IP65 Weather Resistant Refurbished Wyze Wired Doorbell for Outdoor Installation
When it comes to securing your home’s entrance, having a reliable, weatherproof wired doorbell is essential. Wyze offers top-tier smart security solutions that combine durability, high-definition video, and smart features designed specifically for outdoor use. Whether you want a standalone wired doorbell or a complete front porch security system, Wyze’s IP65 weather-resistant products ensure your home stays protected rain or shine.
Wyze Video Doorbell v2: The Ultimate Wired Doorbell for Outdoor Use
Crystal Clear 2K Video Quality
Wyze Video Doorbell v2 delivers stunning 2K resolution video, providing sharp, detailed footage of your porch and visitors. With a 120° vertical by 88° horizontal field of view, you get a comprehensive head-to-toe view of anyone approaching your door.
Robust IP65 Weather Resistance
Built to withstand harsh weather conditions, the Wyze Video Doorbell v2 is rated IP65, meaning it resists dust and water jets from any direction. This makes it perfect for outdoor installation, ensuring reliable performance through rain, snow, or shine.
Local MicroSD Storage & Continuous Recording
Unlike many doorbells, this model includes a microSD card slot for 24/7 local recording. Capture every moment before, during, and after a doorbell press or motion event without relying solely on cloud storage.
Two-Way Audio & Motion-Activated Voice Deterrence
Communicate directly with visitors using two-way talk through the Wyze app. The doorbell also features motion-activated voice deterrence, which can warn unwanted guests that they are being recorded, enhancing your home’s security.
Easy Integration & Compatibility
Wyze Video Doorbell v2 works seamlessly with your existing door chime thanks to the included chime controller. It also integrates with Alexa and Google Home, allowing you to view live feeds and receive smart alerts on your voice assistant devices.
Included 30° Corner Wedge Kit
To optimize your doorbell’s viewing angle, a 30° corner wedge is included, perfect for angled door frames or porches with stairs, eliminating blind spots and maximizing coverage.
Wyze Cam Pan v3: Versatile IP65 Weather-Resistant Outdoor Camera
Wyze Cam Pan v3 in snowy outdoor setting, showcasing its IP65 weather resistance
360° Pan and 180° Tilt for Full Coverage
The Wyze Cam Pan v3 offers a complete 360° horizontal and 180° vertical field of view, allowing you to monitor every corner of your porch or yard. Its quiet, upgraded tracking motor automatically follows motion without disturbing your household.
IP65 Weatherproof Design
Designed for outdoor use, the Cam Pan v3 is fully IP65 rated, making it resistant to dust and water jets. It requires the Wyze Outdoor Power Adapter (sold separately) for safe and reliable outdoor power.
Color Night Vision & Motion Tracking
Equipped with a Starlight Sensor, the camera provides vivid color night vision, ensuring clear footage even in low light. Its automatic motion tracking detects and follows movement, capturing every detail.
Two-Way Audio & Privacy Mode
Communicate with visitors or pets through built-in two-way audio with noise and echo cancellation. When privacy is needed, activate Privacy Mode to point the camera lens downward and disable recording.
Smart Features & App Integration
Set custom detection zones, receive push notifications, and enjoy compatibility with Alexa, Google Assistant, and IFTTT. Supports local storage up to 256GB microSD cards and offers cloud storage options with Cam Plus.
Front Porch Security Bundle: Complete Wired Doorbell & Lock Solution
For those seeking an all-in-one front porch security upgrade, the Wyze Front Porch Security Bundle combines the Wyze Video Doorbell v2 with Wyze Lock and Chime for seamless control and monitoring.
Features of the Bundle
- 1080p HD video doorbell with two-way audio and IP65 weather resistance
- Remote lock/unlock capabilities with Wyze Lock and lock history tracking
- Motion event alerts and integration with Alexa and Google Assistant
- Includes all necessary mounting hardware, chime, and accessories for easy installation
This bundle is perfect for homeowners wanting a comprehensive, wired outdoor security system with smart home integration.
Why Choose Wyze for Your Outdoor Wired Doorbell?
Wyze products stand out for their combination of affordability, advanced features, and robust weather resistance. The IP65 rating ensures your wired doorbell and cameras perform reliably outdoors, protecting your home in all weather conditions.
