20ft Wyze Cam USB Extension Cable for Easy Behind-Drape Setup
Extend Your Wyze Cam Setup with the 20ft USB Extension Cable
If you're looking to position your Wyze Cam behind thick drapes or in hard-to-reach spots without blocking the camera feed, the Wyze Cam USB Extension Cable - 20ft is the perfect solution. This accessory gives you the freedom to place your camera exactly where you need it, extending the reach of your existing USB cable by 20 feet.
Key Features of the Wyze Cam USB Extension Cable - 20ft
  • Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto models.
  • Length: A generous 20-foot cable length allows flexible placement behind thick curtains, inside cabinets, or across rooms without signal loss.
  • Easy Setup: Simply plug the extension cable between your Wyze Cam and its power source to instantly increase your camera’s range.
  • Affordable: Priced at just $7.99, it’s a cost-effective way to enhance your home security setup.
Say goodbye to short cables and enjoy the freedom of flexible camera placement without compromising your Wyze Cam’s video feed quality.
Enhance Your Security with Wyze Cam v4 Outdoor Bundle
For those who want a robust security solution that works indoors or outdoors, the Wyze Cam v4 Outdoor Bundle offers unmatched clarity and smart features. While the USB extension cable helps with flexible placement indoors, the v4 Outdoor Bundle is designed for versatile use, including outdoor monitoring.
Why Choose Wyze Cam v4 Outdoor Bundle?
  • Crystal-clear 2.5K QHD Resolution: Capture every detail with stunning clarity, perfect for monitoring your home’s exterior or interior.
  • Enhanced Color Night Vision: See vibrant colors even in low-light conditions, a significant upgrade over traditional night vision.
  • Motion-Activated Spotlight: Automatically lights up when motion is detected, deterring intruders and improving video quality.
  • Wi-Fi 6 Support: Enjoy a stronger, more reliable connection at greater distances.
  • 24/7 Local Recording: Continuous recording with a built-in microSD card slot ensures you never miss a moment.
  • Smart Home Compatibility: Works with Alexa and Google Assistant for voice control and automation.
This bundle includes the Wyze Cam v4, an outdoor power adapter, and a 128GB microSD card, making it a complete package for comprehensive home security.
Whole Home Security Starter Kit: All-in-One Protection
If you want a complete security solution that covers multiple areas of your home, the Whole Home Security Starter Kit is an excellent choice. It includes the Wyze Cam v4 along with other essential devices to keep your home safe.
What’s Inside the Starter Kit?
  • 1x Wyze Cam v4 for high-quality video monitoring.
  • 1x Wyze Video Doorbell v2 to monitor your front door.
  • 1x Wyze Home Monitoring Starter Kit for comprehensive security coverage.
Available in White, Grey, and Black, this kit offers a cohesive and stylish security system that integrates seamlessly with your Wyze ecosystem.
Additional Accessories for Wyze Cam USB Connectivity
To complement your Wyze Cam setup, consider these handy accessories:
Wyze L-Shaped Micro USB Adapter
  • Designed to work with Wyze Outdoor Power Adapter v1 or other Micro USB cables.
  • Ideal for use with Wyze Cam Pan v3 or Cam v3 Pro.
  • Helps with cable management and positioning in tight spaces.
Wyze Cam Pan v3 USB Cable
  • Replacement USB cable specifically for Wyze Cam Pan v3.
  • Ensures reliable power and data connection for your pan-and-tilt camera.
Practical Tips for Using USB Extension Cables with Wyze Cam
  • Avoid Signal Loss: Use high-quality USB extension cables like the official Wyze 20ft cable to maintain stable power and video feed.
  • Cable Routing: Run the cable discreetly behind drapes or along walls to keep your setup neat and unobtrusive.
  • Power Source: Ensure your power adapter is close enough or use an outdoor power adapter for outdoor cameras.
  • Camera Placement: Position your camera where it has a clear view but is protected from direct sunlight or harsh weather if used outdoors.
Home Security Camera Setup Behind Curtains Position your Wyze Cam discreetly behind thick drapes using the 20ft USB extension cable for optimal coverage without blocking the feed.
Conclusion
For anyone needing to extend the reach of their Wyze Cam behind thick drapes or in challenging locations, the Wyze Cam USB Extension Cable - 20ft is an essential accessory. Pair it with the powerful Wyze Cam v4 Outdoor Bundle or the comprehensive Whole Home Security Starter Kit for a versatile and reliable home security system. Additional accessories like the Wyze L-Shaped Micro USB Adapter and Wyze Cam Pan v3 USB Cable further enhance your setup, ensuring your cameras stay powered and connected no matter where you place them. Secure your home with flexible, high-quality Wyze solutions today!
