Customizable LED Strips for Mood Lighting & Party Sync
Customizable LED Strips for Mood Lighting and Party Sync
Transform your living space or party venue with vibrant, customizable LED lighting that syncs perfectly with your mood and music. Whether you're looking to create a relaxing ambiance or an electrifying party atmosphere, Wyze offers a range of smart lighting solutions designed to elevate your environment with brilliant colors and smart features.
Wyze Light Strip Pro: Ultimate Customizable LED Strip
Multi-Color Segment Control for Personalized Vibes
The Wyze Light Strip Pro is the perfect choice for those who want full control over their lighting experience. Featuring 16 customizable segments, this LED strip allows you to create dynamic, multi-color patterns that can be tailored to any mood or event.
  • 16 Million Colors RGB + Tunable White: Choose from a vast palette of colors and adjust white tones to suit your setting.
  • Music Mode: Sync your lights to the beat of your favorite songs for an immersive party experience.
  • Trimmable Design: Easily cut the strip to fit any space, making it ideal for rooms of all sizes.
  • Voice Control: Compatible with Alexa and Google Assistant for hands-free lighting adjustments.
  • Timers & Automations: Set schedules, sleep routines, and vacation modes to automate your lighting.
  • Indoor Use Only: Designed for safe and effective indoor ambiance lighting.
  • Long Lifespan: Enjoy up to 25,000 hours of vibrant illumination.
Available in 16.4 ft and 32.8 ft lengths, the Wyze Light Strip Pro is powered by a 12V adapter and connects via Wi-Fi (2.4 GHz) and Bluetooth for seamless control. Wyze Light Strip Pro in Living Room Create stunning mood lighting behind your sofa with Wyze Light Strip Pro.
Wyze Light Strip: Brilliant LED Accent Lighting
For a simpler yet effective LED strip option, the Wyze Light Strip offers brilliant accent lighting with 16 million colors to brighten up your space.
  • Single Customizable Zone: Perfect for uniform color lighting along the strip.
  • Cuttable & Adhesive Backing: Easily mount and trim to fit your desired area.
  • Music Feature: Uses a built-in microphone to sync lights with music beats.
  • Indoor Use Only: Ideal for enhancing indoor spaces with vibrant colors.
  • Available Lengths: Choose between 16.4 ft and 32.8 ft options.
  • Connectivity: Supports Wi-Fi (2.4 GHz) and Bluetooth for easy app control.
This LED strip is a great choice for adding colorful accents to your kitchen, gaming setup, or party space. Wyze Light Strip under Kitchen Cabinets Add colorful LED accents under cabinets or shelves with Wyze Light Strip.
Wyze Bulb Color: 16 Million Colors in a Smart Bulb
Complement your LED strips with the Wyze Bulb Color, a smart bulb that delivers 16 million colors and tunable white light to set the perfect mood anywhere in your home.
  • Extra Bright: Up to 1100 lumens for vivid, bright lighting.
  • Wide Color Temperature Range: 1800K to 6500K for warm to cool white light.
  • Dimmable: Adjust brightness to suit your mood or activity.
  • Smart Integrations: Works with Alexa, Google Assistant, and IFTTT.
  • Connectivity: Wi-Fi (2.4 GHz) and Bluetooth enabled.
  • Long Life: Rated for 25,000 hours of use.
  • Suitable for Damp Locations: Safe for kitchens and bathrooms.
Available in packs of 2, 4, or 6, these bulbs are perfect for creating immersive lighting scenes that match your LED strips for a cohesive party or mood lighting setup. Wyze Bulb Color in Cozy Living Room Set the mood in your living room with Wyze Bulb Color’s vibrant hues.
Why Choose Wyze for Your Mood Lighting and Party Sync?
Wyze smart lighting products combine advanced technology with user-friendly features, making it easy to customize your lighting environment. Whether syncing lights to music beats or creating relaxing sleep routines, Wyze offers versatile solutions that fit any lifestyle.
  • Seamless App Control: Manage all your lights from one intuitive app.
  • Voice Assistant Compatibility: Control lights hands-free with Alexa or Google Assistant.
  • Music Sync: Lights that dance to your favorite tunes.
  • Customizable Zones: Tailor lighting effects to different areas.
  • Energy Efficient: Long-lasting LEDs with low power consumption.
Product Summary
ProductKey FeaturesPrice Range (USD)
Wyze Light Strip Pro16 customizable segments, music sync, voice control$29.99 - $44.99
Wyze Light StripSingle zone, music sync, cuttable$19.99 - $35.99
Wyze Bulb Color16 million colors, dimmable, smart integrations$26.26 - $64.98 (packs)
Elevate your home or party lighting with Wyze’s customizable LED strips and smart bulbs — the perfect combination for mood lighting and party sync.
