IP67 Waterproof Outdoor LED Lights with Long Lasting 100ft Installation
When it comes to securing and illuminating your outdoor spaces, choosing the right waterproof LED lights and cameras is essential. For durable, weather-resistant solutions that offer long-lasting performance and easy installation up to 100 feet, Wyze offers a range of cutting-edge outdoor cameras and lighting products designed to meet your needs.
Explore the best Wyze outdoor cameras and floodlights that combine IP65 weather resistance, vibrant LED illumination, and smart features for ultimate home security and convenience.
Wyze Cam Floodlight v2: Powerful IP65 Waterproof Outdoor LED Lighting
Experience bright, smart lighting with Wyze Cam Floodlight v2
The Wyze Cam Floodlight v2 is the ultimate outdoor LED light solution for those seeking powerful illumination combined with smart security features:
- 2800 Lumens Brightness: Two dimmable LED light panels provide intense, clear lighting to brighten large outdoor areas.
- IP65 Weather Resistance: Built to withstand rain, snow, and harsh weather conditions, ensuring reliable performance year-round.
- 2K Video with Color Night Vision: Capture crystal-clear video footage with a 160° wide-angle view, even in low light.
- Motion-Activated Spotlight & Siren: Automatically light up your driveway or yard when motion is detected, plus a 105dB siren to deter intruders.
- 24/7 Local Recording: Supports up to 256GB microSD card for continuous video storage without subscription fees.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation.
- Hardwired Power Supply: Ensures continuous power for long-lasting operation and supports installation distances up to 100 feet with proper wiring.
This floodlight is perfect for illuminating driveways, backyards, and entryways, providing both safety and peace of mind.
Wyze Cam v4: Advanced IP65 Weather-Resistant Outdoor Camera with Spotlight
Secure your home with Wyze Cam v4’s enhanced night vision and spotlight
Wyze Cam v4 is a versatile outdoor camera that combines high-resolution video with smart lighting features:
- IP65 Weather Resistance: Designed to operate flawlessly in rain, snow, and extreme temperatures.
- 2.5K QHD Resolution: Capture stunningly clear video with enhanced color night vision for detailed monitoring day and night.
- Motion-Activated Spotlight & Siren: Light your path or scare off unwanted visitors with a built-in spotlight and 99 dB siren.
- Wi-Fi 6 Support: Enjoy a stronger, more reliable connection even at longer distances.
- 24/7 Local Recording: Continuous recording to microSD card (up to 256GB) without monthly fees.
- Easy Installation: Magnetic mount and screw-free setup make installation quick and flexible, supporting long cable runs up to 100 feet.
- Smart Assistant Compatibility: Works seamlessly with Alexa, Google Assistant, and IFTTT for voice commands and automation.
Wyze Cam v4 is ideal for homeowners looking for a smart, weatherproof camera with integrated lighting to secure outdoor spaces effectively.
Wyze Cam Pan v3: Weather-Resistant 360° Outdoor Security Camera
Full coverage outdoor security with Wyze Cam Pan v3
For comprehensive outdoor surveillance with flexible coverage, the Wyze Cam Pan v3 offers:
- IP65 Weather Resistance: Suitable for outdoor use with the Wyze Outdoor Power Adapter (sold separately).
- 360° Pan and 180° Tilt: Covers every angle of your property with smooth, quiet motorized movement.
- 1080p HD Video with Color Night Vision: See clear, colorful footage even in darkness.
- Automatic Motion Tracking: The camera follows moving objects automatically for detailed monitoring.
- Two-Way Audio: Communicate through the camera using the Wyze app.
- Customizable Detection Zones: Focus alerts on specific areas to reduce false alarms.
- Long Cable Support: Compatible with outdoor power adapters and cables that support installations up to 100 feet.
This camera is perfect for users who want dynamic, full-area outdoor surveillance with reliable weatherproofing.
Why Choose Wyze for Your Outdoor LED Lighting and Security?
Wyze products combine robust IP65 weather resistance with smart features and easy installation, making them ideal for outdoor use in any climate. Whether you need bright LED floodlights or versatile security cameras with integrated lighting, Wyze offers solutions that last and perform.
