How to Mount a Wyze Cam on a Window Without Frame Damage
How to Place a Wyze Cam in a Window Without Damaging the Frame
Installing a Wyze Cam on a window can be tricky if you want to avoid damaging the window frame or glass. Fortunately, Wyze offers specialized accessories designed to make window mounting easy, secure, and damage-free. This guide highlights the best Wyze products to help you mount your camera on a window safely while ensuring optimal video clarity and flexibility.
Wyze Window Mount: The Perfect Solution for Glass Surfaces
Clear View Without Glare or Reflection
The Wyze Window Mount is specifically designed to attach your Wyze Cam v3, v3 Pro, v4, Wyze Cam OG, or OG Telephoto directly to glass surfaces. This mount allows you to place your camera inside your home, facing outward through the window, providing a clear, unobstructed view without the glare or reflection issues common with window glass.
  • Compatible with multiple Wyze Cam models including v3, v3 Pro, v4, OG, and OG Telephoto.
  • Easy to install and remove without leaving marks or damage on your window frame.
  • Ideal for renters or anyone who wants a non-permanent, damage-free mounting solution.
  • Compact and discreet design blends seamlessly with your window.
Mount your Wyze Cam on the glass itself to enjoy a crystal-clear outdoor view while keeping your camera protected indoors.
Wyze Cam Floodlight on Deck at Dusk Enhance your home security with clear outdoor views from your window-mounted Wyze Cam.
Wyze Cam USB Extension Cable: Freedom to Place Your Camera Anywhere
Extend Your Camera’s Reach Without Compromise
One common challenge when mounting a Wyze Cam on a window is the limited length of the USB power cable. The Wyze Cam USB Extension Cable (20ft) solves this problem by providing ample length to position your camera exactly where you want it, even if the nearest power outlet is far from the window.
  • 20 feet of durable, weather-resistant USB extension cable.
  • Compatible with Wyze Cam v2, v3, v3 Pro, v4, Pan v2/v3, OG, and OG Telephoto.
  • White cable blends well with most home interiors.
  • Rated for outdoor use (IP67), so it can handle temperature extremes from -22°F to 122°F.
  • USB Type A Male to Female connectors for easy plug-and-play setup.
This cable lets you mount your camera on a window using the Wyze Window Mount without worrying about power outlet proximity or unsightly cable runs.
Wyze Cam Mounting Kit: Secure and Damage-Free Installation
Everything You Need for a Safe Mount
For those who want additional mounting options or need to secure their Wyze Cam on walls or other surfaces near windows, the Wyze Cam Mounting Kit is a handy accessory. It includes:
  • A mounting bracket designed for Wyze Cam v2, v3, and v3 Pro.
  • Adhesive tape that sticks firmly but can be removed without damaging surfaces.
  • A longer 5-foot Micro USB cable for flexible placement.
  • Screws and wall plate for more permanent mounting if desired.
This kit is perfect if you want to mount your camera near a window frame without drilling or causing damage, using the adhesive option for a no-hassle setup.
Tips for Mounting Your Wyze Cam on a Window Without Damage
  • Use the Wyze Window Mount to attach the camera directly to the glass, avoiding any contact with the window frame.
  • Employ the Wyze Cam USB Extension Cable to reach power outlets without stretching or forcing cables.
  • If mounting near the window frame, use the Wyze Cam Mounting Kit with adhesive tape to prevent holes or marks.
  • Clean the glass surface thoroughly before attaching the window mount for maximum adhesion.
  • Position the camera to avoid direct sunlight hitting the lens to reduce glare and improve image quality.
Summary of Recommended Wyze Accessories for Window Mounting
Product NameKey FeaturesPrice (USD)
Wyze Window MountGlass surface mount, glare-free view9.98
Wyze Cam USB Extension Cable20ft length, weather-resistant, wide compatibility7.99
Wyze Cam Mounting KitAdhesive & screws, longer USB cable included5.99
Using these accessories together ensures a clean, damage-free installation of your Wyze Cam on any window, enhancing your home security with minimal effort.
Wyze Cam Mounted Outdoors Secure your Wyze Cam outdoors or on windows with versatile mounting options.
