Clear Daytime and Nighttime Footage Cameras for Property Line Coverage
When it comes to securing your property line with crystal-clear footage both day and night, Wyze offers top-tier wireless cameras designed to deliver exceptional video quality, smart detection, and reliable weather resistance. Whether you want a battery-powered camera for flexible placement or a floodlight camera for broad illumination and coverage, Wyze has you covered.
Wyze Battery Cam Pro: Wire-Free, High-Resolution Security
Stunning 2.5K HDR Video Quality
The Wyze Battery Cam Pro captures your property line in sharp 2560 x 1440 (2.5K) HDR resolution, ensuring every detail is visible during the day and night. Its CMOS-Starlight sensor combined with an F1.6 lens delivers vibrant, clear footage even in low-light conditions.
Integrated Spotlight & Night Vision
Equipped with two IR LEDs (850 nm) and two powerful white LEDs (5500K, 187 lumens), this camera provides excellent night vision with color illumination, making nighttime footage as clear as daytime. The integrated spotlight also acts as a deterrent for unwanted visitors.
Advanced Motion Detection
Radar + PIR motion detection technology accurately senses movement, reducing false alerts from pets or environmental factors. The built-in 100 dB siren adds an extra layer of security by scaring off intruders.
Long-Lasting Battery & Weatherproof Design
Powered by a removable, rechargeable 6200mAh battery, the Wyze Battery Cam Pro can last up to 6 months on a single charge. Its IP65 weatherproof rating means it withstands rain, snow, and dust, making it perfect for outdoor property line monitoring.
Flexible Connectivity & Smart Home Integration
Supports both 2.4 GHz and 5 GHz WiFi networks and integrates seamlessly with Alexa, Google Assistant, and IFTTT for voice control and automation.
Dimensions: 2.5 x 1.8 x 3.5 inches
Weight: 0.94 lbs
Colors: Black, White
Wyze Battery Cam Pro + Solar Panel: Continuous Power for Extended Coverage
All the Features of the Battery Cam Pro
This variant includes everything the Wyze Battery Cam Pro offers: 2.5K HDR video, radar + PIR motion detection, integrated spotlight, and siren.
Solar Panel for Uninterrupted Operation
The included solar panel keeps your camera charged continuously, eliminating the need for manual recharging. This is ideal for property lines where power outlets are unavailable or inconvenient.
Enhanced Night Vision with Color Mode
Enjoy color night vision thanks to the white LEDs, providing clear and colorful footage after dark to better identify people or objects near your property boundary.
Easy Installation & Weatherproof
Like the standard Battery Cam Pro, this model is IP65 rated and supports dual-band WiFi, ensuring reliable performance in various outdoor environments.
Secure your property line with flexible, wireless Wyze cameras.
Wyze Cam Floodlight Pro: Bright, Wide-Angle Coverage with Smart Detection
Ultra-Wide 180° Field of View
Cover your entire yard or property line with the Wyze Cam Floodlight Pro’s expansive 180° diagonal field of view. Its 2.5K QHD video resolution ensures you don’t miss any detail.
Powerful 3000 Lumen LED Floodlights
Three dimmable light panels provide bright, 5000K daylight color temperature illumination, lighting up your property line clearly at night. The floodlights activate intelligently based on AI-powered motion detection.
AI-Powered Motion Detection & Alerts
The camera uses advanced onboard AI to detect people, vehicles, and other objects, minimizing false alarms. It automatically turns on the floodlights only when necessary, acting like a vigilant security guard.
Weather-Resistant & Durable
With an IP65 rating and operating temperature range from -20°C to 60°C (-4°F to 140°F), this camera is built to withstand harsh outdoor conditions year-round.
Smart Home Compatibility
Works with Alexa, Google Assistant, and IFTTT for voice commands and automation. It supports dual-band WiFi for stable connectivity.
Dimensions: 10.2 in x 9.1 in x 7.8 in
Weight: 2.9 lbs
Brighten and secure your property line with Wyze Cam Floodlight Pro.
Why Choose Wyze Cameras for Property Line Security?
Wyze cameras combine high-resolution video, smart detection technologies, and weatherproof designs to provide reliable, clear footage day and night. Their wireless, battery-powered options offer flexible installation without the hassle of wiring, while the Floodlight Pro adds powerful illumination and AI-driven alerts for comprehensive coverage.