- Durability: All outdoor cameras and lights are rated IP65, ensuring protection against dust and water jets.
- Long-Range Installation: Hardwired options and power adapters support cable runs up to 100 feet, perfect for large properties.
- Smart Features: Motion detection, AI-powered alerts, two-way audio, and smart assistant compatibility enhance security and convenience.
- Local Storage & Cloud Options: Flexible recording options with microSD cards and optional cloud subscriptions.
- Affordable & Reliable: High-quality performance without breaking the bank.
Summary of Featured Products
Product Name | Waterproof Rating | Lighting Type | Video Resolution | Installation Range | Key Features |
Wyze Cam Floodlight v2 | IP65 | 2800 Lumens LED Flood | 2K | Hardwired, 100ft+ | Motion spotlight, siren, 24/7 local |
Wyze Cam v4 | IP65 | Motion-Activated LED | 2.5K QHD | Wired, 100ft+ | Spotlight, siren, Wi-Fi 6, 24/7 local |
Wyze Cam Pan v3 | IP65 | No built-in LED light | 1080p HD | Wired, 100ft+ | 360° pan/tilt, motion tracking |
Enhance Your Outdoor Setup with Wyze Accessories
To maximize your outdoor lighting and security system, consider adding:
- Wyze Outdoor Power Adapter: Ensures safe, weatherproof power delivery for cameras.
- MicroSD Cards: For extended local video storage up to 256GB.
- Smart Switches: Control your outdoor lights remotely and automate schedules.
Invest in Wyze’s IP65 waterproof outdoor LED lights and cameras for a secure, well-lit home environment with easy, long-lasting installation up to 100 feet.
What does IP65 waterproof rating mean for Wyze outdoor LED lights and cameras?
An IP65 waterproof rating means Wyze outdoor LED lights and cameras are protected against dust and water jets from any direction, making them suitable for use in rain, snow, and harsh weather conditions.How far can Wyze outdoor cameras and lights be installed from a power source?
Wyze outdoor cameras and LED lights support installation distances up to 100 feet or more when using hardwired power supplies or compatible outdoor power adapters, making them ideal for large properties.Which Wyze outdoor camera has built-in LED floodlights?
The Wyze Cam Floodlight v2 features two dimmable LED light panels with 2800 lumens brightness, providing powerful illumination for driveways, backyards, and entryways.Can Wyze outdoor cameras record video continuously without a subscription?
Yes, Wyze outdoor cameras support 24/7 local recording to microSD cards (up to 256GB), allowing continuous video storage without monthly subscription fees.Are Wyze outdoor cameras compatible with smart home assistants?
Yes, Wyze outdoor cameras and lights are compatible with Alexa, Google Assistant, and IFTTT, enabling voice control and smart home automation.What are the main differences between Wyze Cam Floodlight v2, Wyze Cam v4, and Wyze Cam Pan v3?
Wyze Cam Floodlight v2 offers 2800 lumens LED floodlights and 2K video; Wyze Cam v4 features motion-activated LED spotlight, 2.5K QHD video, and Wi-Fi 6; Wyze Cam Pan v3 provides 360° pan and 180° tilt coverage with 1080p HD video but does not have built-in LED lighting.How do Wyze outdoor cameras enhance home security?
Wyze outdoor cameras offer features like motion-activated spotlights, sirens, color night vision, two-way audio, and customizable detection zones to deter intruders and provide real-time alerts for enhanced home security.What accessories are recommended for Wyze outdoor LED lights and cameras?
Recommended accessories include the Wyze Outdoor Power Adapter for weatherproof power delivery, microSD cards for extended local storage, and smart switches for remote control and automation of your outdoor lighting.Can Wyze outdoor cameras be installed easily?
Yes, Wyze outdoor cameras are designed for easy installation, with options like magnetic mounts, screw-free setups, and long cable support for flexible placement up to 100 feet from the power source.Do Wyze outdoor cameras work in extreme weather conditions?
Yes, all Wyze outdoor cameras and lights are rated IP65, ensuring reliable operation in rain, snow, and extreme temperatures for year-round outdoor use.