Final Thoughts
Mounting your Wyze Cam on a window without damaging the frame is simple with the right accessories. The Wyze Window Mount offers a direct glass mounting solution that avoids frame damage and glare. Pair it with the Wyze Cam USB Extension Cable for flexible power placement, and the Wyze Cam Mounting Kit for additional mounting versatility. Together, these products provide a seamless, secure, and damage-free way to keep an eye on your home through any window.
FeatureWyze Window MountWyze Cam USB Extension Cable - 20ftWyze Cam Mounting Kit
Compatible CamerasWyze Cam v3, v3 Pro, v4, Wyze Cam OG, OG TelephotoWyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoWyze Cam v2, v3, v3 Pro
PurposeMount camera on glass/window to reduce glareExtend USB cable length by 20 feetMounting bracket, adhesive, and longer Micro USB cable
Included ItemsWindow mount accessory20ft USB extension cableWall plate, 5ft USB extension cable, adhesive tape, screw set
Price$9.98$7.99$5.99
Mounting SurfaceGlass/windowN/A (cable only)Walls or ceilings
Cable IncludedNoYes (20ft USB extension)Yes (5ft USB extension)
Glare/Reflection ReductionYesNoNo
Outdoor UseYes (for window mounting)Yes (cable can be used outdoors if needed)No (intended for indoor use)
Return Policy30-day hassle-free returns30-day hassle-free returnsNot specified
How can I mount a Wyze Cam on a window without damaging the frame or glass?You can mount a Wyze Cam on a window without damaging the frame or glass by using the Wyze Window Mount. This accessory attaches directly to the glass surface, providing a secure and damage-free installation. It is easy to install and remove, making it ideal for renters or anyone seeking a non-permanent solution.
What Wyze Cam models are compatible with the Wyze Window Mount?The Wyze Window Mount is compatible with Wyze Cam v3, v3 Pro, v4, Wyze Cam OG, and OG Telephoto models. This ensures you can enjoy a clear, glare-free view through your window with a wide range of Wyze cameras.
Does the Wyze Window Mount reduce glare and reflections when recording through glass?Yes, the Wyze Window Mount is specifically designed to minimize glare and reflections, providing a clear and unobstructed view when your Wyze Cam is placed inside facing outward through a window.
How can I extend the power cable for my Wyze Cam when mounting it on a window?You can use the Wyze Cam USB Extension Cable, which is 20 feet long and weather-resistant. This cable allows you to position your camera exactly where you want it, even if the nearest power outlet is far from the window.
Is the Wyze Cam USB Extension Cable suitable for outdoor use?Yes, the Wyze Cam USB Extension Cable is rated IP67 for outdoor use and can withstand temperatures from -22°F to 122°F, making it durable and reliable for both indoor and outdoor installations.
What is included in the Wyze Cam Mounting Kit for window installations?The Wyze Cam Mounting Kit includes a mounting bracket for Wyze Cam v2, v3, and v3 Pro, adhesive tape for damage-free installation, a 5-foot Micro USB cable for flexible placement, and screws with a wall plate for more permanent mounting if desired.
Can I mount my Wyze Cam near a window frame without drilling holes?Yes, you can use the adhesive tape included in the Wyze Cam Mounting Kit to mount your camera near a window frame without drilling or causing any damage. The adhesive is strong yet removable, making it a great option for renters.
What are the best tips for mounting a Wyze Cam on a window without causing damage?To mount a Wyze Cam on a window without damage, use the Wyze Window Mount to attach the camera directly to the glass, utilize the Wyze Cam USB Extension Cable for flexible power placement, and use the adhesive option from the Wyze Cam Mounting Kit if mounting near the frame. Always clean the glass before installation and position the camera to avoid direct sunlight for optimal image quality.
What are the prices of the recommended Wyze accessories for window mounting?The Wyze Window Mount is priced at $9.98, the Wyze Cam USB Extension Cable at $7.99, and the Wyze Cam Mounting Kit at $5.99. These accessories provide a cost-effective and damage-free solution for mounting your Wyze Cam on windows.
Why should I use Wyze accessories for window mounting my camera?Wyze accessories like the Window Mount, USB Extension Cable, and Mounting Kit are specifically designed to provide secure, flexible, and damage-free installation options for your Wyze Cam. They help you achieve optimal video clarity, easy setup, and protect your window frames and glass from damage.
What are the key features of the Wyze Window Mount?How does the Wyze Cam USB Extension Cable help with camera placement?Do you have any deals, ongoing sales, discounts, or promotions?
