Best Smart Tracking Security Cameras for Indoor & Outdoor Use
Smart Tracking Security Cameras for Indoor and Outdoor Home Surveillance
When it comes to securing your home, having smart tracking security cameras that work seamlessly both indoors and outdoors is essential. Whether you want to monitor your front porch, backyard, or living room, the latest Wyze cameras offer advanced features like 360° pan and tilt, high-resolution video, night vision, motion-activated lighting, and wireless convenience. Explore the best Wyze smart cameras designed to keep your home safe and under watchful eyes 24/7.
Wyze Cam Pan v3: 360° Pan & Tilt for Complete Coverage
Wyze Cam Pan v3 is a versatile indoor/outdoor security camera that offers a full 360° pan and 180° tilt, ensuring no blind spots around your home. Its IP65 weather resistance makes it durable for outdoor use when paired with the Wyze Outdoor Power Adapter (sold separately). Available in sleek black or white, this camera is perfect for monitoring wide areas like patios, garages, or living rooms.
  • 360° Pan & 180° Tilt: Covers every angle with smooth motorized movement.
  • IP65 Weather Resistant: Built to withstand rain, snow, and dust.
  • Indoor/Outdoor Use: Flexible placement options for comprehensive home security.
  • Multiple Pack Options: Available in 1, 2, or 3 packs for expanded coverage.
"Wyze Cam Pan v3 lets you watch over your home with unmatched flexibility and weatherproof reliability."
Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3 providing weather-resistant outdoor surveillance
Wyze Cam v4: Crystal-Clear 2.5K QHD with Enhanced Night Vision
For those who want ultra-clear video quality, the Wyze Cam v4 delivers 2.5K QHD resolution with a CMOS Starlight Sensor that enhances color night vision. This camera supports Wi-Fi 6 for faster, more reliable connections and integrates smoothly with Alexa and Google Assistant for voice control convenience.
  • 2.5K QHD Video: Sharp, detailed footage day and night.
  • Enhanced Color Night Vision: See vibrant colors even in low light.
  • Motion-Activated Spotlight: Automatically lights up when motion is detected.
  • Wide Field of View: 115.8° diagonal for broad coverage.
  • Smart Home Compatible: Works with Alexa and Google Assistant.
Ideal for both indoor and outdoor use, Wyze Cam v4 ensures you never miss a moment with 24/7 local recording and multiple color options to blend with your home decor.
Wyze Cam Floodlight v2: Bright Security with 2800 Lumens LEDs
Illuminate and secure your outdoor spaces with the Wyze Cam Floodlight v2. This camera combines powerful 2800 lumens LED floodlights with 2K video and color night vision to keep your driveway, backyard, or front porch brightly lit and monitored.
  • 2800 Lumens Brightness: Lights up large outdoor areas effectively.
  • 2K Video with Color Night Vision: Clear footage even in the dark.
  • 160° Wide-Angle View: Covers broad outdoor spaces.
  • AI-Powered Light Control: Automatically adjusts lighting based on activity.
  • Two-Way Talk & Siren: Communicate or deter intruders remotely.
  • Dusk-to-Dawn Automation: Lights turn on/off automatically based on ambient light.
  • IP65 Weather Resistant: Built for all weather conditions.
"Wyze Cam Floodlight v2 is your all-in-one outdoor security solution with smart lighting and sharp video."
Wyze Cam Floodlight v2 illuminating driveway at night Wyze Cam Floodlight v2 providing bright, smart outdoor security
Wyze Battery Cam Pro: Wire-Free 2.5K HDR with Radar Motion Detection
For ultimate flexibility, the Wyze Battery Cam Pro offers wire-free installation with rechargeable battery packs and no hub required. It features 2.5K HDR video resolution, integrated spotlight, siren, and advanced radar + PIR motion detection for precise tracking.
  • Wire-Free & Rechargeable: Easy to install anywhere without wiring.
  • 2.5K HDR Video: High dynamic range for clear, vibrant footage.
  • Radar + PIR Motion Detection: Accurate detection reduces false alerts.
  • Integrated Spotlight & Siren: Deter unwanted visitors instantly.
  • Dual-Band Wi-Fi Support: Compatible with 2.4 & 5 GHz networks.
  • IP65 Weatherproof: Ready for outdoor conditions.
Perfect for monitoring entryways, backyards, or any spot where wiring is inconvenient.
Wyze Cam OG & OG Telephoto: Affordable Indoor/Outdoor Security
The Wyze Cam OG is a budget-friendly option that still packs essential features like 1080p HD video, 120° field of view, and improved 2-way audio with a built-in spotlight. The OG Telephoto model adds a 3x telephoto lens for zoomed-in views without losing clarity. Wyze Cam OG:
  • 1080p Full HD video.
