Wyze Window Mount: Stable, Weatherproof Camera Mount for Glass
Innovative Window Mount for Stable Outdoor Camera Security
When it comes to securing your home or business with outdoor cameras, stability and weather resistance are key. The Wyze Window Mount is an innovative accessory designed specifically to keep your Wyze cameras stable and glare-free when mounted on glass surfaces, even in harsh weather conditions. Whether you own a Wyze Cam v3, v3 Pro, v4, or the original Wyze Cam OG series, this mount offers a reliable solution to enhance your exterior security setup.
Wyze Window Mount: Clear, Stable, and Weather-Resistant
Designed for Glass Surfaces
The Wyze Window Mount allows you to attach your Wyze camera directly to any window, providing a crystal-clear view without the usual glare or reflections that can interfere with image quality. This is perfect for monitoring outdoor areas while keeping your camera protected indoors.
Compatibility and Versatility
  • Works with Wyze Cam v3, v3 Pro, v4, Wyze Cam OG, and Wyze Cam OG Telephoto
  • Ideal for smart home users looking to upgrade exterior security
  • Perfect for RVs, campers, motorhomes, and travel trailers
Weather Stability
This mount is engineered to keep your camera stable even in harsh weather conditions, ensuring consistent surveillance without the risk of camera shake or misalignment caused by wind or rain.
"Mount your cam on a glass surface with this accessory and enjoy a clear view free of glare or reflection."
Additional Wyze Mounting Solutions for Outdoor Security
While the Wyze Window Mount excels at glass surface mounting, Wyze offers other mounting accessories designed to keep your cameras stable and secure in various outdoor environments.
Wyze Universal Mount (Long)
For those needing versatile mounting options beyond windows, the Wyze Universal Mount (Long) provides a durable metal mount with an extended neck. It’s perfect for ceiling or patio installations and supports a wide range of Wyze cameras (except Wyze Cam OG and OG Telephoto).
  • Heavy-duty metal construction
  • Adjustable for optimal camera angles
  • Easy installation with included wall anchors and screws
  • Supports up to 2 kg load bearing
Enhance Outdoor Security with Wyze Floodlight Cameras and Mounts
For comprehensive outdoor security, consider pairing your mounts with Wyze’s advanced floodlight cameras, which combine bright lighting with high-quality video surveillance.
Wyze Cam Floodlight Plug-In Mount
This plug-and-play mount eliminates the need for complex junction box installations. It’s compatible with Wyze Cam Floodlight v1, v2, and Floodlight Pro models, providing a simple and weather-safe mounting solution.
  • 20 ft power cord for flexible placement
  • Rated for outdoor use with operating temperatures from -22°F to 122°F
  • Includes mounting kit and foam tape for secure installation
Wyze Cam Floodlight Pro + Plug-In Mount Bundle
Get the ultimate security combo with the Floodlight Pro camera and plug-in mount bundled together. Features include:
  • 2.5K QHD resolution with 180° ultra-wide field of view
  • Color night vision and 3000 lumens of bright light output
  • IP65 water resistance for harsh weather durability
  • Compatible with Alexa, Google Assistant, and IFTTT integrations
A slightly more affordable option with:
  • 2K HD video and vibrant color night vision
  • 160° wide-angle view and advanced motion detection
  • 2800-lumen LEDs and a 105dB siren for deterrence
  • Easy installation with included plug-in mount and cable management
Outdoor Security with Wyze Floodlight Bright and reliable outdoor security with Wyze Floodlight Pro
Why Choose Wyze Mounts for Your Outdoor Cameras?
  • Stable and secure mounting in harsh weather conditions
  • Clear, glare-free views when mounted on windows
  • Easy installation with included hardware and plug-in options
  • Versatile compatibility with multiple Wyze camera models
  • Enhanced security with floodlight camera integration
Easy Outdoor Installation Simple and secure outdoor camera installation with Wyze mounts
Summary
For anyone seeking an innovative window mount that keeps their Wyze camera stable and weather-resistant, the Wyze Window Mount is the perfect choice. Complement it with Wyze’s universal mounts or floodlight plug-in mounts for a complete, reliable outdoor security system that withstands the elements and delivers clear, uninterrupted surveillance.
