IP65 Weatherproof Outdoor Security Cameras with Wireless Floodlight
IP65 Rated Weatherproof Outdoor Security Cameras with Wireless Floodlight and Wide Viewing Angles
When it comes to securing your home or business outdoors, having a reliable, weatherproof security camera with a wide field of view and integrated lighting is essential. Whether you want to monitor your property day and night or keep an eye on your loved ones, the latest Wyze outdoor cameras offer advanced features like IP65 weather resistance, wireless floodlights, and expansive viewing angles ranging from 120° to 160°. Below, explore the top Wyze cameras designed to meet these needs with cutting-edge technology and user-friendly features.
Wyze Cam Pan v3 Series: Ultimate 360° Pan & 180° Tilt Weatherproof Security
Wyze Cam Pan v3 in snowy outdoor setting Experience full outdoor protection with Wyze Cam Pan v3 in any weather
Key Features:
  • IP65 Weather Resistance: Built to withstand rain, snow, and dust, making it perfect for outdoor use with the Wyze Outdoor Power Adapter (sold separately).
  • 360° Horizontal Pan & 180° Vertical Tilt: Covers every angle with smooth, automatic motion tracking to follow moving objects silently.
  • 120° Field of View: Wide enough to monitor large areas without blind spots.
  • Color Night Vision: Enhanced night vision with a Starlight sensor for clear, colorful images even in low light.
  • Two-Way Audio: Communicate directly through the camera using the Wyze app, ideal for greeting visitors or deterring intruders.
  • Privacy Mode: Easily disable the camera’s view by pointing it downward when privacy is needed.
  • Local & Cloud Storage: Supports microSD cards for continuous recording and optional Cam Plus subscription for advanced alerts.
Available Options:
  • Wyze Cam Pan v3 + 30-Day Cam Plus Bundle
  • Pan v3 Security Bundle (includes two cameras and microSD cards for extended coverage)
The Wyze Cam Pan v3 is a versatile choice for those who want full panoramic coverage with weatherproof durability and smart tracking capabilities.
Wyze Cam v4: Wireless Floodlight Camera with 2.5K QHD Resolution
Wyze Cam v4 with wireless floodlight Wireless floodlight and crystal-clear 2.5K video resolution for enhanced outdoor security
Standout Features:
  • IP65 Weatherproof Design: Durable polycarbonate body and glass/plastic lens materials ensure reliable outdoor performance.
  • 2.5K QHD Video Resolution: Ultra-clear video quality with 2560x1440 pixels for detailed monitoring.
  • 115.8° Diagonal Field of View: Wide-angle lens captures more of your surroundings.
  • Motion-Activated Spotlight: Bright white LEDs (72 lumens) illuminate the area when motion is detected, enhancing visibility and deterring unwanted visitors.
  • Color Night Vision: See vivid colors even at night thanks to the advanced Starlight sensor.
  • Two-Way Talk & Built-In Siren: Communicate through the camera and activate a loud siren for added security.
  • Wi-Fi 6 Support & Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home control.
  • Local Storage & Cloud Options: Supports microSD cards up to 512GB and cloud storage subscriptions.
Mounting Flexibility:
  • Multiple mounting options including stand, wall, ceiling, and magnetic mounts for easy installation anywhere outdoors.
Wyze Cam v4 is perfect for users seeking a wireless floodlight camera with superior video quality and smart features to keep your property safe day and night.
Wyze Cam OG: Compact IP65 Outdoor Camera with Built-In Spotlight
Highlights:
  • IP65 Weather Resistance: Ready for outdoor use in various climates.
  • 120° Field of View: Wide enough to cover entryways, patios, or driveways.
  • Built-In 40 Lumen Spotlight: Provides additional illumination to brighten dark areas.
  • 1080p HD Video: Crisp video quality with 20 FPS during the day and 15 FPS at night.
  • Upgraded Two-Way Audio: Clear communication with noise and echo cancellation.
  • 90 dB User-Activated Siren: Scare off intruders with a loud alarm.
  • Fast Live Streaming: 3X faster notifications and streaming compared to previous models.
  • Custom Detection Zones & Smoke/CO Alerts: Tailor motion alerts and receive critical safety notifications.
The Wyze Cam OG is an excellent choice for those who want a compact, spotlight-equipped outdoor camera with reliable weatherproofing and smart alert features.
Why Choose IP65 Rated Wyze Outdoor Cameras?
IP65 rating means these cameras are dust-tight and protected against water jets from any direction, ensuring they perform reliably in rain, snow, or dusty environments. This makes them ideal for outdoor security where weather conditions can be unpredictable.
  • Wide Viewing Angles: From 120° to 360° pan and tilt, these cameras cover large areas with minimal blind spots.
  • Wireless Floodlight Integration: Brighten dark areas automatically to improve visibility and deter intruders.
  • Smart Features: Motion tracking, two-way audio, privacy modes, and smart alerts keep you connected and in control.
  • Flexible Storage: Choose between local microSD storage or cloud subscriptions for continuous or event-based recording.
