High-Resolution Property Surveillance Cameras with Smart Focus
High Resolution Cameras for Property Surveillance with Smart Focus Technology
When it comes to securing your property, having a high-resolution camera equipped with smart focus technology is essential. These advanced cameras not only capture crystal-clear footage but also intelligently track and focus on important activities, ensuring you never miss a detail. Below, we explore the top Wyze cameras designed for property surveillance, highlighting their specs and smart features that make them ideal for protecting your home or business.
Wyze Cam v4: The Clearest Wyze Cam Ever Made
Stunning 2.5K QHD Resolution with Smart Focus
Wyze Cam v4 delivers unmatched clarity with its 2.5K Quad High Definition resolution, providing sharp and detailed video footage. Its smart focus technology uses AI-powered auto-zoom to track moving objects, allowing you to focus on what matters while still viewing the bigger picture.
Enhanced Color Night Vision & Motion-Activated Spotlight
Unlike traditional night vision, Wyze Cam v4 features enhanced color night vision that reveals vibrant colors even in low-light conditions, giving you superhero-like vision after dark. The integrated motion-activated spotlight and 99 dB siren add an extra layer of security by deterring intruders and lighting your way.
Robust Weather Resistance & Connectivity
Rated IP65 for weather resistance, this camera is perfect for both indoor and outdoor use, standing strong against rain, snow, and dust. It supports Wi-Fi 6 for a stronger, more reliable connection and integrates seamlessly with Alexa, Google Assistant, and IFTTT for smart home automation.
Continuous Local Recording & Smart Alerts
Wyze Cam v4 supports 24/7 local recording to microSD cards up to 256GB (sold separately), so you never miss a moment without needing a subscription. It also offers advanced motion and sound detection, including smoke and CO alarm alerts, ensuring comprehensive property monitoring. Wyze Cam v4 in action Wyze Cam v4 providing smart home security indoors and outdoors
Wyze Battery Cam Pro: Wire-Free 2.5K HDR Surveillance Anywhere
High-Definition 2.5K HDR Video Without Wires
The Wyze Battery Cam Pro offers stunning 2.5K HDR video resolution with rich colors and balanced lighting, ideal for capturing clear footage day or night. Its wireless design means no power outlets or hubs are required, making it perfect for flexible placement around your property.
Dual Radar + PIR Motion Detection & Integrated Spotlight
Equipped with both radar and PIR sensors, this camera detects motion with exceptional accuracy and speed. The built-in 150-lumen spotlight and 99 dB siren provide active deterrence, while custom detection zones let you focus alerts on critical areas.
Removable Rechargeable Batteries & Solar Power Option
Say goodbye to downtime with hot-swappable battery packs that can be charged separately. For extended outdoor use, pair it with the Wyze Solar Panel to keep your camera powered sustainably.
Weatherproof & Dual-Band Wi-Fi Support
With an IP65 rating, the Battery Cam Pro withstands harsh weather conditions. It supports both 2.4 GHz and 5 GHz Wi-Fi bands for faster, more reliable connectivity and features easy Bluetooth setup without QR codes.
Wyze Cam Pan v3: 360° Pan and 180° Tilt with Smart Tracking
Full Coverage with 360° Horizontal and 180° Vertical View
Wyze Cam Pan v3 offers a complete panoramic view with smooth 360° horizontal rotation and 180° vertical tilt, ensuring no blind spots on your property. Its 1080p resolution delivers clear video, while 8x digital zoom lets you focus on distant details.
IP65 Weather Resistance for Indoor/Outdoor Use
Built with durable polycarbonate and glass lens materials, this camera is rated IP65 for weather resistance, making it suitable for outdoor installation when paired with the Wyze Outdoor Power Adapter.
Advanced Two-Way Audio and Smart Integrations
Communicate clearly with built-in noise and echo-canceling two-way audio. The camera integrates with Alexa, Google Assistant, and IFTTT, allowing voice control and automation.
Fast Rotation and Intelligent Alerts
With rotation speeds up to 110° per second, the Pan v3 can quickly track moving objects. Push notifications keep you informed of any detected motion, and microSD support up to 256GB allows local recording. Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3 providing 360° surveillance in all weather conditions
Wyze Cam Floodlight Pro: Bright, Smart, and High-Resolution Security
2.5K QHD Video with 180° Wide-Angle Lens
Wyze Cam Floodlight Pro combines high-resolution 2.5K QHD video with a massive 180° diagonal field of view, covering your entire yard or driveway in vivid detail.
