Wyze Duo Cam: Durable Doorbell Camera for Extreme Weather
Durable Doorbell Cameras Built for Extreme Weather Conditions
When it comes to securing your home’s entryway, having a doorbell camera that withstands harsh weather while delivering crystal-clear video is essential. Wyze offers some of the most reliable and weather-resistant doorbell cameras designed to perform flawlessly in extreme conditions. Whether you face heavy rain, snow, or scorching heat, these devices ensure your home stays protected and connected.
Wyze Video Doorbell v2: The Ultimate Weather-Resistant Doorbell Camera
Exceptional Video Quality and Weather Durability
The Wyze Video Doorbell v2 is engineered for durability and clarity. Featuring a robust polycarbonate body and resin lens, this wired doorbell camera delivers stunning 2K (2048 x 1536) resolution video, capturing every detail with its CMOS Starlight Sensor and F2.0 aperture. Its wide 166.8° diagonal field of view ensures you never miss a visitor or package.
Built to Brave the Elements
Certified with an IP65 weather resistance rating, the Wyze Video Doorbell v2 operates reliably in temperatures ranging from -4°F to 122°F (-20°C to 50°C). This makes it perfect for extreme weather conditions, from freezing winters to hot summers. The device also supports local microSD storage up to 256GB and cloud storage options for secure video retention.
Smart Features for Enhanced Security
  • Two-way audio with noise and echo cancellation lets you communicate clearly with visitors.
  • Motion-activated voice deterrence helps ward off unwanted guests.
  • Real-time alerts keep you informed instantly.
  • Integrates seamlessly with Alexa, Google Assistant, and IFTTT for smart home automation.
What’s Included
The package comes complete with the Wyze Video Doorbell v2, a chime controller, wall plate, wedge for angled mounting, installation kit, wire caps, extension wires, screws, and a quick start guide.
The Front Porch Security Bundle: Comprehensive Protection with Convenience
All-in-One Smart Home Security
For those seeking a complete front porch security solution, the Wyze Front Porch Security Bundle combines the Wyze Video Doorbell with Wyze Lock and Wyze Chime. This bundle offers 1080p HD video, two-way audio, and remote door locking/unlocking capabilities, all managed through the Wyze app.
Weather-Resistant and Reliable
The included Wyze Video Doorbell in this bundle is IP65 rated, ensuring it withstands rain, snow, and dust. It operates in the same temperature range as the standalone doorbell, making it ideal for extreme weather conditions.
Enhanced Security Features
  • View motion events and lock history remotely.
  • Works with Alexa and Google Assistant for voice control.
  • Multiple chime sounds and automation options included.
Additional Weather-Resistant Wyze Cameras for Outdoor Security
Wyze Cam Pan v3: 360° Weatherproof Surveillance
Wyze Cam Pan v3 in Snowy Outdoor Setting The Wyze Cam Pan v3 is a versatile indoor/outdoor camera with 360° horizontal pan and 180° vertical tilt, providing comprehensive coverage of your property. Its IP65 rating guarantees protection against rain and dust, and it operates efficiently in temperatures from -4°F to 122°F (-20°C to 50°C).
  • 1080p HD video with 20 FPS daytime and 15 FPS nighttime.
  • 8x digital zoom and 120° field of view.
  • Two-way audio with noise and echo cancellation.
  • Requires Wyze Outdoor Power Adapter for safe outdoor use.
Wyze Battery Cam Pro: Wire-Free, Weatherproof Security
The Wyze Battery Cam Pro offers 2.5K HDR video resolution with integrated spotlight and siren, perfect for wire-free outdoor monitoring. Its IP65 weatherproof rating and operating temperature range of -4°F to 122°F (-20°C to 50°C) make it a durable choice for extreme climates.
  • Removable rechargeable battery packs with up to 6 months battery life.
  • Radar + PIR motion detection for precise alerts.
  • Two-way audio and 100 dB siren.
  • Supports 2.4 GHz and 5 GHz Wi-Fi for flexible connectivity.
Why Choose Wyze for Extreme Weather Doorbell Cameras?
Wyze doorbell cameras and outdoor security devices are designed with durability and smart technology in mind, ensuring your home stays secure no matter the weather. Their IP65 certification means they resist dust and water ingress, while operating smoothly in freezing cold or hot temperatures. With high-resolution video, two-way audio, and smart integrations, Wyze products provide peace of mind and convenience.
