Top Home Security Kits Compatible with Wyze Cam v2 & v3
Best Home Security Kits Compatible with Wyze Cam v2 and v3
If you're looking to upgrade your home security system with kits compatible with Wyze Cam v2 and v3, the latest Wyze Cam v4 and its bundles offer exceptional features, seamless integration, and enhanced protection. These kits provide crystal-clear video, advanced night vision, and smart home compatibility, making them ideal for securing your home day and night.
Wyze Cam v4: The Ultimate Upgrade for Home Security
Wyze Cam v4 is the latest in Wyze’s lineup, designed to deliver unmatched security with superior image quality and smart features.
Key Features:
  • 2.5K Quad High Definition (QHD) Resolution: Capture every detail with 2560x1440 video clarity, a significant upgrade from the 1080p resolution of Wyze Cam v2 and v3.
  • Enhanced Color Night Vision: Unlike traditional black-and-white night vision, Wyze Cam v4 uses advanced hardware to provide vibrant color images even in low-light conditions.
  • Wide Dynamic Range (WDR): Enjoy richer, more vibrant colors and better image quality in challenging lighting environments.
  • IP65 Weather Resistance: Perfect for both indoor and outdoor use, the camera withstands rain, snow, and dust.
  • Motion-Activated Spotlight & Siren: Deter intruders with a bright spotlight and a loud 99 dB siren.
  • Advanced Two-Way Talk: Clearer conversations with improved audio hardware and noise cancellation.
  • Wi-Fi 6 Support: Ensures a stronger, more reliable connection for uninterrupted monitoring.
  • Local Storage & Continuous Recording: Supports microSD cards up to 512GB for 24/7 local recording without subscription fees.
  • Smart Alerts: Motion and sound detection with customizable detection zones and alerts for smoke and CO alarms.
  • Easy Setup & Mounting: Bluetooth setup with screw-free magnetic mounts for quick installation.
Technical Specs:
  • Field of View: 115.9° diagonal, 98.5° horizontal, 53.1° vertical
  • Dimensions: 2in x 2in x 2 3/8in
  • Weight: 0.49 lb (222 g)
  • Power: Wired with 6-foot micro USB cable
Wyze Cam v4 is a perfect replacement or upgrade for users of Wyze Cam v2 and v3, offering enhanced video quality, smarter features, and robust weather resistance. Wyze Cam v4 lifestyle
Wyze Cam v4 Outdoor Bundle: Ready for All-Weather Protection
For those who want a complete outdoor security solution compatible with Wyze Cam v2 and v3 systems, the Wyze Cam v4 Outdoor Bundle is an excellent choice.
What’s Included:
  • Wyze Cam v4 with 2.5K QHD resolution and color night vision
  • Wyze Outdoor Power Adapter for reliable outdoor power supply
  • 128GB Wyze MicroSD Card for continuous 24/7 local recording
Why Choose the Outdoor Bundle?
  • Weatherproof Design: IP65 rating ensures the camera performs flawlessly in rain, snow, or shine.
  • Motion-Activated Spotlight & Siren: Enhanced deterrence with bright lighting and loud siren.
  • Wi-Fi 6 Connectivity: Maintains a strong connection even at greater distances.
  • Smart Detection: Receive alerts for motion, sound, and specific zones to reduce false alarms.
  • Voice Assistant Compatibility: Works seamlessly with Alexa and Google Assistant for voice control.
This bundle is ideal for users upgrading from Wyze Cam v2 or v3 who want a hassle-free outdoor security setup with all necessary accessories included. Outdoor security lifestyle
Wyze Cam v4 Home Security Bundle: Comprehensive Indoor & Outdoor Protection
The Wyze Cam v4 Home Security Bundle offers a multi-camera solution with everything you need to secure your home inside and out.
Bundle Highlights:
  • Multiple Wyze Cam v4 units with 2.5K QHD video and enhanced color night vision
  • 128GB microSD cards included for local continuous recording
  • IP65 weather resistance for versatile indoor/outdoor placement
  • Motion-activated spotlight and siren for added security
  • Person detection and smart alerts to focus on what matters most
  • Multiple mounting options: stand, wall, ceiling, or magnetic mounts
This bundle is perfect for users who want to replace or supplement their existing Wyze Cam v2 or v3 cameras with the latest technology and comprehensive coverage.
