Affordable Home Security Kits for Quick, Easy Beginner Setup
Affordable Home Security Bundle Kit for Quick Beginner Installation
Securing your home doesn’t have to be complicated or expensive. Whether you’re a first-time user or looking for a simple, effective way to protect your property, these affordable home security bundles offer quick installation and user-friendly features. Designed for beginners, these kits combine essential devices like cameras, doorbells, and keypads to give you peace of mind with minimal setup.
Complete Security Starter Kits for Easy Setup
Whole Home Security Starter Kit
This all-in-one starter kit is perfect for beginners who want a comprehensive yet affordable solution. It includes:
  • Wyze Cam v4: A versatile indoor/outdoor camera with crystal-clear 2.5K QHD resolution and enhanced color night vision.
  • Wyze Video Doorbell v2: Keep an eye on your front door with real-time alerts and two-way audio.
  • Wyze Home Monitoring Starter Kit: Includes sensors and a hub to monitor doors and windows.
Available in Black, Grey, or White, this kit offers everything you need to start protecting your home immediately with easy app integration.
Quick installation and intuitive controls make this kit ideal for beginners who want reliable home security without hassle.
Home Security Lifestyle
Advanced Camera Features for Enhanced Protection
Wyze Cam v4
The Wyze Cam v4 is a standout security camera that delivers exceptional video quality and smart features:
  • 2.5K QHD Resolution: Crystal-clear video to capture every detail.
  • Enhanced Color Night Vision: See vibrant colors even in low light.
  • Motion-Activated Spotlight: Automatically lights up when motion is detected.
  • 24/7 Local Recording: Save footage locally with a microSD card (up to 512GB).
  • Wi-Fi 6 Support: Faster and more reliable wireless connection.
  • Smart Home Compatibility: Works seamlessly with Alexa, Google Assistant, and IFTTT.
  • Multiple Mounting Options: Stand, wall, ceiling, or magnetic mounts for flexible placement.
  • Built-in Siren and Two-Way Talk: Deter intruders and communicate remotely.
This camera is weather-resistant (IP65 rated) and suitable for both indoor and outdoor use, making it a versatile choice for any home.
Enhanced Security with Additional Accessories
Wyze Sense Keypad
Add convenience and control with the Wyze Sense Keypad, designed for indoor use:
  • Remote Arm and Disarm: Control your security system from anywhere.
  • Emergency Button: Quickly alert first responders in case of emergency.
  • Supports Up to 100 Accessories: Expand your system as needed.
  • Permanent Adhesive Mounting: Easy to install and secure.
  • Requires Wyze Sense Hub: Integrates seamlessly with your existing Wyze Home Monitoring system.
This keypad is perfect for users who want quick access to arm or disarm their system without using a smartphone. Wyze Sense Keypad Lifestyle
Optimize your doorbell’s viewing angle with this handy accessory:
  • Adjustable Angles: Includes 15° horizontal and 7.5° vertical brackets to eliminate blind spots.
  • Weather Resistant: Durable plastic construction designed for outdoor use.
  • Quick Installation: Perfect for angled door frames or porches with stairs.
  • Compatible Only with Wyze Video Doorbell v2.
This wedge kit enhances your doorbell’s coverage, ensuring you never miss a visitor or package delivery.
Outdoor Security Made Simple
Wyze Cam v4 Outdoor Bundle
For those who want a dedicated outdoor security solution, this bundle includes:
  • Wyze Cam v4: Same high-quality camera with weather resistance.
  • Wyze Outdoor Power Adapter: Reliable wired power source for continuous operation.
  • Wyze MicroSD Card 128GB: Ready for local 24/7 recording.
Features include motion and sound detection, smoke and CO alerts, and wide dynamic range for clear images in challenging lighting. Compatible with Alexa and Google Assistant, this bundle is a great choice for securing your home’s exterior with minimal setup.
Why Choose These Affordable Home Security Kits?
These kits are designed with beginners in mind, offering quick installation, intuitive controls, and comprehensive protection without breaking the bank. With smart home integration and reliable hardware, you can confidently monitor your home day and night.
Start your home security journey today with these affordable, easy-to-install bundles that combine cameras, sensors, and accessories for a safer home.