With Wyze’s wired doorbell and outdoor cameras, you get:
- High-resolution video with wide viewing angles
- Durable, weatherproof construction for outdoor installation
- Two-way audio for real-time communication
- Local and cloud storage options for video recordings
- Smart home compatibility with Alexa and Google Assistant
Summary of Recommended Products for IP65 Weather Resistant Wired Doorbell Outdoor Installation
Product Name | Key Features | IP Rating | Price Range |
Wyze Video Doorbell v2 | 2K video, two-way audio, local microSD, wedge kit | IP65 | $44.98 |
Wyze Cam Pan v3 | 360° pan, 180° tilt, color night vision, motion tracking | IP65 | $39.98 |
Front Porch Security Bundle | Doorbell v2 + Wyze Lock + Chime, full porch security | IP65 | $124.96+ |
Engage with visitors or pets easily using Wyze’s two-way audio feature
Installation Tips for Outdoor Wired Doorbell
- Ensure your existing doorbell wiring is compatible with Wyze Video Doorbell v2 (16V-24V AC, ≥10VA)
- Use the included chime controller to maintain your home’s traditional doorbell sound
- Utilize the 30° wedge kit for optimal camera angle on angled door frames or porches with stairs
- For Wyze Cam Pan v3 outdoor use, purchase the Wyze Outdoor Power Adapter for safe weatherproof power supply
- Mount devices securely using the provided mounting kits and follow Wyze’s quick start guides
Wyze’s IP65 weather-resistant wired doorbell and outdoor cameras provide a smart, durable, and affordable solution for enhancing your home’s security. Whether you want a standalone wired doorbell or a full front porch security system, Wyze has you covered with advanced features and reliable outdoor performance.
What does IP65 weather resistance mean for Wyze wired doorbells and cameras?
IP65 weather resistance means that Wyze wired doorbells and cameras are protected against dust and water jets from any direction. This rating ensures reliable performance outdoors, even in harsh weather conditions like rain, snow, or dust storms.Is the Wyze Video Doorbell v2 suitable for outdoor installation?
Yes, the Wyze Video Doorbell v2 is specifically designed for outdoor installation. It features an IP65 weather-resistant rating, making it durable and reliable in all weather conditions.What video quality does the Wyze Video Doorbell v2 offer?
The Wyze Video Doorbell v2 delivers crystal clear 2K resolution video with a 120° vertical by 88° horizontal field of view, providing sharp, detailed footage and a comprehensive view of your porch and visitors.Does the Wyze Video Doorbell v2 support local video storage?
Yes, the Wyze Video Doorbell v2 includes a microSD card slot for 24/7 local recording. This allows you to capture every moment before, during, and after a doorbell press or motion event without relying solely on cloud storage.Can I communicate with visitors using the Wyze Video Doorbell v2?
Absolutely. The Wyze Video Doorbell v2 features two-way audio, allowing you to speak directly with visitors through the Wyze app. It also includes motion-activated voice deterrence to warn unwanted guests that they are being recorded.Is the Wyze Video Doorbell v2 compatible with Alexa and Google Home?
Yes, the Wyze Video Doorbell v2 integrates seamlessly with Alexa and Google Home. You can view live feeds and receive smart alerts on your voice assistant devices.What is included with the Wyze Video Doorbell v2 for installation?
The Wyze Video Doorbell v2 comes with a chime controller for compatibility with your existing door chime and a 30° corner wedge kit to optimize the viewing angle, especially for angled door frames or porches with stairs.What are the key features of the Wyze Cam Pan v3 outdoor camera?
The Wyze Cam Pan v3 offers 360° pan and 180° tilt for full coverage, IP65 weatherproof design, color night vision with a Starlight Sensor, automatic motion tracking, two-way audio, privacy mode, and compatibility with Alexa, Google Assistant, and IFTTT.Does the Wyze Cam Pan v3 require any special accessories for outdoor use?
Yes, for safe and reliable outdoor power, the Wyze Cam Pan v3 requires the Wyze Outdoor Power Adapter, which is sold separately.Can I store video locally on the Wyze Cam Pan v3?
Yes, the Wyze Cam Pan v3 supports local storage with microSD cards up to 256GB, allowing for continuous recording and playback without relying solely on cloud storage.What is included in the Wyze Front Porch Security Bundle?
The Wyze Front Porch Security Bundle includes the Wyze Video Doorbell v2, Wyze Lock, and Chime. It offers 1080p HD video, two-way audio, IP65 weather resistance, remote lock/unlock capabilities, motion event alerts, and integration with Alexa and Google Assistant.How do I install the Wyze Video Doorbell v2 outdoors?
To install the Wyze Video Doorbell v2 outdoors, ensure your existing doorbell wiring is compatible (16V-24V AC, ≥10VA), use the included chime controller, and mount the device securely with the provided hardware. Utilize the 30° wedge kit for optimal camera angle if needed.Why should I choose Wyze for my outdoor wired doorbell and security camera needs?
Wyze offers affordable, advanced, and weather-resistant security solutions. Their products feature high-resolution video, wide viewing angles, durable IP65 construction, two-way audio, local and cloud storage options, and smart home compatibility with Alexa and Google Assistant.What are the price ranges for Wyze’s IP65 weather-resistant security products?
The Wyze Video Doorbell v2 is priced at $44.98, the Wyze Cam Pan v3 at $39.98, and the Front Porch Security Bundle starts at $124.96. These prices offer affordable options for comprehensive outdoor security.Can I use Wyze’s two-way audio feature to interact with visitors or pets?
Yes, Wyze’s two-way audio feature allows you to easily communicate with visitors or pets through the Wyze app, enhancing convenience and security at your front door.
