wyze Cam v4, an outdoor power adapter, and a 128GB microSD card for local recording.
Why Choose Wyze Cam v4 Outdoor Bundle?
  • Crystal-clear 2.5K QHD Resolution: Capture every detail with stunning clarity, perfect for monitoring your porch or yard.
  • Enhanced Color Night Vision: See vibrant colors even in low light, making nighttime monitoring more effective.
  • Motion-Activated Spotlight: Automatically lights up when motion is detected, deterring unwanted visitors.
  • Wi-Fi 6 Support: Ensures a stronger, more reliable connection even at greater distances.
  • 24/7 Local Recording: Continuous recording with the included microSD card, so you never miss a moment.
  • Smart Home Compatibility: Works with Alexa and Google Assistant for voice control and integration.
This bundle is perfect for mounting above a tall porch ceiling, especially when paired with the 20ft USB extension cable to ensure continuous power supply. Outdoor porch security camera in use Capture your porch with crystal-clear security.
Why a Long USB Extension Cable is Essential for Porch-Mounted Wyze Cams
Mounting a Wyze Cam above a tall porch ceiling can create challenges with power access. The Wyze Cam USB Extension Cable - 20ft solves this by providing:
  • Flexibility in Camera Placement: No need to compromise on camera angle or height due to cable length.
  • Neat and Safe Installation: Avoids stretching cables across walkways or outdoor areas, reducing tripping hazards.
  • Compatibility with Multiple Wyze Models: Future-proofs your setup if you upgrade or add more cameras.
Pairing this extension cable with the Wyze Cam v4 Outdoor Bundle ensures your security system is both powerful and practical.
"Say goodbye to short cables and enjoy the freedom of a 20ft cable." – Wyze Cam USB Extension Cable
Summary
For anyone looking to mount a Wyze Cam above a tall porch ceiling, the Wyze Cam USB Extension Cable - 20ft is an essential accessory that extends your camera’s reach without hassle. When combined with the Wyze Cam v4 Outdoor Bundle, you get a powerful, high-resolution security solution with enhanced night vision and smart features, all backed by reliable continuous power. Upgrade your home security setup today with these Wyze essentials designed for convenience, clarity, and peace of mind.
FeatureWyze Cam USB Extension Cable - 20ftWyze Cam v4 Outdoor Bundle
Product TypeAccessorySecurity Camera Bundle
Price$7.99 USD$69.99 USD
Cable Length20 ft USB extension cableIncludes 6-foot flat micro USB to USB-A cable (Wyze Cam v4)
CompatibilityWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoWyze Cam v4
Camera ResolutionN/A2.5K QHD (2560x1440)
Night VisionN/AEnhanced Color Night Vision
SpotlightN/AMotion-activated spotlight
RecordingN/A24/7 local recording with microSD card
Wi-Fi SupportN/AWi-Fi 6 support
Smart Home IntegrationN/ACompatible with Alexa and Google Assistant
Outdoor UseN/AYes (with included outdoor power adapter)
Return Policy30-day hassle-free returns30-day hassle-free returns
Included Items1x 20ft USB extension cable1x Wyze Cam v4, 1x Wyze Outdoor Power Adapter, 1x 128GB microSD Card
What is the Wyze Cam USB Extension Cable - 20ft used for?The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze Cam’s power supply, making it ideal for mounting cameras above tall porch ceilings or in locations far from power outlets.
Which Wyze Cam models are compatible with the 20ft USB Extension Cable?The 20ft USB Extension Cable is compatible with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto models.
How do I install the Wyze Cam USB Extension Cable?Installation is simple—just plug the extension cable between your Wyze Cam and the power adapter to extend your camera’s reach.
Why should I use a long USB extension cable for my porch-mounted Wyze Cam?A long USB extension cable allows flexible camera placement, ensures a neat and safe installation by avoiding stretched or exposed cables, and helps you mount your camera at the optimal height or angle without worrying about power access.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes a Wyze Cam v4, an outdoor power adapter, and a 128GB microSD card for continuous local recording.
What are the key features of the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle offers 2.5K QHD resolution, enhanced color night vision, a motion-activated spotlight, Wi-Fi 6 support, 24/7 local recording, and compatibility with Alexa and Google Assistant.
How does the Wyze Cam v4 Outdoor Bundle improve outdoor security?The Wyze Cam v4 Outdoor Bundle provides crystal-clear video quality, effective night vision, motion-activated lighting to deter intruders, and reliable continuous recording, making it ideal for monitoring porches and outdoor areas.
Can I use the 20ft USB extension cable with the Wyze Cam v4 Outdoor Bundle?Yes, the 20ft USB extension cable is fully compatible with the Wyze Cam v4 Outdoor Bundle, ensuring your camera stays powered even when mounted in high or distant locations.
How much does the Wyze Cam USB Extension Cable - 20ft cost?The Wyze Cam USB Extension Cable - 20ft is affordably priced at $7.99.
Is the Wyze Cam USB Extension Cable suitable for both indoor and outdoor use?Yes, the Wyze Cam USB Extension Cable - 20ft is ideal for both indoor and outdoor Wyze Cam installations, especially where power outlets are far from the mounting spot.
Can you tell me more about the installation process for the Wyze Cam USB Extension Cable?Is the Wyze Cam USB Extension Cable compatible with all Wyze Cam models?Are there any ongoing promotions or discounts available for the Wyze Cam products?
