Customizable RGB LED Strip Lights for TV Backlighting
Enhance Your TV Backlighting with Customizable RGB LED Strips
Transform your TV viewing experience with vibrant, customizable RGB LED strip lighting designed specifically for TV backlighting. Whether you want to create an immersive ambiance for movie nights, gaming sessions, or just add a splash of color to your living space, these LED strips offer brilliant accent lighting with full control over colors and effects.
Wyze Light Strip: Brilliant Accent Lighting for Your TV
The Wyze Light Strip is a perfect choice for those seeking simple yet stunning LED backlighting. Available in two lengths—16.4 feet and 32.8 feet—it provides ample coverage for most TV setups.
Key Features:
  • 16 million colors to choose from, allowing you to match any mood or décor.
  • Single customizable zone for uniform color or effects along the entire strip.
  • Cuttable design lets you trim the strip to fit your TV perfectly.
  • Music feature syncs lighting to the beat using the built-in microphone.
  • Easy installation with adhesive backing and included clips.
  • Indoor use only, powered by a 12V corded electric adapter.
  • Long lifespan of 25,000 hours ensures durable performance.
  • Connectivity via Wi-Fi (802.11 b/g/n, 2.4 GHz) and Bluetooth for seamless app control.
This light strip is ideal if you want a straightforward, vibrant glow behind your TV that can be controlled easily through your smartphone. Wyze Light Strip Lifestyle Create stunning TV backlighting with Wyze Light Strip
Wyze Light Strip Pro: Advanced Multi-Color Segment Control
For users who want the ultimate customization, the Wyze Light Strip Pro offers multi-color segment control, allowing you to divide the strip into up to 16 individually controllable zones. This means you can display multiple colors and dynamic effects simultaneously, perfect for immersive TV backlighting.
Why Choose Wyze Light Strip Pro?
  • 16 customizable segments for multi-color effects along the strip.
  • Supports 16 million RGB colors plus tunable white for precise ambiance.
  • Music Mode syncs lights to your favorite tunes, enhancing entertainment.
  • Trimmable design to fit any TV size or space.
  • Voice control compatible with Alexa and Google Assistant.
  • Includes vacation mode, sleep routines, timers, and automations for smart living.
  • Available in 16.4 ft and 32.8 ft lengths.
  • Powered by 12V adapter with Wi-Fi and Bluetooth connectivity.
  • Rated for indoor use with a lifespan of 25,000 hours.
This strip is perfect for tech-savvy users who want dynamic, customizable lighting effects that can adapt to any scene or mood. Wyze Light Strip Pro Lifestyle Customize your TV backlighting with multi-zone RGB control
Wyze Bulb Color: Complement Your Backlighting with Smart RGB Bulbs
While LED strips provide direct backlighting, the Wyze Bulb Color can enhance your entire room’s lighting atmosphere. These smart bulbs offer 16 million colors and tunable white light, perfect for setting the right mood around your TV area.
Highlights:
  • 16 million colors with dimmable brightness up to 1100 lumens.
  • Wide color temperature range from 1800K (warm) to 6500K (cool).
  • Compatible with Alexa, Google Assistant, and IFTTT for voice and automation control.
  • Suitable for damp locations, making them versatile for various indoor settings.
  • Long life expectancy of 25,000 hours.
  • Available in multi-packs for easy room-wide lighting upgrades.
Pairing Wyze Bulb Color with LED strips creates a layered lighting effect that enhances your TV viewing environment with rich, customizable colors. Wyze Bulb Color Lifestyle Set the perfect mood with Wyze Bulb Color smart lighting
Why Choose Wyze LED Lighting for TV Backlighting?
"Color your world with brilliant LED accent lighting."
Wyze offers a range of smart lighting solutions designed to bring your TV setup to life with customizable RGB effects. Whether you want simple, uniform backlighting or advanced multi-zone color control, Wyze’s LED strips and bulbs provide:
  • Easy installation with adhesive backing and flexible trimming.
  • Extensive color options with 16 million RGB colors.
  • Smart app control with Wi-Fi and Bluetooth connectivity.
  • Integration with voice assistants for hands-free operation.
  • Music sync features to enhance entertainment experiences.
  • Durable, long-lasting LED technology.
Upgrade your TV backlighting today with Wyze’s customizable RGB LED strips and smart bulbs to create an immersive and vibrant viewing atmosphere.
Product Summary
Product NameKey FeaturesSizes AvailablePrice Range (USD)
Wyze Light Strip16 million colors, music sync, cuttable16.4 ft, 32.8 ft$19.99 - $35.99
Wyze Light Strip ProMulti-color segments, voice control, music mode16.4 ft, 32.8 ft$29.99 - $44.99
Wyze Bulb Color16 million colors, tunable white, dimmableMulti-pack options$26.26 - $64.98
Enhance your TV viewing with Wyze’s customizable RGB LED lighting solutions and enjoy a personalized, colorful ambiance that fits your style and space perfectly.
