Advanced Multi-Color LED Light Strips for Smart Home Automation
Advanced Multi-Color LED Light Strips for Indoor Smart Home Automation
Transform your indoor spaces with cutting-edge multi-color LED light strips designed for smart home automation. Whether you want to create vibrant ambiance, sync lighting to your music, or automate your lighting routines, these advanced LED strips offer unparalleled customization and seamless integration with your smart home ecosystem.
Wyze Light Strip Pro: Ultimate Multi-Color Segment Control
Experience the next level of smart lighting with the Wyze Light Strip Pro, engineered to deliver up to 16 RGB colors simultaneously on a single strip. Unlike traditional LED strips that show only one color at a time, the Pro model features a chip between every 3 LEDs, enabling multi-color segment control and advanced lighting effects.
Key Features:
  • Multi-Color Segment Control: Display up to 16 colors at once for dynamic, layered lighting effects.
  • Protective Epoxy Coating: Durable clear coating protects components while maintaining flexibility and a sleek look.
  • Trimmable Design: Easily cut the strip at designated points to perfectly fit your space.
  • Music Mode: Sync lights to your favorite music using the built-in microphone for immersive party vibes.
  • Sun Match: Automatically adjusts color temperature to match the natural daylight cycle, enhancing your daily rhythm.
  • Voice Control: Compatible with Alexa and Google Assistant for hands-free lighting commands.
  • Vacation Mode & Sleep Routines: Simulate occupancy or create gradual wake-up and wind-down lighting schedules.
  • Sizes Available: 16.4 feet and 32.8 feet variants to suit different room sizes.
Customize your vibe with multi-color segment control and advanced smart features that bring your indoor lighting to life.
Wyze Light Strip Pro in Living Room Create vibrant living room lighting with Wyze Light Strip Pro
Wyze Light Strip: Brilliant Accent Lighting with 16 Million Colors
For those seeking brilliant LED accent lighting with simpler control, the Wyze Light Strip offers 16 million colors in a single-color-per-strip format. Perfect for backlighting screens, framing headboards, or brightening dark corners, this strip is easy to install and integrates smoothly with your smart home.
Highlights:
  • 16 Million Colors: Choose from a vast palette to color your world with stunning LED accents.
  • Music Mode: Lights pulse and change with your music beats for lively atmospheres.
  • Sun Match: Syncs with natural light cycles to support your daily routines.
  • Voice Control: Works with Alexa and Google Assistant for effortless adjustments.
  • Vacation Mode & Sleep Routines: Enhance security and comfort with automated lighting schedules.
  • Sizes Available: 16.4 feet and 32.8 feet options.
Add a splash of color anywhere with simple peel-and-stick installation and smart automation.
Wyze Light Strip in Kitchen Under-cabinet kitchen lighting with Wyze Light Strip
Smart Lighting Kit: Bulb Color BR30 + Light Strip Pro Bundle
Elevate your smart home lighting setup with the Smart Lighting Kit, combining the power of the Wyze Light Strip Pro with the versatile Wyze Bulb Color BR30. This bundle offers a comprehensive lighting solution for indoor spaces, blending accent strip lighting with powerful, tunable smart bulbs.
Bundle Features:
Wyze Bulb Color BR30:
  • Brightness range from 30 to 950 lumens
  • Color temperature adjustable from 1800K to 6500K
  • High color rendering index (90+) for vivid, natural colors
  • Long lifespan of 25,000 hours
  • Suitable for damp locations, perfect for bathrooms or kitchens
  • 16.4 feet of multi-color LED strip with 16 customizable zones
  • Advanced segment control and music sync
  • Connectivity: Both devices support 2.4 GHz Wi-Fi and Bluetooth for reliable smart home integration.
  • Indoor Use: Designed specifically for indoor environments with operating temperatures from -4°F to 122°F.
  • Warranty: 1-year coverage for peace of mind.
This kit is ideal for users who want a versatile, multi-functional lighting system that covers both ambient and accent lighting needs.
Why Choose Advanced Multi-Color LED Light Strips for Your Smart Home?
Multi-color LED strips are revolutionizing indoor lighting by offering customizable, dynamic, and automated lighting experiences that adapt to your lifestyle.
  • Personalized Ambiance: Create moods for every occasion with millions of colors and segment control.
  • Smart Automation: Integrate with voice assistants and smart home apps for effortless control.
  • Energy Efficient: LED technology ensures bright lighting with low power consumption.
  • Easy Installation: Flexible, trimmable strips with adhesive backing fit any indoor space.
  • Enhanced Security: Use vacation modes and timers to simulate occupancy when away.
Conclusion
For indoor smart home automation enthusiasts seeking advanced multi-color LED light strips, the Wyze Light Strip Pro stands out with its segment control and rich feature set. The Wyze Light Strip offers a brilliant, simpler alternative for accent lighting, while the Smart Lighting Kit bundle provides a comprehensive solution combining smart bulbs and LED strips. Upgrade your home lighting today to enjoy vibrant colors, smart automation, and immersive experiences tailored to your lifestyle.
Product Highlights Summary
  • Wyze Light Strip Pro: Multi-color segment control, music sync, sun match, trimmable, voice control.
  • Wyze Light Strip: 16 million colors, music mode, sun match, voice control, easy installation.
  • Smart Lighting Kit: Combines Wyze Bulb Color BR30 and Light Strip Pro for versatile smart lighting.
