Color LED Lighting Bundles to Transform Your Living Room
Light Up Your Living Room with Color LED Lighting Bundles
Transform your living room into a vibrant, dynamic space with the perfect color LED lighting bundles. Whether you want to set the mood for a cozy night, energize your space with bright colors, or add smart home convenience, Wyze offers a range of smart lighting products designed to illuminate your living room with style and intelligence.
Wyze Bulb Color: The Ultimate Smart Color Bulb
Brilliant 16 Million Colors & Tunable White Light
The Wyze Bulb Color is a top-tier smart bulb that offers an astonishing 16 million colors to choose from, allowing you to customize your living room lighting to match any mood or occasion. It also features tunable white light ranging from a warm 1800K to a crisp 6500K, perfect for everyday use or special ambiance.
Powerful Brightness & Energy Efficiency
With up to 1100 lumens of brightness, this bulb is extra bright yet energy-efficient, consuming only 12 watts. Its high color rendering index (90+) ensures colors in your room appear vivid and natural.
Smart Connectivity & Compatibility
Easily control your Wyze Bulb Color via the Wyze app on Android 9.0+ or iOS 15.0+ devices. It supports Wi-Fi (2.4 GHz), Bluetooth, and integrates seamlessly with Alexa, Google Assistant, and IFTTT for voice commands and automation.
Long-lasting & Suitable for Damp Locations
Designed to last 25,000 hours, the bulb is suitable for damp locations, making it versatile for indoor living rooms or covered outdoor spaces. Living Room with Colorful Smart Bulbs Alt text: Living room illuminated with colorful smart bulbs creating a cozy atmosphere
Wyze Light Strip: Brilliant LED Accent Lighting
Flexible & Customizable LED Strip
Add a splash of color along your walls, behind your TV, or under shelves with the Wyze Light Strip. Available in 16.4 feet and 32.8 feet lengths, it offers brilliant LED accent lighting with 16 million colors to brighten up your living room corners and edges.
Easy Installation & Control
The strip comes with adhesive backing and clips for easy mounting. It’s cuttable to fit your space perfectly and controlled via the Wyze app or voice assistants. The built-in microphone enables music sync, making your lighting dance to your favorite tunes.
Energy Efficient & Long-lasting
Consuming 18 watts for the 16.4 ft version and 36 watts for the 32.8 ft, the light strip is designed for indoor use only and lasts up to 25,000 hours. Living Room with LED Light Strip Alt text: Modern living room with LED light strip behind sofa creating ambient lighting
Wyze Bulb Cam + Accessory Bulbs: Smart Lighting with Security
Dual Function: Lighting and Security
The Wyze Bulb Cam combines smart lighting with 2K HD video security. It offers color night vision, motion-activated lighting, and instant alerts, making it perfect for living rooms where security and ambiance matter.
Easy Setup & Control
Fits most fixtures with an E26 base and controlled via the Wyze app. The accessory bulbs provide additional lighting support and can be linked up to 5 per Bulb Cam for extended coverage.
Brightness & Features
Each bulb delivers up to 800 lumens at 3000K color temperature, with manual, schedule, and automation controls. The Bulb Cam also features two-way audio and a 160° field of view for comprehensive room monitoring.
Protect your home while lighting it beautifully with Wyze Bulb Cam’s smart features.
Why Choose Wyze for Your Living Room Lighting?
  • Versatile Color Options: From millions of colors to tunable whites, customize your lighting to fit any mood.
  • Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT for seamless voice and automation control.
  • Energy Efficient & Long-lasting: Save on energy bills with bulbs and strips designed to last over 25,000 hours.
  • Easy Installation: Simple setup with adhesive strips, standard bulb bases, and intuitive app control.
  • Enhanced Security: Combine lighting with smart cameras for peace of mind.
Brighten your living room with Wyze’s color LED lighting bundles and enjoy a smart, stylish, and secure home environment.
Product Summary
ProductKey FeaturesPrice Range
Wyze Bulb Color16M colors, 1100 lumens, Alexa/Google$26.26 - $64.98
Wyze Light Strip16.4 or 32.8 ft, music sync, adhesive$19.99 - $35.99
Wyze Bulb Cam + Bulbs2K video, color night vision, motion light$64.98 - $84.98
Illuminate your living room with color and intelligence today!