FeatureWyze Light StripWyze Light Strip ProWyze Bulb Color
TypeConnected HomeSmart LightingSmart Lighting
Size/Variants16.4 ft ($19.99), 32.8 ft ($35.99)16.4 ft ($29.99), 32.8 ft ($44.99)2 Pack ($26.26), 4 Pack ($44.44), 6 Pack ($64.98)
Colors16 million colors (one color per strip)Up to 16 colors per strip (multi-color segment control)16 million colors
Lighting EffectsBasic lighting effectsAdvanced lighting effectsCustom presets, white light temperature control
Protective CoatingNo epoxy coatingProtective epoxy coatingN/A
Music ModeYes (built-in microphone)Yes (built-in microphone)Yes
Sun MatchYesYesYes
Voice ControlAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant, IFTTT
Vacation ModeYesYesYes
Sleep RoutinesYesYesYes
Timers & AutomationsYesYesYes
Trimmable DesignNot specifiedYesN/A
Segment ControlNoYes (chip every 3 LEDs)N/A
PowerNot specifiedNot specified12 watts
ConnectivityNot specifiedNot specifiedWiFi 802.11 b/g/n 2.4GHz, Bluetooth
Life ExpectancyNot specifiedNot specified25,000 hours
Price Range$19.99 - $35.99$29.99 - $44.99$26.26 - $64.98 (depending on pack size)
What are the benefits of using RGB LED strips for TV backlighting?RGB LED strips for TV backlighting enhance your viewing experience by creating an immersive ambiance, reducing eye strain, and adding vibrant, customizable colors to your living space. They are perfect for movie nights, gaming sessions, or simply adding a stylish accent to your room.
What is the difference between Wyze Light Strip and Wyze Light Strip Pro?The Wyze Light Strip offers a single customizable color zone for uniform lighting, while the Wyze Light Strip Pro features up to 16 individually controllable segments for multi-color effects and dynamic lighting. The Pro version also supports advanced features like voice control, vacation mode, sleep routines, and automations.
How do I install Wyze LED light strips on my TV?Wyze LED light strips are easy to install with their adhesive backing and included clips. Simply measure and trim the strip to fit your TV, peel off the adhesive, and stick the strip to the back of your TV. Plug in the 12V adapter and connect via Wi-Fi or Bluetooth for app control.
Can I control Wyze Light Strip and Light Strip Pro with my smartphone?Yes, both Wyze Light Strip and Light Strip Pro can be controlled through the Wyze app on your smartphone. The app allows you to adjust colors, brightness, effects, and set up automations or schedules.
Are Wyze LED light strips compatible with voice assistants?Wyze Light Strip Pro is compatible with Alexa and Google Assistant, allowing you to control your lighting with voice commands. The standard Wyze Light Strip does not support voice control.
What is the lifespan of Wyze LED light strips and bulbs?Both Wyze LED light strips and Wyze Bulb Color have a long lifespan of up to 25,000 hours, ensuring durable and reliable performance for years of use.
Can I sync Wyze LED lights to music?Yes, both Wyze Light Strip and Light Strip Pro feature a music sync mode that uses a built-in microphone to synchronize lighting effects with the beat of your music, creating a dynamic entertainment experience.
Are Wyze LED light strips suitable for all TV sizes?Wyze LED light strips are available in 16.4 ft and 32.8 ft lengths and feature a cuttable design, allowing you to trim the strip to fit TVs of various sizes perfectly.
Can Wyze Bulb Color be used to complement TV backlighting?Yes, Wyze Bulb Color smart bulbs offer 16 million colors and tunable white light, making them ideal for enhancing your room’s lighting atmosphere and complementing your TV backlighting setup.
Are Wyze LED lighting products suitable for indoor use?Yes, Wyze Light Strip, Light Strip Pro, and Bulb Color are all designed for indoor use. The Wyze Bulb Color is also suitable for damp locations, making it versatile for various indoor settings.
What connectivity options do Wyze LED light strips offer?Wyze LED light strips support Wi-Fi (2.4 GHz) and Bluetooth connectivity, allowing for seamless app control and integration with smart home systems.
How many colors can Wyze LED light strips and bulbs display?Wyze Light Strip, Light Strip Pro, and Bulb Color all support up to 16 million RGB colors, giving you endless options to match your mood or décor.
What is the price range for Wyze LED lighting products?Wyze Light Strip is priced between $19.99 and $35.99, Wyze Light Strip Pro ranges from $29.99 to $44.99, and Wyze Bulb Color multi-packs are available from $26.26 to $64.98.
What are the key features of the Wyze Light Strip?Can you tell me more about the installation process for the Wyze Light Strip?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Light Strip?