Wyze Cam v4 + FREE 32GB MicroSD Card: Great Value Starter Kit
For those seeking a budget-friendly upgrade compatible with Wyze Cam v2 and v3, the Wyze Cam v4 with a free 32GB microSD card offers excellent value.
Features:
  • 2.5K QHD resolution with color night vision
  • IP65 weather resistance for indoor/outdoor use
  • Supports Wi-Fi 6 for reliable connectivity
  • Includes 32GB microSD card for local recording right out of the box
This kit is ideal for users who want to experience the advanced features of Wyze Cam v4 without investing in a full bundle.
Wyze Cam v3 Spotlight Kit: Enhance Your Existing Wyze Cam v3
If you already own a Wyze Cam v3 and want to add motion-activated lighting, the Wyze Cam v3 Spotlight Kit is a perfect accessory.
Spotlight Kit Features:
  • 70 lumens brightness with 130-degree beam angle
  • IP65 rated for outdoor durability
  • Easy USB-powered connection
  • Motion-activated to illuminate dark areas and deter intruders
  • Compact and easy to install alongside your Wyze Cam v3
This accessory upgrades your Wyze Cam v3’s night vision capabilities by adding a powerful spotlight, enhancing security during nighttime hours.
Why Choose Wyze Security Kits Compatible with Wyze Cam v2 and v3?
Wyze’s latest cameras and bundles provide a seamless upgrade path with improved video quality, smarter detection, and robust weather resistance. Whether you want indoor monitoring or outdoor protection, these kits integrate easily with your existing Wyze ecosystem and smart home devices.
Summary
ProductKey BenefitsIdeal For
Wyze Cam v42.5K QHD, color night vision, IP65, spotlight & sirenUpgrade from v2/v3, indoor/outdoor use
Wyze Cam v4 Outdoor BundleIncludes power adapter & 128GB microSD, weatherproofOutdoor security with full accessories
Wyze Cam v4 Home Security BundleMulti-camera, 128GB microSD, person detectionWhole home coverage
Wyze Cam v4 + FREE 32GB MicroSDBudget-friendly with local recordingStarter kit upgrade
Wyze Cam v3 Spotlight KitAdds motion-activated spotlightEnhance existing Wyze Cam v3
Upgrade your home security today with Wyze’s compatible kits and enjoy peace of mind with smart, reliable, and high-quality surveillance.
Wyze Cam v4 vibrant colors
FeatureWyze Cam v4Wyze Cam v4 Outdoor BundleWyze Cam v4 Home Security BundleWyze Cam v4 + FREE 32GB MicroSD CardWyze Cam v3 Spotlight Kit
Price$100.00$69.99$169.99$35.98$16.98
Resolution2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD (2560x1440)N/A
Night VisionEnhanced Color Night VisionEnhanced Color Night VisionEnhanced Color Night VisionEnhanced Color Night VisionN/A
SpotlightMotion-activated spotlightMotion-activated spotlightMotion-activated spotlightMotion-activated spotlight70 lumens, motion-activated
SirenYes (99 dB)Not specifiedYesNot specifiedNo
AudioEnhanced Two-Way Talk, 99 dB speakerNot specifiedImproved 2-way audioNot specifiedNo
Weather ResistanceIP65IP65IP65Not specifiedIP65
Power SourceWiredWiredWiredWired5V 1A (Micro USB)
Local RecordingmicroSD card up to 512 GBmicroSD card 128 GB includedmicroSD card 128 GB included32GB MicroSD card includedNo
Wi-Fi Support2.4 GHz Wi-Fi, Wi-Fi 6Wi-Fi 6Wi-Fi 6Wi-Fi 6No
Motion & Sound DetectionYesYesYesYesNo
Motion Detection ZonesYesYesYesYesNo
Smoke & CO AlertsYesYesYesYesNo
Field of View (FOV)DFOV 115.8°, HFOV 98.5°, VFOV 53.1°Not specifiedDFOV 115.8°, HFOV 98.5°, VFOV 53.1°Not specifiedNo
Mounting OptionsStand, Wall, Ceiling, MagneticNot specifiedStand, Wall, Ceiling, MagneticNot specifiedNo
Bluetooth Version5.2Not specifiedNot specifiedNot specifiedNo
IntegrationsAlexa, Google Assistant, IFTTTAlexa, Google AssistantAlexa, Google AssistantAlexa, Google AssistantNo
Warranty1 YearNot specified1 YearNot specified1 Year
Included AccessoriesNoneWyze Outdoor Power Adapter, 128GB microSDNone32GB MicroSD Card includedSpotlight x1, USB cable splitter x1
Dimensions2in x 2in x 2 3/8inNot specified2in x 2in x 2 3/8inNot specified21.5 x 55.8 x 34.4 mm
Weight0.49 lb (222 g)Not specified0.49 lb (222 g)Not specifiedNot specified
What are the best home security kits compatible with Wyze Cam v2 and v3?The best home security kits compatible with Wyze Cam v2 and v3 include the Wyze Cam v4, Wyze Cam v4 Outdoor Bundle, Wyze Cam v4 Home Security Bundle, Wyze Cam v4 + FREE 32GB MicroSD Card, and the Wyze Cam v3 Spotlight Kit. These kits offer advanced features, seamless integration, and enhanced protection for both indoor and outdoor security.
