Lightweight Wyze Camera Mounts for Door & Window Surveillance
Lightweight Accessories to Hang a Wyze Camera for Door Surveillance
When it comes to securing your door with a Wyze camera, having the right lightweight mounting accessories is essential. Whether you want to attach your camera to a window or mount it on a wall or ceiling, Wyze offers versatile solutions designed for easy installation and optimal surveillance. Below, we explore the best Wyze accessories tailored for door surveillance, focusing on lightweight, practical mounts that enhance your camera’s performance.
Wyze Window Mount: Perfect for Glass Surfaces
Clear View with Minimal Glare
The Wyze Window Mount is an ideal lightweight accessory for mounting your Wyze Cam v3, v3 Pro, v4, or Wyze Cam OG series directly onto glass surfaces such as windows. This mount allows you to upgrade your exterior security by positioning your camera on a window, providing a clear, glare-free view of your doorstep or entryway.
  • Compatibility: Works with Wyze Cam v3, v3 Pro, v4, and OG series
  • Design: Lightweight and easy to attach on glass
  • Benefit: Reduces glare and reflection for crystal-clear video
  • Price: $9.98 (v2 style)
  • Installation: Simple suction or adhesive mounting without drilling
This mount is perfect for renters or anyone who prefers a non-invasive installation method that doesn’t require drilling holes or permanent fixtures.
“Mount your Wyze Cam on a glass surface and enjoy a clear view free of glare or reflection.”
Wyze Cam Floodlight Outdoor Lifestyle Enhance your home security with easy-to-install Wyze mounts and cameras.
Wyze Cam Mounting Kit: All-in-One Mounting Solution
Complete Kit for Versatile Mounting
For those who want a more traditional mounting option, the Wyze Cam Mounting Kit offers everything you need to securely install your Wyze Cam v2, v3, or v3 Pro on walls or ceilings.
  • Includes: Mounting bracket, adhesive tape, screws, and a longer 5-foot Micro USB cable
  • Compatibility: Wyze Cam v2, v3, and v3 Pro
  • Lightweight: Compact components that don’t add bulk
  • Installation: Choose between adhesive or screw mounting for flexibility
This kit is perfect for mounting your camera near your door or porch where you want a fixed, stable position with power access.
Wyze Cam v4: The Ultimate Door Surveillance Camera
Advanced Features for Superior Security
Pair your mounting accessories with the Wyze Cam v4 for unmatched door surveillance. This camera is designed to deliver crystal-clear 2.5K QHD video resolution and enhanced color night vision, making it perfect for monitoring your front door day and night.
  • Resolution: 2.5K QHD (2560x1440) for sharp video
  • Night Vision: Enhanced color night vision with 4 IR LEDs and 2 white spotlight LEDs
  • Field of View: Wide 115.8° diagonal for broad coverage
  • Connectivity: Supports Wi-Fi 6 for reliable streaming
  • Mounting Options: Stand, wall mount, ceiling mount, and magnetic adhesive mount
  • Weather Resistance: IP65 rated for outdoor durability
  • Additional Features: Built-in siren, two-way audio, Alexa and Google Assistant compatibility
Lightweight and compact (only 0.49 lb), the Wyze Cam v4 is easy to mount using the window mount or mounting kit, making it a perfect companion for door surveillance. Wyze Plug-In Cam Lifestyle Wyze Cam v4 mounted for outdoor door surveillance.
Why Choose Lightweight Wyze Mounting Accessories?
  • Easy Installation: No heavy tools or complicated setups required
  • Non-Invasive: Ideal for renters or temporary setups without damaging walls or windows
  • Versatile Compatibility: Works with multiple Wyze camera models
  • Enhanced Security: Position your camera exactly where you need it for optimal door monitoring
Whether you want to mount your Wyze Cam on a window for a glare-free view or use a mounting kit for a more permanent setup, these lightweight accessories provide the flexibility and convenience you need for effective door surveillance.
