Tidy Wyze Cam Setup: 20ft USB Extension Cable for Baseboards
Tidy Cable Solution for Running Wyze Cam Along Baseboards
When setting up your Wyze Cam along baseboards, managing cable length and neatness is essential for a clean, professional look. The Wyze Cam USB Extension Cable - 20ft is the perfect accessory to extend your camera’s reach without clutter or unsightly wiring. This cable allows you to run your Wyze Cam discreetly along walls and baseboards, giving you flexibility in camera placement while maintaining a tidy setup.
Wyze Cam USB Extension Cable - 20ft: Extend Your Reach with Ease
  • Length: 20 feet of durable USB cable, ideal for running along baseboards or behind furniture.
  • Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto models.
  • Flexibility: Enables you to position your camera exactly where you need it without being limited by the original short USB cable.
  • Neat Installation: Perfect for hiding cables along baseboards, corners, or under carpets to keep your home looking organized.
Say goodbye to short cables and enjoy the freedom of a 20ft cable that blends into your home environment.
Enhance Your Wyze Cam Setup with Smart Power Solutions
If you are running your Wyze Cam outdoors or want to avoid visible power outlets, consider the Cam v4 + Lamp Socket v2 Bundle. This innovative solution powers your Wyze Cam directly from an outdoor lamp socket, eliminating the need for extra wiring or extension cables.
Cam v4 + Lamp Socket v2 Bundle: Smart Power Without the Mess
  • Power Source: Uses your existing outdoor light fixture to power Wyze Cam v4 and compatible models.
  • No Extra Wiring: Avoids long, unsightly cables by drawing power from your lamp socket.
  • Smart Lighting: Integrates with Wyze app to control outdoor lights, set motion-activated illumination, and automate dusk-to-dawn lighting.
  • Easy Installation: Simply screw in the lamp socket adapter like a lightbulb—no electrician needed.
  • Compatibility: Supports Wyze Cam v3, v3 Pro, v4, OG, OG Telephoto, and Pan v3.
This bundle is ideal for outdoor camera setups where cable management is challenging, providing a clean, professional look without compromising functionality.
Why Choose Wyze for Your Home Security?
Wyze offers a range of products designed to work together seamlessly, providing flexible, smart, and tidy solutions for your home security needs. Whether you want to run cables discreetly along baseboards or power your cameras through existing fixtures, Wyze has you covered.
With Wyze’s accessories and bundles, you can create a clean, efficient, and smart security system tailored to your home’s unique layout.
Summary of Featured Products
Wyze Cam USB Extension Cable - 20ft Extend your camera’s reach with a long, flexible USB cable perfect for neat baseboard runs. Cam v4 + Lamp Socket v2 Bundle Power your Wyze Cam from an outdoor lamp socket for a wire-free, smart lighting solution.
Wyze Cam installed neatly along baseboards in a modern living room Alt text: Wyze Cam neatly installed along baseboards in a stylish home interior Outdoor Wyze Cam powered by lamp socket with smart lighting Alt text: Wyze Cam powered by lamp socket with motion-activated outdoor lighting
Optimize your Wyze Cam installation with the right accessories to keep your cables tidy and your home secure. The 20ft USB extension cable and smart lamp socket bundle offer practical, elegant solutions for both indoor and outdoor setups.
What is the Wyze Cam USB Extension Cable - 20ft used for?The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze Cam, allowing you to run the cable neatly along baseboards, walls, or behind furniture for a clean and organized installation.
Which Wyze Cam models are compatible with the 20ft USB extension cable?The 20ft USB extension cable is compatible with Wyze Cam v2, v3, v4, v3 Pro, Pan v2, Pan v3, OG Standard, and OG Telephoto models.
How does the Wyze Cam USB Extension Cable help with cable management?The 20ft USB extension cable allows you to discreetly run your Wyze Cam’s power cable along baseboards, corners, or under carpets, helping to keep your home looking tidy and free from unsightly wiring.
Can I use the Wyze Cam USB Extension Cable for outdoor camera setups?While the USB extension cable is ideal for indoor use along baseboards and behind furniture, for outdoor setups, Wyze recommends the Cam v4 + Lamp Socket v2 Bundle, which powers your camera directly from an outdoor lamp socket.
What is the Cam v4 + Lamp Socket v2 Bundle and how does it work?The Cam v4 + Lamp Socket v2 Bundle allows you to power your Wyze Cam directly from an outdoor lamp socket, eliminating the need for extra wiring or extension cables. Simply screw in the lamp socket adapter like a lightbulb for easy installation.
Which Wyze Cam models are compatible with the Lamp Socket v2 Bundle?The Lamp Socket v2 Bundle supports Wyze Cam v3, v3 Pro, v4, OG, OG Telephoto, and Pan v3 models.
Does the Lamp Socket v2 Bundle offer smart lighting features?Yes, the Lamp Socket v2 integrates with the Wyze app, allowing you to control outdoor lights, set motion-activated illumination, and automate dusk-to-dawn lighting for enhanced security and convenience.
Is professional installation required for the Lamp Socket v2 Bundle?No, professional installation is not required. The Lamp Socket v2 adapter is easy to install—just screw it into your existing outdoor light fixture like a standard lightbulb.
Why should I choose Wyze accessories for my home security setup?Wyze accessories are designed for seamless compatibility, flexible installation, and tidy cable management, helping you create a clean, efficient, and smart home security system tailored to your needs.
Can you tell me more about the compatibility of the Wyze Cam USB Extension Cable with different Wyze Cam models?What are the benefits of using the Cam v4 + Lamp Socket v2 Bundle for outdoor setups?Do you have any deals, ongoing sales, discounts, or promotions available for Wyze products?