FeatureWyze Bulb ColorWyze Light StripWyze Bulb Cam + Accessory Bulbs
TypeSmart LightingConnected HomeCameras
Color Options16 million colors16 million colorsWhite light (3000K)
Brightness (Lumens)30 lm (min) - 1100 lm (max)Not specified (LED accent lighting)Up to 800 lm (bulb and accessory bulb)
Wattage2W (dim) - 75W (max)Not specified15W (Bulb Cam), 8W (Accessory Bulb)
DimmableYes (takes offense if used)Yes (via app)Yes (manual and motion-activated)
Color Temperature ControlYes (white light temperature control)Yes (Sun Match feature)Fixed at 3000K
CRI Rating90+Not specifiedNot specified
ConnectivityWi-Fi 802.11 b/g/n 2.4 GHz, BluetoothWi-Fi 802.11 b/g/n 2.4 GHz, BluetoothWi-Fi 802.11 b/g/n 2.4 GHz, Bluetooth Low Energy (BLE)
Voice ControlAlexa, Google AssistantAlexa, Google AssistantNo direct voice control (via Wyze app)
Special FeaturesCustom presets, Sleep routines, Music mode, Brilliant notifications, Vacation mode, GroupingMusic Mode, Sun Match, Sleep routines, Vacation mode, Timers & Automations2K HD video, Color night vision, Motion alerts, Two-way audio, Siren, Local & cloud storage
Form FactorA19 bulbLED strip (16.4 ft or 32.8 ft)E26 bulb with built-in camera
Pack Variants2 Pack, 4 Pack, 6 Pack16.4 ft, 32.8 ftBulb Cam + 1, 2, or 3 Accessory Bulbs
Price Range$26.26 - $64.98$19.99 - $35.99$64.98 - $84.98
Weather ResistanceNot specifiedIndoor use onlyIP65 rated (weather resistant)
WarrantyNot specifiedNot specified1-year product warranty
App ControlWyze appWyze appWyze app
What are the benefits of using Wyze color LED lighting bundles in my living room?Wyze color LED lighting bundles allow you to transform your living room with millions of customizable colors, tunable white light, and smart home integration. They offer energy efficiency, long-lasting performance, easy installation, and the option to enhance security with smart camera features.
How many colors can the Wyze Bulb Color produce?The Wyze Bulb Color can produce up to 16 million colors, allowing you to customize your living room lighting to match any mood or occasion.
Is the Wyze Bulb Color energy efficient?Yes, the Wyze Bulb Color is highly energy efficient, consuming only 12 watts while delivering up to 1100 lumens of brightness. It is designed to last up to 25,000 hours.
Can I control Wyze smart lighting products with my phone?Yes, you can control all Wyze smart lighting products using the Wyze app, available for Android 9.0+ and iOS 15.0+ devices. The app allows you to adjust colors, brightness, schedules, and automation settings.
Are Wyze lighting products compatible with Alexa and Google Assistant?Yes, Wyze lighting products are compatible with Alexa, Google Assistant, and IFTTT, enabling voice control and smart home automation.
What is the brightness of the Wyze Bulb Color and Wyze Bulb Cam accessory bulbs?The Wyze Bulb Color delivers up to 1100 lumens, while the Wyze Bulb Cam accessory bulbs provide up to 800 lumens at a 3000K color temperature.
Can Wyze Bulb Color be used in damp locations?Yes, the Wyze Bulb Color is suitable for damp locations, making it versatile for indoor living rooms or covered outdoor spaces.
What lengths are available for the Wyze Light Strip?The Wyze Light Strip is available in 16.4 feet and 32.8 feet lengths, allowing you to choose the perfect size for your living room setup.
Does the Wyze Light Strip support music sync?Yes, the Wyze Light Strip features a built-in microphone that enables music sync, so your lighting can dance to your favorite tunes.
How do I install the Wyze Light Strip?The Wyze Light Strip comes with adhesive backing and clips for easy mounting. It is also cuttable, so you can customize the length to fit your space perfectly.
What is the Wyze Bulb Cam and how does it enhance security?The Wyze Bulb Cam is a smart bulb with built-in 2K HD video security, color night vision, motion-activated lighting, instant alerts, two-way audio, and a 160° field of view. It combines lighting and security for comprehensive living room protection.
How many accessory bulbs can be linked to the Wyze Bulb Cam?You can link up to 5 accessory bulbs per Wyze Bulb Cam for extended lighting coverage in your living room.
Are Wyze lighting products easy to install?Yes, Wyze lighting products are designed for easy installation, featuring standard bulb bases, adhesive strips for light strips, and intuitive app control for setup and management.
How long do Wyze bulbs and light strips last?Wyze bulbs and light strips are designed to last up to 25,000 hours, providing long-term, reliable lighting for your living room.
What is the price range for Wyze living room lighting products?Wyze Bulb Color ranges from $26.26 to $64.98, Wyze Light Strip from $19.99 to $35.99, and Wyze Bulb Cam with accessory bulbs from $64.98 to $84.98.
What are the different lengths available for the Wyze Light Strip?Can the Wyze Bulb Color be controlled with voice commands?Do you have any deals, ongoing sales, discounts, or promotions?
