DIY Install IP65 Wired Video Doorbell for Front Porch Security
DIY Install IP65 Weather Resistant Wired Video Doorbell for Front Porch
Enhance your front porch security with a reliable, weather-resistant wired video doorbell that you can easily install yourself. Whether you want crystal-clear video, two-way audio, or smart home integration, the right video doorbell can provide peace of mind and convenience. Below, explore top Wyze products designed for DIY installation, all featuring IP65 weather resistance to withstand outdoor elements.
Wyze Video Doorbell v2: Clear 2K Wired Video Doorbell with Weather Resistance
The Wyze Video Doorbell v2 is a standout choice for a wired, weatherproof video doorbell designed for front porch use. It offers:
  • 2K Video Resolution (2048 x 1536) for sharp, detailed footage day and night.
  • IP65 Weather Resistance, ensuring durability against rain, snow, and dust.
  • Wide Field of View: 135° horizontal and 103° vertical, covering a broad area.
  • Two-Way Audio with noise and echo cancellation to communicate with visitors.
  • Local Storage: Supports microSD cards up to 256GB for continuous recording.
  • Motion-Activated Voice Deterrence to help ward off unwanted guests.
  • Easy DIY Installation: Comes with a complete installation kit including wire caps, screws, wall plate, and wedge for angled mounting.
This doorbell operates on 16V-24V AC power and integrates seamlessly with Alexa, Google Assistant, and IFTTT for smart home control.
Perfect for homeowners seeking a high-resolution wired doorbell that stands up to all weather conditions.
Wyze Video Doorbell v2 on Front Porch Stylish and weather-resistant Wyze Video Doorbell v2 installed on a front porch.
The Front Porch Security Bundle: Complete Smart Home Security Solution
For those wanting an all-in-one front porch security upgrade, the Front Porch Security Bundle combines the Wyze Video Doorbell with smart lock technology:
  • 1080p HD Video Doorbell with two-way audio and motion detection.
  • Wyze Lock for remote locking/unlocking and lock history monitoring via the Wyze app.
  • IP65 Weather Resistance on the doorbell for reliable outdoor use.
  • Multiple Chime Sounds and automation options for personalized alerts.
  • Smart Home Integration: Works with Alexa and Google Assistant.
  • Remote Access: View your porch and control your lock from anywhere.
This bundle is ideal for DIY enthusiasts who want to secure their front porch and door with a single, easy-to-install package.
A perfect smart home starter kit for enhanced porch security and convenience.
Wyze Video Doorbell Pro: Wired or Battery-Powered with Ultra-Wide View
If you want flexibility in power options and a wider viewing angle, the Wyze Video Doorbell Pro offers:
  • Crystal-clear HD Video with ultra-wide viewing angle for maximum coverage.
  • Dual Power Options: Hardwired or battery-powered for easy installation.
  • IP65 Weather Resistance to endure outdoor conditions.
  • Smart Detection Alerts: Person, package, vehicle, and pet detection with Cam Plus subscription.
  • Motion-Activated Security Light for added safety.
  • Two-Way Audio with quick response capability.
  • Multiple Chime Tunes and Volume Levels for customizable alerts.
  • Screw or Adhesive Mounting: Install in 30 seconds with no hassle.
This doorbell is perfect for users who want a versatile, high-performance wired video doorbell with smart features and easy DIY setup. Wyze Video Doorbell Pro Lifestyle Wyze Video Doorbell Pro providing wide-angle coverage and smart alerts.
Wyze Video Doorbell (Wired): Compact Full HD Wired Doorbell with IP65 Rating
For a more budget-friendly wired video doorbell option, the Wyze Video Doorbell (Wired) offers:
  • 1080p Full HD Video with 120° vertical and 88° horizontal field of view.
  • IP65 Weather Resistance for reliable outdoor use.
  • Two-Way Audio with noise and echo cancellation.
  • Motion Detection with real-time alerts.
  • 8x Digital Zoom for close-up views.
  • Easy DIY Installation: Includes wedge for angled mounting and all necessary hardware.
  • Smart Home Compatibility: Alexa, Google Assistant, and IFTTT support.
This doorbell is ideal for those who want a simple, effective wired video doorbell with solid weatherproofing and clear video.
Wyze Video Doorbell v2 Wedge Kit: Perfect Angle Adjustment Accessory
To complement the Wyze Video Doorbell v2, the Wedge Kit accessory allows you to:
  • Adjust Viewing Angles with 15° horizontal and 7.5° vertical brackets.
  • Eliminate Blind Spots on angled door frames or porches with stairs.
  • Weather-Resistant Design to match the doorbell’s durability.
  • Quick and Easy Installation with included screws and guide.
Compatible Only with Wyze Video Doorbell v2. This accessory is essential for optimizing your doorbell’s field of view and ensuring maximum porch coverage.
Why Choose an IP65 Weather Resistant Wired Video Doorbell?
IP65 rating means your video doorbell is dust-tight and protected against water jets from any direction, making it perfect for outdoor front porch installation in all weather conditions.
Wired video doorbells with IP65 certification provide:
  • Reliable Power Supply: No need to worry about battery life.
  • Consistent Connectivity: Stable Wi-Fi connection for real-time alerts.
  • Durability: Withstand rain, snow, dust, and temperature extremes.
  • Enhanced Security: High-resolution video and two-way audio for clear communication.
Conclusion
For a DIY install of an IP65 weather resistant wired video doorbell on your front porch, Wyze offers several excellent options:
  • Wyze Video Doorbell v2 for high-resolution 2K video and robust weatherproofing.
  • Front Porch Security Bundle for a comprehensive smart home security upgrade.
  • Wyze Video Doorbell Pro for flexible power options and ultra-wide coverage.