Feature / ProductWyze Cam USB Extension Cable - 20ftWyze Cam v4 Outdoor BundleWhole Home Security Starter KitWyze L-Shaped Micro USB AdapterWyze Cam Pan v3 USB Cable
TypeAccessoriesBundleSecurity KitReplacement PartsReplacement Parts
Price$7.99$69.99$155.95$5.99$1.99
Description20ft USB extension cable for Wyze Cam modelsWyze Cam v4 + Outdoor Power Adapter + 128GB microSD1x Wyze Cam v4, 1x Wyze Video Doorbell v2, 1x Starter KitAdapter for Wyze Outdoor Power Adapter v1 or Micro USB cableReplacement USB cable for Wyze Cam Pan v3
Compatible DevicesWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoWyze Cam v4Wyze Cam v4, Wyze Video Doorbell v2, Home Monitoring KitWyze Cam Pan v3, Wyze Cam v3 Pro, Wyze Outdoor Adapter v1Wyze Cam Pan v3
Cable Length20ftIncluded 6ft micro USB to USB-A cableIncluded 6ft micro USB to USB-A cableN/A6" (1.8 m)
Key FeaturesExtends USB cable length2.5K QHD resolution, Enhanced Color Night Vision, Motion-activated spotlight, 24/7 local recording, Wi-Fi 6 supportComplete home security with camera, doorbell, and monitoring kitAllows outdoor power adapter to work with Pan v3 or v3 ProReplacement USB cable
WarrantyNot specified30-day hassle-free returnsNot specifiedNot specified30-day hassle-free returns
CollectionsShop All, Camera AccessoriesShop All, Sales, Deals, Security BundlesShop All, Security BundlesReplacement Parts, Shop All, Camera AccessoriesReplacement Parts, Shop All, Camera Accessories
What is the Wyze Cam USB Extension Cable - 20ft used for?The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze Cam’s power supply, allowing you to position your camera in hard-to-reach spots, behind thick drapes, or across rooms without losing signal quality.
Which Wyze Cam models are compatible with the 20ft USB Extension Cable?The 20ft USB Extension Cable is compatible with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto models.
How do I set up the Wyze Cam USB Extension Cable?Setup is simple—just plug the extension cable between your Wyze Cam and its power source to instantly increase your camera’s range by 20 feet.
Will using a 20ft USB extension cable affect my Wyze Cam’s video feed quality?No, the official Wyze 20ft USB extension cable is designed to maintain stable power and video feed quality, ensuring reliable camera performance even at extended distances.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes a Wyze Cam v4, an outdoor power adapter, and a 128GB microSD card, providing a complete package for indoor and outdoor security monitoring.
What are the key features of the Wyze Cam v4 Outdoor Bundle?Key features include 2.5K QHD resolution, enhanced color night vision, a motion-activated spotlight, Wi-Fi 6 support, 24/7 local recording, and compatibility with Alexa and Google Assistant.
What does the Whole Home Security Starter Kit include?The Whole Home Security Starter Kit includes one Wyze Cam v4, one Wyze Video Doorbell v2, and one Wyze Home Monitoring Starter Kit, offering comprehensive security coverage for your home.
Are there additional accessories available for Wyze Cam USB connectivity?Yes, additional accessories include the Wyze L-Shaped Micro USB Adapter for better cable management and the Wyze Cam Pan v3 USB Cable as a replacement for pan-and-tilt cameras.
How can I avoid signal loss when using a USB extension cable with my Wyze Cam?To avoid signal loss, use high-quality USB extension cables like the official Wyze 20ft cable and ensure your power adapter is suitable for the extended distance.
Can I use the Wyze Cam USB Extension Cable outdoors?While the extension cable can be used to power outdoor cameras, it’s important to use an outdoor-rated power adapter and ensure the cable is protected from harsh weather conditions.
What colors are available for the Whole Home Security Starter Kit?The Whole Home Security Starter Kit is available in White, Grey, and Black, allowing you to choose a color that matches your home’s style.
How much does the Wyze Cam USB Extension Cable - 20ft cost?The Wyze Cam USB Extension Cable - 20ft is affordably priced at $7.99.
Can you tell me more about the compatibility of the Wyze Cam USB Extension Cable with different Wyze Cam models?What are some practical tips for using the USB extension cable with my Wyze Cam?Do you have any deals, ongoing sales, discounts, or promotions available right now?