  • Easy Installation: Multiple mounting options and wireless capabilities simplify setup.
Conclusion
For anyone searching for an IP65 rated weatherproof outdoor security camera with wireless floodlight and wide viewing angles between 120° and 160°, Wyze offers a range of affordable, feature-packed options:
  • Wyze Cam Pan v3 for full 360° pan and 180° tilt coverage with weatherproof durability.
  • Wyze Cam v4 for wireless floodlight security with stunning 2.5K resolution and smart home compatibility.
  • Wyze Cam OG for a compact spotlight camera with fast streaming and reliable outdoor protection.
Protect your home or business with these advanced Wyze cameras designed to deliver clear, colorful video and smart security features in any weather.
Feature / ProductWyze Cam Pan v3 + 30-Day Cam Plus BundlePan v3 Security BundleWyze Cam v4Wyze Cam Pan v3Wyze Cam OG
Price (USD)39.9882.99105.94 (single)29.98 (single)19.98 (single)
Weather ResistanceIP65IP65IP65IP65Indoor/Outdoor* (not specified)
Resolution2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD (2560x1440)1080p (1920x1080)
Field of View360° pan, 180° tilt360° pan, 180° tilt115.9° (D) x 98.5° (H) x 53.1° (V)360° pan, 180° tilt120°
Night VisionColor Night VisionColor Night VisionEnhanced Color Night VisionColor Night VisionColor Night Vision
SpotlightBuilt-in spotlightBuilt-in spotlightMotion-activated spotlightBuilt-in spotlightBuilt-in spotlight
SirenYesYesYesYesYes
AudioTwo-way talkTwo-way talkEnhanced two-way talkTwo-way talkImproved two-way audio
Continuous Local RecordingYes (with microSD)Yes (with microSD)Yes (with microSD)Yes (with microSD)Yes (with microSD)
MicroSD Card SupportUp to 512GBUp to 512GBUp to 512GBUp to 512GBNot specified
Motion & Sound DetectionYesYesYesYesYes
Motion Detection ZonesYesYesYesYesNot specified
Smoke & CO AlertsYesYesYesYesNot specified
Wi-Fi SupportWi-Fi 6Wi-Fi 6Wi-Fi 6Wi-Fi 6Not specified
MountingMagnetic mountMagnetic mountMagnetic mountMagnetic mountNot specified
Outdoor Power Adapter RequiredYes (sold separately)Yes (sold separately)Yes (sold separately)Yes (sold separately)Not specified
Bundle Includes30-Day Cam Plus subscriptionSecurity bundle onlySingle camera (various bundles available)Single cameraSingle camera
What does IP65 weatherproof rating mean for Wyze outdoor security cameras?An IP65 weatherproof rating means Wyze outdoor security cameras are dust-tight and protected against water jets from any direction. This ensures reliable performance in rain, snow, and dusty environments, making them ideal for outdoor security.
Which Wyze outdoor security cameras have wireless floodlights?The Wyze Cam v4 features a wireless floodlight with bright white LEDs that activate when motion is detected, providing enhanced visibility and deterring unwanted visitors.
What are the viewing angles of Wyze outdoor security cameras?Wyze outdoor security cameras offer wide viewing angles ranging from 115.8° to 120°, with the Wyze Cam Pan v3 providing 360° horizontal pan and 180° vertical tilt for full panoramic coverage.
Can Wyze outdoor cameras record video locally and to the cloud?Yes, Wyze outdoor cameras support local storage via microSD cards and offer optional cloud storage subscriptions for continuous or event-based recording.
Do Wyze outdoor security cameras have color night vision?Yes, Wyze outdoor security cameras like the Cam Pan v3 and Cam v4 feature color night vision with advanced Starlight sensors, allowing you to see clear, colorful images even in low-light conditions.
Are Wyze outdoor cameras compatible with smart home systems?Wyze Cam v4 supports Wi-Fi 6 and is compatible with Alexa, Google Assistant, and IFTTT, enabling seamless integration with your smart home devices.
What mounting options are available for Wyze outdoor security cameras?Wyze outdoor cameras offer multiple mounting options, including stand, wall, ceiling, and magnetic mounts, making installation flexible and easy for any outdoor location.
Which Wyze camera is best for full panoramic outdoor coverage?The Wyze Cam Pan v3 is the best choice for full panoramic outdoor coverage, offering 360° horizontal pan, 180° vertical tilt, and IP65 weather resistance for comprehensive monitoring.
What security features do Wyze outdoor cameras offer?Wyze outdoor cameras provide advanced security features such as motion tracking, two-way audio, built-in sirens, privacy modes, custom detection zones, and smoke/CO alerts to keep your property safe.
How do Wyze outdoor cameras enhance night-time security?Wyze outdoor cameras enhance night-time security with features like color night vision, built-in spotlights or floodlights, and motion-activated lighting to illuminate dark areas and deter intruders.
What are the key features of the Wyze Cam Pan v3?Can you tell me more about the Wyze Cam v4 and its capabilities?Do you have any ongoing sales or discounts for the Wyze cameras?
