Ultimate House Surveillance Kit with Wide Dynamic Range Cameras and Motion Detection Zones
Protect your home with a cutting-edge surveillance system designed to deliver crystal-clear video, advanced motion detection, and seamless connectivity. This house surveillance kit features Wyze’s top-tier cameras equipped with Wide Dynamic Range (WDR) technology and customizable motion detection zones, ensuring you never miss a detail—day or night.
Advanced Surveillance Cameras for Superior Security
Wyze Cam v4 – Crystal-Clear 2.5K QHD with Wide Dynamic Range
Experience unmatched home security with the
Wyze Cam v4, a powerhouse camera that combines high-resolution video with enhanced color night vision and motion-activated spotlight features.
- 2.5K QHD Resolution (2560x1440): Capture every detail in stunning clarity.
- Wide Dynamic Range (WDR): Balances bright and dark areas for vibrant, true-to-life images even in challenging lighting conditions.
- Enhanced Color Night Vision: See full-color video at night with 4 IR LEDs plus 2 white spotlight LEDs (72 lumens).
- Motion-Activated Spotlight: Automatically lights up when motion is detected to deter intruders.
- Field of View: Wide 115.8° diagonal, 98.5° horizontal, and 53.1° vertical coverage.
- Connectivity: Supports Wi-Fi 6 for fast, reliable streaming and works with Alexa, Google Assistant, and IFTTT.
- Local and Cloud Storage: Save footage locally on microSD cards up to 512GB or opt for cloud storage with subscription.
- Weather Resistance: Rated IP65 for indoor/outdoor use, built to withstand temperatures from -4°F to 122°F.
This camera’s wide dynamic range ensures clear visibility in scenes with mixed lighting, such as bright sunlight and shadows, making it ideal for front yards, backyards, and entryways.
For a complete setup, the
Wyze Cam v4 Home Security Bundle offers the same advanced features as the single camera but includes multiple units for comprehensive coverage around your home. This bundle is perfect for monitoring multiple zones with precision motion detection and spotlight alerts.
Wyze Battery Cam Pro – Wire-Free, Motion Detection with Radar + PIR
For flexible placement without wiring constraints, the
Wyze Battery Cam Pro delivers 2.5K HDR video with advanced motion detection technologies:
- Radar + PIR Motion Detection: Combines radar sensing and passive infrared for highly accurate motion alerts and fewer false alarms.
- Wire-Free Design: Powered by removable rechargeable 6200mAh batteries lasting up to 6 months per charge.
- Integrated Spotlight & Siren: Built-in white LEDs (187 lumens) and a 100 dB siren to deter unwanted visitors.
- Wide Field of View: 134° diagonal, 108° horizontal, and 56° vertical coverage.
- Dual-Band Wi-Fi Support: Connects to both 2.4 GHz and 5 GHz networks for stable streaming.
- Weatherproof: IP65 rating for reliable outdoor use in harsh weather.
- Local Storage: Supports microSD cards up to 256GB.
This camera is ideal for areas where wiring is difficult or impossible, such as detached garages, gardens, or remote corners of your property.
Seamless Connectivity with Wyze Wi-Fi 6 Mesh Router
A robust surveillance system requires a strong and reliable network. The
Wyze Wi-Fi 6 Mesh Router ensures your cameras and smart devices stay connected with lightning-fast speeds and extensive coverage.
- Wi-Fi 6 Technology: Supports internet speeds up to 1 Gbps with AX3000 bandwidth.
- Coverage: Each router covers up to 1500 sq. ft., and multiple units can be linked for whole-home coverage.
- Device Support: Connects 50+ devices simultaneously without lag.
- Advanced Security: WPA3-PSK encryption keeps your network safe.
- Easy Setup: Bluetooth Low Energy 5.1 provisioning and intuitive app controls.
- Multiple Operation Modes: Router, bridge, and auto WAN/LAN sensing for flexible network configurations.
This router is perfect for smart homes with multiple cameras and devices, eliminating dead zones and buffering issues to keep your surveillance footage smooth and uninterrupted.
Reliable Wi-Fi 6 Mesh Router for Smart Homes
Why Choose This Surveillance Kit?
