Durable IP65 Floodlight Cameras with Dual Band WiFi
Durable IP65 Floodlight Cameras with Dual Band WiFi Connectivity
When it comes to securing your home or business, having a reliable floodlight camera that withstands harsh weather and offers seamless connectivity is essential. For those searching for durable IP65-rated floodlight cameras with dual band WiFi, Wyze offers top-tier options that combine powerful lighting, crystal-clear video, and smart features to keep your property safe day and night. Explore the best Wyze floodlight cameras designed for outdoor security, featuring IP65 weather resistance and advanced WiFi capabilities including dual-band support for faster, more stable connections.
Wyze Cam Floodlight Pro: The Ultimate Dual-Band Floodlight Camera
Wyze Cam Floodlight Pro in action with bright floodlight illuminating a deck at dusk Alt: Wyze Cam Floodlight Pro illuminating outdoor deck at dusk
Key Features and Benefits
  • Dual-Band WiFi Connectivity (2.4 & 5 GHz): Enjoy faster, more reliable wireless connections that reduce interference and improve streaming quality.
  • 180° Ultra-Wide Field of View: Covers your entire yard with fewer blind spots, thanks to the widest viewing angle in the floodlight camera category.
  • 2.5K QHD Video Resolution: Capture stunningly detailed video footage with Quad HD clarity, day or night.
  • AI-Powered Motion Detection: Onboard AI computer vision detects people, vehicles, and more, triggering motion-activated lights and smart notifications.
  • Powerful 3000 Lumens LED Lighting: Three adjustable floodlight heads provide bright, customizable illumination to deter intruders.
  • IP65 Weather Resistance: Built to withstand rain, snow, and extreme temperatures, ensuring year-round durability.
  • Ambient Light Mode & Voice Deterrence: Constant low-level lighting with motion-triggered brightness and a 105 dB siren plus voice prompts to scare off unwanted visitors.
  • Easy DIY Installation: Replace your existing floodlight in under 20 minutes with no electrician needed.
Wyze Cam Floodlight Pro is perfect for homeowners who want a high-performance, weatherproof security camera with the convenience of dual-band WiFi for seamless connectivity.
Wyze Cam Floodlight v2: Reliable and Bright with Smart Features
Wyze Cam Floodlight v2 illuminating a driveway with person detected Alt: Wyze Cam Floodlight v2 lighting driveway with detected person
Why Choose Wyze Cam Floodlight v2?
  • IP65 Weatherproof Rating: Designed to endure all weather conditions, from heavy rain to snow.
  • 2K Video with Color Night Vision: See clear, colorful video even in low light, with a 160° wide-angle lens for broad coverage.
  • 2800 Lumens Bright LED Floodlights: Motion-activated and adjustable lights that illuminate your property effectively.
  • Dual-Band WiFi Support: Connects over 2.4 GHz networks with easy setup and stable performance.
  • 24/7 Local Recording: Continuous recording to microSD card (up to 256GB) without subscription fees.
  • Two-Way Talk & Loud Siren: Communicate with visitors or scare off intruders with a 105 dB siren.
  • AI-Powered Light Control & Dusk-to-Dawn Automation: Lights adjust automatically based on ambient conditions and motion.
  • Wide 270° PIR Motion Detection: Detects movement across a broad area to trigger lights and alerts promptly.
  • Smart Assistant Integration: Works seamlessly with Alexa and Google Assistant for voice control and live feed viewing.
Wyze Cam Floodlight v2 offers a perfect balance of affordability, durability, and smart home compatibility for everyday outdoor security needs.
Additional Accessories: Wyze Cam Floodlight Plug-In Mount
For those who prefer a plug-in power option instead of hardwiring, the Wyze Cam Floodlight Plug-In Mount provides a simple, cost-effective solution.
  • Plug-n-Play Installation: No need for junction boxes or electrician visits.
  • Compatible with Wyze Floodlight Cameras: Works with Wyze Cam Floodlight v1, v2, and Pro models.
  • Outdoor Safe with 20 ft Power Cord: Designed for outdoor use with a long, durable cable.
  • UL and RoHS Certified: Meets safety and environmental standards.
This accessory is ideal for renters or anyone with an accessible outdoor power outlet who wants to avoid complex wiring.
Why Choose Wyze Floodlight Cameras for Your Outdoor Security?
"Wyze floodlight cameras combine powerful illumination, advanced AI detection, and durable IP65 weatherproofing with smart home integration and dual-band WiFi connectivity, making them the perfect choice for reliable outdoor security."
  • Durability: IP65 rating ensures protection against dust and water, suitable for all weather conditions.
  • Connectivity: Dual-band WiFi (Pro model) supports both 2.4 GHz and 5 GHz networks for faster, more stable connections.
  • Smart Features: AI-powered motion detection, two-way talk, sirens, and smart assistant compatibility.