With options like the Battery Cam Pro and its solar-powered variant, plus the Floodlight Pro for wide-angle lighting and monitoring, you can customize your property line security setup to fit your needs perfectly.
Additional Accessories for Enhanced Convenience
Wyze Removable Battery Pack
Extend your Battery Cam Pro’s uptime with a 6200mAh rechargeable battery pack. It charges via USB-C and lasts up to 6 months per charge, ensuring your camera stays powered without interruption.
Wyze Battery Charging Dock
Charge two Wyze Battery Cam Pro batteries simultaneously with this compact dual charging dock, making battery management simple and efficient.
Summary of Wyze Cameras for Property Line Coverage
Product | Video Resolution | Night Vision Type | Power Source | Weatherproof | Special Features |
Wyze Battery Cam Pro | 2.5K HDR | IR + White LED Color | Rechargeable Battery (6200mAh) | IP65 | Radar + PIR motion, Siren, Spotlight |
Wyze Battery Cam Pro + Solar | 2.5K HDR | IR + White LED Color | Battery + Solar Panel | IP65 | Continuous solar charging |
Wyze Cam Floodlight Pro | 2.5K QHD | Color Night Vision | Hardwired 110-120V AC | IP65 | 3000 lumens floodlight, AI motion |
Secure your property line with Wyze’s clear, reliable cameras that deliver peace of mind around the clock.
What makes Wyze cameras ideal for property line security?
Wyze cameras are designed for property line security with high-resolution video, advanced motion detection, and weatherproof construction. They offer clear footage both day and night, flexible wireless installation, and smart home integration for comprehensive and reliable monitoring.How clear is the video quality on Wyze Battery Cam Pro?
The Wyze Battery Cam Pro delivers stunning 2.5K HDR video resolution (2560 x 1440), ensuring sharp and detailed footage of your property line during both daytime and nighttime.Does Wyze Battery Cam Pro offer night vision?
Yes, the Wyze Battery Cam Pro features integrated IR LEDs and powerful white LEDs for excellent night vision. It provides color night vision, making nighttime footage as clear and vibrant as daytime.How does Wyze Battery Cam Pro detect motion?
Wyze Battery Cam Pro uses advanced radar and PIR (Passive Infrared) motion detection technology to accurately sense movement and reduce false alerts from pets or environmental factors. It also includes a 100 dB siren to deter intruders.Is the Wyze Battery Cam Pro weatherproof?
Yes, the Wyze Battery Cam Pro is IP65 weatherproof, making it resistant to rain, snow, and dust. It is built to withstand various outdoor conditions for reliable property line monitoring.How long does the Wyze Battery Cam Pro battery last?
The Wyze Battery Cam Pro is powered by a removable, rechargeable 6200mAh battery that can last up to 6 months on a single charge, depending on usage and environmental factors.What is the benefit of the Wyze Battery Cam Pro + Solar Panel?
The Wyze Battery Cam Pro + Solar Panel includes all the features of the standard Battery Cam Pro, plus a solar panel for continuous charging. This eliminates the need for manual recharging and is ideal for property lines without convenient power outlets.What are the key features of the Wyze Cam Floodlight Pro?
The Wyze Cam Floodlight Pro offers a 2.5K QHD video resolution, ultra-wide 180° field of view, powerful 3000 lumen LED floodlights, AI-powered motion detection, and IP65 weather resistance. It provides bright, wide-angle coverage and smart alerts for enhanced property line security.Can Wyze cameras be integrated with smart home systems?
Yes, Wyze cameras support integration with Alexa, Google Assistant, and IFTTT, allowing for voice control and automation within your smart home ecosystem.What accessories are available for Wyze Battery Cam Pro?
Wyze offers a removable 6200mAh rechargeable battery pack for extended uptime and a dual battery charging dock for convenient battery management, ensuring your camera remains powered without interruption.Are Wyze cameras easy to install on property lines?
Yes, Wyze cameras are designed for easy installation. The battery-powered models offer wire-free setup, and the solar panel variant provides continuous power without the need for electrical outlets, making them ideal for property line coverage.What is the difference between Wyze Battery Cam Pro and Wyze Cam Floodlight Pro?
The Wyze Battery Cam Pro is a wireless, battery-powered camera with 2.5K HDR video, radar + PIR motion detection, and optional solar charging. The Wyze Cam Floodlight Pro is a hardwired camera with 2.5K QHD video, ultra-wide 180° field of view, 3000 lumen floodlights, and AI-powered motion detection for broad, illuminated coverage.
