Compact Wyze Cam Window Mount – Secure, Obstruction-Free Design
Compact Mount Design for Wyze Cam on Glass
When it comes to mounting your Wyze Cam on glass surfaces like windows, the Wyze Window Mount stands out as the perfect accessory. Designed specifically to secure Wyze Cam models such as the v3, v3 Pro, v4, Wyze Cam OG, and OG Telephoto, this mount offers a compact and obstruction-free solution that ensures your camera stays firmly in place without blocking the view.
Why Choose Wyze Window Mount?
  • Glare and Reflection Reduction: The mount is engineered to minimize glare and reflections, providing a crystal-clear view through your window.
  • Versatile Compatibility: Works seamlessly with multiple Wyze Cam models, including the latest versions.
  • Easy Installation: Attach your camera directly to any glass surface without complicated tools or drilling.
  • Compact and Sleek: Its low-profile design keeps your camera discreet and unobtrusive.
Upgrade your exterior security by mounting your Wyze Cam on your window with confidence and clarity.
Wyze Cam Floodlight on Deck Enhance your home security with unobstructed views using Wyze mounts
Additional Mounting Solutions for Wyze Cameras
While the Wyze Window Mount is ideal for glass surfaces, Wyze offers other mounting accessories to fit different installation needs.
Wyze Cam Mounting Kit
  • Complete Mounting Set: Includes a mounting bracket, adhesive, and a longer Micro USB cable.
  • Compatibility: Designed for Wyze Cam v2, v3, and v3 Pro.
  • Affordable and Practical: Perfect as a spare or replacement kit for flexible camera placement.
This kit is a great option if you want to mount your Wyze Cam on walls or other surfaces where adhesive and cable length are considerations.
Wyze Universal Mount (Long)
  • Durable Metal Construction: Heavy-duty metal mount with a longer neck for versatile mounting options.
  • Flexible Placement: Ideal for ceilings, patios, or other elevated spots.
  • Wide Compatibility: Works with Wyze Cam v1, v2, v3, v3 Pro, and Pan series (not compatible with Wyze Cam OG or OG Telephoto).
  • Adjustable and Easy to Install: Provides a sturdy and customizable mounting solution.
Enhance Your Outdoor Security with Wyze Floodlight Plug-In Mount
For those looking to combine lighting and security, the Wyze Cam Floodlight Plug-In Mount offers a simple, plug-and-play solution without the need for complex wiring or junction boxes.
  • Easy Installation: No junction box required; just plug in and mount.
  • Outdoor Safe: Built to withstand temperatures from -22°F to 122°F.
  • Compatible Models: Works with Wyze Cam Floodlight v1, v2, and Floodlight Pro.
  • Long Power Cord: 20 ft cable for flexible placement.
  • Certified Safety: UL, RoHS, and other certifications ensure reliability.
This mount is perfect for illuminating your outdoor spaces while keeping your home secure with Wyze’s advanced camera technology. Wyze Cam Mounted Outdoors Secure your home with versatile Wyze mounts for outdoor use
Summary: Best Mounting Options for Wyze Cameras
Product NameBest ForKey FeaturesPrice
Wyze Window MountGlass/window mountingReduces glare, compact, compatible with many Wyze cams$9.98
Wyze Cam Mounting KitWall or surface mountingMounting bracket, adhesive, longer USB cable$5.99
Wyze Universal Mount (Long)Ceiling, patio, versatile mountsHeavy-duty metal, adjustable, wide compatibility$9.99
Wyze Cam Floodlight Plug-In MountOutdoor floodlight camerasPlug-n-play, outdoor safe, 20 ft power cord$19.98
With these mounting accessories, securing your Wyze Cam to glass or other surfaces is effortless and reliable. Whether you want a sleek window mount or a versatile outdoor solution, Wyze has you covered.