FeatureWyze Light Strip ProWyze Light StripSmart Lighting Kit - Bulb Color BR30 + Light Strip Pro BundleWyze Light Party
TypeSmart LightingConnected HomeSmart LightingConnected Home
Length Variants16.4 ft, 32.8 ft16.4 ft, 32.8 ft16.4 ft (with Bulb Color BR30)32.8 ft
Price$29.99 (16.4 ft), $44.99 (32.8 ft)$19.99 (16.4 ft), $35.99 (32.8 ft)$53.98 (2 Bulbs + Strip), $77.97 (4 Bulbs + Strip)$59.98 - $83.97 (varies by bundle)
Color CapabilityMulticolor (up to 16 RGB colors simultaneously)One color per stripMulticolor (16 million colors)16 million colors (RGB + tunable white)
Segment ControlYes, chip between every 3 LEDs for multi-color zonesNoYes (Light Strip Pro included)Basic (customizable zones: 1)
Protective CoatingClear epoxy coatingNoYes (Light Strip Pro included)No
Music ModeYes, syncs to music via built-in microphoneYes, syncs to music via built-in microphoneYes (Light Strip Pro included)Yes
Sun MatchYes, syncs color temperature to natural light cycleYes, syncs color temperature to natural light cycleYes (Light Strip Pro included)Yes
Voice ControlAlexa, Google AssistantAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant
Vacation ModeYesYesYesYes
Sleep RoutinesYesYesYesYes
Timers & AutomationsYesYesYesYes
Included BulbsNoNoWyze Bulb Color BR30 included (2 or 4 pack)Wyze Bulb Color or BR30 bulbs included (varies)
Customizable Zones16116 (Light Strip Pro)1
Communication ModesWi-Fi 802.11 b/g/n, 2.4 GHz, BluetoothWi-Fi 802.11 b/g/n, 2.4 GHz, BluetoothWi-Fi 802.11 b/g/n, 2.4 GHz, BluetoothWi-Fi 802.11 b/g/n, 2.4 GHz, Bluetooth
Operating Temperature-4°F to 122°FNot specified-4°F to 122°F-4°F to 104°F
Warranty1 YearNot specified1 Year1 Year
What are the main differences between Wyze Light Strip Pro and Wyze Light Strip?The Wyze Light Strip Pro features advanced multi-color segment control, allowing up to 16 colors to display simultaneously on a single strip, and includes a protective epoxy coating. The standard Wyze Light Strip offers 16 million colors but displays only one color at a time per strip. Both models support music sync, sun match, voice control, and come in 16.4 ft and 32.8 ft lengths.
How does multi-color segment control work on the Wyze Light Strip Pro?Multi-color segment control on the Wyze Light Strip Pro is enabled by a chip between every 3 LEDs, allowing up to 16 different colors to be displayed at once on a single strip. This creates dynamic, layered lighting effects that are not possible with traditional single-color LED strips.
Can I control Wyze LED light strips with voice assistants?Yes, both the Wyze Light Strip Pro and Wyze Light Strip are compatible with Alexa and Google Assistant, allowing you to control your lighting with simple voice commands for hands-free convenience.
What is the Sun Match feature on Wyze LED light strips?The Sun Match feature automatically adjusts the color temperature of your Wyze LED light strips to match the natural daylight cycle. This helps support your daily rhythm by providing energizing light during the day and warmer tones in the evening.
How does Music Mode work on Wyze Light Strips?Music Mode uses a built-in microphone to sync the LED lights with your music, causing the lights to pulse and change colors in time with the beat. This feature is available on both the Wyze Light Strip Pro and Wyze Light Strip, creating immersive party or entertainment lighting.
Are Wyze LED light strips easy to install?Yes, Wyze LED light strips feature a flexible, trimmable design with adhesive backing, making them easy to install on various indoor surfaces. You can cut the strips at designated points to fit your space perfectly.
What is included in the Smart Lighting Kit bundle?The Smart Lighting Kit bundle includes a Wyze Light Strip Pro (16.4 ft) with multi-color segment control and a Wyze Bulb Color BR30. The BR30 bulb offers adjustable brightness (30–950 lumens), tunable color temperature (1800K–6500K), high color rendering, and is suitable for damp locations. Both devices support 2.4 GHz Wi-Fi and Bluetooth.
Are Wyze LED light strips energy efficient?Yes, Wyze LED light strips use energy-efficient LED technology, providing bright and vibrant lighting while consuming less power compared to traditional lighting solutions.
Can Wyze LED light strips be used for security purposes?Yes, both Wyze Light Strip Pro and Wyze Light Strip offer Vacation Mode and customizable timers, allowing you to simulate occupancy and enhance home security when you are away.
What warranty is offered with Wyze smart lighting products?Wyze smart lighting products, including the Light Strip Pro, Light Strip, and Bulb Color BR30, come with a 1-year warranty for added peace of mind.
Are Wyze LED light strips suitable for outdoor use?No, Wyze LED light strips and the Smart Lighting Kit are designed specifically for indoor use, with operating temperatures ranging from -4°F to 122°F.
What sizes are available for Wyze Light Strip Pro and Wyze Light Strip?Both the Wyze Light Strip Pro and Wyze Light Strip are available in 16.4 feet and 32.8 feet lengths, making them suitable for a variety of indoor spaces.
What are the key features of the Wyze Light Strip Pro?How does the music mode work with the Wyze Light Strip?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Light Strip?