Summary of Recommended Products for Door Surveillance
Product NameKey FeaturesPrice
Wyze Window MountGlass surface mount, glare reduction$9.98
Wyze Cam Mounting KitBracket, adhesive, screws, USB extension$5.99
Wyze Cam v42.5K QHD, color night vision, IP65 weatherproof$35.98
Enhance your home security today with these lightweight, easy-to-use Wyze accessories designed to keep your door under watchful eyes.
FeatureWyze Window MountWyze Cam Mounting KitWyze Cam v4
Product TypeAccessoryAccessoryCamera
Compatible ModelsWyze Cam v3/v3 Pro/v4, Wyze Cam OG seriesWyze Cam v2, v3, v3 ProWyze Cam v4
PurposeMount camera on glass window, reduces glareMounting bracket, adhesive, longer USB cableSecurity camera with 2.5K QHD resolution
Price$9.98$5.99$35.98 - $107.94 (varies by pack/color)
Mounting SurfaceGlass windowWall or other surfacesStand, Wall mount, Ceiling mount, Magnetic mount
Included ItemsMount onlyMounting bracket, adhesive, longer Micro USB cableCamera, power adapter, USB cable, mounting plate (varies by bundle)
Key FeaturesClear view free of glare/reflectionSpare mounting plate2.5K QHD, Enhanced Color Night Vision, motion-activated spotlight, Wi-Fi 6, Alexa/Google Assistant compatible
WarrantyNot specifiedNot specified1 Year
Return Policy30-day hassle-free returns30-day hassle-free returns1 Year warranty
What are the best lightweight accessories for hanging a Wyze camera for door surveillance?The best lightweight accessories for hanging a Wyze camera for door surveillance are the Wyze Window Mount and the Wyze Cam Mounting Kit. The Window Mount is ideal for glass surfaces, providing a glare-free view, while the Mounting Kit offers versatile options for wall or ceiling installation.
How does the Wyze Window Mount improve door surveillance?The Wyze Window Mount allows you to attach your Wyze Cam v3, v3 Pro, v4, or OG series directly to glass surfaces like windows. It reduces glare and reflection, ensuring a clear view of your doorstep or entryway without the need for drilling or permanent fixtures.
Which Wyze cameras are compatible with the Wyze Window Mount?The Wyze Window Mount is compatible with Wyze Cam v3, v3 Pro, v4, and Wyze Cam OG series cameras.
Is the Wyze Window Mount easy to install?Yes, the Wyze Window Mount is lightweight and easy to install using suction or adhesive, making it perfect for renters or anyone who prefers a non-invasive setup.
What does the Wyze Cam Mounting Kit include?The Wyze Cam Mounting Kit includes a mounting bracket, adhesive tape, screws, and a 5-foot Micro USB cable, providing everything needed for secure wall or ceiling installation.
Which Wyze cameras are compatible with the Wyze Cam Mounting Kit?The Wyze Cam Mounting Kit is compatible with Wyze Cam v2, v3, and v3 Pro.
Can I install a Wyze camera without drilling holes?Yes, both the Wyze Window Mount and the Wyze Cam Mounting Kit offer adhesive mounting options, allowing you to install your camera without drilling holes or causing permanent damage.
What makes the Wyze Cam v4 ideal for door surveillance?The Wyze Cam v4 offers 2.5K QHD video resolution, enhanced color night vision, a wide 115.8° field of view, IP65 weather resistance, and multiple mounting options, making it perfect for monitoring your front door day and night.
Are Wyze mounting accessories suitable for renters?Yes, Wyze mounting accessories like the Window Mount and Mounting Kit are non-invasive and easy to remove, making them ideal for renters or temporary setups.
How much do Wyze mounting accessories for door surveillance cost?The Wyze Window Mount is priced at $9.98, and the Wyze Cam Mounting Kit is available for $5.99. The Wyze Cam v4 camera is priced at $35.98.
Why should I choose lightweight Wyze mounting accessories for my door camera?Lightweight Wyze mounting accessories are easy to install, non-invasive, compatible with multiple camera models, and allow you to position your camera for optimal door monitoring without heavy tools or complicated setups.
What other mounting options are available for the Wyze Cam v4?Can the Wyze Window Mount be used with other Wyze camera models?Do you have any ongoing sales or discounts for Wyze camera accessories?