Wyze Cam Floodlight Installation Easy setup for Wyze outdoor security solutions
### Product Tags Recap
FeatureWyze Window MountWyze Cam Mounting KitWyze Universal Mount (Long)Wyze Cam Floodlight Plug-In Mount
TypeAccessoriesAccessoriesAccessoriesCameras
Compatible CamerasWyze Cam v3, v3 Pro, v4, OG, OG TelephotoWyze Cam v2, v3, v3 ProWyze Cam v1, v2, v3, v3 Pro, Pan v1/v2/v3, Outdoor v1/v2, Battery Cam ProWyze Cam Floodlight v1, v2, Floodlight Pro
Mounting SurfaceGlass windowWall or surface (with bracket and adhesive)Ceiling, patio, versatile (1/4”-20 mount)Plug-in floodlight mount
Material/BuildNot specifiedIncludes mounting bracket, adhesive, USB cableHeavy-duty metal mountNot specified
Included ItemsMount onlyWall plate, USB extension cable (5 ft), adhesive tape, screw setWyze Universal Metal Mount, screw assemblyFloodlight Plug-in Mount, mounting kit, screws, foam tape, quick start guide
Price$9.98$5.99$9.99$19.98
Special FeaturesClear view free of glare/reflectionLonger Micro USB cable includedLonger neck, adjustable, easy installationPlug-n-play, no junction box needed
Mount Load BearingNot specifiedNot specified70 oz (2 kg)Not specified
Compatibility NotesWorks with multiple Wyze Cam models including OG seriesCompatible with Wyze Cam v2, v3, v3 Pro onlyNot compatible with Wyze Cam OG or OG TelephotoDesigned specifically for Wyze Cam Floodlight series
Color OptionsNot specifiedNot specifiedWhiteBlack, White
What is the Wyze Window Mount and which Wyze Cam models is it compatible with?The Wyze Window Mount is a compact accessory designed to securely attach your Wyze Cam to glass surfaces like windows. It is compatible with Wyze Cam v3, v3 Pro, v4, Wyze Cam OG, and OG Telephoto models.
How does the Wyze Window Mount reduce glare and reflections?The Wyze Window Mount is engineered to minimize glare and reflections, ensuring your camera captures a clear, unobstructed view through your window for optimal security footage.
Is the Wyze Window Mount easy to install?Yes, the Wyze Window Mount offers easy installation. You can attach your camera directly to any glass surface without the need for complicated tools or drilling.
What are the benefits of using a compact mount for Wyze Cam on glass?A compact mount like the Wyze Window Mount keeps your camera discreet and unobtrusive, secures it firmly in place, and ensures your view is not blocked while maintaining optimal camera performance.
What mounting options are available for Wyze Cam besides the window mount?Wyze offers several mounting solutions, including the Wyze Cam Mounting Kit for wall or surface mounting, the Wyze Universal Mount (Long) for ceilings and patios, and the Wyze Cam Floodlight Plug-In Mount for outdoor floodlight cameras.
What is included in the Wyze Cam Mounting Kit and which models does it support?The Wyze Cam Mounting Kit includes a mounting bracket, adhesive, and a longer Micro USB cable. It is compatible with Wyze Cam v2, v3, and v3 Pro models.
What are the features of the Wyze Universal Mount (Long)?The Wyze Universal Mount (Long) features a heavy-duty metal construction with a longer neck for versatile placement. It is adjustable, easy to install, and compatible with Wyze Cam v1, v2, v3, v3 Pro, and Pan series (not compatible with Wyze Cam OG or OG Telephoto).
How does the Wyze Cam Floodlight Plug-In Mount enhance outdoor security?The Wyze Cam Floodlight Plug-In Mount combines lighting and security in a plug-and-play solution. It is outdoor safe, requires no junction box, comes with a 20 ft power cord, and is compatible with Wyze Cam Floodlight v1, v2, and Floodlight Pro.
Are Wyze mounting accessories weather-resistant for outdoor use?Yes, the Wyze Cam Floodlight Plug-In Mount is built to withstand outdoor temperatures from -22°F to 122°F, making it suitable for various weather conditions.
Where can I find the best mounting solution for my Wyze Cam?You can choose from a range of Wyze mounting accessories, including the Window Mount for glass, the Cam Mounting Kit for walls, the Universal Mount (Long) for ceilings and patios, and the Floodlight Plug-In Mount for outdoor security. Each accessory is designed for specific installation needs and camera models.
What other mounting solutions do you offer for Wyze cameras?Can the Wyze Window Mount be used with the Wyze Cam OG Telephoto?Do you have any ongoing sales or discounts for Wyze camera accessories?
