Secure Your Home with Wyze Cam v2 Magnetic Mount Security Camera
When it comes to protecting your home, Wyze offers a range of cutting-edge security cameras designed to provide crystal-clear video, smart features, and versatile mounting options—including the convenient magnetic mount for easy installation. Among these, the Wyze Cam v4 series stands out as the ultimate choice for home security, combining high-resolution video, enhanced night vision, and smart home compatibility.
Discover the Wyze Cam v4 Series: The Next Level in Home Security
Wyze Cam v4 + FREE 32GB MicroSD Card
Experience unmatched security with the Wyze Cam v4, now bundled with a free 32GB MicroSD card for continuous local recording. This camera delivers stunning 2.5K QHD resolution, ensuring every detail is captured with clarity. Its enhanced color night vision and motion-activated spotlight illuminate your property even in the darkest conditions, providing round-the-clock protection.
- Resolution: 2.5K QHD (2560x1440) for crystal-clear video
- Night Vision: Enhanced color night vision with motion-activated spotlight
- Connectivity: Supports Wi-Fi 6 for faster, more reliable streaming
- Smart Features: Person detection, smoke and CO alerts, and motion detection zones
- Compatibility: Works seamlessly with Alexa and Google Assistant
- Weather Resistance: Rated IP65 for reliable outdoor use
- Storage: Unlimited video length with local microSD card recording (card required)
- Power: Wired with outdoor power adapter (sold separately)
This model is perfect for homeowners who want a reliable, high-quality camera with easy installation options, including the magnetic wall mount that lets you position the camera exactly where you need it.
Wyze Cam v4: Versatile and Powerful Security
The standard Wyze Cam v4 offers the same advanced features as the bundle but with flexible purchasing options including single or multi-packs. Its polycarbonate body and glass/plastic lens ensure durability, while the wide field of view (115.8° diagonal) covers more area.
- Mounting Options: Stand, wall mount, ceiling mount, and magnetic wall mount with adhesive for quick setup
- Audio: 99dB waterproof speaker with two-way talk and built-in siren for deterrence
- Video: 8x digital zoom and wide dynamic range (WDR) for balanced lighting
- Night Vision: 4 IR LEDs plus 2 white spotlight LEDs (72 lumens)
- Operating Range: Works in temperatures from -4°F to 122°F (-20°C to 50°C)
- Warranty: 1-year coverage for peace of mind
This camera is ideal for both indoor and outdoor use, providing flexible installation and smart home integration.
Wyze Cam v4 Home Security Bundle: Complete Protection Package
For those seeking a comprehensive security solution, the Wyze Cam v4 Home Security Bundle offers everything you need in one package. It includes multiple cameras with all the features of the Wyze Cam v4 plus a 128GB microSD card for extended local storage.
- Video Quality: 2.5K QHD with enhanced color night vision
- Audio: Improved two-way audio for clear communication
- Storage: 128GB microSD card included, supporting up to 192 hours of HD video
- Mounting: Includes magnetic wall mount and other versatile options
- Weatherproof: IP65 rating for reliable outdoor use
- Smart Features: Person detection, motion-activated spotlight, and Alexa/Google Assistant compatibility
This bundle is perfect for securing multiple areas of your home, both indoors and outdoors, with easy installation and robust features.
Outdoor Security Made Easy with Wyze Cam v4 Outdoor Bundle
Protect your home's exterior with the Wyze Cam v4 Outdoor Bundle, designed specifically for outdoor environments. This bundle includes the Wyze Outdoor Power Adapter and a 128GB microSD card, ensuring continuous power and ample storage.
- Resolution: 2.5K QHD with enhanced color night vision
- Power: Wired with included outdoor power adapter for reliable operation
- Weather Resistance: IP65 rating to withstand rain, dust, and extreme temperatures
- Smart Detection: Motion and sound detection with customizable zones
- Compatibility: Works with Alexa and Google Assistant for voice control
- Storage: 24/7 local recording with microSD card slot
The magnetic mount option allows for quick and secure placement on metal surfaces or walls, making it easy to position your camera exactly where you need it.
Why Choose Wyze Cam v4 with Magnetic Mount?
"The magnetic mount feature on Wyze Cam v4 cameras offers unparalleled flexibility and ease of installation. Whether you want to quickly reposition your camera or mount it without drilling, the magnetic adhesive mount makes securing your home effortless."
- Quick Installation: No tools required; simply attach the camera magnetically to metal surfaces or use the adhesive plate on walls.
