How to Install Wyze Lock Keypad for Keyless Secure Entry
If you're looking to enhance your home security with a convenient, keyless entry system, the
Wyze Lock Keypad is an excellent accessory designed specifically for the Wyze Lock. It allows you to unlock your door without needing your phone or a physical key, providing seamless access for you and your trusted guests.
Introducing the Wyze Lock Keypad
The Wyze Lock Keypad is a smart accessory that pairs directly with your Wyze Lock via Bluetooth. It enables you to enter a secure code to unlock your door, making keyless entry simple and reliable.
Key Features:
- Unlock without your phone or key: Enter a 4-8 digit code on the keypad to gain access.
- Secure local code storage: Access codes are stored locally on the Wyze Lock, not in the cloud, enhancing security.
- Supports up to 50 unique access codes: Perfect for family members, friends, or service providers.
- Anti-Peep Secure Code Entry: Enter extra random digits before or after your code to prevent onlookers from guessing your code.
- Easy installation and setup: Designed to mount conveniently near your door.
Step-by-Step Wyze Lock Keypad Installation Guide
Installing the Wyze Lock Keypad is straightforward and requires minimal tools. Here’s how to get your keypad mounted and ready for use:
What’s in the Box?
- 1x Wyze Lock Keypad
- 1x Keypad Mounting Plate with Adhesive
- 2x AA Batteries
- 2x Screws
- Required Tool: Philips Screwdriver or Power Drill
Installation Steps:
1.
Mount the Plate:
Remove the adhesive backing from the Keypad Mounting Plate. Press the plate firmly against the wall or door frame where you want the keypad installed.
2.
Secure the Plate:
Use the included screws to firmly attach the mounting plate to the wall for extra stability.
3.
Insert Batteries:
Remove the back panel of the keypad, insert the two AA batteries (included), and replace the back panel.
4.
Attach the Keypad:
Snap the keypad onto the mounted plate.
5.
Installation Complete:
Your Wyze Lock Keypad is now physically installed and ready for setup.
Tip: Choose a location within 50 feet of your Wyze Lock to ensure a strong Bluetooth connection.
Setting Up Your Wyze Lock Keypad
Once installed, you need to connect the keypad to your Wyze Lock through the Wyze app:
1. Open the Wyze app and select your Wyze Lock.
2. Tap the gear icon to access Settings.
3. Navigate to
Wyze Lock Keypad Settings and tap
Add Keypad.
4. Press and hold the Lock button on the keypad until the status light flashes green.
5. Tap
Next in the app to begin pairing.
6. Once connected, create a 4-8 digit access code in the app.
7. Save your code securely and you’re all set!
Managing Access Codes and Security
The Wyze Lock Keypad offers robust code management features to keep your home secure and access controlled:
- Multiple Access Codes: Store up to 50 unique codes for family, friends, or service providers.
- Guest Codes: Create codes with specific time frames such as Always, Recurring, Temporary, or One-Time use.
- Code Privacy: Codes are stored locally on the lock and cannot be viewed in the app after creation.
- Anti-Peep Feature: Enter random digits before or after your code to prevent code theft by onlookers.
- Lock Button: Quickly lock your door by pressing the Lock button on the keypad.
Why Choose Wyze Lock Keypad for Your Home?
"Unlock without your phone or key" is more than a tagline — it’s a promise of convenience and security.
- Enhanced Security: The keypad uses AES-128 bit encryption and Bluetooth communication to keep your access codes safe.
- No Physical Key Needed: Eliminate the risk of lost or copied keys.
- Easy Sharing: Share access with trusted users by creating guest codes or sharing the lock via the Wyze app.
- Reliable Access: Even during power or network outages, the keypad works independently to unlock your door.
Summary
The Wyze Lock Keypad is a smart, secure, and easy-to-install accessory that transforms your Wyze Lock into a fully keyless entry system. With simple installation, flexible code management, and advanced security features like Anti-Peep, it’s the perfect solution for modern home access control.
Alt text: Person entering code on Wyze Lock Keypad for keyless home entry
Alt text: Wyze Lock Keypad installed on door frame for secure access
What is the Wyze Lock Keypad and how does it work?
The Wyze Lock Keypad is a smart accessory designed to work with the Wyze Lock, allowing you to unlock your door using a secure 4-8 digit code. It connects to your Wyze Lock via Bluetooth, enabling keyless entry without needing your phone or a physical key.How do I install the Wyze Lock Keypad?
To install the Wyze Lock Keypad, mount the included plate near your door using the adhesive and screws provided. Insert the two AA batteries, snap the keypad onto the plate, and ensure it is within 50 feet of your Wyze Lock for optimal Bluetooth connection.What tools are required for Wyze Lock Keypad installation?
You will need a Philips screwdriver or a power drill to secure the mounting plate with the included screws. All other necessary components, such as the mounting plate, adhesive, screws, and batteries, are included in the box.How do I set up the Wyze Lock Keypad with my Wyze Lock?
After installing the keypad, open the Wyze app, select your Wyze Lock, and go to Settings. Navigate to Wyze Lock Keypad Settings, tap Add Keypad, and follow the on-screen instructions to pair the keypad and create your access code.How many access codes can I create with the Wyze Lock Keypad?
You can create and store up to 50 unique access codes on the Wyze Lock Keypad, making it easy to provide secure access for family, friends, or service providers.What security features does the Wyze Lock Keypad offer?
The Wyze Lock Keypad features AES-128 bit encryption, secure local code storage, and an Anti-Peep feature that lets you enter random digits before or after your code to prevent onlookers from stealing your code.Can I create temporary or guest access codes with the Wyze Lock Keypad?
Yes, the Wyze Lock Keypad allows you to create guest codes with specific time frames, including Always, Recurring, Temporary, or One-Time use, providing flexible access control for visitors.Where are the access codes stored for the Wyze Lock Keypad?
All access codes are stored locally on the Wyze Lock itself, not in the cloud, ensuring enhanced privacy and security.Does the Wyze Lock Keypad work during power or network outages?
Yes, the Wyze Lock Keypad operates independently and will continue to unlock your door even during power or network outages, as it uses battery power and local Bluetooth communication.How do I lock my door using the Wyze Lock Keypad?
Simply press the Lock button on the Wyze Lock Keypad to quickly and securely lock your door.Why should I choose the Wyze Lock Keypad for my home security?
The Wyze Lock Keypad offers keyless, secure, and convenient access to your home. With easy installation, robust security features, flexible code management, and reliable operation even during outages, it is an ideal solution for modern home access control.