FeatureWyze Window MountWyze Universal Mount (Long)Wyze Cam Floodlight Plug-In MountWyze Cam Floodlight Pro + Plug-In MountWyze Cam Floodlight v2 + Plug-In Mount
TypeAccessoriesAccessoriesCamerasCamerasCameras
Compatible CamerasWyze Cam v3/v3 Pro/v4, Wyze Cam OG seriesWyze Cameras with 1/4”-20 mount (excludes OG/OG Telephoto)Wyze Cam Floodlight v1, v2, ProWyze Cam Floodlight ProWyze Cam Floodlight v2
Mounting SurfaceGlass (window)Versatile (ceiling, patio, fences, trees)Plug-in mount for floodlightPlug-in mount for floodlightPlug-in mount for floodlight
MaterialNot specifiedHeavy-duty metalNot specifiedNot specifiedNot specified
Price$9.98$9.99$19.98$169.96 (bundle with camera)$109.96 (bundle with camera)
DimensionsNot specifiedNot specified153mm x 155mm x 79mm153mm x 155mm x 79mmNot specified
WeightNot specifiedNot specified1.39 lbs1.39 lbsNot specified
Power SupplyN/AN/A110 - 120V AC110 - 120V ACN/A
Weather ResistanceNot specifiedWeather resistant (metal mount)Outdoor safeIP65Not specified
Operating TemperatureNot specifiedNot specified-22°F to 122°F-22°F to 122°FNot specified
FeaturesReduces glare, clear view on glassAdjustable, flexible, durable metalEasy plug-n-play, no junction box needed2.5K QHD video, 3000 lumens, AI motion detection, 180° FOV, plug-n-play2K HD video, 2800 lumens, color night vision, 160° wide-angle, plug-n-play
Mount TypeWindow glassCeiling, patio, fences, treesPlug-in mountWall/CeilingPlug-in mount
Compatibility NotesWorks with Cam v3/v3 Pro/v4 and OG seriesNot compatible with Wyze Cam OG/OG TelephotoCompatible with Wyze Cam Floodlight seriesBundle includes Floodlight Pro + Plug-In MountBundle includes Floodlight v2 + Plug-In Mount
WarrantyNot specified30-day hassle-free returnsNot specified1 YearNot specified
What is the Wyze Window Mount and how does it improve outdoor camera security?The Wyze Window Mount is an innovative accessory designed to securely attach Wyze cameras to glass surfaces, such as windows. It provides a stable, glare-free view for your camera, ensuring clear surveillance footage while keeping the camera protected indoors. The mount is engineered to withstand harsh weather conditions, making it ideal for enhancing your home or business's outdoor security.
Which Wyze cameras are compatible with the Wyze Window Mount?The Wyze Window Mount is compatible with Wyze Cam v3, v3 Pro, v4, Wyze Cam OG, and Wyze Cam OG Telephoto models. This makes it a versatile solution for users with different Wyze camera versions.
Can the Wyze Window Mount be used in harsh weather conditions?Yes, the Wyze Window Mount is specifically engineered to keep your camera stable even in harsh weather conditions, such as wind and rain. This ensures consistent and reliable surveillance without camera shake or misalignment.
Does the Wyze Window Mount eliminate glare and reflections when mounting cameras on windows?Yes, the Wyze Window Mount is designed to provide a crystal-clear view by minimizing glare and reflections that can interfere with image quality when mounting cameras on glass surfaces.
Is the Wyze Window Mount suitable for use in RVs, campers, or travel trailers?Absolutely. The Wyze Window Mount is ideal for smart home users as well as those looking to secure RVs, campers, motorhomes, and travel trailers, offering stable and clear camera placement on glass surfaces.
What other mounting solutions does Wyze offer for outdoor cameras?Wyze offers several mounting solutions, including the Wyze Universal Mount (Long) for ceiling or patio installations, and plug-in mounts for Wyze Cam Floodlight models. These mounts provide durable, weather-resistant options for various outdoor environments.
What are the features of the Wyze Universal Mount (Long)?The Wyze Universal Mount (Long) features heavy-duty metal construction, an extended neck for versatile placement, adjustable angles for optimal camera positioning, and easy installation with included wall anchors and screws. It supports most Wyze cameras except the Wyze Cam OG and OG Telephoto.
How does the Wyze Cam Floodlight Plug-In Mount simplify outdoor camera installation?The Wyze Cam Floodlight Plug-In Mount offers a plug-and-play solution that eliminates the need for complex junction box installations. It comes with a 20 ft power cord for flexible placement, is rated for outdoor use in extreme temperatures, and includes a mounting kit and foam tape for secure installation.
What are the benefits of the Wyze Cam Floodlight Pro + Plug-In Mount Bundle?The Wyze Cam Floodlight Pro + Plug-In Mount Bundle provides 2.5K QHD resolution, a 180° ultra-wide field of view, color night vision, 3000 lumens of bright light, IP65 water resistance, and compatibility with Alexa, Google Assistant, and IFTTT. It offers comprehensive outdoor security in one package.
Why should I choose Wyze mounts for my outdoor security cameras?Wyze mounts offer stable and secure camera placement in harsh weather, clear and glare-free views on windows, easy installation with included hardware, versatile compatibility with multiple Wyze camera models, and enhanced security when paired with floodlight cameras.
Can you tell me more about the compatibility of the Wyze Window Mount with different camera models?What other mounting solutions does Wyze offer for outdoor security?Do you have any ongoing sales or promotions for the Wyze Window Mount?