FeatureWyze Light StripWyze Light Strip ProWyze Bulb Color
TypeConnected HomeSmart LightingSmart Lighting
Size / Pack16.4 ft, 32.8 ft16.4 ft, 32.8 ft2 Pack, 4 Pack, 6 Pack
Price$19.99 (16.4 ft), $35.99 (32.8 ft)$29.99 (16.4 ft), $44.99 (32.8 ft)$26.26 (2 Pack), $44.44 (4 Pack), $64.98 (6 Pack)
Colors16 million colors (one color per strip)Up to 16 colors per strip (multi-color segment control)16 million colors
Lighting EffectsBasic lighting effectsAdvanced lighting effectsCustom presets, white light temperature control
Protective CoatingNo epoxy coatingProtective epoxy coatingN/A
Music ModeYesYesYes
Sun MatchYesYesN/A
Voice ControlAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant, IFTTT
Vacation ModeYesYesYes
Sleep RoutinesYesYesYes
Timers & AutomationsYesYesN/A
ConnectivityNot specifiedNot specifiedWi-Fi 802.11 b/g/n 2.4GHz, Bluetooth
PowerNot specifiedNot specified12 watts
DimensionsNot specifiedNot specified2.5 x 2.5 x 5 inches
Life ExpectancyNot specifiedNot specified25,000 hours
Base TypeN/AN/AE26
Additional FeaturesPeel, stick, and plug installationTrimmable design, segment control chipDimmable, color rendering index 90+, tunable white, bright (1100 lumens)
What are the main features of the Wyze Light Strip Pro?The Wyze Light Strip Pro offers 16 customizable segments for dynamic, multi-color patterns, 16 million RGB colors plus tunable white, music sync mode, trimmable design, voice control with Alexa and Google Assistant, timers and automations, and a long lifespan of up to 25,000 hours. It is designed for indoor use and is available in 16.4 ft and 32.8 ft lengths.
How does the music sync feature work on Wyze LED strips?Both the Wyze Light Strip Pro and Wyze Light Strip feature a music sync mode that uses a built-in microphone to detect music beats and synchronize the lighting effects, creating an immersive party atmosphere.
Can I control Wyze LED strips and bulbs with my voice?Yes, Wyze Light Strip Pro and Wyze Bulb Color are compatible with Alexa and Google Assistant, allowing you to control your lighting hands-free using voice commands.
Are Wyze LED strips suitable for outdoor use?No, both the Wyze Light Strip Pro and Wyze Light Strip are designed for indoor use only and are not recommended for outdoor environments.
What is the difference between Wyze Light Strip Pro and Wyze Light Strip?The Wyze Light Strip Pro features 16 customizable segments for multi-color effects and advanced controls, while the Wyze Light Strip offers a single customizable zone for uniform color lighting. Both support music sync, are trimmable, and are available in 16.4 ft and 32.8 ft lengths.
How do I install Wyze LED strips?Wyze LED strips come with adhesive backing for easy mounting. They are trimmable, allowing you to cut them to fit your desired space. Simply peel, stick, and connect to power for quick installation.
What smart integrations are available for Wyze Bulb Color?Wyze Bulb Color works with Alexa, Google Assistant, and IFTTT, enabling seamless integration with your smart home ecosystem for easy control and automation.
Can Wyze Bulb Color be used in kitchens and bathrooms?Yes, Wyze Bulb Color is suitable for damp locations, making it safe for use in kitchens and bathrooms.
How long do Wyze LED strips and bulbs last?Both Wyze LED strips and Wyze Bulb Color are rated for up to 25,000 hours of use, providing long-lasting and energy-efficient lighting.
What connectivity options do Wyze lighting products offer?Wyze Light Strip Pro, Wyze Light Strip, and Wyze Bulb Color all support Wi-Fi (2.4 GHz) and Bluetooth connectivity, allowing for easy app control and integration with smart home devices.
Are Wyze lighting products energy efficient?Yes, Wyze smart lighting products use energy-efficient LEDs that provide vibrant illumination while consuming low power, helping you save on energy costs.
What lengths are available for Wyze LED strips?Both Wyze Light Strip Pro and Wyze Light Strip are available in 16.4 ft and 32.8 ft lengths to suit different room sizes and applications.
Can I automate my Wyze lighting for routines and schedules?Yes, Wyze Light Strip Pro supports timers, sleep routines, and vacation modes, allowing you to automate your lighting according to your daily schedule.
What is the price range for Wyze LED strips and bulbs?Wyze Light Strip Pro is priced between $29.99 and $44.99, Wyze Light Strip ranges from $19.99 to $35.99, and Wyze Bulb Color is available in packs priced from $26.26 to $64.98.
Can you tell me more about the features of the Wyze Light Strip Pro?How does the music sync feature work with the Wyze Light Strip?Do you have any deals, ongoing sales, discounts, or promotions?