  • Wyze Video Doorbell (Wired) for a compact, budget-friendly full HD solution.
  • Wedge Kit accessory to perfect your doorbell’s viewing angle.
Each product is designed for easy installation, smart home integration, and reliable outdoor performance, making your front porch safer and smarter.
FeatureWyze Video Doorbell v2The Front Porch Security BundleWyze Video Doorbell ProWyze Video Doorbell (Wired)Wyze Video Doorbell v2 Wedge Kit
TypeWired Video DoorbellBundle (Wyze Lock + Video Doorbell and Chime)Wired/Wireless Video DoorbellWired Video DoorbellAccessory (Wedge Kit for Doorbell v2)
Video Resolution2K (2304 x 1296)1080p HD (Doorbell in bundle)HD (exact resolution not specified, wider view)1080p Full HD (2048 x 1536 sensor)N/A
Field of ViewHead-to-toe view (exact degrees not specified)Not specifiedUltra-wide viewing angle120° Vertical x 88° HorizontalAdjusts viewing angle (15° horizontal, 7.5° vertical brackets)
Local StoragemicroSD card slot (continuous local recording)Included with doorbellNot specifiedNot specifiedN/A
Cloud StorageOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscriptionN/A
Two-Way AudioYesYesYesYesN/A
Motion-Activated Voice DeterrenceYes (requires Cam Plus or Cam Protect)Not specifiedYesNot specifiedN/A
Pre-roll Motion Recording3-6 secondsNot specifiedNot specifiedNot specifiedN/A
Weather ResistanceIP65IP65 (doorbell)Not specifiedIP65Weather resistant
Chime CompatibilityWorks with existing chime; chime controller includedIncluded with doorbell and chimeChime includedExisting chime will NOT work after installationN/A
PowerWiredWired (doorbell) + Battery (Wyze Lock)Wired or BatteryWiredN/A
Integration with Smart AssistantsAlexa, Google HomeNot specifiedAlexa, Google AssistantAlexa, Google Assistant, IFTTTN/A
Additional FeaturesMotion-activated voice deterrence, quick responses, custom detection zones, 30° corner kit includedIncludes Wyze Lock for remote locking/unlockingMotion-activated security light, 20 chime tunes, quick responses8x digital zoom, noise/echo cancellation, multiple chime soundsIncludes 1x 15° horizontal bracket, 2x 7.5° vertical brackets
Price$44.98$123.99 - $173.97 (varies by variant)$99.98$29.99 - $34.99$8.99 (Wedge Kit Only), $51.97 (Doorbell v2 + Wedge Kit)
InstallationWired, includes mounting wedgeBundle includes devices, installation variesWired or wireless, screw or adhesive mountWired, includes mounting hardwareQuick installation
What is an IP65 weather resistant wired video doorbell?An IP65 weather resistant wired video doorbell is a security device designed for outdoor use, featuring a dust-tight and water-resistant build. The IP65 rating ensures the doorbell can withstand rain, snow, dust, and water jets from any direction, making it ideal for front porch installation in all weather conditions.
Which Wyze video doorbell is best for high-resolution video and weather resistance?The Wyze Video Doorbell v2 is the best choice for high-resolution video and weather resistance. It offers 2K video resolution (2048 x 1536), IP65 weather resistance, a wide field of view, two-way audio, and easy DIY installation, making it perfect for front porch security.
Can I install a Wyze video doorbell myself?Yes, all Wyze video doorbells are designed for easy DIY installation. Each product comes with a complete installation kit, including wire caps, screws, wall plates, and wedges for angled mounting, allowing homeowners to set up their doorbell without professional help.
What smart home systems are Wyze video doorbells compatible with?Wyze video doorbells are compatible with popular smart home systems, including Amazon Alexa, Google Assistant, and IFTTT. This allows you to integrate your doorbell with your existing smart home devices for enhanced convenience and control.
What is included in the Wyze Front Porch Security Bundle?The Wyze Front Porch Security Bundle includes a 1080p HD video doorbell with two-way audio and motion detection, a Wyze Lock for remote locking and unlocking, IP65 weather resistance, multiple chime sounds, automation options, and smart home integration with Alexa and Google Assistant.
Does the Wyze Video Doorbell Pro offer both wired and battery-powered installation?Yes, the Wyze Video Doorbell Pro offers dual power options. You can install it as a wired doorbell or use the battery-powered option for flexible and hassle-free installation, making it suitable for various front porch setups.
What are the benefits of using a wired video doorbell over a battery-powered one?Wired video doorbells provide a reliable power supply, eliminating the need to recharge or replace batteries. They also offer consistent connectivity for real-time alerts and are generally more durable for long-term outdoor use.
How does the Wyze Video Doorbell v2 Wedge Kit improve installation?The Wyze Video Doorbell v2 Wedge Kit allows you to adjust the viewing angle of your doorbell by 15° horizontally and 7.5° vertically. This helps eliminate blind spots on angled door frames or porches with stairs, ensuring optimal coverage and security.
What features does the Wyze Video Doorbell (Wired) offer for budget-conscious buyers?The Wyze Video Doorbell (Wired) is a compact, budget-friendly option that provides 1080p full HD video, IP65 weather resistance, two-way audio, motion detection with real-time alerts, 8x digital zoom, and easy DIY installation. It also supports Alexa, Google Assistant, and IFTTT for smart home integration.
What security features are available with Wyze video doorbells?Wyze video doorbells offer high-resolution video, two-way audio with noise and echo cancellation, motion detection, motion-activated voice deterrence, and smart detection alerts for people, packages, vehicles, and pets (with Cam Plus subscription). Some models also include a motion-activated security light for added safety.
What are the installation requirements for the Wyze Video Doorbell v2?Can the Wyze Video Doorbell v2 be integrated with other smart home devices?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Video Doorbell?