What are the key features of Wyze Cam v4 for home security?Wyze Cam v4 offers 2.5K Quad High Definition (QHD) resolution, enhanced color night vision, wide dynamic range (WDR), IP65 weather resistance, motion-activated spotlight and siren, advanced two-way talk, Wi-Fi 6 support, local storage with up to 512GB microSD card, smart alerts, and easy setup with magnetic mounts. It is compatible with Alexa, Google Assistant, and IFTTT.
How does Wyze Cam v4 improve upon Wyze Cam v2 and v3?Wyze Cam v4 improves upon Wyze Cam v2 and v3 by offering higher 2.5K QHD video resolution, advanced color night vision, better weather resistance (IP65), Wi-Fi 6 connectivity, motion-activated spotlight and siren, and enhanced smart detection features. It is designed as a seamless upgrade for users of previous Wyze Cam models.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes a Wyze Cam v4 with 2.5K QHD resolution and color night vision, a Wyze Outdoor Power Adapter for reliable outdoor power, and a 128GB Wyze MicroSD Card for continuous 24/7 local recording. This bundle is ideal for outdoor security and comes with all necessary accessories.
Is Wyze Cam v4 weatherproof for outdoor use?Yes, Wyze Cam v4 is IP65 weather resistant, making it suitable for both indoor and outdoor use. It can withstand rain, snow, and dust, ensuring reliable performance in various weather conditions.
What are the benefits of the Wyze Cam v4 Home Security Bundle?The Wyze Cam v4 Home Security Bundle provides comprehensive indoor and outdoor protection with multiple Wyze Cam v4 units, 128GB microSD cards for local recording, IP65 weather resistance, motion-activated spotlight and siren, person detection, smart alerts, and versatile mounting options. It is ideal for whole-home security coverage.
Does Wyze Cam v4 support local video storage?Yes, Wyze Cam v4 supports local video storage with microSD cards up to 512GB, allowing for 24/7 continuous recording without the need for subscription fees.
What is included in the Wyze Cam v4 + FREE 32GB MicroSD Card kit?The Wyze Cam v4 + FREE 32GB MicroSD Card kit includes a Wyze Cam v4 with 2.5K QHD resolution, color night vision, IP65 weather resistance, motion-activated spotlight and siren, Wi-Fi 6 support, and a 32GB microSD card for local recording. This kit is a budget-friendly starter option for upgrading your home security.
How can I enhance my existing Wyze Cam v3 with a spotlight?You can enhance your existing Wyze Cam v3 with the Wyze Cam v3 Spotlight Kit. This accessory adds a 70-lumen, motion-activated spotlight with a 130-degree beam angle, is IP65 rated for outdoor durability, and is easy to install via USB connection. It improves night vision and deters intruders.
Are Wyze security kits compatible with smart home devices?Yes, Wyze security kits, including Wyze Cam v4 and its bundles, are compatible with popular smart home devices such as Alexa, Google Assistant, and IFTTT, allowing for voice control and seamless integration into your smart home ecosystem.
Why should I upgrade to Wyze Cam v4 from Wyze Cam v2 or v3?Upgrading to Wyze Cam v4 from Wyze Cam v2 or v3 provides you with superior video quality (2.5K QHD), advanced color night vision, improved weather resistance, smarter detection features, Wi-Fi 6 connectivity, and enhanced security options like a motion-activated spotlight and siren. It ensures better protection and integration with your smart home.
What are the key features of the Wyze Cam v4?Can you tell me more about the Wyze Cam v4 Outdoor Bundle?Are there any ongoing promotions or discounts for the Wyze Cam v4?
