Long Cable Solution for Wyze Cam Behind Thick Exterior Walls
If you need to power your Wyze Cam placed behind a thick exterior wall, the
Wyze Cam USB Extension Cable - 20ft is the perfect accessory to extend your camera’s reach without compromising power or connectivity. This 20-foot USB extension cable is designed specifically to work seamlessly with a wide range of Wyze cameras, allowing you to position your camera exactly where you need it—even through challenging barriers like thick walls.
Wyze Cam USB Extension Cable - 20ft: Freedom to Place Your Camera Anywhere
- Length: 20 feet of USB extension cable to overcome distance limitations.
- Compatibility: Works with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto models.
- Ease of Use: Simply plug in to extend your existing USB power cable without any complicated setup.
- Durability: Designed to maintain stable power delivery over longer distances, ensuring your camera stays powered reliably.
This cable is an essential accessory if your camera’s power source is far from the installation point, especially when mounting outdoors or behind thick walls where standard cables fall short.
Wyze Cam v4: The Ultimate Camera for Outdoor and Indoor Security
Pairing the 20ft USB extension cable with the
Wyze Cam v4 gives you a powerful, flexible security solution that can be installed exactly where you need it—even behind thick walls or in hard-to-reach outdoor locations.
Key Features of Wyze Cam v4
- 2.5K Quad HD Resolution: Capture crystal-clear video with vibrant colors and sharp details.
- Enhanced Color Night Vision: See more at night with color footage, not just black and white.
- IP65 Weather Resistance: Perfect for outdoor use, the camera withstands rain, dust, and extreme weather.
- Motion-Activated Spotlight & Siren: Deter intruders with a bright spotlight and loud siren.
- Advanced Audio: Clear two-way talk with improved microphone and speaker.
- Wi-Fi 6 Support: Enjoy a stronger, more reliable connection even at greater distances.
- Local 24/7 Recording: Supports microSD cards up to 512GB for continuous recording without subscription fees.
- Smart Detection: Motion, sound, smoke, and CO alerts keep you informed in real-time.
- Easy Setup: Bluetooth-enabled setup and magnetic mounting make installation quick and tool-free.
Using the 20ft USB extension cable with the Wyze Cam v4 means you can install this advanced camera in locations previously difficult to power, such as behind thick exterior walls or far from power outlets.
Alt text: Wyze Cam v4 mounted outdoors on a home exterior wall with extended USB cable
Wyze Cam v4 Outdoor Bundle: Complete Security with Power and Storage
For those looking for an all-in-one solution, the
Wyze Cam v4 Outdoor Bundle includes the Wyze Cam v4, Wyze Outdoor Power Adapter, and a 128GB microSD card, providing everything you need for reliable outdoor security.
Bundle Highlights
- Includes 20ft USB Extension Cable Compatibility: Easily extend power to your camera behind thick walls or distant locations.
- Enhanced Color Night Vision & Spotlight: Keep your property safe day and night.
- Wi-Fi 6 & Smart Home Integration: Works with Alexa and Google Assistant for voice control and automation.
- Local Storage: 128GB microSD card included for continuous 24/7 recording.
- Weatherproof Design: Built to withstand outdoor elements with IP65 rating.
This bundle is ideal if you want a hassle-free setup with all necessary components included, ensuring your Wyze Cam v4 is powered and recording continuously, even in challenging installation spots.
Alt text: Home exterior showing Wyze Cam v4 Outdoor Bundle installed with spotlight on
Why Choose Wyze for Your Security Needs?
Wyze offers a range of smart cameras and accessories designed to provide flexible, reliable security solutions. The availability of a
20ft USB extension cable means you no longer have to compromise on camera placement due to power cable length limitations. Whether you have thick exterior walls or want to mount your camera far from power outlets, Wyze’s accessories and cameras like the v4 model ensure you get the best coverage and performance.
"Say goodbye to short cables and enjoy the freedom of a 20ft cable." – Wyze Cam USB Extension Cable
Summary of Products for Long Cable Power Solutions
Extend your camera’s power cable by 20 feet for flexible installation behind thick walls or distant locations.
Wyze Cam v4
Advanced 2.5K QHD camera with color night vision, weather resistance, and smart features, perfect for indoor and outdoor use.
Complete outdoor security kit including Wyze Cam v4, power adapter, and 128GB microSD card for continuous recording.
Optimize your Wyze Cam setup today with the 20ft USB extension cable and enjoy the freedom to place your camera exactly where you need it—even behind thick exterior walls. Combine it with the powerful Wyze Cam v4 or the Outdoor Bundle for unmatched security and convenience.
What is the Wyze Cam USB Extension Cable - 20ft used for?
The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze Cam’s power supply, making it easy to install your camera behind thick exterior walls or in locations far from power outlets without losing power or connectivity.Which Wyze Cam models are compatible with the 20ft USB extension cable?
The 20ft USB extension cable is compatible with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto models.Can I use the Wyze Cam USB Extension Cable outdoors?
Yes, the Wyze Cam USB Extension Cable is suitable for outdoor use, especially when paired with weather-resistant Wyze Cam models like the v4. It allows you to power your camera even when installed behind thick exterior walls or in hard-to-reach outdoor locations.Does the 20ft USB extension cable affect the power or video quality of my Wyze Cam?
No, the Wyze Cam USB Extension Cable is designed to maintain stable power delivery over longer distances, ensuring your camera operates reliably without compromising video quality or connectivity.What are the key features of the Wyze Cam v4?
The Wyze Cam v4 features 2.5K Quad HD resolution, enhanced color night vision, IP65 weather resistance, motion-activated spotlight and siren, advanced two-way audio, Wi-Fi 6 support, local 24/7 recording with microSD cards up to 512GB, smart detection for motion, sound, smoke, and CO, and easy Bluetooth-enabled setup with magnetic mounting.What is included in the Wyze Cam v4 Outdoor Bundle?
The Wyze Cam v4 Outdoor Bundle includes the Wyze Cam v4, a Wyze Outdoor Power Adapter, and a 128GB microSD card for continuous 24/7 local recording. The bundle is compatible with the 20ft USB extension cable for flexible installation.Is the Wyze Cam v4 suitable for outdoor installation?
Yes, the Wyze Cam v4 is IP65 weather-resistant, making it ideal for outdoor use. It can withstand rain, dust, and extreme weather conditions, and can be installed in challenging locations with the help of the 20ft USB extension cable.How do I set up the Wyze Cam v4 with the 20ft USB extension cable?
Setting up the Wyze Cam v4 with the 20ft USB extension cable is simple. Just plug the extension cable into your existing USB power cable and connect it to your camera. The Bluetooth-enabled setup and magnetic mounting make installation quick and tool-free.Does the Wyze Cam v4 support local recording without a subscription?
Yes, the Wyze Cam v4 supports local 24/7 recording with microSD cards up to 512GB, allowing you to record continuously without any subscription fees.Can I control the Wyze Cam v4 with smart home devices?
Yes, the Wyze Cam v4 is compatible with Alexa and Google Assistant, enabling voice control and smart home automation.