AI-Powered Motion Detection with Selective Lighting
This camera uses advanced onboard AI to detect specific objects like people and vehicles, activating its powerful 3,000-lumen LED floodlights only when needed. This smart lighting reduces energy waste and enhances security.
Loud 105 dB Siren and Dual-Band Wi-Fi
The integrated siren can be triggered remotely to scare off intruders. Dual-band Wi-Fi support ensures a stable connection, and compatibility with Alexa, Google Assistant, and IFTTT offers smart home convenience.
Weatherproof and Durable Design
With an IP65 rating, the Floodlight Pro is built to withstand extreme temperatures and weather, making it a reliable outdoor security solution. Wyze Cam Floodlight Pro lighting a side door Wyze Cam Floodlight Pro illuminating and securing your property
Why Choose Wyze Cameras for Property Surveillance?
Wyze cameras combine high-resolution imaging, smart focus technology, and robust weather resistance to provide comprehensive property surveillance. Whether you need wired or wireless options, panoramic views, or integrated floodlights, Wyze offers versatile solutions tailored to your security needs.
With features like AI tracking, enhanced color night vision, motion-activated lighting, and seamless smart home integration, these cameras ensure your property is monitored with precision and clarity around the clock.
Summary of Featured Cameras
Camera ModelResolutionSmart Focus & TrackingPower TypeWeather ResistanceSpecial Features
Wyze Cam v42.5K QHDAI Auto-Zoom & TrackWiredIP65Enhanced Color Night Vision, Spotlight
Wyze Battery Cam Pro2.5K HDRRadar + PIR DetectionBattery (Rechargeable)IP65Wire-Free, Solar Power Compatible
Wyze Cam Pan v31080p360° Pan & 180° TiltWiredIP65Two-Way Audio, Fast Rotation
Wyze Cam Floodlight Pro2.5K QHDAI Object DetectionHardwiredIP653000 Lumens Floodlight, 105 dB Siren
Invest in Wyze’s high-resolution cameras with smart focus technology to elevate your property surveillance. Experience peace of mind knowing your home or business is protected with cutting-edge security solutions designed for clarity, intelligence, and durability.
FeatureWyze Cam v4Wyze Battery Cam ProWyze Cam Pan v3Wyze Cam Floodlight ProWyze Cam Floodlight v2
TypeWired CameraBattery CameraWired Camera (Pan/Tilt)Wired Camera with FloodlightWired Camera with Floodlight
Video Resolution2.5K QHD (2560x1440)2.5K HDR1080p (1920x1080)2.5K QHD (2560x1440)2K (1920x1080)
Field of View (FOV)115.9° D x 98.5° H x 53.1° VNot specified360° horizontal, 180° vertical180° diagonal, 170° horizontal, 95° vertical160° wide-angle
Night VisionEnhanced Color Night VisionColor Night Vision4 IR LEDs (850 nm)Color Night VisionColor Night Vision
SpotlightMotion-activated spotlightIntegrated 150 lumens LED spotlightNoAdjustable 3000 lumen LED lights2800 Lumens LEDs
SirenYes (99 dB)YesNoYes (105 dB)No (not specified)
AudioEnhanced Two-Way Talk, Noise & Echo CancellationTwo-Way Talk, Built-in mic & speakerTwo-Way Audio, Noise & Echo CancellationTwo-Way AudioTwo-Way Talk
Motion DetectionYes, with motion detection zonesRadar + PIR Motion DetectionYesAI Computer Vision Motion DetectionAI-Powered Motion Detection
Local Recording24/7 local recording (microSD up to 256GB)Local recording (microSD, impacts battery life)Supports microSD up to 256GBSupports microSD up to 256GB24/7 local recording
Cloud StorageSubscription available (Cam Plus)Subscription available (Cam Plus)Subscription availableSubscription availableSubscription available
Power SourceWired (USB power adapter included)Battery (removable, rechargeable)Wired (USB power adapter included)Hardwired 110-120V ACWired (power details not specified)
Weather ResistanceIP65IP65IP65IP65 Water ResistanceIP65
Wi-Fi Support2.4 GHz & Wi-Fi 62.4 & 5 GHz dual-band2.4 GHz only2.4 & 5 GHz dual-bandNot specified
Smart Assistant IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTNot specified
Dimensions2in x 2in x 2 3/8inNot specified124mm x 60mm x 63mm10.2" x 9.1" x 7.8"Not specified
Weight0.49 lb (222 g)Not specified11.29 oz (320 g)2.9 lbs (1.32 kg)Not specified
Mounting OptionsStand, Wall, Ceiling, Magnetic MountFlexible mounting optionsScrew 1/4" - 20 mountWall, CeilingNot specified
Additional FeaturesMotion-activated siren, Smoke & CO alerts, AI Auto-ZoomRemovable battery packs, Solar panel compatible, Bird detection360° pan & 180° tilt, 8x digital zoomAI object detection, adjustable lightsAmbient Light Mode, dusk-to-dawn automation, AI Light Control
What are the benefits of using high-resolution cameras with smart focus technology for property surveillance?High-resolution cameras with smart focus technology provide crystal-clear video footage and use AI-powered features to intelligently track and focus on important activities. This ensures you never miss critical details, enhances security, and allows for more effective monitoring of your property.