FeatureWhole Home Security Starter KitWyze Cam v4Wyze Sense KeypadWyze Video Doorbell v2 Wedge KitWyze Cam v4 Outdoor Bundle
Product TypeSecurity BundleCameraHome MonitoringAccessorySecurity Bundle
Price$155.95 USD$35.98 - $107.94 USD (depending on pack/color)$27.98 USD$8.99 (Wedge Kit Only) / $51.97 (Doorbell + Wedge)$69.99 USD
Included Items1x Wyze Cam v4, 1x Wyze Video Doorbell v2, 1x Wyze Home Monitoring Starter KitWyze Cam v4 onlyWyze Sense Keypad onlyWedge Kit (15° Horizontal Bracket, 2x 7.5° Vertical Brackets, screws, guide)Wyze Cam v4, Outdoor Power Adapter, 128GB MicroSD Card
Camera ResolutionWyze Cam v4: 2.5K QHD2.5K QHDN/AN/A2.5K QHD
Night VisionEnhanced Color Night VisionEnhanced Color Night VisionN/AN/AEnhanced Color Night Vision
Motion-Activated SpotlightYesYesN/AN/AYes
Weather ResistanceWyze Cam v4: IP65IP65NoYesIP65
Power SourceWired (Wyze Cam v4)WiredBattery-powered (Indoor use only)N/AWired
CompatibilityAlexa, Google AssistantAlexa, Google Assistant, IFTTTRequires Wyze Home MonitoringCompatible with Doorbell v2 onlyAlexa, Google Assistant
Local RecordingYes (Wyze Cam v4)Yes (microSD card up to 256GB/512GB)N/AN/AYes (128GB microSD included)
Motion Detection ZonesYes (Wyze Cam v4)YesN/AN/AYes
Sound DetectionYes (Wyze Cam v4)YesN/AN/AYes
Emergency ButtonNoNoYesNoNo
Indoor/Outdoor UseIndoor/Outdoor (Wyze Cam v4)Indoor/OutdoorIndoor onlyN/AIndoor/Outdoor
Additional FeaturesIncludes Video Doorbell v2 and Home Monitoring Kit24/7 local recording, Wi-Fi 6 support, AI trackingArm/disarm system remotely, send first respondersAdjust viewing angle for Doorbell v2Includes Outdoor Power Adapter and 128GB microSD
WarrantyNot specified1 YearNot specified1 YearNot specified
What is included in the Whole Home Security Starter Kit?The Whole Home Security Starter Kit includes a Wyze Cam v4 (indoor/outdoor camera with 2.5K QHD resolution and color night vision), a Wyze Video Doorbell v2 (with real-time alerts and two-way audio), and a Wyze Home Monitoring Starter Kit (sensors and hub for doors and windows). It is available in Black, Grey, or White and offers easy app integration for quick setup.
How easy is it to install the Wyze home security bundles?Wyze home security bundles are designed for beginners and feature quick, hassle-free installation. The kits come with intuitive controls and user-friendly instructions, allowing you to set up your home security system in minutes without professional help.
What are the key features of the Wyze Cam v4?The Wyze Cam v4 offers 2.5K QHD resolution for clear video, enhanced color night vision, a motion-activated spotlight, 24/7 local recording with microSD support (up to 512GB), Wi-Fi 6 compatibility, smart home integration (Alexa, Google Assistant, IFTTT), multiple mounting options, a built-in siren, and two-way talk. It is weather-resistant (IP65 rated) for both indoor and outdoor use.
Can I expand my Wyze home security system with additional accessories?Yes, the Wyze Sense Keypad supports up to 100 accessories, allowing you to expand your home security system as needed. The keypad offers remote arm/disarm, an emergency button, and easy adhesive mounting. It requires the Wyze Sense Hub for integration.
Is the Wyze Cam v4 suitable for outdoor use?Yes, the Wyze Cam v4 is IP65 weather-resistant, making it suitable for both indoor and outdoor use. It is designed to withstand various weather conditions while providing high-quality video and smart security features.
What is the purpose of the Wyze Video Doorbell v2 Wedge Kit?The Wyze Video Doorbell v2 Wedge Kit allows you to adjust your doorbell’s viewing angle with 15° horizontal and 7.5° vertical brackets, eliminating blind spots. It is weather-resistant and easy to install, ensuring optimal coverage for your front door. This kit is compatible only with the Wyze Video Doorbell v2.
Does the Wyze Cam v4 support local video recording?Yes, the Wyze Cam v4 supports 24/7 local video recording with a microSD card (up to 512GB), allowing you to store footage securely without a subscription.
Are Wyze home security kits compatible with smart home systems?Yes, Wyze home security kits and devices are compatible with popular smart home systems, including Amazon Alexa, Google Assistant, and IFTTT, enabling seamless integration and voice control.
What makes these home security kits affordable and beginner-friendly?These home security kits are designed to be cost-effective and easy to use, featuring quick installation, intuitive controls, and comprehensive protection. They combine essential devices like cameras, doorbells, and sensors, making them ideal for first-time users or anyone seeking reliable home security without high costs or complicated setup.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes a Wyze Cam v4 (weather-resistant camera), a Wyze Outdoor Power Adapter for continuous wired power, and a Wyze MicroSD Card 128GB for local 24/7 recording. This bundle is perfect for outdoor security with features like motion and sound detection, smoke and CO alerts, and wide dynamic range.
What features does the Wyze Sense Keypad offer for home monitoring?Can the Wyze Sense Keypad be used with other Wyze products?Is there a warranty available for the home security bundle kits?