  • 120° wide field of view.
  • Quick live-streaming and 3X faster notifications.
  • Built-in spotlight and improved 2-way audio.
  • Indoor/outdoor use.
Wyze Cam OG Telephoto:
  • All OG features plus 3x telephoto zoom.
  • Ideal for detailed monitoring of distant areas.
  • Available in white with 1 or 2 pack options.
These cameras are perfect for users seeking reliable, easy-to-use security without breaking the bank.
Why Choose Wyze Smart Tracking Security Cameras?
Wyze offers a comprehensive lineup of smart tracking security cameras tailored for both indoor and outdoor home surveillance. Their cameras combine advanced video quality, smart motion detection, weather resistance, and seamless smart home integration. Whether you prefer wired or wireless setups, floodlight illumination, or pan-and-tilt flexibility, Wyze has a solution to fit your security needs and budget.
"Protect your home with smart, reliable, and affordable Wyze cameras designed for every corner of your property."
Summary of Featured Wyze Cameras
ModelResolutionKey FeaturesIndoor/OutdoorPower SourceSpecial Feature
Wyze Cam Pan v31080p HD360° pan/180° tilt, IP65 weatherBothWired (adapter for outdoor)Full coverage pan & tilt
Wyze Cam v42.5K QHDColor night vision, Wi-Fi 6BothWiredEnhanced night vision
Wyze Cam Floodlight v22K2800 lumens LED, AI light controlOutdoorWiredPowerful floodlight
Wyze Battery Cam Pro2.5K HDRWire-free, radar + PIR detectionOutdoorRechargeable batteryWireless with spotlight & siren
Wyze Cam OG1080p HDBuilt-in spotlight, 2-way audioBothWiredAffordable smart camera
Wyze Cam OG Telephoto1080p HD + 3x zoomTelephoto lens, fast notificationsBothWiredZoom for detailed views
Secure your home today with Wyze’s smart tracking security cameras that combine innovation, convenience, and affordability.
FeatureWyze Cam Pan v3Wyze Cam v4Wyze Cam Floodlight v2Wyze Battery Cam ProWyze Cam OGWyze Cam OG Telephoto
Video Resolution1080p (1920 x 1080)2.5K QHD (2560 x 1440)2K (2304 x 1296)2.5K HDR (2560 x 1440)1080p (1920 x 1080)1080p (1920 x 1080)
Field of View (Diagonal)360° pan, 180° tilt115.9°160°134° (DFOV)120°27° (DFOV)
Night VisionColor Night Vision (Starlight Sensor)Enhanced Color Night VisionColor Night VisionIR LEDs + White LEDsIR LEDs (4 x 850nm)IR LEDs (4 x 850nm)
AudioTwo-Way AudioEnhanced Two-Way TalkTwo-Way AudioTwo-Way AudioBuilt-in Speaker & MicrophoneBuilt-in Speaker & Microphone
SirenNo99 dB105 dB100 dB90 dB user-activatedNot specified
SpotlightNo (sold separately)Motion-activated Spotlight2 dimmable LED panels (2800 lumens)Integrated SpotlightBuilt-in Spotlight (40 lumens)No
Weather ResistanceIP65 (requires Outdoor Power Adapter)IP65IP65IP65IP65IP65
Power SourceWired (requires Outdoor Power Adapter for outdoor)WiredHardwiredBattery (Removable, Rechargeable)WiredWired
WirelessNoNoNoYesNoNo
ConnectivityWi-Fi 2.4 GHzWi-Fi 6 (2.4 GHz)Wi-Fi 2.4 GHzWi-Fi 2.4 & 5 GHzWi-Fi 2.4 GHzWi-Fi 2.4 GHz
Local StoragemicroSD up to 256 GBmicroSD up to 256 GBmicroSD up to 256 GBmicroSD up to 256 GBmicroSD up to 256 GBmicroSD up to 256 GB
Motion DetectionYes, with automatic motion trackingYes, with AI Smart FocusYes, AI-Powered Light ControlRadar + PIR Motion DetectionYesYes
Custom Detection ZonesYesYesNot specifiedNot specifiedYesNot specified
DimensionsNot specifiedNot specified9.5" x 7.7" x 7.0" (24.13 x 19.56 x 17.78 cm)2.5" x 1.8" x 3.5"1.89" x 1.89" x 1.89" (48mm cube)1.89" x 1.89" x 1.89" (48mm cube)
WeightNot specifiedNot specified2.76 lbs (1.25 kg)0.94 lbs4.1 oz (116 g)4.1 oz (116 g)
Operating TemperatureNot specifiedNot specified-4°F to 140°F (-20°C to 60°C)-4°F to 122°F (-20°C to 50°C)-4°F to 131°F (-20°C to 55°C)-4°F to 131°F (-20°C to 55°C)
WarrantyNot specifiedNot specified1 yearNot specified1 year1 year
Price (1 Pack)$39.98$35.98$89.98$159.98$29.98$25.98
What are the best Wyze smart tracking security cameras for indoor and outdoor home surveillance?Wyze offers a range of smart tracking security cameras suitable for both indoor and outdoor use, including the Wyze Cam Pan v3, Wyze Cam v4, Wyze Cam Floodlight v2, Wyze Battery Cam Pro, Wyze Cam OG, and Wyze Cam OG Telephoto. Each model features advanced video quality, motion detection, weather resistance, and smart home integration to keep your home secure 24/7.
