Minimal Footprint Wyze Window Mount for Narrow Ledges
Find the Perfect Minimal Footprint Mount for Your Wyze Camera on Narrow Window Ledges
When it comes to mounting your Wyze camera on narrow window ledges, you want a solution that is compact, secure, and designed specifically for glass surfaces. The Wyze Window Mount is the ideal accessory to upgrade your home security with a minimal footprint, ensuring your camera stays firmly in place without bulky hardware or complicated installation.
Wyze Window Mount: Designed for Narrow Window Ledges
Compact and Glass-Friendly Design
The Wyze Window Mount is engineered to attach your Wyze Cam v3, v3 Pro, v4, Wyze Cam OG, or OG Telephoto directly onto glass surfaces. This mount is perfect for narrow window ledges where space is limited, providing a sleek and unobtrusive way to position your camera.
  • Minimal footprint: Takes up very little space on your window ledge, ideal for tight spots.
  • Reduces glare and reflection: Mounting on the glass surface ensures a clear, unobstructed view.
  • Compatible with multiple Wyze cameras: Works with Wyze Cam v3, v3 Pro, v4, OG, and OG Telephoto.
  • Easy installation: No drilling or complex setup required, just attach and secure.
Upgrade your exterior security by mounting your Wyze camera on the window for a clear view free of glare or reflection.
Specifications and Variants
  • Style v2: Compatible with Cam v3, v3 Pro, v4, and Cam OG series.
  • Price: $9.98
  • Stock: Available
This mount is a top seller in the Camera Accessories collection and is perfect for RVs, campers, motorhomes, and travel trailers where space is at a premium. Wyze Cam Mounted on Window Ledge Alt text: Wyze camera mounted on a narrow window ledge for outdoor security
Other Wyze Mounting Accessories to Consider
While the Wyze Window Mount is the best choice for narrow window ledges, Wyze offers other mounting solutions that might suit different needs:
Wyze Universal Mount (Long)
If you need a versatile mount with a longer neck for ceiling or patio installations, the Wyze Universal Mount (Long) is a durable metal mount compatible with most Wyze cameras (except OG and OG Telephoto). It offers:
  • Heavy-duty metal construction
  • Adjustable angles for flexible positioning
  • Easy installation with included screws and anchors
  • Price: $9.99
This mount is ideal if you want to place your camera in less conventional spots but is not designed specifically for narrow window ledges.
Wyze Cam Floodlight Plug-In Mount
For outdoor lighting combined with security, the Wyze Cam Floodlight Plug-In Mount offers a plug-and-play solution without the need for junction boxes or electricians. It’s perfect for porch or yard security but not suitable for window ledges.
Why Choose the Wyze Window Mount for Narrow Window Ledges?
The Wyze Window Mount stands out as the minimal footprint mounting solution tailored for glass surfaces, making it the perfect choice for narrow window ledges. Its design reduces glare and reflection, ensuring your Wyze camera captures clear, high-quality footage without bulky hardware getting in the way.
  • Compact and discreet
  • Compatible with multiple Wyze camera models
  • Easy to install and reposition
  • Affordable and reliable
Summary
For anyone searching for a minimal footprint mount to place a Wyze camera on narrow window ledges, the Wyze Window Mount is the definitive solution. It offers a sleek, glass-friendly design that keeps your camera secure and your view clear. Whether you have a Wyze Cam v3, v3 Pro, v4, or OG series, this mount fits perfectly and enhances your home security setup without taking up valuable space.
FeatureWyze Window MountWyze Universal Mount (Long)Wyze Cam Floodlight Plug-In Mount
TypeAccessoriesAccessoriesCameras
Compatible CamerasWyze Cam v3, v3 Pro, v4, Wyze Cam OG seriesWyze Cameras with 1/4”-20 mount (not OG/OG Telephoto)Wyze Cam Floodlight v1, v2, Floodlight Pro
Mounting SurfaceGlass (window)Versatile (ceiling, patio, fences, trees)Floodlight power mount (plug-in)
MaterialNot specifiedHeavy-duty metalNot specified
Price$9.98$9.99$19.98
Mount StyleWindow mountLong neck, adjustable and flexiblePlug-n-play floodlight mount
Weather ResistanceNot specifiedWeather resistant (withstands tough weather)Outdoor safe
InstallationMount on glass surfaceEasy installation on various surfacesEasy plug-n-play installation
Power SourceN/AN/A110-120V AC input, 20 ft power cord
Operating TemperatureNot specifiedNot specified-22°F to 122°F
Included ItemsNot specifiedNot specifiedMount, mounting kit, foam tape, quick start guide
Special FeaturesReduces glare, clear view free of reflectionAdjustable angle for perfect coverageEliminates need for junction box
Compatibility NotesWorks with Wyze Cam v3/v3 Pro/v4 and OG seriesNot compatible with Wyze Cam OG/OG TelephotoCompatible with Wyze Cam Floodlight models
What is the best mount for placing a Wyze camera on a narrow window ledge?The Wyze Window Mount is the best solution for mounting your Wyze camera on narrow window ledges. It features a compact, glass-friendly design that securely attaches your camera to glass surfaces without bulky hardware or complicated installation.
Which Wyze camera models are compatible with the Wyze Window Mount?The Wyze Window Mount is compatible with Wyze Cam v3, v3 Pro, v4, Wyze Cam OG, and OG Telephoto models.
Does the Wyze Window Mount reduce glare and reflection when used on glass?Yes, the Wyze Window Mount is designed to reduce glare and reflection by mounting directly onto glass surfaces, ensuring your camera captures clear and unobstructed footage.
Is the Wyze Window Mount easy to install?Absolutely. The Wyze Window Mount requires no drilling or complex setup. Simply attach it to your glass window and secure your camera for a quick and hassle-free installation.
How much space does the Wyze Window Mount take up on a window ledge?The Wyze Window Mount has a minimal footprint, making it ideal for narrow window ledges and tight spaces where traditional mounts may not fit.
What is the price of the Wyze Window Mount?The Wyze Window Mount is priced at $9.98 and is currently in stock.
Can I use the Wyze Window Mount in RVs, campers, or travel trailers?Yes, the Wyze Window Mount is perfect for RVs, campers, motorhomes, and travel trailers where space is limited and a minimal footprint is essential.
Are there other Wyze camera mounts available for different installation needs?Yes, Wyze offers other mounting accessories such as the Wyze Universal Mount (Long) for ceiling or patio installations and the Wyze Cam Floodlight Plug-In Mount for outdoor lighting and security. However, these are not specifically designed for narrow window ledges.
Why should I choose the Wyze Window Mount over other mounting options?The Wyze Window Mount is specifically designed for glass surfaces and narrow window ledges, offering a compact, discreet, and easy-to-install solution that reduces glare and keeps your camera secure without taking up valuable space.
Can you tell me more about the installation process for the Wyze Window Mount?Is the Wyze Window Mount compatible with all Wyze camera models?Do you have any ongoing sales or discounts for the Wyze Window Mount?