  • High-Quality Video: From 2K to 2.5K QHD resolution with color night vision for clear monitoring day and night.
  • Easy Installation: DIY-friendly with plug-in mount options available.
Summary of Durable IP65 Floodlight Cameras with Dual Band WiFi
ProductVideo ResolutionField of ViewLED BrightnessWiFi BandsWeatherproofPrice
Wyze Cam Floodlight Pro2.5K QHD180°3000 lumens2.4 & 5 GHzIP65$149.98
Wyze Cam Floodlight v22K160°2800 lumens2.4 GHzIP65$89.98
Invest in a Wyze floodlight camera today to secure your property with durable, weatherproof technology and enjoy the benefits of dual-band WiFi connectivity for a smarter, safer home.
FeatureWyze Cam Floodlight v2Wyze Cam Floodlight Pro
Video Resolution2K HD (1920 x 1080 approx.)2.5K QHD (2560 x 1440)
Field of View160° wide-angle180° ultra-wide
LED Brightness2800 lumens3000 lumens
Number of Floodlight Heads23 (independently articulating panels)
Night VisionColor Night VisionColor Night Vision
Motion DetectionAdvanced PIR with 270° coverageAI computer vision-based motion detection
AI Detection (with Cam Plus)People, Pets, Vehicle, PackagePeople, Pets, Vehicle, Package
Ambient Light ModeYesYes
Two-Way TalkYesYes
Siren105 dB105 dB
Motion-Activated Voice DeterrenceNoYes
Wi-Fi Compatibility2.4 GHzDual-band 2.4 & 5 GHz
Local Recording24/7 local recording to microSD (up to 256GB)24/7 local recording to microSD (up to 256GB)
Weather ResistanceIP65IP65
PowerHardwired 110-120V ACHardwired 110-120V AC
InstallationDIY install, no junction box neededDIY install, no junction box needed
AI-Powered Light ControlYesYes (more advanced onboard AI)
Price (Regular)$89.98$149.98
What is an IP65-rated floodlight camera?An IP65-rated floodlight camera is designed to be dust-tight and protected against water jets from any direction, making it highly durable and suitable for outdoor use in all weather conditions, including rain and snow.
Which Wyze floodlight cameras support dual-band WiFi connectivity?The Wyze Cam Floodlight Pro supports dual-band WiFi connectivity, allowing you to connect to both 2.4 GHz and 5 GHz networks for faster, more stable wireless performance.
What are the main differences between Wyze Cam Floodlight Pro and Wyze Cam Floodlight v2?Wyze Cam Floodlight Pro offers 2.5K QHD video resolution, a 180° ultra-wide field of view, 3000 lumens of LED brightness, and dual-band WiFi (2.4 & 5 GHz). Wyze Cam Floodlight v2 features 2K video, a 160° field of view, 2800 lumens, and supports 2.4 GHz WiFi. Both are IP65 weatherproof and include smart features like AI-powered motion detection and two-way talk.
Can Wyze floodlight cameras be installed without an electrician?Yes, Wyze floodlight cameras are designed for easy DIY installation. The Wyze Cam Floodlight Pro can replace your existing floodlight in under 20 minutes, and the Wyze Cam Floodlight Plug-In Mount allows for plug-and-play installation without the need for hardwiring or an electrician.
Do Wyze floodlight cameras work with smart home assistants?Yes, Wyze floodlight cameras are compatible with popular smart home assistants like Alexa and Google Assistant, enabling voice control and live feed viewing.
Is continuous local recording available on Wyze floodlight cameras?Yes, the Wyze Cam Floodlight v2 supports 24/7 local recording to a microSD card (up to 256GB), allowing you to record video continuously without subscription fees.
What is the brightness of Wyze floodlight cameras?The Wyze Cam Floodlight Pro features 3000 lumens of adjustable LED lighting, while the Wyze Cam Floodlight v2 offers 2800 lumens, both providing powerful illumination to deter intruders and enhance security.
Are there plug-in options for Wyze floodlight cameras?Yes, the Wyze Cam Floodlight Plug-In Mount accessory allows you to power your Wyze floodlight camera using a standard outdoor outlet, making installation easy and ideal for renters or those without existing junction boxes.
What smart security features do Wyze floodlight cameras offer?Wyze floodlight cameras include AI-powered motion detection, two-way talk, a 105 dB siren, ambient light mode, dusk-to-dawn automation, and smart notifications to keep your property secure day and night.
How weather-resistant are Wyze floodlight cameras?All Wyze floodlight cameras are IP65 weatherproof, ensuring reliable operation in rain, snow, and extreme temperatures for year-round outdoor security.
What are the key features of the Wyze Cam Floodlight Pro?How does the AI-powered motion detection work in the Wyze floodlight cameras?Do you have any ongoing sales or discounts for the Wyze floodlight cameras?