Summary of Key Specs
ProductVideo ResolutionWeather ResistanceOperating Temp RangeSpecial Features
Wyze Video Doorbell v22K (2048x1536)IP65-4°F to 122°F (-20°C to 50°C)Two-way audio, voice deterrence, local & cloud storage
Front Porch Security Bundle1080p HDIP65-4°F to 122°F (-20°C to 50°C)Includes Wyze Lock, chime, Alexa/Google integration
Wyze Cam Pan v31080p HDIP65-4°F to 122°F (-20°C to 50°C)360° pan/180° tilt, two-way audio
Wyze Battery Cam Pro2.5K HDRIP65-4°F to 122°F (-20°C to 50°C)Wire-free, spotlight, siren, radar + PIR detection
Enhance Your Home Security with Wyze
Investing in a durable, weather-resistant doorbell camera like the Wyze Video Doorbell v2 or the comprehensive Front Porch Security Bundle ensures your home is protected in all seasons. Complement your setup with Wyze’s outdoor cameras like the Cam Pan v3 or Battery Cam Pro for full property coverage. Experience smart, reliable security designed to withstand extreme weather conditions. Two-way Audio with Wyze Cam
FeatureWyze Video Doorbell v2The Front Porch Security BundleWyze Cam Pan v3Wyze Battery Cam Pro
TypeWired Video DoorbellBundle: Wyze Lock + Video Doorbell and/or Cam V3Indoor/Outdoor Pan & Tilt CameraWire-Free Battery Camera
Video Resolution2K (approx. 2560 x 1440)1080p HD (Video Doorbell)1080p (1920 x 1080)2.5K HDR (2560 x 1440)
Video Frame RateNot specifiedNot specifiedDay: 20 fps / Night: 15 fpsNot specified
Field of ViewHead-to-toe view (exact degrees not specified)Not specified360° horizontal, 180° vertical134° diagonal, 108° horizontal, 56° vertical
Night VisionColor Night Vision (Starlight sensor)Not specified4 IR LEDs (850 nm)2 IR LEDs + 2 White LEDs (Color Night Vision)
AudioTwo-way audioTwo-way audioTwo-way audio with noise & echo cancellationTwo-way audio with built-in speaker & mic
StorageLocal microSD (continuous 24/7 recording)Not specifiedSupports up to 256 GB microSDSupports up to 256 GB microSD
Cloud StorageOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscription
Power SourceWiredWired (Doorbell), Battery (Lock)Wired (requires power adapter for outdoor use)Removable, rechargeable battery packs
Weather ResistanceIP65Not specifiedIP65IP65
| Special Features | - Motion-activated voice deterrence (with subscription)
  • Pre-roll motion recording (3-6 sec)
  • Works with existing chime (chime controller included)
  • Alexa & Google Home compatible
  • 30° corner wedge included | - Includes Wyze Lock for remote locking/unlocking
  • View lock history in app
  • Video Doorbell with 2-way audio | - 360° pan and 180° tilt
  • 8x digital zoom
  • Alexa, Google Assistant, IFTTT integration | - Integrated spotlight & siren
  • Up to 6 months battery life
  • 2.4 & 5 GHz WiFi support
DimensionsNot specifiedNot specified124mm x 60mm x 63mm2.5 x 1.8 x 3.5 inches
Price (approximate)$44.98$124.96 (Wyze Lock Bolt Matte Black + Video Doorbell v2)$114.94 (single Wyze Cam Pan v3)$159.98 (single Wyze Battery Cam Pro)
Are Wyze doorbell cameras weather-resistant?Yes, Wyze doorbell cameras, including the Wyze Video Doorbell v2 and those in the Front Porch Security Bundle, are IP65 weather-resistant. This means they are designed to withstand rain, snow, dust, and operate reliably in temperatures from -4°F to 122°F (-20°C to 50°C), making them ideal for extreme weather conditions.
What is the video quality of the Wyze Video Doorbell v2?The Wyze Video Doorbell v2 delivers stunning 2K (2048 x 1536) resolution video, ensuring crystal-clear footage of your entryway. It features a CMOS Starlight Sensor and F2.0 aperture for enhanced clarity, even in low-light conditions.
What smart features are included with Wyze doorbell cameras?Wyze doorbell cameras offer two-way audio with noise and echo cancellation, motion-activated voice deterrence, real-time alerts, and seamless integration with Alexa, Google Assistant, and IFTTT for smart home automation.
What is included in the Wyze Video Doorbell v2 package?The Wyze Video Doorbell v2 package includes the doorbell camera, a chime controller, wall plate, wedge for angled mounting, installation kit, wire caps, extension wires, screws, and a quick start guide.
What is the Wyze Front Porch Security Bundle?The Wyze Front Porch Security Bundle is an all-in-one smart home security solution that combines the Wyze Video Doorbell, Wyze Lock, and Wyze Chime. It offers 1080p HD video, two-way audio, remote door locking/unlocking, and is managed through the Wyze app.
Can Wyze doorbell cameras store video locally?Yes, the Wyze Video Doorbell v2 supports local microSD storage up to 256GB, as well as cloud storage options for secure video retention.
Are there other weather-resistant Wyze cameras for outdoor security?Yes, Wyze offers additional weather-resistant cameras such as the Wyze Cam Pan v3 and Wyze Battery Cam Pro. Both are IP65 rated and operate in temperatures from -4°F to 122°F (-20°C to 50°C), making them suitable for outdoor use in extreme weather.
What are the key features of the Wyze Cam Pan v3?The Wyze Cam Pan v3 features 1080p HD video, 360° horizontal pan, 180° vertical tilt, 8x digital zoom, two-way audio, and an IP65 weather resistance rating. It requires the Wyze Outdoor Power Adapter for safe outdoor use.
What makes the Wyze Battery Cam Pro suitable for outdoor use?The Wyze Battery Cam Pro is wire-free, IP65 weatherproof, and operates in extreme temperatures. It offers 2.5K HDR video, integrated spotlight and siren, radar + PIR motion detection, two-way audio, and up to 6 months of battery life with removable rechargeable battery packs.
Why should I choose Wyze for extreme weather doorbell cameras?Wyze doorbell cameras and outdoor security devices are engineered for durability and smart technology. With IP65 certification, high-resolution video, two-way audio, and smart home integrations, Wyze products provide reliable security and peace of mind in any weather.
What are the key features of the Wyze Video Doorbell v2?How does the Wyze Video Doorbell v2 perform in extreme weather conditions?Do you have any ongoing sales or discounts for the Wyze Video Doorbell v2?