"A surveillance system is only as good as its ability to capture clear footage and alert you to real threats. With Wyze’s wide dynamic range cameras and advanced motion detection zones, you get precise, vibrant video and smart alerts tailored to your property’s unique layout."
- Wide Dynamic Range Cameras: Capture balanced images in high-contrast lighting.
- Customizable Motion Detection Zones: Focus alerts on critical areas to reduce false alarms.
- Wireless and Wired Options: Choose between plug-in or battery-powered cameras.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
- Robust Network Backbone: Wi-Fi 6 mesh router ensures seamless connectivity.
Enhance Your Home Security Today
Equip your home with the best in surveillance technology. Whether you need wired cameras with spotlight features or wire-free battery cams with radar motion detection, this kit covers all your security needs. Combined with the Wyze Wi-Fi 6 Mesh Router, you get a reliable, high-performance system that keeps your home safe and connected.
What is included in the Ultimate House Surveillance Kit?
The Ultimate House Surveillance Kit includes Wyze’s advanced cameras with Wide Dynamic Range (WDR) technology, customizable motion detection zones, and the Wyze Wi-Fi 6 Mesh Router for seamless connectivity. The kit offers both wired and wire-free camera options, as well as local and cloud storage solutions.What are the key features of the Wyze Cam v4?
The Wyze Cam v4 features 2.5K QHD resolution, Wide Dynamic Range (WDR) for balanced images in challenging lighting, enhanced color night vision, a motion-activated spotlight, a wide field of view, Wi-Fi 6 connectivity, compatibility with Alexa, Google Assistant, and IFTTT, local and cloud storage options, and IP65 weather resistance for indoor and outdoor use.How does Wide Dynamic Range (WDR) improve home security camera footage?
Wide Dynamic Range (WDR) technology balances bright and dark areas in video footage, ensuring clear, vibrant, and true-to-life images even in scenes with mixed lighting, such as areas with both sunlight and shadows. This helps capture important details that might otherwise be missed.What is the benefit of customizable motion detection zones?
Customizable motion detection zones allow you to focus alerts on specific areas of your property, reducing false alarms and ensuring you are notified only about activity in critical zones, such as entryways or driveways.What makes the Wyze Battery Cam Pro suitable for outdoor and remote locations?
The Wyze Battery Cam Pro is wire-free, powered by removable rechargeable batteries that last up to 6 months per charge. It features radar and PIR motion detection for accurate alerts, an integrated spotlight and siren, a wide field of view, dual-band Wi-Fi support, IP65 weatherproofing, and local storage support, making it ideal for areas without easy access to power.How does the Wyze Wi-Fi 6 Mesh Router enhance surveillance system performance?
The Wyze Wi-Fi 6 Mesh Router provides fast, reliable internet speeds up to 1 Gbps, supports over 50 devices simultaneously, and offers whole-home coverage by linking multiple units. It uses WPA3-PSK encryption for security and features easy setup and multiple operation modes, ensuring your cameras and smart devices stay connected without lag or dead zones.Can I use both wired and wireless cameras in this surveillance kit?
Yes, the Ultimate House Surveillance Kit supports both wired cameras like the Wyze Cam v4 and wire-free options like the Wyze Battery Cam Pro, allowing you to customize your home security setup based on your needs and property layout.Is the surveillance system compatible with smart home devices?
Yes, the Wyze cameras and Wi-Fi 6 Mesh Router are compatible with popular smart home platforms, including Alexa, Google Assistant, and IFTTT, enabling seamless integration and voice control.What storage options are available for recorded footage?
The surveillance cameras support local storage via microSD cards (up to 512GB for Wyze Cam v4 and up to 256GB for Wyze Battery Cam Pro) and offer cloud storage options through a subscription service, giving you flexibility in how you store and access your video recordings.Are the cameras weatherproof and suitable for outdoor use?
Yes, both the Wyze Cam v4 and Wyze Battery Cam Pro are rated IP65, making them weather-resistant and suitable for both indoor and outdoor installation. They are designed to withstand temperatures from -4°F to 122°F.