What features does the Wyze Cam Pan v3 offer for home security?The Wyze Cam Pan v3 provides 360° pan and 180° tilt for complete coverage, IP65 weather resistance for outdoor use (with the Wyze Outdoor Power Adapter), and is available in multiple pack options. It is ideal for monitoring wide areas like patios, garages, or living rooms, ensuring no blind spots in your home security.
Is the Wyze Cam Pan v3 suitable for outdoor use?Yes, the Wyze Cam Pan v3 is IP65 weather resistant and can be used outdoors when paired with the Wyze Outdoor Power Adapter (sold separately). Its durable design makes it suitable for rain, snow, and dust.
What makes the Wyze Cam v4 ideal for both indoor and outdoor surveillance?The Wyze Cam v4 features 2.5K QHD video resolution, enhanced color night vision with a CMOS Starlight Sensor, motion-activated spotlight, wide 115.8° field of view, and compatibility with Alexa and Google Assistant. It supports Wi-Fi 6 for faster connections and offers 24/7 local recording, making it perfect for any location inside or outside your home.
How does the Wyze Cam Floodlight v2 enhance outdoor security?The Wyze Cam Floodlight v2 combines powerful 2800 lumens LED floodlights with 2K video and color night vision. It features a 160° wide-angle view, AI-powered light control, two-way talk, a built-in siren, dusk-to-dawn automation, and IP65 weather resistance, making it an all-in-one solution for bright and reliable outdoor security.
What are the benefits of the Wyze Battery Cam Pro for home monitoring?The Wyze Battery Cam Pro offers wire-free installation with rechargeable batteries, 2.5K HDR video, radar and PIR motion detection for accurate alerts, an integrated spotlight and siren, dual-band Wi-Fi support, and IP65 weatherproofing. It is ideal for locations where wiring is inconvenient, such as entryways and backyards.
What is the difference between Wyze Cam OG and Wyze Cam OG Telephoto?The Wyze Cam OG provides 1080p HD video, a 120° wide field of view, built-in spotlight, improved two-way audio, and is suitable for both indoor and outdoor use. The Wyze Cam OG Telephoto includes all OG features plus a 3x telephoto lens for detailed monitoring of distant areas, making it perfect for zoomed-in surveillance.
Are Wyze security cameras weather resistant?Yes, several Wyze security cameras, including the Wyze Cam Pan v3, Wyze Cam Floodlight v2, Wyze Battery Cam Pro, and Wyze Cam OG, are IP65 weather resistant, making them suitable for outdoor use in various weather conditions.
Do Wyze cameras support smart home integration?Yes, Wyze cameras such as the Wyze Cam v4 are compatible with Alexa and Google Assistant, allowing for seamless smart home integration and convenient voice control.
Which Wyze camera is best for users on a budget?The Wyze Cam OG and Wyze Cam OG Telephoto are affordable options that offer essential features like 1080p HD video, wide field of view, built-in spotlight, and improved two-way audio, making them ideal for budget-conscious users seeking reliable indoor and outdoor security.
Can Wyze cameras record video 24/7?Yes, models like the Wyze Cam v4 support 24/7 local recording, ensuring you never miss a moment of activity around your home.
What power sources do Wyze security cameras use?Wyze security cameras offer both wired and wireless options. Models like the Wyze Cam Pan v3, Wyze Cam v4, and Wyze Cam Floodlight v2 are wired, while the Wyze Battery Cam Pro operates on rechargeable batteries for wire-free installation.
What are the key features of the Wyze Cam Pan v3?Can you tell me more about the weather resistance of the Wyze cameras?Are there any ongoing promotions or discounts for Wyze cameras?
