20ft Wyze Cam USB Extension Cable for Shaded Patio Installations
Extend Your Wyze Cam Reach with the 20ft USB Extension Cable
If you have a Wyze Cam installed near a heavily shaded patio or any outdoor area where power outlets are far, the Wyze Cam USB Extension Cable - 20ft is the perfect accessory to extend your camera’s power source without hassle. This cable is designed specifically to work seamlessly with multiple Wyze Cam models including Wyze Cam v2, v3, v4, and others.
Key Features of the Wyze Cam USB Extension Cable - 20ft
  • Length: 20 feet of flexible USB extension cable to reach distant power outlets.
  • Compatibility: Works with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, and original Wyze Cam models.
  • Durability: Designed for indoor and outdoor use, ideal for shaded patios or areas where the original cable length is insufficient.
  • Easy Setup: Simply plug into your existing Wyze Cam USB power adapter and extend your camera’s reach effortlessly.
This extension cable ensures your Wyze Cam stays powered continuously, even in challenging locations like shaded patios where power access is limited.
Wyze Cam v4: The Ultimate Outdoor Security Camera
For monitoring a heavily shaded patio, the Wyze Cam v4 is an excellent choice. It offers advanced features that make it ideal for outdoor use, especially in low-light or shaded environments.
Why Choose Wyze Cam v4 for Your Patio?
  • 2.5K Quad HD Resolution: Capture crystal-clear video with vibrant colors and sharp details.
  • Color Night Vision: Enhanced hardware allows the camera to see in full color even in low-light conditions, perfect for shaded patios.
  • IP65 Weather Resistance: Built to withstand rain, dust, and other outdoor elements, making it reliable for outdoor installation.
  • Integrated Spotlight & Siren: Motion-activated spotlight brightens dark areas, and a loud siren deters intruders.
  • Advanced Audio: Clear two-way talk with improved microphone and speaker for easy communication.
  • Wide Dynamic Range (WDR): Ensures balanced exposure in scenes with both bright and dark areas, ideal for patios with varying light conditions.
  • Easy Setup: Bluetooth-enabled setup and magnetic mount make installation quick and tool-free.
With the Wyze Cam v4 paired with the 20ft USB extension cable, you can place your camera exactly where you need it, even if the power source is far away or in a shaded spot. Wyze Cam v4 monitoring a shaded patio Alt text: Wyze Cam v4 installed on a shaded patio monitoring outdoor activity
Enhance Your Outdoor Security Setup
If you want a more comprehensive security solution for your home including your patio, consider combining the Wyze Cam v4 and the USB extension cable with other accessories like the Wyze Outdoor Power Adapter or Lamp Socket v2 for flexible power options.
Benefits of Using the Wyze Cam v4 with Extended Power Options
  • Continuous Power: No worries about battery life or short cables.
  • Flexible Placement: Position your camera in the best spot for coverage, even if power outlets are distant.
  • Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT for seamless smart home control.
  • Reliable Connectivity: Supports Wi-Fi 6 for stronger, more stable connections at longer ranges.
Summary
For anyone looking to install a Wyze Cam near a heavily shaded patio or any outdoor area with limited power access, the Wyze Cam USB Extension Cable - 20ft is an essential accessory. Pair it with the Wyze Cam v4 to enjoy superior video quality, color night vision, and weather resistance, ensuring your outdoor security is never compromised.
"Extend your Wyze Cam’s power effortlessly and secure your shaded patio with crystal-clear, color night vision."
FeatureWyze Cam USB Extension Cable - 20ftWyze Cam v4
Product TypeAccessory (USB Extension Cable)Camera
CompatibilityWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoN/A (Standalone camera)
Cable Length20 ft6-Foot Flat micro USB to USB-A cable included
Price$7.99$100.00
DescriptionExtends USB cable length for Wyze Cams2.5K QHD resolution, Enhanced Color Night Vision, motion-activated spotlight, Wi-Fi 6, 24/7 local recording
Weather ResistanceNot specifiedIP65
Video ResolutionN/A2.5K QHD (2560x1440)
Night VisionN/A4 IR LEDs (850 nm) + 2 white spotlight LEDs (72 lumens), Color Night Vision
Mounting OptionsN/AStand, Wall mount, Ceiling mount, Magnetic wall mount (adhesive)
Power Adapter InputN/A110-240 V (AC/DC)
Power Adapter OutputN/AIndoor 5V/1A
WeightN/A0.49 lb (222 g)
DimensionsN/A2in x 2in x 2 3/8in
Warranty30-day hassle-free returns1-Year
What is the Wyze Cam USB Extension Cable - 20ft used for?The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze Cam’s power source, making it easy to install your camera in areas where power outlets are far away, such as shaded patios or outdoor spaces.
Which Wyze Cam models are compatible with the 20ft USB Extension Cable?The 20ft USB Extension Cable is compatible with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, and original Wyze Cam models.
Is the Wyze Cam USB Extension Cable suitable for outdoor use?Yes, the Wyze Cam USB Extension Cable is designed for both indoor and outdoor use, making it ideal for shaded patios and other outdoor areas where the original cable length is insufficient.
How do I set up the Wyze Cam USB Extension Cable?Setting up the Wyze Cam USB Extension Cable is simple. Just plug one end into your existing Wyze Cam USB power adapter and the other end into your camera to extend its reach.
What are the key features of the Wyze Cam v4 for outdoor security?The Wyze Cam v4 offers 2.5K Quad HD resolution, color night vision, IP65 weather resistance, an integrated spotlight and siren, advanced two-way audio, wide dynamic range (WDR), and easy Bluetooth-enabled setup with a magnetic mount.
Why is the Wyze Cam v4 ideal for monitoring shaded patios?The Wyze Cam v4 is perfect for shaded patios because it features color night vision for low-light conditions, IP65 weather resistance for outdoor durability, and wide dynamic range (WDR) to balance exposure in areas with both bright and dark spots.
Can I use the Wyze Cam v4 with smart home devices?Yes, the Wyze Cam v4 integrates with Alexa, Google Assistant, and IFTTT, allowing for seamless smart home control and automation.
What are the benefits of using the Wyze Cam v4 with the 20ft USB Extension Cable?Using the Wyze Cam v4 with the 20ft USB Extension Cable allows for flexible camera placement, continuous power without worrying about battery life, and reliable outdoor security coverage even when power outlets are distant.
Are there additional accessories to enhance my Wyze Cam outdoor setup?Yes, you can enhance your outdoor security setup by combining the Wyze Cam v4 and the USB extension cable with accessories like the Wyze Outdoor Power Adapter or Lamp Socket v2 for more flexible power options.
Does the Wyze Cam v4 support Wi-Fi 6 for better connectivity?Yes, the Wyze Cam v4 supports Wi-Fi 6, providing stronger and more stable wireless connections, especially at longer ranges.
What are the key features of the Wyze Cam USB Extension Cable - 20ft?Is the Wyze Cam USB Extension Cable suitable for outdoor use?Do you have any deals, ongoing sales, discounts, or promotions?