What makes the Wyze Cam v4 ideal for home and business security?The Wyze Cam v4 offers 2.5K QHD resolution for sharp, detailed footage, AI-powered smart focus with auto-zoom tracking, enhanced color night vision, a motion-activated spotlight, and a 99 dB siren. It is IP65 weather-resistant, supports Wi-Fi 6, integrates with Alexa, Google Assistant, and IFTTT, and allows for 24/7 local recording without a subscription.
Does the Wyze Cam v4 support continuous local recording?Yes, the Wyze Cam v4 supports continuous 24/7 local recording to microSD cards up to 256GB (sold separately), so you can store footage without needing a subscription.
How does the Wyze Battery Cam Pro provide flexible surveillance?The Wyze Battery Cam Pro is a wire-free camera offering 2.5K HDR video, dual radar and PIR motion detection, a built-in spotlight and siren, and custom detection zones. Its removable rechargeable batteries and optional solar panel provide flexible, sustainable power for placement anywhere on your property.
Is the Wyze Battery Cam Pro weatherproof?Yes, the Wyze Battery Cam Pro is rated IP65 for weather resistance, making it suitable for outdoor use in various weather conditions.
What are the key features of the Wyze Cam Pan v3 for property monitoring?The Wyze Cam Pan v3 offers 360° horizontal pan and 180° vertical tilt for full coverage, 1080p resolution, 8x digital zoom, fast rotation speeds, advanced two-way audio, and smart integrations with Alexa, Google Assistant, and IFTTT. It is also IP65 weather-resistant for indoor and outdoor use.
Can the Wyze Cam Pan v3 be used outdoors?Yes, the Wyze Cam Pan v3 is IP65 weather-resistant and can be used outdoors when paired with the Wyze Outdoor Power Adapter.
What makes the Wyze Cam Floodlight Pro a powerful outdoor security solution?The Wyze Cam Floodlight Pro features 2.5K QHD video, a 180° wide-angle lens, AI-powered motion detection, 3,000-lumen LED floodlights, a loud 105 dB siren, dual-band Wi-Fi, and IP65 weatherproofing. It provides bright, smart, and high-resolution security for large outdoor areas.
Do Wyze cameras integrate with smart home systems?Yes, all featured Wyze cameras integrate with Alexa, Google Assistant, and IFTTT, allowing for voice control and seamless smart home automation.
What is the weather resistance rating of Wyze surveillance cameras?All the featured Wyze cameras, including Wyze Cam v4, Battery Cam Pro, Cam Pan v3, and Floodlight Pro, are rated IP65 for weather resistance, making them suitable for both indoor and outdoor use.
Can Wyze cameras detect specific types of motion or objects?Yes, Wyze cameras use advanced AI to detect specific objects such as people and vehicles. Some models, like the Floodlight Pro, use AI-powered motion detection to activate lighting and alerts only when needed.
What are the power options available for Wyze surveillance cameras?Wyze offers both wired and wireless cameras. The Wyze Cam v4 and Cam Pan v3 are wired, the Battery Cam Pro uses rechargeable batteries and is compatible with solar power, and the Floodlight Pro is hardwired for continuous power.
How do Wyze cameras enhance night-time security?Wyze cameras feature enhanced color night vision, motion-activated spotlights, and powerful floodlights to provide clear, vibrant footage and active deterrence even in low-light or nighttime conditions.
What are the key features of the Wyze Cam v4 that make it suitable for property surveillance?Can you explain how the smart focus technology works in the Wyze Cam v4?Do you have any ongoing sales or discounts for the Wyze cameras?