- Flexible Positioning: Easily adjust angles to cover blind spots or focus on specific areas.
- Durability: Designed to withstand outdoor elements with IP65 weather resistance.
- Smart Home Integration: Control and monitor your cameras via Alexa, Google Assistant, or the Wyze app.
Additional Wyze Camera Options
Wyze Cam v3
For those who want a proven, award-winning camera, the Wyze Cam v3 remains a solid choice. It features 1080p color night vision, IP65 weatherproofing, and person detection. While it offers slightly lower resolution than the v4, it is still excellent for indoor and outdoor use.
- Resolution: 1080p HD
- Night Vision: Color night vision with IR LEDs
- Weatherproof: IP65 rating for outdoor durability
- Storage: microSD card required for local recording
- Audio: Two-way talk and built-in siren
Conclusion
Securing your home has never been easier or more effective than with the Wyze Cam v4 series, especially with the convenient magnetic mount option. Whether you choose the standalone Wyze Cam v4, the Home Security Bundle, or the Outdoor Bundle, you get high-resolution video, enhanced night vision, smart detection features, and seamless smart home integration. Protect your home day and night with Wyze’s trusted security cameras.
What are the key features of the Wyze Cam v4 security camera?
The Wyze Cam v4 offers 2.5K QHD resolution, enhanced color night vision, motion-activated spotlight, Wi-Fi 6 connectivity, person detection, smoke and CO alerts, motion detection zones, IP65 weather resistance, and compatibility with Alexa and Google Assistant. It also supports unlimited video length with local microSD card recording.How does the magnetic mount work on Wyze Cam v4 cameras?
The magnetic mount on Wyze Cam v4 cameras allows for quick and tool-free installation. You can attach the camera magnetically to metal surfaces or use the included adhesive plate to mount it on walls, making it easy to reposition and adjust the camera angle as needed.Is the Wyze Cam v4 suitable for outdoor use?
Yes, the Wyze Cam v4 is rated IP65 for weather resistance, making it suitable for both indoor and outdoor use. It can withstand rain, dust, and extreme temperatures, ensuring reliable performance in various environments.What storage options are available for Wyze Cam v4?
Wyze Cam v4 supports local recording via a microSD card. The camera is available in bundles that include either a 32GB or 128GB microSD card, allowing for continuous 24/7 video recording and extended storage capacity.Does Wyze Cam v4 support smart home integration?
Yes, Wyze Cam v4 works seamlessly with Alexa and Google Assistant, allowing you to control and monitor your cameras using voice commands or through the Wyze app.What is included in the Wyze Cam v4 Home Security Bundle?
The Wyze Cam v4 Home Security Bundle includes multiple Wyze Cam v4 cameras, a 128GB microSD card for extended local storage, magnetic wall mounts, and all the advanced features of the Wyze Cam v4 such as 2.5K QHD video, enhanced night vision, and smart detection.What is the difference between Wyze Cam v4 and Wyze Cam v3?
Wyze Cam v4 offers higher 2.5K QHD resolution, enhanced color night vision, Wi-Fi 6 support, and improved smart features compared to the Wyze Cam v3, which has 1080p HD resolution and color night vision. Both models are IP65 weatherproof and support local microSD card recording.Can I use Wyze Cam v4 for continuous recording?
Yes, Wyze Cam v4 supports continuous 24/7 recording when a microSD card is installed, allowing you to capture and review footage at any time.What mounting options are available for Wyze Cam v4?
Wyze Cam v4 offers versatile mounting options including stand, wall mount, ceiling mount, and a magnetic wall mount with adhesive for quick and flexible installation.Is the Wyze Cam v4 easy to install?
Yes, the Wyze Cam v4 is designed for easy installation. The magnetic mount allows for quick setup without tools, and the adhesive plate provides additional flexibility for mounting on various surfaces.What is the warranty period for Wyze Cam v4?
Wyze Cam v4 comes with a 1-year warranty, providing peace of mind and coverage for your security camera investment.Does the Wyze Cam v4 have two-way audio?
Yes, Wyze Cam v4 features a 99dB waterproof speaker with two-way talk and a built-in siren, allowing you to communicate with visitors or deter intruders.What is included in the Wyze Cam v4 Outdoor Bundle?
The Wyze Cam v4 Outdoor Bundle includes the Wyze Cam v4, an outdoor power adapter for continuous power, a 128GB microSD card for ample storage, and all the advanced features needed for reliable outdoor security.
